Hi all,
Please be gentle this is my first post on here and although I have owned a fully licensed HEX+CAN cable for many years I am still a novice for the most part. Also apologies in advance for the lengthy post, I just feel it helps to add a bit of backstory and include as much detail as possible.
So the issue I'm having arose shortly after fitting a "Dutchbuild" haldex controller, now this is not a traditional competition haldex controller which would replace the stock module, this actually retains the stock unit and is installed inline between the car and contoller. If I have not explained that clearly enough please visit the link here for more information http://www.vdveer-engineering.nl/index.php/en/products/haldex-controller. Also before installing on the car I updated the firmware to the latest version and downloaded the latest version of the app.
Anyway moving on to the issue at hand, I installed the inline controller on Monday and drove the car monitoring the haldex bias with the software app on my phone and everything seemed to be working fine. To start with I left it in passthru mode which means the inline controller does not alter the signal going to the haldex module so the haldex will behave as it would completely stock. I also tested the lock function and that seemed to work perfectly well too keeping the bias locked in 30/70, 40/60, 50/50 as I selected.
Fast forward to Tuesday, driving home from work I thought I'd give the car a bit of a blast and watch the bias as it changed in real time on the app in passthru mode as I wanted to monitor stock haldex bias behavior before creating my own bias maps as it were (for track use mostly). At first no problems but then I started getting a lot of wheel spin in all gears and the esp light was flashing at me, also noticed the bias showing on the app was no more than around 97/3 even at wot in low gears.
So I scan the car, stupidly I didn't autoscan and save straight away but I had several faults indicated on the ABS, AWD and CAN gateway modules for AWD module, powertrain databus, diagnostic interface for databus, transmission control module (no communication), engine control module (implausible signal). Having done some googling and from talking with dutchbuild themselves it was suggested the CAN gateway needed to re-evalute the network and in order to do this I should recode it with the original coding. I did this and it cleared all the faults bar 2 on the AWD-22 module for transmission control unit and engine control unit. Obviously with the car being a manual the transmission code was odd, so I attempted to recode the AWD module as was suggested in this thread https://forums.ross-tech.com/showthread.php?4768-01315-In-Manual-MK6-Golf-R-after-changing-Haldex-Unit!-Need-Help-Recoding&highlight=haldex+01315. Unfortunatley this had no effect even when changing the wsc to non zeros, I also cycled the key after every coding attempt but as soon as I clear the codes on that module they reappear straight away. Here is the autoscan
So I removed the inline controller and carried out another full scan, this time only 1 fault on AWD-22 for 01315 transmission control module fault but again I am unable to clear it without it immediately reappearing. That scan is here
So the question is why is the haldex still looking for a tcu especially since it is back to stock? I have looked in the CAN gateway installation list and auto trans is not checked. What do I need to do next?
For reference here is an old auto scan from prior to fitting the inline controller
VCDS Version: 19.6.2.0 (x64)
VIN: TRUZZZ8JXA1900307 License Plate: T77RSW
Mileage: 129140km-80243mi Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 3D 42 44 46 47 52 55 56 77
VIN: TRUZZZ8JXA1900307 Mileage: 129140km-80243miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (CEP) Labels:. 07K-907-404-CEP.clb
Part No SW: 8J0 907 404 HW: 8J0 907 404
Component: 2.5l R5/4V TFSI 0020
Revision: F4H03--- Serial number: AUX7Z0I3FNS0PS
Coding: 0113000C180F0160
Shop #: WSC 01236 785 00200
VCID: 6ADBCDA045368F1F19-803E
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 HW: 8J0 614 517 C
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0610199
Shop #: WSC 64465 001 1048576
VCID: 69D9B2AC4030840710-803C
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AQ HW: 8J0 820 043 AQ
Component: J255 Klima 1 Zone 0090
Revision: 00H08006 Serial number: 00000001128652
Coding: 1573893
VCID: 75E1EEDC1C8850E784-8020
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009592348
Coding: F0061E8380141C80CF18000A1800000000894E875B260A02008000000000
VCID: 489F57283BFA9D0F2F-801C
Subsystem 1 - Part No: 8J2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00064784
Shop #: WSC 01236
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00149804
Shop #: WSC 01236
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -r Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K003NDK2
Coding: 0011634
VCID: 79F9E2EC30903487E0-802C
Subsystem 1 - Serial number: 6332DRB408DA531BY
Subsystem 2 - Serial number: 6342DRB408B3CAA3+
Subsystem 3 - Serial number: 63747RB404CE64A5
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004041
VCID: 41894A0C18C0AC47E8-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 G HW: 8J0 920 980 G
Component: KOMBIINSTR. VDO H02 0480
Revision: D0H02002 Serial number: 2243I002000032
Coding: 0037428
VCID: 35612EDC5C0810E744-8060
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K094070228
Coding: E9831F06510602004101
VCID: 377D24D44604E2F756-8062
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 2K0 907 554 HW: 2K0 907 554
Component: Haldex 4Motion 5003
Coding: 0000005
VCID: 6BD5C8A44ACC961762-803E
Fault Status: 01101000
Reset counter: 138
Mileage: 129140 km
Date: 2020.02.26
Time: 16:01:28
Reset counter: 138
Mileage: 129140 km
Date: 2020.02.26
Time: 16:01:28
Revision: D0H02002 Serial number: AUX7Z0I3FNS0PS
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 HW: 8J0 035 193
Component: RNS-E PU EU H02 0220
Revision: 0000001S Serial number: AUZBZ7J6301194
Coding: 0619757
Shop #: WSC 00976 210 67917
VCID: 67DDB4945624B27706-8032
02261 - Data Medium
Fault Status: 00101110
Fault Frequency: 182
Reset counter: 171
Mileage: 126465 km
Date: 2019.11.06
Time: 08:03:52
Mileage: 129140 km
Count: 2602
Clock: 13:32
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 A HW: 8K0 907 440
Component: STS H04 0010
Revision: S0H04000 Serial number: 00000000004331
Coding: 01010101000000000000000101
VCID: 2C570BB88F42512F2B-8078
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8J8 959 801 D HW: 8J8 959 801 D
Component: Tuer-SG H03 0080
Coding: 0004661
VCID: 3E7331F0693ED3BF95-806A
Part No: 8J0 909 144 R
Component: EPS_ZFLS Kl. 239 3501
Revision: 00H22000
VCID: 3F8D4CF46E34DAB79E-806A
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H11 0080
Coding: 1890300001182D298505489AD637
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000005089
Coding: 0246317
VCID: 2541FE9CECA86067F4-8070
16349 - Control Module - Error in Output Stage
Reset counter: 92
Mileage: 90376 km
Date: 2016.11.22
Time: 15:35:09
Part No SW: 8J8 959 802 D HW: 8J8 959 802 D
Coding: 0004660
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0050
Coding: 0000024
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619757
02261 - Data Medium
Reset counter: 171
Mileage: 126465 km
Date: 2019.11.06
Time: 08:03:52
Mileage: 129140 km
Count: 2602
Clock: 13:32
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005086494
Coding: 0011422
VCID: 4683591031EE8B7FDD-8012
End-------------------------(Elapsed Time: 02:05)--------------------------
Revision: 00H60001
Coding: 0610199
Coding: 1573893
Coding: 00064784
Shop #: WSC 01236
Coding: 00149804
Shop #: WSC 01236
Coding: 0011634
Coding: 0004041
Coding: 0037428
Coding: 0000005
Reset counter: 138
Mileage: 129140 km
Date: 2020.02.26
Time: 12:59:30
Coding: 0619757
02261 - Data Medium
014 - Defective
Fault Status: 01101110
Reset counter: 130
Mileage: 126465 km
Date: 2019.11.06
Time: 08:03:52
Mileage: 129140 km
Count: 2602
Clock: 12:49
Coding: 0004661
Revision: 00H22000
Coding: 0246317
Reset counter: 92
Mileage: 90376 km
Date: 2016.11.22
Time: 15:35:09
Coding: 0004660
Coding: 0000024
Coding: 0619757
02261 - Data Medium
014 - Defective
Reset counter: 130
Mileage: 126465 km
Date: 2019.11.06
Time: 08:03:52
Mileage: 129140 km
Count: 2602
Clock: 12:49
Coding: 0011422
End-------------------------(Elapsed Time: 02:09)--------------------------
Address 19,1K0 907 530 S,recoded (Installation List),from,E9831F06510602004101,to,E9831F06510602004101,,
Address 19,1K0 907 530 S,recoded (Long Coding),from,E9831F06510602004101,to,E9831F06510602004101,(01236/785/00200),
Address 22: DTCs cleared
VCDS Version: 18.9.0.2 (x64)
Mileage: 117660km-73110mi Repair Order:
VIN: TRUZZZ8JXA1900307 Mileage: 117660km-73110miles
VCID: 6ADBCDA045368F1A6B-803E
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Mileage: 117657 km
Date: 2018.11.30
Time: 12:44:49
RPM: 705 /min
Load: 5.5 %
Temperature: 96.0°C
Temperature: 29.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
Revision: 00H60001
Coding: 0610199
VCID: 69D9B2AC4030840262-803C
Coding: 1573893
VCID: 75E1EEDC1C8850E2F6-8020
VCID: 489F57283BFA9D0A5D-801C
Coding: 00064784
Shop #: WSC 01236
Coding: 00149804
Shop #: WSC 01236
Coding: 0011634
VCID: 79F9E2EC3090348292-802C
Coding: 0004041
VCID: 41894A0C18C0AC429A-8014
Coding: 0037428
VCID: 35612EDC5C0810E236-8060
VCID: 377D24D44604E2F224-8062
Coding: 0000005
VCID: 6BD5C8A44ACC961210-803E
Coding: 0619757
VCID: 67DDB4945624B27274-8032
02261 - Data Medium
014 - Defective
Fault Frequency: 95
Reset counter: 253
Mileage: 111543 km
Date: 2018.03.25
Time: 20:32:07
Mileage: 117660 km
Count: 212
Clock: 16:33
VCID: 2C570BB88F42512A59-8078
Coding: 0004661
VCID: 3E7331F0693ED3BAE7-806A
Revision: 00H22000
VCID: 3F8D4CF46E34DAB2EC-806A
Coding: 0246317
VCID: 2541FE9CECA8606286-8070
Reset counter: 92
Mileage: 90376 km
Date: 2016.11.22
Time: 15:35:09
Coding: 0004660
Coding: 0000024
Coding: 0619757
02261 - Data Medium
014 - Defective
Fault Frequency: 95
Reset counter: 253
Mileage: 111543 km
Date: 2018.03.25
Time: 20:32:07
Mileage: 117660 km
Count: 212
Clock: 16:33
Coding: 0011422
VCID: 4683591031EE8B7AAF-8012
End-------------------------(Elapsed Time: 02:10)--------------------------
