Troubleshooting Blower - Output Test?
Gmickey
C?ID=354933
We bought my son his first car and knew that the blower motor was not running. Fan switch has no effect and don't know if it's a fuse, the switch, or the blower motor.
I bought the VIN upgrade and added his car today thinking I could run an output test on the blower, as this was something I have been able to do on other cars I own. Unfortunately, that option does not appear for this particular car. Is there a way to test run the blower? Also, I have been unable to find good identification of the location of the fuses associated with the blower on this particular car.
Any advice in troubleshooting would be appreciated. A scan from today is below:
Wednesday,26,February,2020,17:41:08:43616
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWLK73C77EXXXXXX   License Plate: XXXXXXX
Mileage: 251550km-156305mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 53 56 62
          65 6D 72
VIN: WVWLK73C77EXXXXXX   Mileage: 251550km-156305miles
   Part No SW: 3C0 907 115 F    HW: 3C0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZCZ000000000
   Coding: 040C010A19070160
   Shop #: WSC 22231 444 53280
   VCID: 2313EDC877DF5E1FF47-8076
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - MIL ON
                    Fault Status: 11100100
                    Mileage: 251447 km
                    Date: 2020.02.18
                    Time: 15:55:47
                    RPM: 979 /min
                    Load: 15.3 %
                    Speed: 22.0 km/h
                    Temperature: 82.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.970 V
   Part No SW: 09G 927 750 CJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           0841
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 05311 000 00000
   VCID: 7BA3F5A8AFEFC6DF9C7-802E
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0100004316
   Coding: 0046523
   VCID: 323D188C3825C7970F1-8066
   Part No: 1K0 820 047 EB
   Component: Climatic PQ35   090 0505
   VCID: 6889BAE4CE797D47615-803C
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000002329557
   Coding: 148C0F0340041A00470A00000F00000000285D435C0000
   VCID: 372B2998D34722BF38F-8062
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
00156 - Control Circuit for Windshield Washer Pump
                    Fault Status: 00101001
                    Fault Frequency: 22
                    Reset counter: 174
                    Mileage: 250035 km
                    Date: 2019.10.06
                    Time: 16:12:00
                    Voltage: 14.00 V
02398 - Control Circuit for Rear Windshield Washer Pump
                    Fault Status: 01101001
                    Fault Frequency: 15
                    Reset counter: 134
                    Mileage: 250035 km
                    Date: 2019.10.06
                    Time: 16:12:00
                    Voltage: 14.05 V
00897 - Windshield Washer Pump (V5)
                    Fault Status: 01101100
                    Reset counter: 134
                    Mileage: 250059 km
                    Date: 2019.10.07
                    Time: 07:59:00
                    Voltage: 14.40 V
02091 - Rear Window Washer Pump (V13)
                    Fault Status: 01111100
                    Reset counter: 134
                    Mileage: 250059 km
                    Date: 2019.10.07
                    Time: 07:59:00
                    Voltage: 14.40 V
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7F7042332
   VCID: 2B0305E81F0F965F4C7-807E
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 53
                    Mileage: 211451 km
                    Date: 2016.12.19
                    Time: 11:25:15
02788 - Internal Communications Error
                    Reset counter: 174
                    Mileage: 223013 km
                    Date: 2017.07.31
                    Time: 14:37:18
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P1UM2Y1
   Coding: 0012366
   VCID: 2E050CFC2C1DE3776B9-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000032Z4W
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0E130D79Iÿ†63
   Subsystem 5 - Serial number: 30D79Iÿ†6342MSME0F594643Iÿ†63
   Subsystem 6 - Serial number: 94643Iÿ†6351HTS63IKUPQ136ÿ†63
   Subsystem 7 - Serial number: UPQ136ÿ†6361HTS63IKI64A25ÿ†63
   Subsystem 8 - Serial number: I64A25ÿ†63727TS63IK6NLA2Jÿ†63
   Subsystem 9 - Serial number: 6NLA2Jÿ†63827TS63IKAE7I29ÿ
   Subsystem 10 - Serial number: AE7I29ÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507R
   Coding: 0002014
   VCID: 313F17803D23FC8F76B-8064
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 05311 067 57207
   VCID: 33331D88C73FCE9F047-8066
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C06211014F
   Coding: 3FFD0E1CD32002
   VCID: 211FE7C06DC34C0FE6B-8074
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1339817TQ2WC02
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 22575 444 84377
   VCID: 2A0D00EC10F58F57B71-807E
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2365
   Coding: 0001205
   VCID: 3635249CD44DDBB7239-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13900E88D1032E521804141FF00A0F0E081800
   Shop #: WSC 05311 000 08193
00896 - Trunk Lock Unit (F256)
                    Fault Status: 01101000
                    Reset counter: 134
                    Mileage: 251552 km
                    Date: 2020.02.20
                    Time: 17:24:02
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3C0 035 456 C    HW: 3C0 035 456 C
   Component: DSP 10 Kanal        0012
   Revision: 00009000    Serial number: 00000000004921
   VCID: 2019E2C466C94507E95-8074
11 Faults Found:
                    Mileage: 102189 km
                    Date: 2013.01.05
                    Time: 03:11:10
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 27
                    Mileage: 102189 km
                    Date: 2013.01.05
                    Time: 03:11:10
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Fault Frequency: 32
                    Reset counter: 160
                    Mileage: 249311 km
                    Date: 2019.08.23
                    Time: 11:40:28
                    Reset counter: 120
                    Mileage: 214029 km
                    Date: 2017.01.28
                    Time: 20:41:37
00871 - Bass Speaker Front Right (R23)
                    Fault Frequency: 207
                    Reset counter: 123
                    Mileage: 182920 km
                    Date: 2015.12.09
                    Time: 17:43:55
                    Fault Frequency: 28
                    Reset counter: 174
                    Mileage: 250966 km
                    Date: 2019.12.08
                    Time: 13:39:39
                    Fault Frequency: 13
                    Reset counter: 163
                    Mileage: 249773 km
                    Date: 2019.09.28
                    Time: 10:40:21
00877 - Treble Speaker Rear Right (R16)
                    Fault Frequency: 20
                    Reset counter: 41
                    Mileage: 245578 km
                    Date: 2019.06.02
                    Time: 19:02:32
                    Fault Status: 00101011
                    Fault Frequency: 27
                    Reset counter: 159
                    Mileage: 251039 km
                    Date: 2019.12.18
                    Time: 14:58:17
                    Fault Status: 00100111
                    Reset counter: 159
                    Mileage: 251040 km
                    Date: 2019.12.27
                    Time: 15:03:20
                    Reset counter: 159
                    Mileage: 251040 km
                    Date: 2019.12.27
                    Time: 15:03:20
   Part No: 1K0 959 702 K
   Coding: 0001204
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000013
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio PM6       016 0021
   Revision: 00016000    Serial number: VWZ5Z7F2057994
   Coding: 0000010
   Shop #: WSC 05314 000 00000
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2505
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
   Shop #: WSC 22231 444 52579
00667 - Ambient Temperature Signal
                    Fault Status: 00111000
                    Reset counter: 159
                    Mileage: 251041 km
                    Date: 2019.12.30
                    Time: 00:00:13
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
   Component: J605  HECKDECKEL    0405
   Revision: 00H19001
   Shop #: WSC 23250 384 715754
   VCID: 303912843629F587795-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0600H20001001A0157ÿ
   Part No: 3C9 959 704 A
   Coding: 0000144
End----(Elapsed Time: 01:27, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
You have a Climatic module. Since the that module doesn't automatically adjust the fan speed, I imagine the fan speed control is rather rudimentary, quite possibly directly from the fan speed "knob" (I don't recall exactly what it looks like in a 3C Passat with Climatic). I suggest checking wiring diagrams to see how the blower is powered / controlled.
