2011 Tiguan, 180k miles, CEL P2187, P2015
thigg12
C?ID=371417
Looking for some assistance tracking down possible causes for the below fault codes. Overall the car has been running well. Occasionally it would studder while driving at low speeds in traffic and occasionally shut off completely. Generally, it would start right back up and I'd go on my merry way. Unfortunately no CEL and no soft codes either. Yesterday the CEL officially came on and threw P2187. Lots of forums say it could be he PCV valve. I had mine replaced around 112k when the RMS blew, that was a fun $1,200 repair. I've also had 3 intake manifolds on this car, the last one most recently replaced under the extended warranty at 119k miles, right before the extended warranty expired. The code P2015 recently appeared along with P119A Fueld Pressure sensor. These might not be true as they are intermittent. I did recently replace the HPFP roughly 5,000 miles ago with the Bosch OE unit and new follower, thinking that would solve the rough idle and intermittent shutoffs...it didn't...I;ve also been smelling a pretty strong fuel smell each morning when I start the car up and let it idle(warm-up).
Anyways, I'd love to get some advice before I start replacing parts...I can easily replace the PCV myself but fear it may be something larger at play, faulty fuel injectors, 02 sensors, etc.?
Thanks!!
Wednesday,26,February,2020,20:54:54:05814
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 62
          65 72 77
VIN: WVGAV7AXXBW513584   Mileage: 288570km-179309miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 J    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 01 0393
   Revision: P3H06---    Serial number:
   Coding: 0423010A19070160
   Shop #: WSC 55275 001 1048576
   VCID: 3C2135162A6ACC87D5D-8068
008583 - Bank 1; System too Lean at Idle
               P2187 - 000 -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 288450 km
                    Date: 2014.07.19
                    Time: 07:57:19
                    RPM: 766 /min
                    Load: 29.0 %
                    Temperature: 93.0°C
                    Temperature: 10.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent
                    Mileage: 288291 km
                    Date: 2014.07.16
                    Time: 15:42:11
                    RPM: 710 /min
                    Load: 18.8 %
                    Temperature: 91.0°C
                    Temperature: 40.0°C
                    Voltage: 13.970 V
004506 - Fuel Pressure Sensor (G247)
               P119A - 000 - Malfunction
                    Mileage: 288572 km
                    Date: 2014.07.19
                    Time: 20:44:43
                    RPM: 700 /min
                    Load: 21.6 %
                    Temperature: 84.0°C
                    Temperature: 30.0°C
                    Voltage: 13.716 V
   Part No SW: 09G 927 750 LQ    HW: 09G 927 750 LQ
   Component: AQ 250 6F           1771
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 0B43A6CA3F443B3FAC7-805E
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
   Component: J104    C4 450 V2AE 0006
   Revision: --H28---    Serial number: 00000003097523
   Coding: 0002333
   VCID: 392F2C022558F9AFCEB-806C
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B7E03245405DCFEA3-8020
   Part No SW: 5K0 937 087 L    HW: 5K0 937 087 L
   Component: BCM PQ35 H+   111 0135
   Revision: BL111001
   Coding: 6D580A1B80232EC4808800851000050440015186524D8D605C8000000040
   Shop #: WSC 01035 444 83785
   VCID: 3E253F1E3076DE97FB9-806A
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 170810 03  32  0010
   Coding: 009795
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 22014000    Serial number: 003GJPGLU9FP
   Coding: 0012340
   VCID: 4ACD63CE70BE6237571-801E
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 00000000007WVZ
   Subsystem 3 - Serial number: 0007.07.000000100000650007ÿ†63
   Subsystem 4 - Serial number: 650007ÿ†6332MTS677742090 ÿ†63
   Subsystem 5 - Serial number: 42090 ÿ†6342MTS617133065 ÿ†63
   Subsystem 6 - Serial number: 33065 ÿ†6351HTS6PT7ED9KR ÿ†63
   Subsystem 7 - Serial number: ED9KR ÿ†6361HTS6DBTOVVNR ÿ†63
   Subsystem 8 - Serial number: OVVNR ÿ†63727TS61JVDD6KJ ÿ†63
   Subsystem 9 - Serial number: DD6KJ ÿ†63827TS69HVDD6KJ ÿ
   Subsystem 10 - Serial number: DD6KJ ÿ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20140321101201
   Coding: 198A140000
   Shop #: WSC 43852 001 1048576
   VCID: 025D8BEE048E7A77DF1-8056
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Coding: 820000
   Part No SW: 5N0 920 972 B    HW: 5N0 920 972 B
   Component: KOMBI         H03 0406
   Coding: 210F00
   VCID: 323D1B2EF4AE0AF70F1-8066
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 060810F2002468
   Coding: FD807F0740061300006002
   VCID: 2E050F5EEC162E176B9-807A
   Component: IMMO          H03 0406
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC34E1CFE8237771-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668529761
   Coding: 020000
   VCID: 270BFA7ACFEC7F5FA8F-8072
   Part No SW: 1K0 035 274     HW: 1K0 035 274
   Component: RNS315-NAR    H04 0007
   Serial number: VWZAZ2K8409372
   Coding: 040004210400000000001000
   ASAM Dataset: EV_RNS315VWNARV1UDS A01005
   ROD: EV_RNS315VWNARV1UDS.rod
   VCID: 619FA462E1C8C16FA6B-8034
          B11CF 53 [009] - Deactivated
                    Reset counter: 48
                    Mileage: 248085 km
                    Date: 2018.09.29
                    Time: 13:37:23
   Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
   Component: Tuer-SG         009 2101
   Coding: 0001205
   VCID: 3635273E144616D7239-8062
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.285 1501
   Revision: 1BH04843    Serial number: 00180380006301
   Coding: 0000258
   VCID: 42DD4BEE488EBA779F1-8016
   Component: EZE_2         H25 5603
   Coding: 050B0500
   VCID: 6FBBD25A279C671F20F-803A
   Component: J245EE20SKB13  H02 0220
02071 - Local Databus
                    Fault Status: 00101100
                    Reset counter: 213
                    Mileage: 287576 km
                    Date: 2014.07.09
                    Time: 11:20:27
   Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
   Coding: 0001204
   VCID: 372B2A3A134CEFDF38F-8062
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000066657
   Coding: 0023057
   VCID: 323D1B2EF82E0AF70F1-8066
   Part No SW: 5N0 959 703 E    HW: 5N0 959 703 E
   Component: Tuer-SG         007 2102
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018704
   Shop #: WSC 01035 444 12611
02801 - Hard Warning
                    Mileage: 281614 km
                    Date: 2014.03.13
                    Time: 09:48:28
                    Text: 3454295283
                    Pressure: 1.90 bar
                    Pressure: 2.40 bar
                    Temperature: 23.2°C
                    Text: C0
                    Speed: 29.0 km/h
   Part No SW: 5N0 959 704 E    HW: 5N0 959 704 E
   Coding: 0001168
   VCID: 3A2D330E205EF2B7C71-806E
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668349831
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
End----(Elapsed Time: 01:27, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
dieseldub
Bay Area, CA
C?ID=28764
What's the oil level at currently? I have seen severely fuel diluted oil (and overfilled) from HPFP failures. Though those would normally contribute to a too RICH fault instead of too lean, but would be consistent with the smell of gas intermittently as the engine burns the fuel-diluted oil being spewed by the CCV.
The intake manifold runner position/P2015 is very common on TSIs. VW has been through at least 3 different revisions of the whole intake manifold to try and make it longer lived. They have an extended warranty on them as well.
But, both the fuel pressure sensor and intake manifold runner codes have a frequency of only 1.
It would be good to get a fuel pressure gauge in the low pressure side to see if the fuel pressure feeding into the HPFP is just too low or drops out completely when the symptoms are present.
Another good thing to do would be to backprobe the power wire to the in tank fuel pump. The power to the pump is coming from a control module, which is outputting pulse-width modulation (PWM) power to the pump. They seem to spike above 6V when first started, and tend to settle below 5V when running at idle. But when the stalling occurs, you might see the power drop completely. When these modules go bad, they tend to show these symptoms only when they warm up. Remove the module and put it in the freezer for a couple minutes and the car will start up and run again until the module heats up to a certain point.
dieseldub
Bay Area, CA
C?ID=28764
The fuel pump control module is located near where the fuel pump is, under the rear seat bench on the passenger side. #6 in the illustration. It will be on the underside of the floor, so kind of tucked up between the tank and the body. You can get it out through the opening for the sender/pump, but it will be a tight squeeze.
thigg12
C?ID=371417
Thanks for the suggestion. I replaced the HPFP a few thousand miles ago so that shouldnt be causing any issues. I suspected the fuel control module as well, but the car always starts right back up after stalling. Never once have I had to wait for the control module to "cool" before starting the car again. It's been a few days since my original post and oddly enough the CEL has gone off (all on its own). Works been crazy with the markets lately but I plan to rerun autoscan tonight to see if codes are still present. I don't have a fuel pressure pump to test the low side pressure. Although the car stalling out or even rough idling happens so sporadically I probably wouldn't be able to get a reading exactly when the problem happens. That has been the most frustrating part of this whole thing. For over a year now the car continues to randomly stall and hesitate with no CEL or any other major issues presenting themselves. Sadly I actually get excited when I do get a CEL, hoping this will lead me to the root cause and pinpoint the part or parts which are failing. With the car being 9 years old and 180k miles I prefer to limit my "diagnosing" costs. I thought buying a VCDS was going to be more helpful diagnosing underlying problems, perhaps I am not skilled enough to use it.
The fuel injectors are original, could that be causing any issues like this? I would think misfire codes would show up though.
thigg12
C?ID=371417
Are you referring to the fuel pressure sensor? Part Number: 06J906051D
I had the wiring replaced for the fuel pressure sensor in 2017 at approx. 132k miles. I'd have to go back and look at the mechanic's write-up on exactly what he did. Wouldn't there be other codes to point to a faulty wiring or sensor malfunction especially as ti relates to fuel pressure?
Now that I am thinking about it, I'm pretty sure I have new Bosch OEM Fuel Pressure Sensor in my garage from when I bought a new HPFP. Thinking if the HPFP didnt work, I would replace the sensor. Guess its not a bad idea to get it a shot. Although, if its a wiring issue, that may need to be done by a mechanic.
thigg12
C?ID=371417
Quick update. The CEL went off a few days ago and has stayed off. However, symptoms still persist. So this morning I ran another auto-scan, copied below. P2187 still showing with updated mileage, although still intermittent. P119A is same as before. New code now, P0087. Thinking through this one more, I decided to look at past repair orders and as luck would have it, around 36k miles, the car would randomly shut off with battery light indicator on and startup shortly after. VW tech pulled codes P0192 and P0087. He diagnosed a faulty fuel pressure sensor and wiring. Replaced sensor and wiring. This issue didn't pop up again until around 130k miles when CEL came on for P0192 and P0087. My mechanic replaced the fuel pressure sensor and the writing. Now I'm thinking this has to be the same issue as the symptoms are identical. It pisses me off to think this gremlin keeps coming back, but then again, it is a Volkswagen.
I'm always willing to take on mechanical jobs, but I tend to shy away from electrical ones. Later today I am going to poke around the engine and see if I see any obvious wiring problems (broken, frayed, etc.).
Thoughts?
Saturday,07,March,2020,11:57:01:05814
VIN: WVGAV7AXXBW513584   License Plate:
          65 72 77
VIN: WVGAV7AXXBW513584   Mileage: 289410km-179831miles
                    Mileage: 288450 km
                    Date: 2014.07.19
                    Time: 07:57:19
                    RPM: 766 /min
                    Load: 29.0 %
                    Temperature: 93.0°C
                    Temperature: 10.0°C
                    Voltage: 13.970 V
               P119A - 000 - Malfunction - Intermittent
                    Mileage: 288572 km
                    Date: 2014.07.19
                    Time: 20:44:43
                    RPM: 700 /min
                    Load: 21.6 %
                    Temperature: 84.0°C
                    Temperature: 30.0°C
                    Voltage: 13.716 V
000135 - Fuel Rail/System Pressure
               P0087 - 000 - Too Low - Intermittent
                    Mileage: 288952 km
                    Date: 2014.07.25
                    Time: 07:43:20
                    RPM: 634 /min
                    Load: 69.0 %
                    Temperature: 56.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.573 V
   Coding: 0000840
   Component: J104    C4 450 V2D3 0006
   Coding: 0002333
   Revision: 00009001
   Coding: 0000001002
   Revision: BL111001
   Coding: 009795
   Coding: 0012340
   Coding: 198A140000
   Coding: 820000
   Coding: 210F00
   Coding: 020000
                    Reset counter: 48
                    Mileage: 248085 km
                    Date: 2018.09.29
                    Time: 13:37:23
   Coding: 0001205
   Coding: 0000258
   Coding: 050B0500
                    Reset counter: 238
                    Mileage: 287576 km
                    Date: 2014.07.09
                    Time: 11:20:27
   Coding: 0001204
   Coding: 0023057
   Coding: 0001168
   Coding: 018704
                    Mileage: 281614 km
                    Date: 2014.03.13
                    Time: 09:48:28
                    Text: 3454295283
                    Pressure: 1.90 bar
                    Pressure: 2.40 bar
                    Temperature: 23.2°C
                    Text: C0
                    Speed: 29.0 km/h
   Coding: 0001168
   ROD: UHVNA.rod
End----(Elapsed Time: 01:27, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
