Skoda Superb 2 - cruise control display activation
mtl
Slovenia
C?ID=153305
I had a case with two Skoda Superb 2, one MY2011 and the second one MY2012. Both have the same instrument cluster with part nr.: 3T1 920 841 H
On both adaptation channel for cruise control display is present, but on first cruise control speed is shown in Maxi DOT and on the second not.
  • I activated CC display on both
  • activation is accepted on both
  • no error codes on any
  • I also did a full factory reset on settings on Maxi DOT if this would help
  • everything by the book, but the end result is different...
Both have the same Maxi DOT display, but there is quite a big difference in equipment level (for example one (CC not working) has Columbus, etc.). Though, this should probably not be relevant to this case.
So, my assumption is that there should be another thing to be activated in some other module so that instrument cluster would get information about the speed. Can somebody help with any suggestion?
A picture of what I mean with cruise control display:
Full autoscan of Superb MY2011 with working CC display
Friday,31,October,2014,18:25:45:07078
VCDS Version: 14.8.1.0
Data version: 20140905
VIN: TMBAD63T6B90xxxxx   License Plate:
Mileage: 138650km-86153mi   Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBAD63T6B90xxxxx   Mileage: 138650km-86153miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 056 T    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  2157
   Revision: --H09---    Serial number:
   Coding: 0000071
   Shop #: WSC 33361 790 00000
   VCID: 38751CC54B482DFA21-806D
   Part No SW: 1K0 907 379 AS    HW: 1K0 907 379 AS
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 843D601609230001211306E6901C0041300800
   Shop #: WSC 33361 790 00075
   VCID: 030FBB29820EBE22C4-8056
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
   Component: Climatic      150 0303
   Revision: 00006001
   Coding: 0000000002
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 397319C1B84234F2DE-806C
   Part No SW: 1K0 937 087 K    HW: 1K0 937 087 K
   Component: BCM PQ35  H+  103 0615
   Revision: 00103 AD
   Coding: 46990AB8E869F1C040080080110081EC477900AE532081605C0040000040
   VCID: 397319C1B04234F2DE-806C
   Subsystem 1 - Part No: 3T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 04081  26  0602
   Coding: 00D7B7
   Component: RLS 120810 05  54  0403
   Coding: 0730ED
                    Reset counter: 108
                    Mileage: 138652 km
                    Date: 2014.10.31
                    Time: 18:11:25
                    Voltage: 11.95 V
                        Term 50 Off
   Part No SW: 3T0 959 655 B    HW: 3T0 959 655 B
   Component: J234__LCK VW10 HI   1916
   Revision: 19014000    Serial number: 003GRPFGNQM1
   Coding: 0017227
   VCID: 408574251398653A99-8015
   Subsystem 1 - Serial number: 6332MTS621332200
   Subsystem 2 - Serial number: 6342MTS621642200
   Subsystem 3 - Serial number: 6351HTS6UQU1D6KJ
   Subsystem 4 - Serial number: 6361HTS6AOS1D6KJ
   Subsystem 5 - Serial number: 63727TS6T6EJB6KJ
   Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
   Component: LENKS.MODUL   009 0135
   Revision: FF010037    Serial number: 20100802100619
   Coding: 4080140000
   Shop #: WSC 07173 298 08836
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 72E1EEEDA5B487AADF-8027
   Part No SW: 3T1 920 841 H    HW: 3T1 920 841 H
   Component: KOMBI         H04 0406
   Coding: 110B00
   ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
   VCID: 38751CC583482DFA21-806D
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 020810F2003140
   Coding: E9807F0600020200003302
   VCID: 6DDBFD91748A585202-8038
   Component: IMMO          H04 0406
   VCID: 6AD1F68D8D644F6A67-803F
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 B    HW: 8X0 959 793 B
   Component: TSG FA        H09 0409
   Coding: 011C02208000001000
   Shop #: WSC 33361 790 00999
   VCID: 4C9D5015EFD0B15A75-8019
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 194    3001
   Revision: 00H17000
   VCID: 316321E1A832FCB266-8064
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 B    HW: 8X0 959 792 B
   Component: TSG BF        H09 0409
   Coding: 011C02208C00001000
   VCID: 4B9F5309EADEB6627C-801E
   Part No SW: 3T0 035 161     HW: 3T0 035 161
   Component: SWING         008 0065
   Revision: 0I001001    Serial number: SKZ1Z2K6987191
   Coding: 050004000004
   VCID: 67D78FB99676720278-8032
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200000001000
   VCID: 4E995A1D19CC834A1B-801B
   Component: TSG HR        H06 0409
End-------------------------(Elapsed Time: 02:31)--------------------------
Full autoscan of Superb MY2012 with not working CC display
Thursday,17,July,2014,11:10:26:07078
VCDS Version: 14.7.2.0
Data version: 20140714
VIN: TMBAE73T6B90xxxxx   License Plate:
Mileage: 155170km-96418mi   Repair Order:
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBAE73T6B90xxxxx   Mileage: 155170km-96418miles
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JB    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H23 7128
   Revision: 42H23---    Serial number:
   Coding: 00190012042400080000
   Shop #: WSC 33361 790 00101
   ASAM Dataset: EV_ECM20TDI01103L906018JB 003001
   ROD: EV_ECM20TDI01103L906018JB.rod
   VCID: 73EFEBE9DAAE8EA28E-8026
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Coding: 843D601609250002211206E8901A0042300000
   VCID: 75EBD5F1DCDA9092A0-8020
   Part No SW: 3T0 907 044 BD    HW: 3T0 907 044 BD
   Component: Climatronic   H16 0402
   Revision: 00005001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 75EBD5F1D4DA9092A0-8020
   Revision: 00103 AD
   Coding: 40990AB8A00508C040080080310081E4437000AE532081605C8040000040
   VCID: 397319C1B04234F284-806C
   Component: Wischer 24111  26  0602
   Coding: 00D7B7
   Component: RLS 271110 05  54  0403
   Coding: 2730ED
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 153
                    Reset counter: 234
                    Mileage: 152790 km
                    Date: 2014.06.20
                    Time: 06:51:57
                    Voltage: 14.30 V
                        Term 50 Off
                    Fault Frequency: 152
                    Reset counter: 234
                    Mileage: 152790 km
                    Date: 2014.06.20
                    Time: 06:52:12
                    Voltage: 14.30 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28241031001760
   Coding: 108004
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000.rod
   VCID: 438F7B29CA8E7E22DE-8016
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LA8 VW10 HI   1918
   Revision: 20014000    Serial number: 003K2PPVMDCO
   Coding: 0016696
   VCID: 4183712118926C32CC-8014
   Subsystem 1 - Serial number: 6332MTS604543260
   Subsystem 2 - Serial number: 6342MTS604763260
   Subsystem 3 - Serial number: 6351HTS6R6C0G6KJ
   Subsystem 4 - Serial number: 6361HTS6D101G6KR
   Subsystem 5 - Serial number: 63727TS647HUF6KR
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101130101546
   Coding: 008A140000
   VCID: 76E9D2FDC9DC9B8AA9-8023
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Coding: 110B00
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 38751CC583482DFA7B-806D
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 011210F1001258
   Coding: 353302
   VCID: 306524E56338F5BA33-8065
                    Fault Status: 00110100
                    Reset counter: 253
                    Mileage: 153998 km
                    Date: 2014.07.02
                    Time: 19:14:41
01304 - Radio
                    Reset counter: 253
                    Mileage: 153998 km
                    Date: 2014.07.02
                    Time: 19:14:41
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: 6AD1F68D8D644F6A3D-803F
   Part No SW: 3T0 035 680 B    HW: 3T0 035 680 A
   Component: RNS-MID       H42 4120
   Revision: AB001001    Serial number: SKZ6Z7K5337022
   Coding: 04000402000400810000
   VCID: 2F6727997E06EA422A-807A
   Subsystem 1 - Part No: 3T0 051 859 R
   Component: EU East V10  8049
   Part No SW: 8X0 959 793 C    HW: 8X0 959 793 C
   Coding: 011D0220D000001000
   VCID: 4D9B5D1114CAB85238-8018
   Component: EPS_ZFLS Kl. 195    3001
   Revision: 00H17000
   VCID: 316321E1A832FCB23C-8064
   Part No SW: 8X0 959 792 C    HW: 8X0 959 792 C
   VCID: 4C9D5015EFD0B15A2F-8019
   VCID: 4E995A1D19CC834A41-801B
End-------------------------(Elapsed Time: 02:30)--------------------------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I think your problem is ECU that not support this function. This function support ECU and send signal to cluster .
At least it was in older models like this.For Example , 2000 TDI in USA did not have icon on Cluster for CC, but if you install 2001 ECU icon will be there.
Your ECU and other car are not same.
Spacewalker
Poland
C?ID=159607
Correct
EDC16 is a right one for CCS display
Look if you can do a SW Update in EDC17 (CFFB)
If not , ask some tuneup guy to load there SW from VW for example (with CFFB engine too)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
...you forgot that the software level of the cluster is actually different even though the part number is identical. ;)
Jetta 97
C?ID=81680
I do not think that will make a difference.
Software is 04xx on both clusters so it should not make difference. I would say if one is 03xx and other 04xx then maybe.
I think main problem is ECU.
mtl
Slovenia
C?ID=153305
Thx, so the ECU is a problem. This explains then also why this did not work on Alhambra 1.4TSI, though it had also a different instrument cluster:
Address 01: Engine (J623-CTHA)       Labels: None
   Part No SW: 03C 906 026 AM    HW: 03C 906 026 AM
   Component: 1.4l R4 TSI   H02 3444
   Revision: LKH02---    Serial number:
   Coding: 00190032002401000000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM14TSI01103C906026AM 001001
   ROD: EV_ECM14TSI01103C906026AM.rod
   VCID: 6BDFF389829E5679AA9-803E
   Part No SW: 7N5 920 870 K    HW: 7N5 920 870 K
   Component: KOMBI         H03 0905
   Coding: 141F01
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3F8777D9A6661AD9561-806A
prako
Zagreb Cro
C?ID=116509
Pretty strange, that oldest engine ECU support that, and other side newest engine ECU with long coding not support that, maybe is different code for activation CCS in ECU. On my octavia CEGA engine and HW605 of cluster same stuff, i activate on adaptation to active CC display but nothing, when i try retrofit ACC CC display is shown on display...
Eddie-NL
C?ID=41179
probably the module for ACC is causing that to display. Did you fit different stalk set?
exclamation mark means there is a fault with the system
prako
Zagreb Cro
C?ID=116509
Yes, stalk is H version from G6, but he works same as G version, only lamp on instrument, I bay from eBay ACC set for press G6, but seller is make wrong describe, when i put on radarsensor in vcds i see that is from Porsche Panamera... But when i put code to activate ACC on display come new manu for acc and that figure on the down left.... I was canceled that project with acc, maybe it will work with radarsensor for Audi A4, I'm not sure for radar from Passat...
I will find codes, i don't remember right now, but tere are not codes for ACC activation for Passat, i find sone codes for Audi ACC and that i have on IC.
Spacewalker
Poland
C?ID=159607
New cluster SW (06xx) only allow you to ENABLE " Cruise Control Display" .
But "return" message is from ECU.
For example BKD engine 2005 ECU EDC16U1 not support , but EDC16U34 support it well (BKD Engine 2008)
I made plenty of Cluster SW Update, and cant fix that issue.
prako
Zagreb Cro
C?ID=116509
CFFB is EDC17?!
Spacewalker
Poland
C?ID=159607
CFFB is a EDC17
What ACC you was try to fit ?
prako
Zagreb Cro
C?ID=116509
ACC radarsensor was from Porsche Panamera, seller was make mistake in describe, i send it back and i was not try yet with other, like from Passat 3C/3AA...
Spacewalker
Poland
C?ID=159607
Try contact tune-up guy to change SW in ECU but not use SKoda Software, use VW Software
CFGB engine was made for Golf 6, Touran , Scirocco, Passat CC , Sharan etc .
Of course ECU p/n for each of cars is different.
tuneup guy will know how to fix it .
langers2k
C?ID=224085
Can you elaborate Spacewalker? For instance I have a car with the following ECU, the software was originally 7100 but has been updated using Skoda software and ODIS-e.
Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 C    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H24 9813
I've found various VW's with a CFHC engine but as you say the part numbers don't match up. Should I be able to run one of these software versions instead? Thanks,
Touran
Part No SW: 03L 906 018 NQ HW: 03L 907 309 N
Component: R4 2,0L EDC H28 4320
Touran
Part No SW: 03L 906 018 NG HW: 03L 907 309 R
Component: R4 2,0L EDC H25 0864
Caddy
Part No SW: 03L 906 018 NF    HW: 03L 907 309 R
Component: R4 2,0L EDC   H25 0660
Scirocco
Part No SW: 03L 906 018 AQ HW: 03L 907 309 R
Component: R4 2,0L EDC H23 6780
Golf (I think?)
Address 01: Engine       Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 AQ    HW: 03L 907 309 R
Component and/or Version: R4 2,0L EDC   H21 6780
