VW transporter 2001 70VIN
BOBSER1
Ireland
C?ID=275670
Hey folks just looking for some info on a transporter I'm looking at for lack of power .plug in vcds manually have to select chassis (70).try to scan and the only controller that will work is the immobilizer . I cannot print this as it just keeps automatically scanning over and over .any help would be great as access to the engine controller would be great 👍.
Moving this to Car Repair support.
Having to manually select the Chassis on is normal and expected on a T4.
What happens if you manually try to access some of the other modules, like:
[Select]
[01-Engine]
or
[Select]
[03-ABS Brakes]
or
[Select]
[17-Instruments]
BOBSER1
Ireland
C?ID=275670
Cheers uwe ,I have tried to manually select all these modules and the only one that seems to work is the one for immobilizer .the van starts and runs fine too while vcds is connected as I thought maybe it was an immobilizer fault ?software to modern maybe ? Bit baffled myself.
If it starts and runs, and things are generally powering up and working, I don't think it's likely due to an immobilizer fault. An immobilizer fault could prevent communications with 01-Engine (because the K-line gets to the ECU by going into the Immobilzer and coming out as the 'W' line), but not the other systems like 03-ABS and 17-Instruments; the K-line goes to those directly.
I think I would start sleuthing with a meter. Check for continuity from pin 7 of the OBD-II connector to the relevant pin on the some of the other modules.
BOBSER1
Ireland
C?ID=275670
That's great man thanks for your help I will try that out .
NostraJackAss
But but but your Eminence what if immobilizer was defeated?
OP did you check the DLC migration TV connection above fuse block & that ties or permits the K line to be bifurcated?
Ever considered the RTFB and WD are a good start or with a tone generator to light the path to K line and isolation of modules?
JPPSG the entire thread yet?
If the immo was defeated, I don't see how it would prevent comms to other modules that are connected to directly to the K-line (in other words, everything except the ECU). The OP said the Immo itself talks, so we can be reasonably confident the K-line isn't jammed up with random data either.
NostraJackAss
If immobilizer is defeated it can allow for operation and communication will take place on internal W CAN among modules & while if the bridge is unplugged other than immobilizer or if a module is running interference after the immobilizer module on K line could no?
I doubt it, but simple enough to test. Unplug immobilizer module from car. See if other systems like cluster or ABS then talk.
NostraJackAss
Not necessarily just the immobilizer because the main DLC bridge TV BAY often gets messed with above the fuse block unwittingly ( Just from what I see often for FOD ) or by someone unplugging or plugging the K line BUS into a dead side too or wrong connector is all I'm saying but yes isolation of modules is a good way to see too and one by one or tone out with DVOM.
BOBSER1
Ireland
C?ID=275670
hey ,i still haven got to the bottom of this yet as the van is in a different country still .i will check when she is home and when i find out i will update .
Nothing worse than an unsolved problem .and thread...
