2003 vw golf Poor idle
Pablo j
Bristol, UK
C?ID=349756
hi,we have had this car in our workshop for a service , when it arrived the eml indicated a fault p0405 egr excessive flow ( not using a vdcs ) during the service the throttle body was cleaned as was the egr valve .upon restarting the epc warning light was on and the eml . i had a quick look on the net and seen posts about resetting the throttle and egr which i did but with no change to the poor idle . i also carried out a reset of the stored values followed by a reset of the throttle and egr . i have tried a different map sensor with no change and tested for an air leak around the manifold but i was unable to find a cause . I hope someone here has the answer or will be able to point me in the right direction.
Friday,21,February,2020,18:06:40:42129
          76
VIN: WVWZZZ1JZ4D094820   Mileage: 303520km-188598miles
Address 01: Engine        Labels: 036-906-034-AZD.clb
   Part No: 036 906 034 DR
   Component:  MARELLI 4MV        5163
   Coding: 00031
   Shop #: WSC 00659
   VCID: 6597B24B7C7B8F3F5A1-4B5C
   WVWZZZ1JZ4D094820     VWZ7Z0C8450361
17961 - Barometric / Manifold Pressure Signals
            P1553 - 35-00 - Implausible Correlation
17912 - Intake Air System
            P1504 - 35-10 - Leak Detected - Intermittent
Readiness: 1010 0101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0011266
   Shop #: WSC 31414 000 00000
   VCID: 34311F0F822126B71DF-5184
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 31414
   VCID: 221DE9572DD5B807FF3-513C
   Part No: 1J0 920 926 A
   Component: KOMBI+WEGFAHRSP VDO V20
   Coding: 01413
   VCID: 2809FB7F4BE95257A17-513C
01039 - Coolant Temperature Sensor (G2)
            80-10 - Single-Wire Operation - Intermittent
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 31414
   VCID: 70B9D31FB3B95A97397-513C
   Part No: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 31414
   VCID: 36352507915D34A723B-4B1E
   Subsystem 1 - Part No: 1C2959802A
   Component: 1X Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C2959801A
   Component: 1X Tõrsteuer.BF KLO 0202
   Component: 1X Tõrsteuer.HL KLO 0202
   Component: 1X Tõrsteuer.HR KLO 0202
            36-00 - Open Circuit
End----(Elapsed Time: 05:09, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Jef
HQ
You might find this information helpful as well:
Danners74
C?ID=273244
Evening.....my experience with these you'll have a map sensor depending on engine size/code. You have what I would call star ship mileage on that old girl. Early ones on throttle body adaption with age youd end up replacing engine ecu because it wouldnt take the adaption.
The pipework from egr to throttle body base plate can get blocked....clean as required.
The other way Is readapt both with engine warm- lock the car and leave for 30 mins. Retry. It has worked on some. May disconnect battery for 30 mins that may reset.
Failing that potential EGR issue are not uncommon or throttle body.
NostraJackAss
Agreed............
Hey did you know these cars are like the ABA in the USA with a TV and the TV must move back 5 MM before it can commence forward to count the idle control stepper position?
Is the throttle cable too tight and causing the adaption to fail?
Did you try lubing the TV plate and make sure it moves backward first by massaging it & to see the zero marker of stepper is possible seeing if cable is running any interference?
