2009 Rabbit 2.5 ABS Code lost (MK60EC1)
09Rabbit2.5
C?ID=396240
Hello Wizards of Ross-tech. Around Christmas ABS module in my Rabbit crashed completely and dozens of lights went off in my dashboard. I went to ‘not the best mechanic’ he was right I needed a ABS module and junkyard was my best bet. I went to the Junkyard and got him a module from the similar model(4 door golf like mine). due to mine or his lack of knowledge we never looked to copy the old code. 8-10 lights changed to 4 lights on the dashboard though. Finally, googled the symptoms and VCDS came back as the answer. Got my cable shipped few days ago but due to my weekly schedule couldn’t scan till now. I have a lot of codes still being raised as per the scans. Priority is to do something about the ABS code as 00s doesn’t look right :D.
Will appreciate the magic!
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: WVWDB71K99W132981   Mileage: 128920km-80107miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 M    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   3253
   Revision: G6H01---    Serial number: VWX7Z0H83NT7TY
   Coding: 0000075
   VCID: 38292EBD9E550BD7315-806C
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 127107 km
                    Time: 23:17:42
                    RPM: 614 /min
                    Load: 18.0 %
                    Temperature: 90.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.208 V
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low
                    Mileage: 127502 km
                    Time: 21:21:12
                    RPM: 1185 /min
                    Load: 21.6 %
                    Speed: 26.0 km/h
                    Temperature: 79.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.589 V
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 161 /min
                    Load: 72.5 %
                    Temperature: 7.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 9.652 V
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 7DA7FFA9F1F7EEFFA23-8028
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 25155 444 12472
   VCID: 7EA5F8A5F0F1F5E7BB9-802A
                    Reset counter: 0
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 195
                    Count: 45568
                    Fault Status: 01100101
                    Fault Frequency: 17
                    Reset counter: 232
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 279
                    Count: 45568
                    Fault Frequency: 17
                    Reset counter: 232
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 295
                    Count: 45568
                    Fault Frequency: 17
                    Reset counter: 232
                    Mileage: 127107 km
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 270
                    Count: 45568
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EEBDDED5CBD7F15-802C
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000008945525
   Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
   VCID: 323D1C957829E1870F1-8066
   Component: Wischer 230908 021  0501
   Coding: 00038805
   Shop #: WSC 01357
01501 - Bulb for Blinkers; Rear Left (M6)
                    Fault Status: 01101100
                    Reset counter: 233
                    Mileage: 128510 km
                    Voltage: 13.85 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0426336
   Coding: 0000100
   VCID: 333319918733E88F047-8066
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:57
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0C2FBU
   Coding: 0013899
   VCID: 6C81C2ED9A8D777705D-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME4135700C3
   Subsystem 3 - Serial number: 6342MSME4135407EA
   Subsystem 4 - Serial number: 6352QSME340C4C02E
   Subsystem 5 - Serial number: 6362QSME620706245
   Subsystem 6 - Serial number: 63727SME19067350Y
   Subsystem 7 - Serial number: 63827SME186B6D05B
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Coding: 0010022
   VCID: 77ABED81D3CBC4AFF8F-8022
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0003000    Serial number: VWX7Z0H83NT7TY
   Coding: 0007203
   VCID: 3C2132ADAA6D27F7D5D-8068
                    Fault Frequency: 11
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:48
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 050908F2000857
   Coding: ED807F070003020002
   VCID: 353727898947F6BF2A3-8060
                    Fault Status: 00110100
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:51
   Component: IMMO            VDD 1222
   Component: Tuer-SG         006 1219
   Coding: 0001205
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Coding: 1B9006885103281B0904058FB0080F0488DC80
   VCID: 04518A4D921D9F37EDD-8050
   Coding: 0001204
   VCID: 392F2BB9A55F12DFCEB-806C
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       125 0037
   Revision: 00125000    Serial number: VWZ5Z7H2265686
   Coding: 0040401
   VCID: 290FFBF955FFA25FBEB-807C
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   Coding: 0100101
                    Fault Status: 01110100
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:59
00625 - Vehicle Speed Signal
                    Fault Status: 00111000
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:58:20
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0001168
End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.2V)-----------
Did I post it in the right forum? Or email as per instructions??
Here is fine. I'm reasonably confident there are people here who can come up with an appropriate coding for this. Unfortunately, I'm not one of them.
NostraJackAss
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Coding: 0000075
Coding: 0000840
Address 03:
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD FAIL! IN INVESTIGATION
Revision: 00H45001
PART-NUMBERJPPSGDESCRIPTIONREMARK MODEL
1K0 907 375 AHFOD!Control unit for ABSLEGACY PART NUMBERS
1K0 614 517 BD
1K0 907 379 AD
1K0 907 379 CD
Scans on net do not show this module in comparison
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
OP are you aware that this maybe a completely free repair under recall and can be verified at NHTSA?
Coding:
114B000C092500FC881400EC901A00000000 THIS IS NOT YOUR CODE IT IS A STRIP OF ALGORITHM TO VIN # LHD
PLEASE LOOSEN NOOSE?
Vehicle Identification No.WVWDB71K99W132981
Modelgolf 2.5
GO
Date of production27.10.2008
Model year2009
Sales type1K17S3
Engine CodeCBUA
Transmission CodeKGL
[COLOR=#333333]
[/COLOR][TABLE="class: vinInfoTable, width: 533"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PC[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0HA[/TD]
[TD]Vehicle class differentiation -1K0-[/TD]
[/TR]
[TR]
[TH="align: left"]tail pipe[/TH]
[TD="class: prCode"]0P1[/TD]
[TD]Rear side exhaust tailpipe[/TD]
[/TR]
[TR]
[TH="align: left"]Hill start assist[/TH]
[TD="class: prCode"]UG0[/TD]
[TD]Without hill start assist/hill descent
control/comfort driving assist[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]0GT[/TD]
[TD]Emission standard SULEV[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]Without trailer hitch[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UM[/TD]
[TD]Driver's and front passenger air bag, NAR with front
passenger air bag deactivation (2-stage) -
SMART airbag with automatic deactivation[/TD]
[/TR]
[TR]
[TH="align: left"]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E7[/TD]
[TD]Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fueling[/TD]
[/TR]
[TR]
[TH="align: left"]Aerials[/TH]
[TD="class: prCode"]8ZN[/TD]
[TD]Antenna[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SH[/TD]
[TD]Left exterior mirror, flat (US)[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RR[/TD]
[TD]Right exterior mirror, convex (US)[/TD]
[/TR]
[TR]
[TH="align: left"]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WL[/TD]
[TD]Jack for external audio source[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8X[/TD]
[TD]US comfort equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KE[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J1L[/TD]
[TD]Battery 280 A (60 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1ZP[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH="align: left"]Components with special surface[/TH]
[TD="class: prCode"]6FF[/TD]
[TD]Exterior mirror housing and various attachments
colour coded to vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0D[/TD]
[TD]Component parts set, complying with
vehicle type for USA (without
California), various parts[/TD]
[/TR]
[TR]
[TH="align: left"]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH="align: left"]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VM[/TD]
[TD]Information kit in American English[/TD]
[/TR]
[TR]
[TH="align: left"]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH="align: left"]Brake pad wear indicator[/TH]
[TD="class: prCode"]9U1[/TD]
[TD]Brake pad wear indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Heated washer nozzles[/TH]
[TD="class: prCode"]9T1[/TD]
[TD]Heated washer nozzles in front[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH="align: left"]"Charism"[/TH]
[TD="class: prCode"]2H0[/TD]
[TD]Without "drive select"[/TD]
[/TR]
[TR]
[TH="align: left"]Chrome package[/TH]
[TD="class: prCode"]QJ0[/TD]
[TD]Without aluminum/chrome work package[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C24[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH="align: left"]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FE[/TD]
[TD]Tilting and sliding glass sunroof with
sunbshade[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in rear[/TH]
[TD="class: prCode"]1JA[/TD]
[TD]Rear shock absorption, basic version 1[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in front[/TH]
[TD="class: prCode"]G07[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH="align: left"]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G7[/TD]
[TD]Filler neck module 1 with insert[/TD]
[/TR]
[TR]
[TH="align: left"]Installation differentiation for components[/TH]
[TD="class: prCode"]0ER[/TD]
[TD]Installation differentiation for
transmission AQ250
-- vehicle components --[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AG[/TD]
[TD]Electronic immobilizer
with anti-theft alarm system (for USA)[/TD]
[/TR]
[TR]
[TH="align: left"]Inserts[/TH]
[TD="class: prCode"]5MJ[/TD]
[TD]Decorative inserts[/TD]
[/TR]
[TR]
[TH="align: left"]Scuff plates[/TH]
[TD="class: prCode"]7M5[/TD]
[TD]Without impact protection film for door sill[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH="align: left"]Electric interface for external use[/TH]
[TD="class: prCode"]UF0[/TD]
[TD]Without electric interface[/TD]
[/TR]
[TR]
[TH="align: left"]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH="align: left"]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Pedestrian protection[/TH]
[TD="class: prCode"]VL0[/TD]
[TD]Standard pedestrian protection measures[/TD]
[/TR]
[TR]
[TH="align: left"]Pedal cluster[/TH]
[TD="class: prCode"]VF0[/TD]
[TD]Standard pedal cluster[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K4[/TD]
[TD]Separate daytime running light
-- NAR --[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YE[/TD]
[TD]Weight range 5
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]L13[/TD]
[TD]Suspension range 13
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]T8K[/TD]
[TD]5-cylinder SI engine 2.5 l
unit 07K.1[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U5[/TD]
[TD]Luggage pockets on backrest[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment cover[/TH]
[TD="class: prCode"]3U1[/TD]
[TD]Folding trunk cover[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T2[/TD]
[TD]Electronic cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH="align: left"]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment trim[/TH]
[TD="class: prCode"]5A7[/TD]
[TD]Comfort luggage compartment trim with
service lid/snap-on cover[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G1A[/TD]
[TD]6-speed automatic transmission[/TD]
[/TR]
[TR]
[TH="align: left"]Brackets[/TH]
[TD="class: prCode"]3P0[/TD]
[TD]Without bracket for first aid kit and
warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]handle for hand brake lever[/TH]
[TD="class: prCode"]6PA[/TD]
[TD]Hand brake lever handle in plastic[/TD]
[/TR]
[TR]
[TH="align: left"]Rear spoiler[/TH]
[TD="class: prCode"]5J0[/TD]
[TD]Without rear spoiler[/TD]
[/TR]
[TR]
[TH="align: left"]Rear window wiper and washer system[/TH]
[TD="class: prCode"]8M1[/TD]
[TD]Rear window wiper washer system with
intermittent wipe[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]3NU[/TD]
[TD]Rear bench seat, not split, split backrest, folding
centre armrest[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AP[/TD]
[TD]Climatic air-conditioning system
(semi-automatic)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8ES[/TD]
[TD]Twin headlamps for driving on the right,
with integrated high beam (US design)[/TD]
[/TR]
[TR]
[TH="align: left"]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without customized installation[/TD]
[/TR]
[TR]
[TH="align: left"]Interior light in footwell[/TH]
[TD="class: prCode"]6T0[/TD]
[TD]Without interior light in footwell[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U5C[/TD]
[TD]Instrument cluster, mph speedometer
- USA -[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L2[/TD]
[TD]Breakaway interior rearview mirror,
dimming[/TD]
[/TR]
[TR]
[TH="align: left"]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K8G[/TD]
[TD]Hatchback[/TD]
[/TR]
[TR]
[TH="align: left"]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH="align: left"]Refrigerator[/TH]
[TD="class: prCode"]1W2[/TD]
[TD]Glove compartment cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]child safety[/TH]
[TD="class: prCode"]4H3[/TD]
[TD]Manual child safety lock[/TD]
[/TR]
[TR]
[TH="align: left"]Electronic map cooling system[/TH]
[TD="class: prCode"]QS0[/TD]
[TD]Without electronic map cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]Child seats[/TH]
[TD="class: prCode"]QA0[/TD]
[TD]without child seat[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y2[/TD]
[TD]Tropical zones[/TD]
[/TR]
[TR]
[TH="align: left"]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH="align: left"]Rear head restraints[/TH]
[TD="class: prCode"]3T2[/TD]
[TD]Three rear head restraints[/TD]
[/TR]
[TR]
[TH="align: left"]Head restraints[/TH]
[TD="class: prCode"]5ZF[/TD]
[TD]Front head restraints[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel tank treatment[/TH]
[TD="class: prCode"]2LF[/TD]
[TD]Fuel tank with special material
treatment (coextrusion) with changed
protective layer[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z2[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel systems[/TH]
[TD="class: prCode"]1A1[/TD]
[TD]Fuel system for fuel-injected SI engine,
injection system without fuel return[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C1[/TD]
[TD]Body measures for increased safety
requirements[/TD]
[/TR]
[TR]
[TH="align: left"]Child seat anchors in front[/TH]
[TD="class: prCode"]3G0[/TD]
[TD]Without child seat anchora in front
(ISOFIX)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear license plate carrier[/TH]
[TD="class: prCode"]6P2[/TD]
[TD]Rear license plate carrier (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate carrier[/TH]
[TD="class: prCode"]6W3[/TD]
[TD]Front license plate carrier (small, NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K0[/TD]
[TD]Without surface protection, with
additional transport protection measures[/TD]
[/TR]
[TR]
[TH="align: left"]Paint coating[/TH]
[TD="class: prCode"]FB0[/TD]
[TD]standard paint coating[/TD]
[/TR]
[TR]
[TH="align: left"]Rear cargo area[/TH]
[TD="class: prCode"]3GA[/TD]
[TD]Without luggage compartment floor[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]Reading lamp[/TH]
[TD="class: prCode"]8S4[/TD]
[TD]Two reading lights in front, two in rear[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH="align: left"]Backrest release[/TH]
[TD="class: prCode"]3H2[/TD]
[TD]Backrest release for right front seat[/TD]
[/TR]
[TR]
[TH="align: left"]Air duct, front area[/TH]
[TD="class: prCode"]VK1[/TD]
[TD]Air duct, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Load edge protection[/TH]
[TD="class: prCode"]2P1[/TD]
[TD]Plastic loading edge protection[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P4[/TD]
[TD]Manually adjustable lumbar support in
front seats[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]1ME[/TD]
[TD]Steering wheel[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RW[/TD]
[TD]10 speakers (passive)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q0[/TD]
[TD]without beam length regulator[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH="align: left"]Marten repeller[/TH]
[TD="class: prCode"]UM0[/TD]
[TD]Without marten repeller[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q0[/TD]
[TD]Without multi-function display/
trip computer[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]D77[/TD]
[TD]5-cylinder SI engine 2.5 l/125 kW (20V)
(R-5)
base engine is T8K[/TD]
[/TR]
[TR]
[TH="align: left"]Left vanity mirror[/TH]
[TD="class: prCode"]4SH[/TD]
[TD]Left vanity mirror illuminated with
cover and special mirror imprint (NAR),
extractable[/TD]
[/TR]
[TR]
[TH="align: left"]Right vanity mirror[/TH]
[TD="class: prCode"]4TH[/TD]
[TD]Vanity mirror, right, illuminated, with
extractable[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH="align: left"]rear fog lamp[/TH]
[TD="class: prCode"]8TA[/TD]
[TD]witout rear fog lamp[/TD]
[/TR]
[TR]
[TH="align: left"]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WA[/TD]
[TD]Without fog lights[/TD]
[/TR]
[TR]
[TH="align: left"]Upgrading measures[/TH]
[TD="class: prCode"]GP0[/TD]
[TD]Vehicles without special upgrade
measures[/TD]
[/TR]
[TR]
[TH="align: left"]Rear of platform module base[/TH]
[TD="class: prCode"]4P0[/TD]
[TD]Rear floor panel module, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH="align: left"]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]CM6[/TD]
[TD]Alloy wheels 6.5J x 16[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8US[/TD]
[TD]Radio "Premium"
(double-size standard radio)[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JF[/TD]
[TD]Non-smoker's package (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K4[/TD]
[TD]Tire pressure monitoring system 315 MHz
High[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]H4B[/TD]
[TD]All-season tires 205/55 R16 H (NAR)[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G2[/TD]
[TD]Steel spare wheel with original
equipment tire[/TD]
[/TR]
[TR]
[TH="align: left"]Restraint systems, front[/TH]
[TD="class: prCode"]4QQ[/TD]
[TD]3-point seat belts in front with
pretensioner and height adjustment,
US label[/TD]
[/TR]
[TR]
[TH="align: left"][/TH]
[TD="class: prCode"]P2S[/TD]
[TD]Golf 16-inch alloy wheel package[/TD]
[/TR]
[TR]
[TD="class: prCode"]PEC[/TD]
[TD]Exhaust California (only for Golf USA
was: PMC)[/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q1[/TD]
[TD]Gearshift knob/handle in plastic[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH="align: left"]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, left[/TH]
[TD="class: prCode"]3TF[/TD]
[TD]Comfort seat in front, left[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, right[/TH]
[TD="class: prCode"]3SF[/TD]
[TD]Comfort seat, front right[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate for sales name[/TH]
[TD="class: prCode"]QD0[/TD]
[TD]Without nameplate for sales name[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P7[/TD]
[TD]Visual and acoustic seat belt reminder,
electric contact in buckle[/TD]
[/TR]
[TR]
[TH="align: left"]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZD[/TD]
[TD]3-point seat belts, outer rear with US
label[/TD]
[/TR]
[TR]
[TH="align: left"]Center rear seat belts[/TH]
[TD="class: prCode"]3C8[/TD]
[TD]3-point seat belt, center rear with US
label[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N0U[/TD]
[TD]Seat trim covers in velour[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3PD[/TD]
[TD]Manual height adjustment for front
seats, electric backrest adjustment for
left front seat[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH="align: left"]Safety head restraint system[/TH]
[TD="class: prCode"]3K0[/TD]
[TD]w/o safety head restraint system[/TD]
[/TR]
[TR]
[TH="align: left"]Side lights[/TH]
[TD="class: prCode"]7R4[/TD]
[TD]Side marker lamps and turn signal
repeaters (turn signals with white lens)[/TD]
[/TR]
[TR]
[TH="align: left"]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH="align: left"]Control number (no PR family)[/TH]
[TD="class: prCode"]S5K[/TD]
[TD]Control (in-plant)[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH="align: left"]Protective side molding[/TH]
[TD="class: prCode"]4B2[/TD]
[TD]Body-colored protective side molding[/TD]
[/TR]
[TR]
[TH="align: left"]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH="align: left"]Supertone system and tone sequence
control[/TH]
[TD="class: prCode"]9J0[/TD]
[TD]Without supertone system and tone
sequence control[/TD]
[/TR]
[TR]
[TH="align: left"]power outlet[/TH]
[TD="class: prCode"]7B2[/TD]
[TD]12 volt socket in luggage compartment[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper[/TH]
[TD="class: prCode"]2JC[/TD]
[TD]Comfort bumpers[/TD]
[/TR]
[TR]
[TH="align: left"]Rear stabilizer bar[/TH]
[TD="class: prCode"]0BD[/TD]
[TD]Rear stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Front stabilizer bar[/TH]
[TD="class: prCode"]0AD[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Drawers under front seats[/TH]
[TD="class: prCode"]QN0[/TD]
[TD]Without drawers under front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Heavy-duty/sports version[/TH]
[TD="class: prCode"]2UA[/TD]
[TD]Standard design[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N4[/TD]
[TD]Windshield wiper intermittent control
with potentiometer (four speeds)[/TD]
[/TR]
[TR]
[TH="align: left"]Special approval measures[/TH]
[TD="class: prCode"]3M0[/TD]
[TD]Without special measures[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate set[/TH]
[TD="class: prCode"]0NV[/TD]
[TD]Nameplate set "2.5"[/TD]
[/TR]
[TR]
[TH="align: left"]Special alarm systems[/TH]
[TD="class: prCode"]9A0[/TD]
[TD]Without taxi alarm system[/TD]
[/TR]
[TR]
[TH="align: left"]Door storage compartments in front[/TH]
[TD="class: prCode"]3YR[/TD]
[TD]Door pockets with insert mats[/TD]
[/TR]
[TR]
[TH="align: left"]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q1[/TD]
[TD]Mass damper for steering wheel, 26.5 Hz[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K0[/TD]
[TD]Central locking w/ radio remote control
and interior controls[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B38[/TD]
[TD]Legal requirements for California[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D2[/TD]
[TD]Carrier frequency 315 MHz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Door and side trim panels[/TH]
[TD="class: prCode"]4AF[/TD]
[TD]Door and side trim panel in foam film
and woven fabric[/TD]
[/TR]
[TR]
[TH="align: left"]doors[/TH]
[TD="class: prCode"]0A2[/TD]
[TD]4 doors[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV8[/TD]
[TD]Satellite radio reception NAR[/TD]
[/TR]
[TR]
[TH="align: left"]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EB[/TD]
[TD]without identification plate[/TD]
[/TR]
[TR]
[TH="align: left"]Delivery equipment[/TH]
[TD="class: prCode"]2A8[/TD]
[TD]Delivery equipment, water border[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first aid kit and warning
triangle[/TD]
[/TR]
[TR]
[TH="align: left"]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH="align: left"]Preparation for rotating beacon/siren
combination[/TH]
[TD="class: prCode"]9F0[/TD]
[TD]Without preparation for rotating
beacon/siren combination[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH="align: left"]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH="align: left"]LongLife Service Regime[/TH]
[TD="class: prCode"]QG0[/TD]
[TD]without service interval extension[/TD]
[/TR]
[TR]
[TH="align: left"]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH="align: left"]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W1[/TD]
[TD]Washer fluid level indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Additional body panels,
side[/TH]
[TD="class: prCode"]6EA[/TD]
[TD]Without additional side body covers
(stone guard)[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B7[/TD]
[TD]Child seat anchors as per Canadian
requirements a. ISOFIX child seat system[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
[COLOR=#333333]
[/COLOR]
FOD FAIL!
Let me translate this for the new member. It means the ABS module installed here isn't the "correct" one for the car. That doesn't necessarily mean it won't work though, but it certainly lessens the odds.
Jack: It also isn't all that helpful without telling us what the correct one(s) would be.
United States
The parts catalog cannot conclusively determine which ABS module was factory installed but I'm reasonably confident it would have been born with 1K0 907 379 AD. If so, that supers to 1K0 907 375 AN if you were to install a new repair kit from the dealer.
PL24 shows different part numbers so you may have a compatibility concern of some sort as Jack mentioned.
Either way, I believe the factory coding was:
113B400D492500FC881402EC921A00413000
09Rabbit2.5
C?ID=396240
That's not a good news :( .. Uwe said its not the end for this module maybe? before I make attempts to go look for another one again, what can I do?
cannot undo the noose all the way yet but I am here finally!!
I did take my car to the dealership, they gave me a run around and said since I never took my car in before ABS broke down, expense will be out of pocket. Should I call NHTSA?
09Rabbit2.5
C?ID=396240
Thank youuu. Will try this code and report back in 15- 30 minutes.
09Rabbit2.5
C?ID=396240
It worked!! :D now I gotta learn how to make it stick and take care of other codes !!
09Rabbit2.5
C?ID=396240
Everything is looking good now. I am going to run another scan tomorrow and see which codes are still around. I will first reach out to NHTSA and do more research to get VW dealership to honor the recall.
My motivation and concern now is what if this module goes bad later too. At least, between all this I found a amazing community & a way to deal with this car in the long run!!
Thaank you.
nazdaq100
London, United Kingdom
C?ID=314050
Thaank you.
This is a wonderful news I am always intrigued to learn an after auto scan if you can please post. this way we can determine the exact unique long coding which was successful with abs part number
Cheerio
NostraJackAss
OP and forum readers, recently people have been in apprehension, well " sometimes " & to when I question if a vehicle comports under useful life warranty or recall campaigns, and not sure if people realize this pattern behavior?
Did you know some may see this as an agenda, well, so I'm told and the ones with such apprehension, could it be a vicarious invisible hand?
Did you know as a professional or any professional in this industry or you deal with, they have a lawful responsibility to inform you before taking your money and unless you are made aware of safety or free repair campaigns and possibly sign off on it & before to commence in a paid for repair and with an expectation of estimate when engaging such defects even unwittingly of defect before a possible public disclosure?
Did you know professionals can charge for these estimates or diagnosis too and is why before giving advice professionally in shop, I charge for it with upfront agreed fees & acknowledged before we start; so insurance companies and manufactures become responsible to consumer for my time & as a third party & so the consumer has a claim directly & since I don't accept direction of pay from insurance companies or an OEM?
Did you know If doing estimates in good faith or informing people properly & as a licensed professional, if this is considered an agenda, I guess I'm guilty of it, however, knowing your industry and giving an expectation of professional advice is not legal advice, it's a requirement of working within guidelines of State & Federal regulations?
Even though what I do here is free, I still feel bound by aforementioned, so if I seem bullish on it, I apologize.
Can you see I have no angle other than I take issue with the interference our industry suffers & when it cant make money on it due to parts being too expensive or exceeding a value of a vehicle and due to using said defects or failure to circumvent comporting with a regulation & to effectively curb cars & to even force consumers out of shops or self repair enthusiasts by a creative hidden unjust enrichment scheme & maybe even in spirit of a Vail of alleged high security and into a new car sales floor or only OEM repair franchises to maintain a monopoly?
Does anyone see my point, sorry for being a PITA?
09Rabbit2.5
C?ID=396240
Well, there seems to be a lot more going on then it seems.
Saturday,22,February,2020,10:40:26:26625
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Home
VIN: WVWDB71K99W132981   License Plate: AAAAAAA
Mileage: 129010km-80163mi   Repair Order:
VIN: WVWDB71K99W132981   Mileage: 129010km-80163miles
03-ABS Brakes -- Status: Sporadic communication error 1000
   Coding: 0000075
                    Mileage: 127107 km
                    Time: 23:17:42
                    RPM: 614 /min
                    Load: 18.0 %
                    Temperature: 90.0°C
                    Temperature: 66.0°C
                    Voltage: 13.208 V
               P3078 - 000 - Airflow at Idle too Low - Intermittent
                    Mileage: 127502 km
                    Time: 21:21:12
                    RPM: 1185 /min
                    Load: 21.6 %
                    Speed: 26.0 km/h
                    Temperature: 79.0°C
                    Temperature: 37.0°C
                    Voltage: 13.589 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 173 /min
                    Load: 71.0 %
                    Temperature: 26.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 10.287 V
   Coding: 0000840
   Revision: 00H45001
   Coding: 113B400D492500FC881402EC921A00413000
   Coding: 00038805
   Shop #: WSC 01357
                    Reset counter: 236
                    Mileage: 128510 km
                    Voltage: 13.85 V
   Coding: 0000100
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:57
   Coding: 0013899
   Coding: 0010022
   Coding: 0007203
                    Fault Frequency: 11
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:48
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:17:51
   Coding: 0001205
   Coding: 0001204
   Coding: 0040401
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 234
                    Mileage: 128959 km
                    Time: 19:16:34
   Coding: 0001168
   Coding: 0100101
                    Reset counter: 198
                    Mileage: 127107 km
                    Time: 23:17:59
                    Reset counter: 238
                    Mileage: 127107 km
                    Time: 23:58:20
   Coding: 0001168
End----------(Elapsed Time: 01:14, VBatt start/end: 14.2V/14.3V)-----------
NostraJackAss
https://forums.ross-tech.com/showth...lost-(MK60EC1)&p=192850&viewfull=1#post192850
Did you know this car has a 15 year 150K warranty for useful life?
Part No SW: 07K 906 055 M HW: 07K 906 055 M <<<<<<<<<<<<<<<<<<<<<<<<<< HERE!
Component: 2,5l R5/4V G 3253 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< NO NO over HERE!
Coding: 0000075
Did you know your car is due for a ton of firmware GHG updates and all these repairs are covered under useful life warranty for these faults or as a result if they illuminate an MIL or not?
Part Version 07K906055M_3859
9203
9970
9971
07K906055M__Z105
See my point of this post?
https://forums.ross-tech.com/showth...lost-(MK60EC1)&p=192949&viewfull=1#post192949
Have you looked your car up here?
https://literature.vw.com/calibration_lookup.asp
You seemed receptive OP, would you like me to continue to document for you in self evident answered questions?
Could you post the OBD2 MODE 3 & 9 data in VCDS?
09Rabbit2.5
C?ID=396240
I’m totally with you on this one. I should have been a smart consumer before attempting all the mojo.
I have read all your post and agree with you. I will have to do things the right way!!
I’ll post the scans your requested shortly!
