EA 288 DIESEL COOLING SYSTEM BLEED
Danners74
C?ID=273244
Hi guys I really need your help...…..
Have a 2014 Skoda with dirty water and flushing the cooling system. Ive done loads with ODIS but im doing this for a friend. I need to bleed the cooling system and it has two circuits. I've bled the high pressure circuit with ease!!!!! Its the low pressure circuit I cant work out for the life of me on VCDS!!!!! :banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead: Its driving me nuts as I cant input a value on the basic settings for test low pressure cooling system. Just for record it has to be done with battery on charge as it takes approx. 15 minutes.
Would appreciate help :thumbs:
Pleeeeeeeeease help asap. Kind regards Danners :cry:
Danners74
C?ID=273244
Not sure if this belongs here? UWE???
Moving to Car Repair Support.
Where's your Auto-Scan? EA 288 don't all use the same ECU! ;)
Gone But Not Forgotten
Does the car support a secondary inline heater hose thermostat, be sure to observe for it if it does?
Danners74
C?ID=273244
erm sorry UWE. ITs and old one but nothing has changed. Im pretty well up there when it comes to these cooling systems with ODIS but I don't have it. I just need to bleed the low pressure system.
May thanks heres my old log.:)
Saturday,20,April,2019,15:43:41:56713
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: TMBBG7NE6E0026157   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE6E0026157   Mileage: 145861km-90633miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012030501090000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F3AE606479094EF377-807A
8 Faults Found:
5227 - Fuel Rail/System Pressure
          P0087 00 [032] - Too Low
5231 - Fuel Rail/System Pressure
4635 - Engine Oil Temp. Sensor (G8)
          P0196 00 [036] - Implausible Signal
                    Mileage: 145861 km
                    Date: 2019.04.20
                    Time: 15:32:48
                    Engine speed: 0.00 /min
                    Coolant temperature: 15 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 13.440 V
                    Fuel consumption: 0.00 l/h
                    Engine oil temperature: 27.4 °C
                    Oil warning threshold: 0.000 mm
                    Status of oil pressure switches-Bits 0-7: 0
                    Oil fill level: 120.000 mm
                    Extern.temp.sens.1 bank 1: raw value: 16.0 °C
                    Fuel temp. sensor 1 bank 1: raw value: 17.7 °C
4640 - Engine Oil Temp. Sensor (G8)
          P0197 00 [036] - Signal too Low
                    Mileage: 145861 km
                    Date: 2019.04.20
                    Time: 15:32:53
                    Coolant temperature: 16 °C
                    Engine oil temperature: 27.6 °C
10382 - Thermostat for Cylinder Head
          P199E 00 [039] - Open Circuit
                    Mileage: 145861 km
                    Date: 2019.04.20
                    Time: 15:32:45
                    Voltage terminal 30: 13.180 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 10.00 %
                    Shut-off timer: last engine shut-off time: 16726 s
          U0428 00 [040] - -
                    Mileage: 144144 km
                    Date: 2019.04.11
                    Time: 11:29:34
                    Engine speed: 1091.00 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 11 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.680 V
                    Unlearning counter according OBD: 29
21125 - Invalid Data Received from Airbag Control Module
          U0452 00 [032] - -
                    Fault Frequency: 9
                    Mileage: 127394 km
                    Date: 2019.01.05
                    Time: 16:31:07
                    Engine speed: 1275.00 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 20 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 77 °C
                    Voltage terminal 30: 14.460 V
                    Unlearning counter according OBD: 8
                    Limitation: accelerator pedal: 240.7 Nm
                    selected gear-Bits 0-7: 2
20359 - Internal Control Module
          P0606 00 [109] - Processor Fault
                    Mileage: 124926 km
                    Date: 2018.12.20
                    Time: 22:42:35
                    Intake air temperature: 76 °C
                    Voltage terminal 30: 10.000 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 65
                    Engine status: COENG_READY
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 616430000002C8
   Coding: 1A078A91242209720078060541CA245851249000608224F000430070C002
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 4BC29296D348C8CF3BF-801E
0294 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 36
                    Mileage: 144144 km
                    Date: 2019.04.11
                    Time: 11:29:34
0297 - Steering angle sensor
                    Reset counter: 141
                    Date: 2018.12.16
                    Time: 17:08:07
          C1146 02 [008] - Signal Failure
                    Reset counter: 37
                    Mileage: 144144 km
                    Date: 2019.04.11
                    Time: 11:29:52
   Part No SW: 5E0 907 044     HW: 5E0 907 044
   Component: Climatronic   H02 0604
   Revision: 00001K06
   Coding: 01110104000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_SK37.rod
   VCID: 629C5F3244C26987E89-8036
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011316401734
   Coding: 0F000842424700DB07A04082B10407280000000000000000000000000000
   Shop #: WSC 73430 790 00063
   ROD: EV_BCMBOSCH_011.rod
   VCID: 48C8AD9AC23E23D716D-801C
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130612  041 0570
   Serial number:         130614132916
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY13114297F
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000057118745
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20411109
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [008] - Open or Short to Plus
                    Reset counter: 37
                    Mileage: 143765 km
                    Date: 2019.04.09
                    Time: 20:08:13
12307 - License Plate Light
          B12CA 01 [008] - Electrical Failure
                    Fault Frequency: 58
                    Reset counter: 41
                    Mileage: 123935 km
                    Date: 2018.12.17
                    Time: 15:42:32
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 154
                    Reset counter: 48
545300 - Databus
          [Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
                    Reset counter: 37
                    Mileage: 144144 km
                    Date: 2019.04.11
                    Time: 11:29:34
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831316901243
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   VCID: 3828DD5AB2DE535766D-806C
13637426 - Databus
                    Reset counter: 37
                    Mileage: 144144 km
                    Date: 2019.04.11
                    Time: 11:29:34
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P4PBXDEKJ
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5AF646D770A46FE77-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 606 13
   Serial number: 3576U000000D53092D0A
   Subsystem 2 - Part No SW: -----------    HW: 454 000 606 13
   Serial number: 3586U0000009D4C8EC0
   Subsystem 3 - Part No SW: -----------    HW: 454 800 506 13
   Serial number: 3516RA21B7C010000000
   Subsystem 4 - Part No SW: -----------    HW: 454 800 506 13
   Serial number: 3526RAAF17A01000000B
   Subsystem 5 - Part No SW: -----------    HW: 454 802 403 13
   Serial number: 3556V5F225300000000$
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 20061304401359
   Coding: 0600
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 76B41362F84AE527B41-8022
   Part No SW: 5E0 920 961 D    HW: 5E0 920 961 D
   Component: KOMBI         233 2210
   Coding: 27A402002180A60001082A00000000
   VCID: 290E081E7974FADFE93-807C
   Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1144
   Revision: --------    Serial number: 0000673783
   Coding: 030000040B087300EF000248080F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 392ED85E89D44A5F993-806C
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 1405400703
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000066303029
   Coding: 001000208001020000001100
   VCID: 55F674EE058C8E3F9DB-8000
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000284656
   Coding: 1D0200
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D26CC4E9DFC767FB5B-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000066310638
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000289351
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
   Component: MU-S-D-ER     040 0421
   Serial number: S7E02406130917
   Coding: 03730100FF0000001111120100A800002F0000860100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 211E103E0144329FB13-8074
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9NK6001DZ
End----------(Elapsed Time: 01:11, VBatt start/end: 14.2V/14.2V)-----------
Are you going to fix the fault's for thermostat being in error?
There is an Adaptation channel in that ECU called:
IDE08287 -- Bleeding of coolant circuit (not active, active).
There are also two Basic Settings:
IDE04795 -- Test - bleed low temperature circuit
IDE08087 -- Test - bleed cooling circuit
I'm not sure which of these will do what you're looking for, but they do exist.
Danners74
C?ID=273244
Morning all. The low pressure side of things is the only one that doesn't work.I cant get it to work as I don't know what value to input on the screen as it comes up and says out of range.
Jack European parts this was an old scan and yes id rectified a wiring issue by the charge air cooler on top of engine. Like I said I know these puppies and their quirks. Just not how to get the low pressure system to bleed.
Ive done the bleeding cooling circuit which is the running one. The other one is with the ignition off.....it just will not work.
Regards Danners
Danners74
C?ID=273244
bump bumpety
:eek::eek:
Regards Danners
Sorry, I'm on restriction for being bad & currently in a one on one cell, my neck is so tight, I can hardly breathe with this noose attached............. ;)
Hey CO is lunch coming soon?
danners......
What is the current scan now after all repairs & current DTC's of record?
What is not happening screenshots maybe?
chli1976
Austria
C?ID=176693
Have the same problem as @Danners74
bleed low temperature circuit does not work on a 2015 Skoda Octavia with 04L 906 021 N_6547 ecu.
Have done it with ODIS now
If needed i can send diagnostic protocoll, but in german language
TimP
Stoke-on-Trent, UK
C?ID=289525
Tim Preston
As I don’t have ODIS, I really need to know how to bleed the cooling system on my 2016 Seat Alhambra with the TDI 184 engine using VCDS.
I have run the cooling system bleed successfully, but have the same problem as the others on here with the low temperature circuit bleed.
One thing that occurred to me is that the cooling system bleed routine actually does the whole system on these cars as both circuits are linked under some circumstances. This would actually seem more logical than having two separate routines.
However, I really need to know as I do not want to risk damaging the engine.
By the way, I have the full factory manual and have followed it to the letter (until it tells me to connect the VAS system and follow the on screen guidance).
Please can someone help as without any proper guidance VCDS doesn’t seem to be very much use.
Thanks.
