Indicator tweak from 3 flashes to 5
busterboy
C?ID=383133
Hi guy's, I have an Audi A8L 2017 model and wondered has anyone found a way / code to make the indicator flash 5 times instead of the default 3 flashes it does when you just "tap" the stick instead of the full click.
Scan here for anyone who might be able to help please.
Thursday,13,February,2020,14:15:51:17234
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4H4HN020264   License Plate: KX17 ZGG
Mileage: 78018km-48478mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 28 30 34 36 3B 42 44 46 47
          52 53 55 56 57 5F 62 6C 6D 6F 72 81 85 88 89 8F 90 AC
VIN: WAUZZZ4H4HN020264   Mileage: 78018km-48478miles
Address 01: Engine (J623-CTBD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 997 401 F    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  X14 0002
   Revision: 58X14---
   Coding: 0A2A4032052601030800
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30TDI0114H0997401F 001002
   ROD: EV_ECM30TDI0114H0907401Q.rod
   VCID: 3038EB363AA766A7795-8064
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30TDIRdW  H22 1011
   Revision: --H22---
   VCID: 7CA00F06A66F52C795D-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AB    HW: 4H0 907 379 AB
   Component: ESP PREMIUM   H10 0930
   Coding: 60E5EB8006A7D701E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005025
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 72BC213EF42B14B7CF1-8026
   Part No SW: 4H0 907 064 HB    HW: 4H0 907 064 HB
   Component: BCM2 2.0      H61 0825
   Coding: 05B76F4E000000000000
   VCID: 70B82B36FAA726A7395-8024
   Serial number: 3217000018256009
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000245068453
   Coding: 0038320000047201000001010101112131313333283333
   VCID: 3430E726CE3F5A871DD-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
   Component: Klima 4 Zonen H20 0210
   Coding: 362102BE3C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2B02FC5A1381057F4C7-807E
   Part No SW: 4H0 907 063 GB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0368
   Revision: 1902003S    Serial number: 00001624426601
   Coding: 0105001440349FE0C9014087A0001800009DC30A2F080201800008946100170000400034030000
   VCID: 6E84354EE09330572B9-803A
   Subsystem 1 - Part No SW: 4H2 955 119 D    HW: 4H2 955 119 A
   Component: WWS641 161220  H38 0100
   Serial number:         170109145514
   Coding: 0045F7
   Serial number: 20173521X81A955547A0
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 29 03 2017  00000716
   Component: EVLS-SG  H08 0300
   Serial number: WA126451000028834772
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 0F088C9800PAG0MUFU03
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100DAGN5
   Coding: 30333045313430303038554A305234483053
   VCID: 3B22CC1AE3E195FFDC7-806E
   Serial number: 3575HRB405T468HIAP1U
   Serial number: 3585HRB405R468HI59LS
   Serial number: 3515JRB4012597JML9FD
   Serial number: 3525JRB4014597JM89UI
   Serial number: 3554VRB401659GF2IPDS
   Serial number: 3564VRB401659GF2OOV9
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 01335QD6000MQ
   Coding: 000034
   VCID: 372AD02ADF49B19F38F-8062
   Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
   Component: E221 - MFL  H09 0010
   Serial number: 16 12 2016  H0035393
   Part No SW: 4H0 920 910 T    HW: 4H0 920 910 T
   Component: TDieGB------- H55 0903
   Revision: 44081303    Serial number: 658080417592008
   Coding: 33AF08001B412600010000
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 3536DA22C5C5438F2A3-8060
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2170227000937
   Part No SW: 4H0 907 468 AH    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000002576217
   Coding: C0CD077F08
   VCID: 77AA102A9F49719FF8F-8022
   Subsystem 1 - Part No SW: 4H0 915 181 G    HW: 4H0 915 181 G
   Component: J367-BDM  H08 0270
   Serial number: 54038025081481182402
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 17087002207011200410
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2800000000
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 3828D316D2D7BEE7315-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000002795
   Coding: 01010101000000000001000202
   VCID: 649057663E5F8A074DD-8030
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3AE84A2799795F60F-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000244721443
   Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA7703TDDN
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372AD02ADFC9B19F38F-8062
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H08 0280
   Revision: --------    Serial number: 0000247627063
   Coding: 011F1E015E0162C202083006
   VCID: 48C8A3D6A2B7CE67415-801C
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000627986
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2CC91EECDBACF7C71-806E
   Revision: 00002001    Serial number: 0438557057
   Coding: 011B0E2280B93985F320C7C40A0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 959 591 B    HW: 8V3 959 591 A
   Component: J245 PS50.402  H03 0004
   Serial number: 0000FST001J16RI00000
   Coding: 901F00
   Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H13 0080
   Serial number: A2017000000000155033
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS014  H06 0005
   Serial number:     WOO1000KP4O
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 66001288
   Revision: CJ007001    Serial number: 00000000209450
   Coding: 030000
   VCID: 1D6622825DB5FBCFC23-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H08 0280
   Revision: --------    Serial number: 0000246267884
   VCID: 3C20CF06E66F92C7D5D-8068
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002158373
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 323CE13E34AB54B70F1-8066
   Coding: 02F6022022130200
   VCID: 3430E726CEBF5A871DD-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E00300
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E00300
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E00300
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109CQ0H5019221
   Coding: 010103010000000001
   VCID: 2D06F2422D150B4F523-8078
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801302534001
   Coding: 03000000
   Part No SW: 4H0 035 654 D    HW: 4H0 035 654 D
   Component: H-BNT-EU      H51 1072
   Revision: --------    Serial number: 449D$0HB004073
   Coding: 02010100000BF1EF45908B1E00000003000101000000000000
   VCID: 270A006A0FE9211FA8F-8072
   Subsystem 1 - Part No: 8R0 060 884 FK
   Component: EUR 2018/2019  2702
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDHY901B62$
   Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000238757
   Component: CD-Database  9040
                    Reset counter: 192
                    Mileage: 78018 km
                    Date: 2020.02.13
                    Time: 14:11:45
                    Text: DU902A,Front,M,0,0,6
03623 - Invalid Security/Release Code
                    Reset counter: 192
                    Mileage: 78018 km
                    Date: 2020.02.13
                    Time: 14:11:44
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H08 0280
   Revision: --------    Serial number: 0000250127716
   Coding: 010F1E01400062C202083006
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 024611010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914_AU64.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 090701351
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBA284AE719395F20F-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000229387
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6392547A3BD18D3FB47-8036
   Component: TSG HR        H08 0280
   Revision: --------    Serial number: 0000250127711
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN170123  0022
   ROD: EV_GSM2x3Mono.rod
   VCID: 2C00FF46168F024745D-8078
   Component: DPC-SG        H28 0081
   Coding: E0140000
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00030660119201
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00030660179801
   Coding: 272FF2
   Component: RGS-VL        H16 0080
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EEE3231AD6FAF76B-8064
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 170600241
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:51, VBatt start/end: 14.5V/14.5V)-----------
   Revision: 58X14---
   Revision: --H22---
   Coding: 0045F7
   Coding: 02004E
   Coding: 020300
   Coding: 000034
   Analog_clock:
   Coding: C0CD077F08
   Voltage stabilizer:
   Coding: 2800000000
   Coding: 008000
   ROD: EV_SARA2.rod
   Coding: 901F00
   Coding: 030000
   Coding: E00300
   Coding: E00300
   Coding: E00300
   Coding: E00300
   Coding: 03000000
                    Reset counter: 192
                    Mileage: 78018 km
                    Date: 2020.02.13
                    Time: 14:11:45
                    Reset counter: 192
                    Mileage: 78018 km
                    Date: 2020.02.13
                    Time: 14:11:44
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Coding: 021004C020
   Coding: 220000
   ROD: EV_Ambie.rod
   Coding: E0140000
   Coding: 672FF2
   Coding: 272FF2
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:52, VBatt start/end: 14.6V/14.5V)-----------
I'm not aware of a way to do that in that series of BCMs.
busterboy
C?ID=383133
Oh never mind Ewe, Thank you for your speedy response. :)
:p
Mari
C?ID=150535
Don't know for sure... but found this somewhere on the internet...
[46-Central Conv.]
[Adation]
Search for "Blinkerzyklen"
Value 1-5
[46-Central Conv.]
[Adation]
Value 1-5
His BCMs don't use UDS, meaning they don't have named Adaptation channels.....
busterboy
C?ID=383133
Apologies for refreshing this thread but wondered if anyone had found the answer to my question yet.
It's not super important but would be better and safer if it could be changed.:p
