VW Golf MK5 GTi Radio AUX Coding RCD 300
nazdaq100
London, United Kingdom
C?ID=314050
Hi,
Recently had someone come in for 56-Radio Aux coding on a VW Golf MK5
I have tried many codings:
Coding: 0040402 - Original - Says NO CDC when you press the CD button on RCD300
Coding: 0040400 - Accepts - No Options
Coding: 0040401 - Coding Rejected
Customer has mentioned he's taken the CD changed plug out back of the RCD 300 and replaced it with AUX cable
Any info would be extremely helpful
Sunday,16,February,2020,18:45:53:42869
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1KZ6W019234   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ6W019234   Mileage: 207640km-129021miles
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2229039
   Coding: 0403000318070060
   Shop #: WSC 00227 210 01318
   VCID: 63925E2E375FCF4FB47-8036
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
                    Mileage: 206139 km
                    Time: 15:51:56
                    RPM: 758 /min
                    Load: 18.4 %
                    Temperature: 72.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.097 V
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 40D8B1A28689B457895-8014
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   VCID: 678A4A3EC367A36F68F-8032
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000001957958
   Coding: E58D8F2700041800001400001400000000087F075C
   VCID: 2B02F60E1F0F470F4C7-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 01279
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 01279
01800 - Light Switch (E1)
                    Reset counter: 101
                    Mileage: 205421 km
                    Voltage: 14.35 V
                    Reset counter: 101
                    Mileage: 206944 km
                    Voltage: 7.30 V
                    Reset counter: 101
                    Mileage: 206944 km
                    Voltage: 6.80 V
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0FV558
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 372ADA7ED347F3EF38F-8062
   Subsystem 1 - Serial number: 6332MSME0A6E726BR
   Subsystem 2 - Serial number: 6342MSME0A6E066ES
   Subsystem 3 - Serial number: 6351HSME07651D6EJ
   Subsystem 4 - Serial number: 6361HSME075C221B8
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000012
   VCID: 76B4177A94CD4AE7E39-8022
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   Shop #: WSC 00323 067 57207
   VCID: 6E843F1AEC9D72272B9-803A
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056140AE1
   Coding: 3D3F0740070003
   VCID: 2A0CF30A10F55E07B71-807E
   Component: IMMO            VDD 1012
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2348
   Coding: 0000692
   VCID: 3634D77AD44D0AE7239-8062
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 3332EE6EC73F1FCF047-8066
   Part No: 1K0 959 433 AK
   Coding: 01C802087F2D8405485FC69010CC
   Shop #: WSC 00000 785 00200
   VCID: 79AE1C46A5D3259F8EB-802C
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
   Part No: 1K0 959 702 K
   Coding: 0000692
01553 - Motor for Central Locking; Passenger Door (V57); Lock
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0040400
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2422
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 3430ED72C23118F71DD-8060
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D06F816211B493F523-8078
End----------(Elapsed Time: 01:08, VBatt start/end: 12.3V/12.3V)-----------
siLc
Tallinn, Estonia
C?ID=330192
Radio part number reveals this is a RCD300 with black buttons? Yeah, this is not going to work. You can't get direct AUX-in and instead will have to use a AUX-in converter (CD changer emulator). A RCD300 with silver buttons would support direct AUX-in like you described.
nazdaq100
C?ID=314050
Thanks I will keep in mind truly grateful will let the customer know
