Error code with dates in the future
JCS13
FRANCE
HC800959 (2nd hand)
I use a HEX + CAN interface for VW T6 of 2017.
after a auto-scan with VCDS 19.6.2, I find error codes with dates of 2026 and 2033.
Why are the dates not correct?
The problem is it a bad time management in the calculator or a version too old my ross-tech interface.
Thank you for answer
Extract off auto-sacn
Sunday,19,January,2020,09:43:07:35032
VCDS Version: 19.6.2.0
VIN: WV2ZZZ7HZHH050025 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 5F 61 69
VIN: WV2ZZZ7HZHH050025 Mileage: 17880km-11110miles
Address 01: Engine (2D2D2-CXFA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KM HW: 04L 907 445
Component: R4 2.0l TDI H02 6186
Revision: 23002001
Coding: 0019401C432401080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 020B31B49587C95FB1-8056
30540 - Throttle Position Sensor (G69)
P0121 00 [032] - Implausible Signal
Mileage: 15875 km
Date: 2033.01.03
Time: 11:23:05
27176 - Coolant Pump for Intercooler
P190D 00 [032] - Mechanical Malfunction
Mileage: 12789 km
Date: 2026.01.14
Time: 07:03:32
South Molton, UK
The dates are stored by the modules in the car and just read by VCDS, so the strange dates are "created" by the firmware in the car not VCDS.
Sometimes those dates are "relative" rather than absolute, and if the offset isn't correct, well....
Eric
HC800000
Please provide:
1) Unedited autoscan
2) Adp and MWB maps from cluster
JCS13
FRANCE
HC800959 (2nd hand)
Morning,
I am new to VCDS. Can you explain to me how to provide the Adp and MWB maps from cluster.
thank you
-----------full scan : -------
   Revision: 23002001
                    Mileage: 15875 km
                    Date: 2033.01.03
                    Time: 11:23:05
                    Engine speed: 0.00 /min
                    Coolant temperature: 83 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 12.281 V
                    Unlearning counter according OBD: 13
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: -0.01 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 100.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.27 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4.740 V
                    Mileage: 12789 km
                    Date: 2026.01.14
                    Time: 07:03:32
                    Engine speed: 830.25 /min
                    Normed load value: 31.0 %
                    Coolant temperature: 60 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 13.210 V
                    Unlearning counter according OBD: 26
                    Air mass at air mass meter 1: 28.8 kg/h
                    Extern.temp.sens.1 bank 1: raw value: 16.0 °C
                    Charge air cool.output temp.sens.1 bank 1: raw value: 24.5 °C
                    Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 10.00 %
                    Turbocharg. 1 compressor outlet:temp.sensor 1 bank 1: raw value: 29.0 °C
Readiness: N/A
   Revision: 00000000    Serial number: 42446000002000
   Coding: 617E40982567847E86750278A48721D2780000
   Shop #: WSC 02739 790 50316
   VCID: 3F8DF840A6F564B79E-806A
   Serial number: 04091613470053
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34544E17FADBFD5-802A
   Part No SW: 7E0 907 047 AH    HW: 7E0 907 047 AH
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 70EF6B7CAB2BCBCF57-8024
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 251160827
   Coding: 62A0393A0B332012002809742C2B8CD40F94710F60444D60320400230840
   Shop #: WSC 02737 534 543441
   VCID: 2A5BB9144577F11FD9-807E
   Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU031081662442041
   Coding: 0400A0
   Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU030081662435642
   Coding: 1400A0
   Subsystem 3 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160001732220126354
   Coding: B0FFFF
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261620303094
   Coding: 10800C
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71E96E78A021C2C758-8024
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01R H08 0018
   Revision: --------    Serial number: 003V400138Z%
   Coding: 000000000000000000000000000000003152
   Shop #: WSC 02734 790 50316
   VCID: 3B758C50B2ED7897B2-806E
   Serial number: 3495ZRB40533V6TCFPDP
   Serial number: 3505ZRB400A571NGHHGU
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Coding: 140F010300
   VCID: 39799658B8D14A87A0-806C
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273 A    HW: 7E0 963 273 A
   Component: STH-T5GP2     003 0009
   Coding: 4101
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B55BC10428DE81722-807E
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042205
   VCID: 68DF031C9BFB030F0F-803C
   Component: IMMO          H03 1104
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB79148DF7311F19-803E
   Part No SW: 1K8 035 150 H    HW: 1K8 035 150 H
   Component: MU-E--ER      055 7067
   Serial number: 24081600010076
   Coding: 06570000FF00000041110001000000001F0000C40000010001
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 2A5BB9144D77F11FD9-807E
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 530B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75410903001608151438
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000412480371
   Coding: 0100000101000000
   VCID: 326BA1746DA7B9DF61-8066
End-------------------------(Elapsed Time: 03:11)--------------------------
Morning,
thank you
^^^^^Look at RT's magnificent video HERE. This video has a dual purpose, but if you start at about 2:19 minutes, you will learn how to generate an Adp (or, "admap") for individual control modules like the cluster (which VCDS identifies as the "Instrument" module @ address hex17 -see your auto-scan).
At about 2:33 minutes into the video choose different options as follows:
For an Adp:
Single controller address = 17
Under "Function", tick Adaptations
Under "output", click the CSV file radio button
the set-up should look like this, (but use "17", instead of "09" in the pic:
For a MWB map, again enter 17 into Single controller address, but tick Measuring values under Function
For each type of map - then just press the Go button and magic stuff will happen!!
May the force be with yo
PS: you can tick both Adaptations AND Measuring values to streamline the process and to generate a single file containing the 2 x data sets - if you want
JCS13
FRANCE
HC800959 (2nd hand)
hello,
thank to DV52 for the procedure.
below Adaptations AND Measuring values data:
;SW:7E0-920-870-S   HW:7E0-920-870-S ---  Instruments
;Component:KOMBI         H03 1104, Coding:140F010300
;EV_Kombi_UDS_VDD_RM09,A05733,EV_Kombi_UDS_VDD_RM09_005_VW25.rod
;Wednesday,19,February,2020,14:33:23:35032
;VCDS Version: Release 19.6.2  Data version: 20190930 DS308.0
;VCID: 39799658B8D14A87A0-806C
IDE00301-Distance,17880 km,2
IDE00342-ESI: Resetting ESI,Reset ,1
IDE00343-Language version,French ,1
IDE00344-Seat belt warning,Version 4 ,1
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,1
IDE00492-MAS02003-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SID on ,1
IDE00492-MAS02006-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI) ,1
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,1
IDE00492-MAS02011-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver ,1
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality ,1
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,1
IDE00493-Display correction of fuel gauge,-0.5 ,1
IDE00500-Hour,14 H,1
IDE00501-Minute,32 min,1
IDE00505-Speed threshold of dynamic oil pressure warning,kein Offset ,1
IDE00510-ESI: distance driven from inspection,6900 km,2
IDE00511-ESI: time from inspection,434 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,20000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,40000 km,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,9200 km,2
IDE00518-ESI: thermal load,4500 km,2
IDE00711-Trip recorder,not installed ,1
IDE00714-MAS00888-Additional coding-Tank characteristic curve,1 ,1
IDE00714-MAS01209-Additional coding-Speed source,via CAN ,1
IDE00714-MAS01210-Additional coding-Coolant temperature source,via CAN ,1
IDE00714-MAS01211-Additional coding-Locking bit,locked ,1
IDE00714-MAS04066-Additional coding-Number of fuel level sensors,1 ,1
IDE00827-ESI: minimum value of time between inspections,730 d,2
IDE02200-Component protection showroom mode,not activated ,1
IDE02327-Indicator light for start-stop operation,active ,1
IDE02489-Display depiction,Not available ,1
IDE02494-Automatic door locking,Yes ,1
IDE03177-MAS02569-Acoustics for timeout signaling-All-wheel electronics,Not available ,1
IDE03177-MAS02570-Acoustics for timeout signaling-Lock Electronics,Not available ,1
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,2
IDE03346-IDE00316-Units adjusted-Time,24h ,2
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,2
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,2
IDE03346-MAS02201-Units adjusted-Temperature,°C ,2
IDE03346-MAS03032-Units adjusted-Volume,Liter ,2
IDE03346-MAS03033-Units adjusted-Consumption,Liters per 100 km ,2
IDE03346-MAS03034-Units adjusted-Pressure,bar ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,40000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,6900 km,2
IDE03352-FIX: Time since last time-dependent inspection,435 d,2
IDE03481-MAS01632-Emergency telephone number-Status,not active ,25
IDE03481-MAS04225-Emergency telephone number-Preselection,000000000000000000000000 ,25
IDE03481-MAS04226-Emergency telephone number-Telephone number,000000000000000000000000 ,25
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On ,5
IDE04848-Volume to be replenished,No ,1
IDE05583-Pause recommendation,Yes ,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE06418-Light warning buzzer: condition,closed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE07221-Cylinder shut-off,No ,1
IDE08753-IDE00837-MFA display cylinder shut down-Instantaneous consumption,No ,1
IDE08753-MAS03930-MFA display cylinder shut down-Average consumption,No ,1
IDE08753-MAS03934-MFA display cylinder shut down-Range,No ,1
IDE08753-MAS05871-MFA display cylinder shut down-Full engine operation,No ,1
IDE09257-Power steering,Version 2 ,1
IDE10059-MAS00844-Component protection mode-Radio,requested ,1
IDE10059-MAS01799-Component protection mode-Navigation,not requested ,1
IDE10059-MAS05506-Component protection mode-Stopping distance reduction,not requested ,1
IDE10059-ENG114193-Component protection mode-Vorhalt,not requested ,1
ENG112420-MAS03095-additional_adaption-Function status,No ,3
ENG112420-MAS03118-additional_adaption-Logic address,0 ,3
ENG112417-indicator_celebration,not active ,1
ENG141644-Scale_dimming_algorithm,Autolicht / Abblendlicht / Nebellicht ,1
ENG108924-Service_Key_Clear_All_Counters,Yes ,1
ENG112416-IDE01766-velocity_detection-Distance impulses,4 ,1
ENG112416-MAS01209-velocity_detection-Speed source,Distance impulses ,1
Elapsed Time: 00:36
Thank you by advance
Eric
HC800000
You only have the adaptations here. I'm looking specifically for IDE00819: Day counter . On a Passat NMS with the same ASAM ID, it's only present in measuring values.
JCS13
FRANCE
HC800959 (2nd hand)
With the tool 'Controller Channel Map' option Single Controller adress on 17,
I do not have a CSV file generated for Measuring value.
I only have a CSV file for the Adaptations but there is no value IDE00819
is what I use the right method?
thank you
Eric
HC800000
Measuring values should be in a CSV file starting with "blockmap-17".
Eric
HC800000
Do you have measuring values when you connect manually to controller 17? Did you completely drain your battery? :)
Eric
HC800000
Wait, you have a HEX-USB+CAN... that's why. Connect to 17 manually, enter "day" in the search field, select something that matches "day counter", and save/screenshot the value VCDS displays.
JCS13
FRANCE
HC800959 (2nd hand)
in manual mode, the value is 1245d for IDE00819.
sorry, i dont understand : Did you completely drain your battery?.
^^Eric: What a fascinating thread and what an extremely interesting question - what is the format of the date field on OBD?
I just pulled a random hex17 module from my database: the IDE00819 value is 206 for the admap date 13 August 2018 (confirmed by the year, month, day, channel values in the module).
If I'm not violating Ross-Tech commercial secrets - what is the conversion algorithm to human date (Please don't tell me to read the Standard)?
What standard?
"OBD Standards" only apply to generic OBD-II /EBOD data, which this isn't.
^^^Uwe: my question (and your response) clearly confirms that I don't understand the "OBD Standards"!!
When I look back on my (fortunately) unremarkable life, its one of my many regrets. Hopefully there's still time and it's on my bucket list - but much alcohol is required before I get the courage to buy a copy of the Standards and then even more drink is needed to fortify the grey-matter in my head before opening the first page of the document.
But I do envy anyone who can refer to the OBD standards with authority -respect!!
JCS13
FRANCE
HC800959 (2nd hand)
Hello Eric
do you have suggestion?
thank for your help
Eric
HC800000
Sorry, I can't make sense of it. The freeze frame, when it depends on the day counter, is supposed to be in the past compared to the time you're scanning. I see that your VCDS autoscan has the correct date, yet those FF dates are ahead of the scan's date. I was thinking maybe the day counter would be a very high or somehow negative value, but your day counter looks normal. Even then it would hardly explain the two different years. Either it's a new freeze frame format we don't understand, or your engine got the date from the cluster wrong. A scan with ODIS would tell us which it is.
