Power steering not working after battery removal on mk5 Jetta
C?ID=313143
I had to remove my battery in my 2007 2.5 AT Jetta to replace some coolant hoses and sat for about a week while I waited for parts. After I was done and got it all buttoned up, I had a steering light and an ABS light on the dash. I drove it down the street and both lights went away. It felt however, that the power steering was not working at all. I though that maybe the assist was turned way down, but in module 44 channel 1 it shows an error and says not available. I have a few OEM+ mods (mk6 steering wheel/module, B7 Passat 17" wheels/TPMS, 2010 Jetta cluster, highline CECM, updated CAN, GLI HID), but they all seem fine. ABS shows a power steering fault so I know it's gotta be something in there. Any ideas?
Autoscan:
Sunday,16,February,2020,12:23:39:41190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: 3VWEG71K57M125932   License Plate:
Mileage: 294110km-182751mi   Repair Order:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEG71K57M125932   Mileage: 294110km-182751miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 Q    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9650
   Revision: --H01---    Serial number: VWZ7Z0G9019242
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 3728238D03478ADF38D-8063
   Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
   Component: AQ 250 6F           0920
   Revision: 00H69000    Serial number:
   Coding: 0000072
   VCID: 005A885116090D67C97-8055
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B0D79D57BF26FFC45-8027
   Part No: 1K0 820 047 GS
   Component: Climatic PQ35   120 0606
   VCID: 7BA0FFBD7FEF6EBF9C5-802F
   Revision: 00H54000    Serial number: 00000007187910
   Coding: 05058A1700000000070A00000F000000000811035C000100000000000000
   Shop #: WSC 09513 444 52621
   VCID: 71BCDD952DA314EF369-8025
   Component: Wischer 020207 020  0501
   Coding: 00038805
   Shop #: WSC 09513
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M00UX8R
   Coding: 0013889
   VCID: 6C82CCE10A81F90705F-8039
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME15144A499
   Subsystem 3 - Serial number: 6342MSME156E340DI
   Subsystem 4 - Serial number: 6351HSME0C2B4F5DT
   Subsystem 5 - Serial number: 6361HSME0C36602EB
   Subsystem 6 - Serial number: 63727SME0B636C68C
   Subsystem 7 - Serial number: 63827SME0B5D1C3EK
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0001731
   VCID: 7AAEFAB970D557B7873-802F
   Subsystem 1 - Part No: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H09 0013
   Coding: 00000130
   Part No SW: 5K0 920 973 B    HW: 5K0 920 973 B
   Component: KOMBI         H05 0705
   Coding: 271D01
   Shop #: WSC 00066 123 00120
   VCID: 303A1891EAA95DE7797-8065
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 27
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 260412F2003028
   Coding: 351002
   VCID: 3A2E3AB93C5597B7C73-806F
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8ECAF90CF5E737773-803F
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000108978115
   Coding: 0001205
   VCID: 3B203FBD3F6FAEBFDC5-806F
                    Fault Status: 01111000
                    Fault Frequency: 142
                    Reset counter: 252
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 8
                    Mileage: 291198 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 34321481123161C71DF-8061
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 13900F880186083F3F04058FB0880F0488DC40
   Shop #: WSC 00066 123 12345
   VCID: 74B2D48152B121C7DDF-8021
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000576778105
   Coding: 0001204
   VCID: 3C223CA13A61A987D5F-8069
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5518
   Revision: --------    Serial number: VWZZZ4H6234825
   Coding: 16000440040006
   Shop #: WSC 00078 790 00217
   VCID: 46D65E4978ADE357B3B-8013
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001060360
   Coding: 0001168
   VCID: 3E2636A92C7DBB97FBB-806B
00107 - Signal Central Locking SAVE/LOCK Rear Left
                    Reset counter: 37
                    Mileage: 294110 km
                    Fault Frequency: 19
                    Reset counter: 252
                    Mileage: 290827 km
   Component:    RDK              0420
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001047766
   Coding: 0001168
   VCID: 3FD84BAD2B77B29FF0D-806B
End----(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
downtime
Finland
C?ID=280813
Do you have the amber steering wheel icon on the dash? If no then the power steering should work fine.
C?ID=313143
Logically, I agree. Currently there's no lights, BUT it's definitely not working (or if it is, the ratio is EXTREMELY low) as the input needed is MUCH higher. ABS is showing:
So, there appears to be SOMETHING wrong.
downtime
Finland
C?ID=280813
Does it clear when you erase the dtcs on ABS module?
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, please disconnect the battery again for a few minutes, then connect it again, please note that the voltage must be above 12 volts. If so, drive, turning the steering wheel all the way to the left and right. Please note that the battery is really sufficiently charged. In the diagnostic log you can see that the voltage is below 12 volts.
C?ID=313143
It did yes, BUT the effort required is still MUCH higher than it should be.
