I have recently retrofitted TV module to my Q8 4M but for some reason the AV input option is not showing. TV works just as it should. I believe this option should be within the media screen but there is nothing in the manual to provide any further clues. From early years the AV input option just seems to appear along with the TV. I have tested with a "real" AV input signal and the TV measuring values confirm signal present.
Any assistance appreciated.
SCAN below of current configuration. Sadly the car is full of errors which Audi are struggling to fix.
Cheers,
Cheers,
Sunday,16,February,2020,15:09:48:23598
VIN: WAUZZZF1XKD020041 License Plate:
Chassis Type: F1-AU58 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 47 52 57 5F
61 65 69 6D 74 81 82 A5 AC BB BC C4 CA CB CC CD CF D6 D7 DB
DC DE
VIN: WAUZZZF1XKD020041 Mileage: 22225km-13809miles
57-TV Tuner -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DHXA) Labels: Redir Fail!
Part No SW: 4M8 907 401 HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0001
Revision: CAH26---
Coding: 2A2A4012057E050334286000000400000000000000000000
Shop #: WSC 31414 242 00001
ASAM Dataset: EV_ECM30TDI0114M8907401 001002
ROD: EV_ECM30TDI0114M8907401.rod
VCID: 6E85CE9CA012C7972BB-803A
Part No SW: 4M8 927 158 G HW: 0D5 927 156 P
Component: 0D5 30TDIRdW H05 1001
Revision: --H05---
Coding: 100000
Shop #: WSC 31414 239 00001
ASAM Dataset: EV_TCMALX52011 002014
ROD: EV_TCMALX52011.rod
VCID: 40D94024CA0601E7897-8014
Automatic Transmission Fluid Pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP H01 0705
Serial number: 180317000200
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M6 907 379 N HW: 4M6 907 379
Component: ESP9 Premium H06 0850
Coding: 24AA329631A40B96D39E5C95187E96E2F5BAC9244C8CD0CB3A186947AF5D93
Shop #: WSC 61854 444 00001
ROD: EV_ESP9BOSCHCMP_004_AU65.rod
VCID: 48C95804E23639A7417-801C
450048 - Databus
U1122 00 [040] - Implausible Message
[Signal_FT_Tuer_Status_invalid_(0)_or_Signal_FT_Tuer_Status_QBit_invalid_(1)]
Mileage: 21803 km
Date: 2020.02.08
Time: 12:08:42
78 00 82 00 42 00 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 20
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M6 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0042
Serial number: 00000356876723
Coding: 0038B2400001BE810043010101010000810000070700878700000000000000
Shop #: WSC 31414 050 00001
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
VCID: 3D2739D0BDF46C0FE21-8068
Valve Block 1 In Passenger Side Front Seat:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N477 VB1 BFSv H04 0011
Serial number: SJ8001131118402580EB
Coding: BF2F00
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Coding: 07000143C13900DD070C57889FFB8C78131B33110406009781010A001B3316810A45090200100000000003030041081B1802000044010104000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74B1DCF4CE3EED47DDF-8020
Subsystem 1 - Part No SW: 4M8 955 119 A HW: 4M8 955 119 A Labels: 1KX-955-119.CLB
Component: J400FRWISCH 052 0997
Serial number: 904853F0401825000080
Coding: 7DC727
Serial number: 22115216X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4K2 941 501 A HW: 4K2 941 501 A
Component: E1 - LTM H09 0086
Serial number: 14S09.11.1800690839
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE114091823810927
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 L HW: 4K0 947 135 L
Component: Dachmodul H42 0413
Serial number: Q00659725
Coding: 0D0104
Electrically Adjustable Steering Column:
Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA135181000058589407
Coding: 0A0100
Front windshield washer pump:
Subsystem 7 - Part No SW: 4N0 907 605 C HW: 4N0 907 605 A
Component: J1100/SWP H21 0015
Serial number: 00000000001833000817
Coding: 040000
67736 - Databus
[Camera sensor blocked]
Reset counter: 48
Mileage: 21746 km
Date: 2020.02.06
Time: 12:50:57
average_Voltage_terminals: 14.80 V
Outside air temperature sensor-Outside air temperature on CAN: 6.50 ∞C
interior_temperature: 15.00 ∞C
Vehicle speed: 32.75 km/h
Terminal control-Terminal 75 status: On
Terminal control-Terminal 15 status signal: On
Terminal control-Terminal 15 via CAN: On
Terminal control-Term 75: qualification: OFF
393767 - Motor for Left Side Vent Flap
B10C9 07 [008] - Mechanical Failure
Reset counter: 48
Mileage: 21745 km
Date: 2020.02.06
Time: 12:49:17
average_Voltage_terminals: 14.60 V
Outside air temperature sensor-Outside air temperature on CAN: 8.00 ∞C
interior_temperature: 14.50 ∞C
Vehicle speed: 1.52 km/h
405507 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[Function limitation due to energy management system]
Reset counter: 48
Mileage: 21722 km
Date: 2020.02.04
Time: 22:06:16
average_Voltage_terminals: 11.40 V
Outside air temperature sensor-Outside air temperature on CAN: 7.00 ∞C
interior_temperature: 9.00 ∞C
Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4M0 907 561 L HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: 5665FF5C78082C00010360E0000000BE4A1246484481009E00
Shop #: WSC 31414 042 00001
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 392F2DC0A9DC502FCE9-806C
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Reset counter: 50
Mileage: 21803 km
Date: 2020.02.08
Time: 12:10:45
Control Module temperature: 10 ∞C
Voltage terminal 15: 13.3 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
Steering_angle-Data: 341.400 ∞
Yaw_rate-Data: -0.025 rad/s
adjustment_calculation: On
Misalignment angle: horiz: 0.223 ∞
Misalignment angle: horiz: fast algorithm: 0.242 ∞
Congestion pilot: status: OFF
Outside air temperature: 8.50 ∞C
Sensor blindness: radar: no blindness detected
2344 - Databus
[FAULT_CAMERA_DIRT_OBJ]
Reset counter: 48
Mileage: 21746 km
Date: 2020.02.06
Time: 12:50:46
Control Module temperature: 26 ∞C
Voltage terminal 15: 14.0 V
Velocity_vehicle_reference: 14.07 m/s
Longitudinal_acceleration_vehicle_reference: -0.29 m/s≤
Steering_angle-Data: -1.300 ∞
Yaw_rate-Data: 0.092 rad/s
Misalignment angle: horiz: 0.226 ∞
Misalignment angle: horiz: fast algorithm: -0.112 ∞
Outside air temperature: 6.50 ∞C
2343 - Databus
[FAULT_CAMERA_DIRT_PEDEST]
Reset counter: 48
Mileage: 21746 km
Date: 2020.02.06
Time: 12:50:46
2135 - Door Control Module; Front Driver Side
U14B7 00 [008] - Signal Not Qualified
[FAULT_DRIVER_DOOR_INVALID]
Reset counter: 50
Mileage: 21803 km
Date: 2020.02.08
Time: 12:10:45
Voltage terminal 15: 12.0 V
Steering_angle-Data: 341.500 ∞
Yaw_rate-Data: 0.000 rad/s
Address 15: Airbags (J234) Labels:* None
Part No SW: 4N0 959 655 Q HW: 4N0 959 655 Q
Component: AirbagVW31 H09 2710
Serial number: 003YZM01HLRV
Coding: AACCF0C000C00000985400FFF08D41A800C5
Shop #: WSC 31414 030 00001
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 4ACD620CFC3ACBB7573-801E
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2018320353200000
Coding: 03F001
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2018321306600000
Coding: 03F001
Subsystem 3 - Part No SW: ----------- HW: 480 001 711 18
Serial number: 3570000000051B79C53P
Subsystem 4 - Part No SW: ----------- HW: 480 001 711 18
Serial number: 3580000000011A79C53L
Subsystem 5 - Part No SW: ----------- HW: 480 032 111 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C143E5EE60ED9X
Subsystem 6 - Part No SW: ----------- HW: 480 031 911 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C10D1E2CD03E0A
Subsystem 7 - Part No SW: ----------- HW: 480 032 310 18
Component: FrontSensor_D 002 0149
Serial number: 355001C185A20E408AEG
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 032 310 18
Component: FrontSensor_P 002 0149
Serial number: 356001C149F1E9F13C1Q
Side Sensor B-Pillar Driver Front:
Subsystem 9 - Part No SW: ----------- HW: 480 032 111 18
Component: SideSens_B_Df 002 0149
Serial number: 352001C143E5EA80AB1I
Side Sensor B-Pillar Passenger Front:
Subsystem 10 - Part No SW: ----------- HW: 480 031 911 18
Component: SideSens_B_Pf 002 0149
Serial number: 355001C10D1E2530FB27
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 79AFEDC0E95C902F8E9-802C
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 790 C HW: 4K0 920 790 C
Component: FBenRDWACC--- H11 0153
Coding: A58410E67C88060001A3E164B080680008003000
ROD: EV_DashBoardAU65X_VW53.rod
VCID: 2D0709906D94FC8F521-8078
Part No SW: 4N2 907 468 AB HW: 4N2 907 468 AB
Component: Gateway H14 0037
Revision: 8P030005 Serial number: 0588P769518B26
Coding: 02010005000486408C960000005B0132DC9A00471C000000097D078E10000000
Shop #: WSC 31414 245 00001
ASAM Dataset: EV_CGateCONTIAU491 003150
ROD: EV_CGateCONTIAU491_003_AU58.rod
Subsystem 1 - Part No SW: 4M8 951 523 HW: 4M8 951 523
Component: J453 MFL H07 0004
Serial number: 20181122100820 30881
Subsystem 2 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
Serial number: 7588520200181116073C
131595 - Tire Pressure Monitoring Module
U0127 00 [008] - No Communications
[Timeout_Node_0x0B_DiagAdress_65_RDK]
Reset counter: 49
Mileage: 21786 km
Date: 2020.02.07
Time: 11:22:04
8519683 - Energy Management Active
U140B 00 [008] - -
Reset counter: 48
Mileage: 21722 km
Date: 2020.02.04
Time: 22:06:56
EM_vehicle_state: 02 10
Static current shutdown level: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 18000342682014
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW41.rod
VCID: 34311CF48EBEAD471DF-8060
Component: MEM-FS 009 0042
Serial number: 00000356887363
Coding: 00389A400001BE810003010101010000810000070700878700000000004000
Valve Block 1 In Driver Side Front Seat:
Component: N475 VB1 FSv H04 0011
Serial number: SJ80011311184025805E
Coding: BF2F00
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 F HW: 4N0 907 566 A
Component: MRR_HR H12 0266
Coding: 5FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_AU58.rod
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS001 0425
Serial number: YE007RI626569
Coding: 001DDA42520104C2A009B436
Shop #: WSC 00460 210 00000
VCID: 46D5563CE8222FD7B3B-8012
196677 - Switch for Interior Door Handle
B132E 29 [008] - Signal Implausible
Reset counter: 50
Mileage: 21803 km
Date: 2020.02.08
Time: 12:05:27
196709 - Switch for Exterior Door Handle
B132F 29 [008] - Signal Implausible
Reset counter: 50
Mileage: 21803 km
Date: 2020.02.08
Time: 12:05:27
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Coding: B2000101010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313F15E071AC986F769-8064
Part No SW: 8W0 907 064 FP HW: 8W0 907 064 DP
Component: BCM2 MLBevo 025 0406
Coding: 013500002FB100406309A0046C00C80203004000804F02502F0400200504823F001F0100010F01
ASAM Dataset: EV_BCM2HellaAU736 015015
ROD: EV_BCM2HellaAU736_015_AU58.rod
VCID: 0F7BB318C7D8AE9F40D-805A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY182842VMQ
Subsystem 2 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000248300
Rear Light Left 1:
Subsystem 3 - Part No SW: 4M8 945 069 B HW: 4M8 945 069 B
Component: SHL_li1 H04 0004
Serial number: 069B1811150000037063
Subsystem 4 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11315144
Rear Light Left 2:
Subsystem 5 - Part No SW: 4M8 945 217 F HW: 4M8 945 217 F
Component: SHL_li2 H04 0004
Serial number: 217F1811050000033098
Rear Light Right 1:
Subsystem 6 - Part No SW: 4M8 945 070 B HW: 4M8 945 070 B
Component: SHL_re1 H04 0004
Serial number: 070B1811140000036935
Rear Light Right 2:
Subsystem 7 - Part No SW: 4M8 945 218 F HW: 4M8 945 218 F
Component: SHL_re2 H04 0004
Serial number: 218F1811050000033098
Part No SW: 4N0 035 223 B HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0150
Revision: 00000001 Serial number: AUZ8ZAJ6S00ZBS/
Coding: 0135360A00AAAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 2313EFA83B503AFFF45-8076
Part No SW: 4M1 959 792 J HW: 4M1 959 792 D
Component: TSG BFS001 0425
Serial number: YE007RJO12468
Coding: 001DDA025E0104C2A009B434
VCID: 45D75130D52424CFBA1-8010
Address 57: TV Tuner (R78) Labels:* None
Part No SW: 8V0 919 191 C HW: 8V0 919 191
Component: DVB-DTV H08 1800
Coding: 0107030000000100000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TVMELC 001033
ROD: EV_TVMELC_VW27.rod
VCID: 3FDB43D8B7F87E1FF0D-806A
8209 - Antenna 1 for TV
B124D 11 [008] - Short to Ground
Reset counter: 51
Mileage: 21722 km
Date: 2020.02.06
Time: 09:47:03
Voltage terminal 30: 12.8 V
Connection status antenna 1-Antenna current: 0 mA
Connection status antenna 1-TV tuner to impedance converter: Short circuit to ground
Connection status antenna 1-Impedance converter to antenna: Not available
Connection status antenna 1-Phantom voltage: 0.3 V
Connection status antenna 1-level: 0
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 063 A HW: 4K0 035 063 A
Component: MU-H-LND-EU 046 2470
Coding: 0135360100000000C3111102C00800302F0001E601F008008E
VCID: 211FE5A0214C28EFE69-8074
Subsystem 1 - Part No: V03 959 804 LN
Component: MIB2P_EU_Q219 0371
Subsystem 2 - Part No SW: 4M8 919 605 A HW: 4M8 919 605
Component: DU AU536 High H41 0144
Serial number: INX00108101800100506
Compact Disc Database:
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 4N1 919 616 A HW: 4N1 919 616
Component: LSR-D5/C8 H33 0108
Serial number: 00004418000227672057
Display Unit 5 For Multimedia System:
Subsystem 5 - Part No SW: 4N0 919 603 B HW: 4N0 919 603
Component: DU AU651 Bot H41 0144
Serial number: INX00112081800050718
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800707102001
Address 61: Battery Regul. (J1120) Labels: None
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 290FFD80597CE0AFBE9-807C
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0010
Serial number: 40000000005092
ROD: EV_RDKHUFAU736_AU58.rod
VCID: 2F3B139867988E9F60D-807A
Part No SW: 4M0 907 383 G HW: 4M0 907 383 B
Component: Anhaenger H33 0273
Revision: 9A001003 Serial number: 0499625962
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 363526FC98C2BF5723B-8062
Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C737-6252-2
Coding: 28F0
ROD: EV_DeckLidCONTIAU736_AU38.rod
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4M8 907 777 N HW: 4M8 907 777
Component: Fahrwerk-SG H51 2031
Serial number: 2411180589
Coding: B85C6050F840
ASAM Dataset: EV_ChassContrContiAU651 001011
ROD: EV_ChassContrContiAU651_001_AU58.rod
VCID: 4CC16414F64ED58765F-8018
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130460309
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M8 713 041 A HW: 4N2 713 041 C
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18080448660610
ROD: EV_GSMWaehlZFAU736.rod
VCID: 2A0D028C5C7AEBB7B73-807E
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4M8 919 617 C HW: 4M8 919 617 C
Component: HeadupDisplay H08 1815
Coding: 4700E0
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_AU58.rod
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AC HW: 4N0 907 107 H
Component: zFAS Var C H09 0291
Coding: 04C184000000000000FFD60000F0C60C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001_AU58.rod
VCID: 005980248A86C1E7C97-8054
2117691 - Ethernet Databus
U11C4 00 [008] - No Communications
[Databus_Ethernet_no_communication]
Reset counter: 48
Mileage: 21769 km
Date: 2020.02.06
Time: 16:37:27
Ethernet signal quality: no link
2117692 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[Databus_Ethernet_missing_PDU]
Reset counter: 48
Mileage: 21769 km
Date: 2020.02.06
Time: 16:37:15
221284 - Front Camera for Driver Assist Systems
C12B3 FD [008] - View Temporarily Restricted
[temp view limitations]
Reset counter: 48
Mileage: 21746 km
Date: 2020.02.06
Time: 12:50:46
EyeQ temperatures-CPU: -40 ∞C
EyeQ temperatures-VPM: 14 ∞C
Vehicle speed: 49.77 km/h
Front camera: blinding detection-Status: not active
Front camera: blinding detection-Blinding detected by light assistance assessment module: Yes
Front camera: blinding detection-Blinding detected by road sign recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by lane recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by object recognition assessment module: Yes
Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
Front camera: blinding detection-Blinding detected by road profile estimation assessment module: Yes
Front camera: blinding detection-Blinding detected by free space recognition assessment module: Yes
Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
Front camera: blinding detection-Glare detected: No
Front camera: blinding detection-free view detected once: No
282656 - Video Cable for Information Electronics 1
B13B9 01 [008] - Electrical Failure
Reset counter: 48
Mileage: 21769 km
Date: 2020.02.06
Time: 16:37:15
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 50
Mileage: 21803 km
Date: 2020.02.08
Time: 12:10:46
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 D HW: 4M0 907 355 B
Component: SCR-Stg-G3H05 0006
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736_VW53.rod
VCID: 323D1AEC74AAA3770F3-8066
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS003 0425
Serial number: YE007RK617541
Coding: 000DD802000104C2A008B024
Reset counter: 48
Mileage: 21745 km
Date: 2020.02.06
Time: 11:15:35
Reset counter: 48
Mileage: 21745 km
Date: 2020.02.06
Time: 11:15:35
Component: TSG HBFS003 0425
Serial number: YE007RK614195
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
VCID: 3A2D32CCACDA5B37C73-806E
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Coding: 728040053632
VCID: 75B7E1F0C544F44FEA1-8020
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
Component: HAL_MLBevoH08 0698
Revision: -------- Serial number: CCC_098_B_1122_
Coding: 42242A00
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010.rod
VCID: 6FBBD398A718CE9F20D-803A
Address CC: Starter-Generator (----) Labels:* None
Part No SW: 4N0 903 028 H HW: 4N0 903 028 H
Component: BSG-HP1-65 H16 0523
Serial number: 01121800020076
Coding: 28000000000000
ASAM Dataset: EV_Start48VAU651 001006
ROD: EV_Start48VAU651_001.rod
VCID: 303910E47AA69167797-8064
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0202
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 353721F085C4B44F2A1-8060
11567105 - Cleaning Failed
B17FC 00 [008] - -
Reset counter: 52
Mileage: 21787 km
Date: 2020.02.07
Time: 18:53:00
Control Module temperature-Host: external temperature: 15 ∞C
Control Module temperature-Zynq: internal temperature: 30 ∞C
Control Module temperature-Host: internal temperature: 17 ∞C
Control Module temperature-Zynq: external temperature: 12 ∞C
Voltage terminal 15: 14.810 V
Vehicle speed: 48.39 km/h
Request for cleaning of laser scanner: not active
Washer fluid level: OK
Heating and cleaning management-Visibility: 0 %
Heating and cleaning management-Degree of contamination: 35 %
Heating and cleaning management-Heating status: 02
Heating and cleaning management-Cleaning status: 05
Outside air temperature: 8 ∞C
Counter_lense_cleanings-Cleaning_Sequence: 0
Counter_lense_cleanings-lense_clean_count_total: 0
Counter_lense_cleanings-lense_clean_count_trip: 2
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0266
Coding: 5FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_AU58.rod
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0031
ROD: EV_LMSLeftHELLAAU58X_AU38.rod
VCID: 72BDDAECB42AE377CF3-8026
ROD: EV_LMSRightHELLAAU58X_AU38.rod
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 F HW: 4N0 907 669 A
Component: MRR_VR H12 0266
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651_AU58.rod
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H12 0266
Coding: 003000
Shop #: WSC 31414 142 00001
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_AU58.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 A HW: 4N0 035 502 A
Component: WLC Front H10 0057
Coding: 400000
VCID: 221DEAAC244A33F7FF3-8076
End----(Elapsed Time: 03:00, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
