Stalling issues with cold engine in my 2017 alltrack TSI
fenderblender
C?ID=97779
Hi Folks--I'm posting the relevant portion from my scan below. There are a couple of odd symptoms = like I said I get stalling issues when starting from a stop while the engine is cold.
Also--not sure it's related to the above issue, but my traction control light also flashes intermittently and I get a loss of power. This also seems to happen when cold and the loss of power is alleviated when I turn the traction control off. This started happening after recently replacing my tires.
Would welcome any advice. Thanks!
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 L HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0002
Revision: --H13---
Coding: 311D00122426002F0000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
ROD: EV_ECM18TFS0208V0906264L.rod
VCID: 45819B70C44FAF67EA-8011
15101 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [096] - -
26372 - Leak in Air Intake System
P2279 00 [096] - -
23126 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Hmm... All those faults are "Intermittent - Not Confirmed".
Please post the whole Auto-Scan for context. There may be more clues in other modules and/or the Gateway Installation List.
