Hello Everyone.
Hope someone can help me with this:
Background: I purchased my first Audi in September of last year due to totaling of last car. About 6 weeks after purchase there was an icestorm and I slid into a curb going about 2mph. Immediately my power steering went out. After some research I figured it was probably the steering rack or the steering control module. Upon recommendation from family member I went to a non dealership mechanic. After getting the car back with the steering rack replaced along with steering control module I found that there were more errors lights showing up. These included ESP, Dynamic Steering Fault(ok to drive it says), Sports Differential not working, Adaptive Headlight control failure. The mechanic stated that they should go away after a few days driving. I doubted this and I was correct. The errors remained, after talking to the mechanic, he stated it would have to be programmed at the dealership. After paying the mechanic I really do not have the cash to take to dealer. I had already planned on purchasing vagcom and thought maybe I could fix myself. I would appreciate any help on this, basically, just need to know if there is a way to fix the issues using Vagcom or if I need to take to authorized dealer.
So now for some information:
2013 Audi S5 Prestige Cabriolet
PR Codes
And the autoscan:
Thanks in advance for any help anyone can give.
BTW Absolutely love my Audi
PR Codes
E0A 7GB 4UB 6XM 5SG 5RW
1KE J0Z 1LJ 1AT 1BD
3FT 5TG 7X7
F0A 9G3 0G7 0YM 0JJ
TC6 3KA 8EH U1B X9A QZ7
2PK 8Q5 9Q8 8Z6 D11
7T6 CP7 7K6 4X1 2K4
3L4 4I3 5D2
1SA Q4Q 4GQ
And the autoscan:
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUVGAFH7DN008235 License Plate:
Mileage: 92260km-57327mi Repair Order:
Chassis Type: FH-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 26 36 3C 42 44 46 47 52
53 56 5F 62 6C 72 A9
VIN: WAUVGAFH7DN008235 Mileage: 92260km-57327miles
26-Auto Roof -- Status: Cannot be reached 1100
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 1A250034052600060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 38292EBFA2D39E17315-806C
6201 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:10
Engine speed: 701.00 /min
Normed load value: 11.4 %
Coolant temperature: 69 °C
Intake air temperature: 24 °C
Voltage terminal 30: 13.405 V
Engine speed: actual: 672 /min
MAF_ENVD: 114.38823 mg/stroke
Coolant temperature (unfiltered): 69.75 °C
Engine: operating status: IS
Engine load: 11.328125 %
Vehicle speed: actual: 0 km/h
7888 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [039] - -
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:35
Engine speed: 708.00 /min
Normed load value: 10.6 %
Voltage terminal 30: 13.609 V
Engine speed: actual: 704 /min
Battery voltage: 13.609375 V
Readiness: 1110 1101
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H01 0006
Revision: --H01---
ASAM Dataset: EV_TCMDL501021 001010
ROD: EV_TCMDL501021.rod
VCID: 40D9465FFA03D6D7895-8014
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Coding: 291D1A
VCID: 04518A4FAE1B0AF7EDD-8050
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H11 0621
Coding: 0D834F00000000000000
Subsystem 1 - Part No SW: 8K0 959 754 AB HW: 8K0 959 754 AB
Serial number: 0512000079242006
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000256743011
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000045198993
Coding: 00037025002C00000000
VCID: 45D7574BE5A1F3FFBA3-8010
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01281120120448
Coding: 6603228000
VCID: 392F2BBB9959871FCEB-806C
00830 - Convertible Top Control Module (J256)
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:05
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000501313302
Coding: 26000091863CAFE0210048C300003D0D0F9CD288A2090221000008004000010200040070000000
Shop #: WSC 28660 002 1048576
VCID: 7AADF4B7DCDF4C07871-802E
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 241112 H07 0080
Serial number: SWF12110245035
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20766405
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000001911121325
Component: USHL4.2 H30 0030
Serial number: 0000002274555R40Y102
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 3D29CB56000000000001
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:05
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:10
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 E HW: 8F0 959 655 E
Component: AirbagVW-AU10 H12 0430
Serial number: 003KKD80410Q
Coding: 303741353731303030304A55304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaECUVWAUDI010.rod
VCID: 3A2D34B79CDF8C07C71-806E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R120000C1A2
Serial number: 6334MSME74036D23B
Serial number: 6344MSME7304104E7
Serial number: 6352QSME5A25326EO
Serial number: 6362QSME03262440%
Serial number: 63732SME2C6E516EG
Serial number: 63832SME3428234C
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LKJ0022Z
Coding: 000036
VCID: 44D14A4FEE9BCAF7ADD-8010
014 - Defective
Fault Status: 01101110
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:05
(no units): 41.0
Text: 29652D32001000EA02
Steig. Befuellungskennlinie: 2.250 l/mm
Raw, Form. N/A: 000 016 000
Text: 368D0000393FCFCF10
Work Shop Code: 81871
Raw, Index/Key Err.: 207 016 118
Part No SW: 8T0 920 983 P HW: 8T0 920 983 P
Component: KOMBIINSTR. H35 0556
Revision: 00000000 Serial number: UUZ43WKCD
Coding: 8BB719008B01D705020000
VCID: 4BC36173C3C5058F6C7-801E
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0055
Revision: 1Z100027 Serial number: 2741Z12B11019B
Coding: 80C303FF00
Shop #: WSC 02391 823 56573
VCID: 4CC1626FC6CB02B765D-8018
Serial number: 0690688501
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:07
Bin. Bits: 11111
Voltage: 13.10 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H13 0100
Serial number: 001311120001400
VCID: 2F3B15E3579D59AF60F-807A
0127 - Please Check Fault Codes in Control Module for Steering Wheel Electronics
U1028 00 [137] - -
[Lenkradwinkelsensor Bitte Fehlerspeicher auslesen DTC_CAN_LWI_INVALID_VALUE]
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:08
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [137] - -
[ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:08
Address 26: Auto Roof
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000045232319
Coding: 001B7B25002C00000000
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H04 0060
Serial number: 0188339073
Coding: 010211
VCID: 3FDB45A387FDA92FF0F-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H04 0060
Serial number: 0188079291
Coding: 000102
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C53724E08332C03
VCID: 56F5800708074867C39-8002
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:05
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0024399094
Coding: 100000000001
Shop #: WSC 21787 001 1048576
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311A8FBEBB7A771DD-8060
4215044 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Fehlerwert "Lenkradwinkel"]
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:08
Write only channel
4208000 - Steering Angle Sensor
B1168 F1 [137] - Synchronization Failed
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:08
Write only channel
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
[Lenkungsendanschläge nicht angelernt]
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:08
Write only channel
Revision: 00002001 Serial number: 0188371774
Coding: 010606BA00FA402180B0033200000000
Subsystem 1 - Part No SW: 8F0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000598182
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:05
Part No SW: 8F1 035 223 A HW: 8F1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94833008237001
VCID: 1F1BE52327BDC92FD0F-804A
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:10
Voltage: 13.60 V
Temperature: 21.0°C
Temperature: 24.0°C
Bin. Bits: 00000100
Bin. Bits: 00010000
Bin. Bits: 00000000
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
Coding: 011C53324E08332C03
VCID: 55F7870B1501437FCA3-8000
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:05
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000182776
ROD: EV_ParkiBrake_AU48.rod
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156KW0C7670001
Coding: 020007010000000101
VCID: 2517F7CB05E113FF9A3-8070
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:08
Bin. Bits: 00000000 00010000
Part No SW: 8R1 035 746 K HW: 8R1 035 746 B
Component: H-BNT-NA H44 1040
Revision: -------- Serial number: 204K$0C7545706
Coding: 140200030206A1EF55028B4E00000401150000000000000000
Shop #: WSC 05338 002 1048576
VCID: 3FDB45A3877DA92FF0F-806A
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130K%0C2589807
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001344503
Component: CD-Database 4949
Part No SW: 8T0 959 795 F HW: 8T0 959 795 F
Component: TSG HL H08 0304
Coding: 010C13304008372C03
VCID: 4EC5686730D730A70B9-801A
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2XB081
Coding: 1000009
VCID: 678BBDC3B36DC1EF68F-8032
Reset counter: 20
Mileage: 92263 km
Date: 2020.02.13
Time: 17:43:05
Reverse OFF
Count: 3
Component: TSG HR H08 0304
Address A9: Struct. Borne Sound Labels: None
VCID: 55F7870B1581437FCA3-8000
No ASAM data for: "Unknown" (AU48)
End----------(Elapsed Time: 03:05, VBatt start/end: 13.8V/14.4V)-----------
Thursday,13,February,2020,19:03:03:00349
Gateway Installation List: 8R0 907 468 P
47-Sound System -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
