Audi A6(c5)ABS module won't code with VCDS???
NHLFANS
Pirate
Walking the Plank
Latvia
HC812424 (CLONE!)
Hi , all :)
First of all I'm sorry for my bad grammar , English is not my strong size , but I try to explain what kind of problem I had :)
I need to reprogramm my car's ABS/ESP module and set steering wheel angle. I try , but something is wrong.
My car is :
Audi A6(c5) Avant
2002 year
1.9 TDI ( engine code AWX 96kw/130hp.)
Manual gearbox
ABS modul is Bosch ESP 5.7
4B0 614 517 G
Brake type is 1 LB
That's how I try :
1) Switch ignition On
2) Connect the VCDS to my car
3) Go to ABS Brakes
4) Then I go to this link http://wiki.ross-tech.com/wiki/index.php/Audi_A6/S6/RS6/allroad_(4B)
5) There I select my type car , than [03] - brake electronics & than Bosch 5.7
6) There is nummbers I need , if I understand it correctly I need Login 07555 & Coding 06255. Correct ?
7) Than back in VCDS I select Login and enter 07555
8) Than I select Coding and enter 06255
And right now my problems begin :(
VCDS reconnect's to ABS , than it shows that soft coding is 00000 & wsc 00000
And nothing happens.
Can anybody explain what I doing wrong , why I can't reprogram ABS ?
Hopefully you can understand what kind of problem I had :)
Wednesday,28,January,2015,17:39:49:62939
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4B72N006264   License Plate:
Mileage: 179950km-111815mi   Repair Order:
[Remainder of scan from pirated VCDS removed]
Well, you are using an illegally pirated clone of our product. You should return it to whomever you bought it from and demand a full refund. If no refund is forthcoming, you should take the matter up with your payment processor and/or law enforcement authorities.
Real ones are available directly from us:
http://store.ross-tech.com/shop/cat/IC.html
... or from any of our authorized resellers:
http://www.ross-tech.com/distributors.html
If you purchase a Genuine system in the future please post the scan information using it and we can reevaluate your forum status. Bonus points if you smash the clone into bits like this guy.
bskmiki
Romania
Hi, has this problem been solved?
What problem? Legitimate versions of VCDS have no problem coding Bosch 5.7 ABS modules.
