Are you sure there’s an update existing? The unit updates are really hard to find.
From VW the only way you get an update is if there’s a for it. Also as the units are updated through SD card and not via OBD, most likely none of the maintenance shops will let you have it.
There might be a better luck on some other forum. You could try MHH-Auto for example.
I know who can provide me with any update under the counter ... the problem is that the under counter is not left in my hand but they take it away after the update. For my project that will help many I need the files ...
it's a good project, if it works (and it should work), all the losers with the mirrorlink will have app connect (only for high MIB2)
Thurs updates are many and they can be done ... the problem is that they don't pass you easy .... for the hardware h41 0199 the last update is the 1100 ... to have it from VW (those few) they had to pray in Chinese
but a curiosity, erWin allows access to private individuals even for a single day, could I download the update in this way ?? or for these updates you have to make specific requests from VW dialer??
for audi there are russian and pure ebay sites that sell the SD with firmware .... for vw nothing
