Hi
I have a Passat in the workshop today brought in by a chap who attempted to replace his parking brake module without first making a record of the ABS coding, and all is now lost. Please could some kind person let me the know the correct coding. Autoscan below;
Incidentally, he replaced the module due to a fault with the drivers side caliper. He wound the calipers back using a Delphi scan tool to replace the pads, then when he went to close the calipers, the right side did not shut. I notice that there is a fault stored in the parking brake module relating to this (02433 - Supply Voltage for Right Parking Brake Motor (V283). Is this likely to be a fuse?
Many thanks!
Many thanks!
Thursday,13,February,2020,11:38:53:06582
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ3CZ6E194633 License Plate: MJ06BXW
Mileage: 234850km-145929mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
VIN: WVWZZZ3CZ6E194633 Mileage: 234850km-145929miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
Component: R4 2.0l PPD1.5 G 9627
Revision: --H05--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00051 210 83201
VCID: 699A40AE4060540710-803C
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Fault Status: 11011000
Reset counter: 229
Mileage: 234854 km
Time: 20:27:49
Text: 0 Nm
Text: 0.0 %
Voltage: 11.75 V
Bin. Bits: 00000100
Text: 1016 Nm
Readiness: N/A
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667073821
Coding: 0013569
Shop #: WSC 05311 000 00000
VCID: 2F2EEEB6BE04FA370E-807A
Mileage: 234854 km
Time: 20:35:31
Mileage: 234854 km
Time: 20:35:31
Mileage: 234854 km
Time: 20:35:31
Mileage: 234854 km
Time: 20:35:31
Mileage: 234854 km
Time: 20:35:31
Mileage: 234854 km
Time: 20:35:31
Part No: 1K0 820 047 DP
Component: Climatic PQ35 090 0505
VCID: 75A21CDE1CD880E784-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000005320703
Coding: 00880F0700041A00000A00000F000000000859435C0000
VCID: 2E10F3B2B90EF33F05-807A
Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 05 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2P1S3CZX
Coding: 0012341
VCID: 2D12F4BEB40888273C-8078
Subsystem 1 - Serial number: 6332MSME0D422233
Subsystem 2 - Serial number: 6342MSME0D0F0E58
Subsystem 3 - Serial number: 6351HTS64IKILM23
Subsystem 4 - Serial number: 6361HTS64IKESK52
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C9953507C
Coding: 0000014
VCID: 2A18FFA285E69F1FD9-807E
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 960 H HW: 3C0 920 960 H
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0014000 Serial number: 00000000000000
Coding: 0007405
Shop #: WSC 05311 067 57207
VCID: 281C05AA9BEAAD0FCF-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C062110228
Coding: 3DFD2C04C22003
VCID: 210A188EF8D05C4788-8074
Reset counter: 229
Mileage: 234854 km
Time: 20:35:33
01304 - Radio
Reset counter: 229
Mileage: 234854 km
Time: 20:35:36
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
VCID: 3228E7C2AD36D7DF61-8066
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2366
Coding: 0000693
VCID: 3620DBD2415ECBFF4D-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3424E1DA5722D9EF73-8060
Component: KSG PQ46 ELV 038 0455
Coding: 0191020851030E763804941570085FCE103C80
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
Reset counter: 229
Mileage: 234854 km
Time: 20:33:52
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000692
VCID: 373ED6D6465432F756-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 229
Mileage: 234848 km
Time: 20:35:32
Voltage: 11.49 V
Count: 171
Fault Status: 11101101
Reset counter: 229
Mileage: 234848 km
Time: 20:35:31
Voltage: 11.49 V
Count: 236
011 - Open Circuit - MIL ON
Fault Status: 11101011
Reset counter: 229
Voltage: 11.59 V
Count: 117
02844 - Lamp for Automatic Parking Function
Fault Status: 11101001
Reset counter: 229
Voltage: 11.90 V
Count: 64
000 - - - MIL ON
Reset counter: 229
Voltage: 11.90 V
Count: 170
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703
Component: Tuer-SG 021 2505
Coding: 0000144
VCID: 70AC2DCA63BAA5CF57-8024
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704
Coding: 0000144
VCID: 71AA28CE68B0ACC758-8024
Component: PTC-Element 0404
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----(Elapsed Time: 01:30, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
