Address 02: Auto Trans Cannot be reached
   #41
rich222
H11-028163
Do you have a scan from the 06 car we can look at to see what the difference might be?
Different ABS module and transmission has some different data.
Here's the full can from the 06 car:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63WX7C040471   Mileage: 163550km-101625miles
Address 01: Engine        Labels: 07C-906-018-BWR1.clb
   Part No SW: 07C 906 018 BP    HW: 07C 906 018 EC
   Component: BY-6.0L-TT      G  ª6767
   Revision: --H01---    Serial number: VWZ3Z0F3483839
   Coding: 0001175
   Shop #: WSC 00083 000 00000
   VCID: 74B1DBBF72AD3CA7DDF-513C
009571 - Turbocharger Boost Control Position Sensor Circuit
               P2563 - 008 - Implausible Signal
                    Fault Status: 01101000
                    Mileage: 163509 km
                    RPM: 1202 /min
                    Load: 41.6 %
                    Temperature: 9.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.462 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Mileage: 163552 km
                    Temperature: 84.0°C
                    Temperature: 47.0°C
                    Voltage: 11.938 V
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 09E 927 760 S    HW: GS1 911 4
   Component: AG6 09E 6.0L W12TT  2807
   Revision: 00000001    Serial number:        0084638
   Coding: 0000111
   VCID: 40D9476F7695D007897-513C
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
   Part No: 3W0 614 517 D
   Component: ESP 5.7 4WD     H01 0021
   Coding: 0007878
   Shop #: WSC 15937 000 00000
   VCID: 363521B724516EB723B-51F2
   Part No SW: 3D0 909 137 B    HW: 5WK 484 95
   Component: 59 Kessy            6700
   Revision: 67006015    Serial number: VWZ3Z0F3483839
   Coding: 0422125
   VCID: 2615F1F7F4F11E3793B-5160
00087 - Terminal 30 for Starting Relevant Consumers
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000002
   Shop #: WSC 15937 250 45725
   VCID: 47CB5C7353BBE73F48D-5160
02569 - Control Module for Massage (J740)
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 F
   Component: Climatronic BY614   2014
   Coding: 0000111
   VCID: 34311BBF322D7CA71DF-5160
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000107
   VCID: 2F3B14D3DB0B5F7F60D-5160
01498 - Bulb for Parking Lamps; Right (M3)
Address 11: Engine II        Labels: 07C-906-018-BWR2.clb
   Coding: 0001175
009607 - Turbocharger Boost Control Position Sensor 2
               P2587 - 008 - Implausible Signal
                    Mileage: 163509 km
                    RPM: 1203 /min
                    Load: 41.2 %
                    Temperature: 9.0°C
                    Temperature: 9.0°C
                    Voltage: 13.462 V
Address 15: Airbags        Labels: None
   Part No SW: 3W8 909 601     HW: 3W8 909 601
   Component: 11 Airbag 9.41  H13 0040
   Revision: 91H13004    Serial number: 0039L0001B57
   Coding: 0012593
   VCID: 7BA3F0835FF373DF9C5-5160
   Subsystem 1 - Serial number: 63328RB40133062A3
   Subsystem 2 - Serial number: 63428RB401339EC2N
   Subsystem 3 - Serial number: 63528RB40132FF1FW
   Subsystem 4 - Serial number: 63628RB401339EA5Q
   Subsystem 5 - Serial number: 63700RB4        I
   Subsystem 6 - Serial number: 63800RB4        J
                    Fault Frequency: 64
                    Reset counter: 39
                    Fault Frequency: 8
                    Reset counter: 39
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 D
   Coding: 0000012
   VCID: 2E0509D7DC0156776BB-5160
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No: 3W8 920 840
   Component: KOMBIINSTRUMENT RB8 0610
   Coding: 0021403
   VCID: 79AFEA8B55CF41CF8E9-5160
Address 18: Aux. Heat        Labels: None
   Part No: 3D0 815 005 T
   Component: Standheizung        2426
   Shop #: WSC 00075 106 58457
01412 - Glow-Plug with Flame Monitoring (Q8)
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D7AF06B50087397-5160
Address 34: Level Control        Labels: 3Wx-907-553-34.clb
   Part No: 3W0 907 553 A
   Component: LUFTFDR.-CDC- 3C3V0 7203
   Coding: 0005561
   VCID: 38292F8F2E4598C7317-5160
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000002
   VCID: 3FDB44930B6BAFFFF0D-5160
Address 37: Navigation        Labels: None
   Part No: 3W0 919 887 D
   Component:    NAVIGATION       2085
   Coding: 0400000
   VCID: 48C95F4F5EA5E847417-5160
00480 - Control Module in Instruments for Infotainment CAN (J285)
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 E
   Component: Dachmodul           0707
   Coding: 0002461
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component: 55 HSG              0101
   Coding: 0000040
   Shop #: WSC 00075 106 68832
   VCID: 333318A337237B9F045-4B00
   Subsystem 1 - Part No: 3W8 959 701 C
   Component: Tuersteuergeraet FS 1002
   Subsystem 2 - Part No: 3W8 959 702 C
   Component: Tuersteuergeraet BF 1002
   Subsystem 3 - Part No: 3W8 959 703 B
   Component: Tuersteuergeraet HL 0401
   Subsystem 4 - Part No: 3W8 959 704 B
   Component: Tuersteuergeraet HR 0401
   Subsystem 5 - Part No: 3W0 909 610 F
   Component: 14 HDSG             1809
   Subsystem 6 - Part No: 7L0 907 719 A
9 Faults Found:
00576 - Terminal 15
00934 - Electric Window Motor; Rear Left (V26)
00935 - Electric Window Motor; Rear Right (V27)
01699 - Motor for Central Locking; Hatch/Trunk (V53)
00319 - Rear Lid Hydraulic Motor (V241)
   Part No: 3W8 035 456
   Component: 12K-AUDIOVERST      3000
00871 - Bass Speaker Front Right (R23)
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 D    HW: 3W0 907 801 D
   Component: EPB  BC6HX24    HC6 X240
   Coding: 0022413
   VCID: 372B2CB3235B97BF38D-5160
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 H
   Component: Heckspoiler         0002
   VCID: 303917AFC3354087797-51F2
01509 - Spoiler not Extended at Speed Exceeding Warning Threshold
            35-10 - - - Intermittent
Address 57: TV Tuner        Labels: 3D0-919-146.lbl
   Part No: 3D0 919 146
   Component: TV Tuner        H07 1205
   Coding: 0000010
   VCID: 6597B6FBC977D52F5A1-5160
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No: 3W7 907 273
   Component: Reifendruckueberw.  0003
   Coding: 0080311
   VCID: 7DA7FE9B41E77DEFA21-5160
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 E
   Component: Wische&
   Shop #: WSC 00000 725 65552
   VCID: 392F2A8B154F81CFCE9-5160
00003 - Control Module
            014 - Defective
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 2411EBFF82CDEC278DF-5160
   Part No: 3W0 919 283 A
   Component: 02 Einparkhilfe     0303
   VCID: 3B2330831F73B3DFDC5-5160
Address 77: Telephone        Labels: None
   Part No SW: 3W0 035 385 BA    HW: 3W0 035 385 BA
   Component: rSAP ECU            0060
   Coding: 0000272
   VCID: 75B7E6BB79D725AFEA1-5160
            014 - Defective
01523 - Microphone for Telephone (R38)
End----(Elapsed Time: 07:33, VBatt start/end: 11.7V/11.6V. VIgn 0.0V)------
Heres my 08 car:
Thursday,13,February,2020,17:35:21:24880
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: SCBCF63W88C058594   License Plate: FINAL SCAN
Mileage: 101750km-63224mi   Repair Order:
Chassis Type: 3W (6N0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 34 36 37 38 46 47
          53 54 65 68 71 76 77
VIN: SCBCF63W88C058594   Mileage: 101750km-63224miles
38-Roof Electronics -- Status: OK 0000
54-Rear Spoiler -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (   )       Labels: 07C-906-018-BWR1.clb
   Part No SW: 07C 906 018 FQ    HW: 07C 906 018 FK
   Component: BY- 6.0L -TT NC G  �1932
   Revision: --H03---    Serial number: VWX3Z0H3750512
   Coding: 0001175
   Shop #: WSC 00083 790 00000
   VCID: 79AFEA8B55CF41CF8EB-5160
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: None
   VCID: 55F7863B9D4745AFCA3-8000
No Faults Found
   Part No SW: 3D0 909 137 D    HW: 5WK 485 05
   Component: 74 Kessy            6840
   Revision: 68406620    Serial number: VWX3Z0H3750512
   Coding: 0422125
   VCID: 2809FFCFFEB50847A15-807C
   Part No: 3W0 959 759 C
   Component:    CM Seat Pass.    0018
   Coding: 0000001
   Shop #: WSC 30646 002 1048576
   VCID: 49CF5A4B45FF114F5EB-801C
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 Q
   Component:    ZAB COCKPIT      2215
   Coding: 0400327
   VCID: 3A2D358710498AD7C71-5160
00857 - CD Changer Unit (R41)
   Coding: 0000111
   VCID: 34311BBF327D7CA71DD-8060
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 M    HW: 3D0 937 049 M
   Component: J519                6500
   Revision: -4004---    Serial number: --------------
   Coding: 40020000AB2A11000000000000000000
   Coding: 0001175
   Component: 15 Airbag 9.41  H14 0040
   Revision: 91H14004    Serial number: 0039L000AVE2
   Coding: 0012597
   VCID: 7BA3F0835FA373DF9C7-802E
   Subsystem 1 - Serial number: 63328RB403A6D593R
   Subsystem 2 - Serial number: 63428RB403A68F07S
   Subsystem 3 - Serial number: 63528RB403A6D5BB$
   Subsystem 4 - Serial number: 63628RB403A68F0D-
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 L
   Component: J527                3601
   Coding: 0000232
   VCID: 48C95F4F5EF5E847415-801C
   Part No SW: 3W0 920 841 E    HW: 3W0 920 841 E
   Component: J285 KOMBI-INST.    1623
   Revision: K0H10V35
   Coding: 0005402
   Shop #: WSC 01179 210 93569
   VCID: 372B2CB3234B97BF38F-8062
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3W0 920 841 E
   Component: J533  GW-K-CAN TP20 1623
   Coding: DFF8FF2E170E4701
   VCID: 70B9D7AF06A50087395-8024
   Part No: 3W0 907 553 E
   Component: LUFTFDR.-CDC- 3C3V0 7213
   Coding: 0005571
   VCID: 3C21339F1A2DB4E7D5D-8068
   Part No: 3W0 959 760 C
   Component:    CM Seat Driver   0018
   Coding: 0000001
   VCID: 41DF426B7DCFD90F86B-8014
No Faults Found
   Part No: 3W0 907 135 F
   Component: Dachmodul           0802
   Coding: 0006589
   VCID: 392F2A8B151F81CFCEB-806C
   Part No: 3D0 959 933 H
   Component: 0P HSG              0200
   Coding: 0000040
   Shop #: WSC 54455 002 1048576
   VCID: 353726BB395765AF2A3-4B00
   Subsystem 1 - Part No: 3W8 959 701 J
   Component: Tuersteuergeraet FS 1106
   Subsystem 2 - Part No: 3W8 959 702 J
   Component: Tuersteuergeraet BF 1106
   Subsystem 3 - Part No: 3W8 959 703 D
   Component: Tuersteuergeraet HL 0703
   Subsystem 4 - Part No: 3W8 959 704 D
   Component: Tuersteuergeraet HR 0703
   Subsystem 5 - Part No: 3W0 909 610 H
   Component: 14 HDSG             2013
01816 - Exterior Door Handle Switch in Drivers Door (F272)
   VCID: 79AFEA8B559F41CF8EB-802C
   Part No SW: 3W0 907 801 H    HW: 3W0 907 801 H
   Component: EPB  BC7H0300   HC7 0300
   Coding: 0022413
   Shop #: WSC 58237 002 1048576
   VCID: 3B2330831F73B3DFDC7-5160
   VCID: 303917AFC3354087795-51A8
   Part No SW: 3W7 907 273 A    HW: 3W7 907 273 A
   Component: J0502 RDK           0004
   Revision: 0004 004    Serial number: 00000700004300
   Coding: 3501E052A5F9A5A5F9A7DA00A7DA00
   VCID: 3E2539970C31A6F7FB9-806A
   Part No: 3W2 955 023 G
   Component: Wischermodul       �9328
   VCID: 3B2330831F23B3DFDC7-806E
   VCID: 2411EBFF829DEC278DD-8070
   Part No: 3W0 919 283 B
   Component: 0C Einparkhilfe     0404
   Part No SW: 3W0 035 385 AS    HW: 3W0 035 385 AS
   Component: rSAP Bentley        0262
   Revision: 00008000    Serial number: 30800000056451
   Coding: 0031000
   VCID: 0655917714613E37F39-8052
End----(Elapsed Time: 02:37, VBatt start/end: 12.0V/11.8V. VIgn 11.8V)-----
And heres what I read using the K line:
Control Module Part Number: 09E 927 760 K    HW: GS1 911 4
  Component and/or Version: ZWGU3406  6L W12TT  3406
           Software Coding: 0000111
            Work Shop Code: WSC 00083 790 00000
                      VCID: 38292F8F2E4598C7315-5160
  Address 03: ABS Brakes       Labels: 3W0-614-511.clb
Control Module Part Number: 3W0 614 511     HW: 3W0 614 511
  Component and/or Version: ESP 8.1 4WD     H01 0250
           Software Coding: 0002308
                      VCID: 6C81C3DF2A9DE46705D-5160
No fault code Found.
   #42
OK, the older car has no proper Gateway Installation List, and thus VCDS tries every way to talk to every control module in the list for that car vs. just trying via CAN. We may have to put some sort of VIN-based exception into VCDS for this.
The transmission in the older car is definitely talking via K-Line rather than on CAN.
Look at the huge difference in times for those scans too; the new car scans in 2:37 vs the older one taking 7:33.
rich222
H11-028163
Thats interesting! Is there anything in the scan that shows the TCM in the 06 car is talking via K line?
Does this shed any light on why VCDS is also having a problem with the ABS unit on my car? Rather than fail to communicate immediately (like it does with the TCM), it tries serveral times and looks like it connects but then drops out. The ABS lights on the dash come up each re-try.
   #44
Yes. But exactly what is more-or-less a trade secret. ;)
No, not really, at least not to me.
rich222
H11-028163
OK, thanks for looking at this.
   #46
grant@gendan
Hi all,
I have a customer with a 2009 and 2010 Bentley experiencing the same problems with a HEX-NET Pro.
They cannot communicate with the ABS or TCM. I am awaiting copies of their Autoscans to be emailed but the problem sounds identical to the one described here.
More interestingly, they took one of the Bentleys to a colleague using a HEX+CAN USB and the V20.4 of VCDS and everything worked fine (also tried HUC on his laptop to rule out a PC problem) - all systems showed up correctly on the HUC AutoScan and they could access the ABS and TCM.
Any ideas?
Thanks,
   #47
grant@gendan
Here's the AutoScan:
Thursday,04,June,2020,11:50:27:38696
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: SCBDH23W0BC0696xx   License Plate:
Mileage: 32000km-19883mi   Repair Order:
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 23 26 34 36 37
          38 46 47 53 57 65 68 6C 71 76 77
VIN: SCBDH23W0BC0696xx   Mileage: 32000km-19883miles
Address 01: Engine (   )       Labels: None
   Part No SW: 07C 906 018 JD    HW: 07C 906 018 HE
   Component: BY - 6.0 L - TT A  ª7781
   Revision: --H06---    Serial number: VWX3Z0J3926309
   Coding: 0011170
   Shop #: WSC 00083 790 00191
   VCID: 70ACF30462343B06FB-5160
   VCID: 55E2A290B8967E2E08-8000
No Faults Found
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component: 7G Kessy            6850
   Revision: 00H23072    Serial number: VWX3Z0J3926309
   Coding: 0422125
   VCID: 2A18216C816801D675-807E
   Subsystem 1 - Part No: 4E0 905 852 E
   Component: ELV                 2141
   Part No: 3W0 959 759 E
   Component:    CM Seat Pass.    0023
   Coding: 0000002
   Shop #: WSC 00092 106 66965
   VCID: 4BD644E82E5238DEAE-801E
   Part No: 3W0 035 007 P
   Component:    ZAB COCKPIT      2270
   Coding: 0451337
   Shop #: WSC 00083 790 00196
   VCID: 393A0E2071CEBA4E0C-5160
   Part No: 3W7 907 040 A
   Component: Climatronic BY615   2027
   Coding: 0001111
   VCID: 3620051C45D05536E1-8062
   Part No SW: 3D0 937 049 N    HW: 3D0 937 049 N
   Component: J519                6900
   Revision: -4005---    Serial number: --------------
   VCID: 3522021058D65E2EE8-8060
Address 11: Engine II        Labels: None
   Coding: 0011170
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 3W0 907 567 A    HW: 3W0 907 567 A
   Component: AC201  RDW BY615   00871
   Revision: 00031000    Serial number: 00000000070526
   Coding: 0010615
   Shop #: WSC 00083 790 00204
   VCID: 3D321A3065E6866E20-5160
Address 15: Airbags        Labels: 3W7-909-601.clb
   Part No SW: 3W7 909 601     HW: 3W7 909 601
   Component: 25 Airbag 9.42  H09 0050
   Revision: 92H09005    Serial number: 00388000C33.
   Coding: 0012853
   VCID: 7AB8D12C3148715645-802E
   Subsystem 1 - Serial number: 63328RB405D00F9CW
   Subsystem 2 - Serial number: 63428RB405D00A9DT
   Subsystem 3 - Serial number: 63700RB4        I
   Subsystem 4 - Serial number: 63800RB4        J
   Part No: 7L6 953 549 K
   Coding: 0000042
   VCID: 47DE78D8323ADCBE8A-8012
   Part No SW: 3W0 920 841 J    HW: 3W0 920 841 J
   Component: J285 KOMBI-INST.    2227
   Revision: K0H10V45
   Coding: 0007402
   VCID: 3C3417347FFC8F6617-8068
   Part No SW: 6N0 909 901     HW: 3W0 920 841 J
   Component: J533  GW-K-CAN TP20 2227
   Coding: DFFBFFAE9F065701
   VCID: 70ACF30463343B06FB-8024
Address 23: Brake Booster        Labels: None
   Part No: 3W0 907 563 B
   Component: BREMSBOOSTER    007 0430
   Revision: 00007000    Serial number: 00000000017554
   VCID: 3A38112C71C8B15605-806E
Address 26: Auto Roof        Labels: 3W7-959-255.clb
   Part No: 3W7 959 255 B
   Component: J256  VSG BY615     2617
   Revision: 00026000    Serial number: 00000007500001
   VCID: 46C075DC3530C5B671-8012
   Part No: 3W7 907 553
   Component: LUFTFDR.-CDC- 3C3V0 7405
   Coding: 0005581
   Shop #: WSC 52972 001 1048576
   VCID: 7EB0DD3C2D605D7679-802A
   Part No: 3W0 959 760 E
   Component:    CM Seat Driver   0023
   Coding: 0000002
   VCID: 43C66CC80602F09E56-8016
   Coding: 0006077
   VCID: 393A0E2074CEBA4E0C-806C
   Component: 46 HSG              0200
   Coding: 0000040
   Shop #: WSC 00092 106 182479
   VCID: 352202105DD65E2EE8-4B1E
   Subsystem 1 - Part No: 3W7 959 701 A
   Component: Tuersteuergeraet FS 1103
   Subsystem 2 - Part No: 3W7 959 702 A
   Component: Tuersteuergeraet BF 1103
   Subsystem 3 - Part No: 3W7 959 703 B
   Component: Tuersteuergeraet HL 0704
   Subsystem 4 - Part No: 3W7 959 704 B
   Component: Tuersteuergeraet HR 0704
   Component: 15 HDSG             2013
Address 47: Sound System        Labels: None
   Part No: 3W0 035 466 K
   Component:   PREMIUM AMPLIFIER 0025
   VCID: 3D321A3060E6866E20-8068
   Part No SW: 3W0 907 801 F    HW: 3W0 907 801 F
   Component: EPB  BC7H0280   HC7 0280
   Coding: 0022413
   Shop #: WSC 00083 790 00213
Address 57: TV Tuner        Labels: None
   Part No SW: 3D0 919 148     HW: 3D0 919 148
   Component: TV-Tuner            0160
   Revision: R0H16000    Serial number: 91100500749302
   Coding: 0000003
   VCID: 679E985857FAFCBEAA-5160
   Revision: 0004 004    Serial number: 00000700009196
   Coding: 3501E05286FD5286FDA7DA00A7DA00
   Shop #: WSC 00083 790 00208
   VCID: 3E301D3C6DE09D7639-806A
   Part No: 3W2 955 023 H
   Component: Wischermodul       ª0400
   VCID: 3C3417347BFC8F6617-8068
   Part No SW: 3W3 907 441     HW: 3W3 907 441
   Component: J772__Rearview      0023
   Revision: 00H14000    Serial number:    PA8 J0Y0021
   Coding: 2000002
   VCID: 76A0C51C0050153621-5160
   Part No: 3D0 915 181 E
   VCID: 2502D250E8762EAE58-8070
   Part No SW: 3W0 919 283 D    HW: 3W0 919 283 D
   Component: J446  ST Parkhilfe  0094
   Revision: 11H04001    Serial number: 90031029200520
   Coding: 0101006
   Part No SW: 3W0 035 385 AT    HW: 3W0 035 385 AT
   Component: rSAP Bentley        0266
   Revision: 00008000    Serial number: 31000000324950
   Coding: 0031000
   Shop #: WSC 00083 790 00202
   VCID: 075EB8D872BA1CBE4A-8052
End----------(Elapsed Time: 03:47, VBatt start/end: 12.0V/12.0V)-----------
I suggested trying 'Bypass CAN init' (as mentioned in this thread) and this allowed access to these 3 control modules - ABS, TCM and Nav. This is useful temporary work-around but any ideas how to fix this communication problem for the V2 and HN ?
Thanks,
rich222
H11-028163
   Coding: 0011170
No Faults Found
   Coding: 0422125
   Component: ELV                 2141
   Coding: 0000002
   Coding: 0451337
   Coding: 0001111
   Coding: 0011170
   Coding: 0010615
   Coding: 0012853
   Coding: 0000042
   Revision: K0H10V45
   Coding: 0007402
   Coding: 0005581
   Coding: 0000002
   Coding: 0006077
   Coding: 0000040
   Coding: 0022413
   Coding: 0000003
   Coding: 2000002
   Coding: 0101006
   Coding: 0031000
Thanks,
Waiting too!
Damn these wonky Bentley's!
Last I heard was that for some reason these modules will only talk on the K line interface (which is what bypass Can Init does). I was going to investigate further... but got distracted by something else. I guess there is some nuanced comms method between the gateway and the modules that VCDS doesn't know about. Not sure it will be investigated further by Ross Tech until more people report the same issue.
   #49
NostraJackAss
Did you know these vehicle's support a range of legacy K and L lines, CAN TP 1.6 & 2.0 & even in some cases later UDS and many support W type internal CAN too among modules on separate network outside of gateway?
Did you also know & depending on how wired in production by RTFB, you can observe it in WD?
The aforementioned interface is sometimes needed depending on scanner used.
   #50
grant@gendan
Hmm, this is interesting...HUC Scan just run on the same car:
Friday,05,June,2020,09:10:42:42230
   Coding: 0011170
   VCID: 70EFECAE6007E506FB-515E
   Part No SW: 09E 927 760 AS    HW: GS1 911 4
   Component: ZVCC3621  6L W12TT  3621
   Revision: --H05---    Serial number:        0139159
   Coding: 0000111
   VCID: 0109B96A5BADFC8E04-515E
   Part No SW: 3W0 614 511 K    HW: 3W0 614 511 K
   Component: ESP 8.1 4WD     H01 0700
   Coding: 0002307
   VCID: 377D17B242E9723EFA-8062
   Coding: 0422125
   VCID: 2A5B3EC6815BDFD675-807E
   Component: ELV                 2141
01176 - Key
                    Fault Frequency: 0
                    Date: 2020.06.04
                    Time: 15:07:48
   Coding: 0000002
   VCID: 4B955B422E61E6DEAE-801E
   Coding: 0451337
   VCID: 3979118A73FD644E0C-515E
   Coding: 0001111
   VCID: 36631AB645E38B36E1-8062
   VCID: 35611DBA58E5802EE8-8060
   Coding: 0011170
   Coding: 0010615
   VCID: 3D71059A60D5586E20-8068
   Coding: 0012853
   VCID: 7AFBCE86317BAF5645-802E
   Coding: 0000042
   VCID: 479D6772320902BE8A-8012
   Revision: K0H10V45
   Coding: 0007402
   VCID: 3C77089E7FCF516617-8068
   VCID: 70EFECAE6307E506FB-8024
   VCID: 3A7B0E8671FB6F5605-806E
   VCID: 46836A7635031BB671-8012
   Coding: 0005581
   VCID: 7EF3C2962D53837679-802A
   Coding: 0000002
   VCID: 4385736206312E9E56-8016
   Part No: 3W0 919 887 P
   Component:    NAVIGATION       2222
   Coding: 0400000
   VCID: 54A7403EF35FB926FF-8000
   Coding: 0006077
   VCID: 3979118A74FD644E0C-806C
   Coding: 0000040
   VCID: 35611DBA5FE5802EE8-4B1C
   Coding: 0022413
   Coding: 0000003
   VCID: 67DD87F252C922BEAA-8032
   VCID: 3E7302966DD3437639-806A
   VCID: 3C77089E7BCF516617-8068
   Coding: 2000002
   VCID: 76E3DAB60563CB3621-8022
   VCID: 2541CDFAE845F0AE58-8070
   Coding: 0101006
   Coding: 0031000
   VCID: 071DA7727289C2BE4A-8052
End-------------------------(Elapsed Time: 04:57)--------------------------
   #51
Bruce
Near Philadelphia, PA, USA
So, the work around suggested of bypassing the CAN init works. What is the problem then? The tool can be made to work with one click.
The team is working the problem. Use the work around until such time as a solution is found.
   #52
rich222
H11-028163
Interesting. I'm using HEX-V2 Dual-K & CAN.
My car is an 09 Speed.
   #53
United States
Hi guys,
I believe Richard has a Legacy HEX-USB+CAN and a HEX-NET/HEX-V2. If so, there is some debugging that may shed light on the issue. In that case the following steps would be highly appreciated to obtain the most comprehensive set of files:
1) HEX-USB+CAN (good baseline info):
[Options]
Change the Debug level from 0 to 1024
[Apply]
[Select]
[02-Auto Trans] or [03-ABS Brakes]. Please base the address selection on the car and which module(s) aren't working properly under normal circumstances
Exit the controller and [Exit] VCDS.
Slide the files with .dlm extensions in the Debug folder into a new folder named HUC1024. By default that would be: C:\Ross-Tech\VCDS\Debug
Make sure the Debug folder is empty after completing the HEX-USB+CAN testing.
2) HEX-NET (or HEX-V2) :
Debugging needs to be performed on the same car with the USB wire (not wireless).
1) Repeat the Debug level 1024 instructions above. Please move the .dlm files into a folder called: HN1024
Again, make sure the Debug folder is empty after completing that sequence.
2) Change the Debug level from 0 to 1028
Repeat the original steps. Both .dlm and .edl files will be generated moving forward. Please move those into a folder named HN1028 so the Debug folder is empty.
3) The last debug level in VCDS is 1044. Repeat the VCDS steps saving .dlm and .edl files to a new folder called HN1044.
Zipping all of those up and sending them to support via e-mail with a link to this thread would be ideal!
rich222
H11-028163
Hi guys,
[Options]
[Apply]
[Select]
Hi Dana,
I have the USB HEX V2 only. I can get the debug files tomorrow if it's not raining too hard.
Thanks for looking at this.
   #55
rich222
H11-028163
Emailed log files this morning (uk time).
   #56
rich222
H11-028163
The plot thickens.... Tried using a HEX+CAN USB interface and it read everything fine.
Would that be using K line?
   #58
What protocol does it show in the upper left-hand corner on this screen?
United States
Hi Richard,
Thanks for the recent HEX+CAN USB interface Debugs!
   #60
rich222
H11-028163
Any update on this issue?
(Spooky - you posted at same time as me!)
