Hi all,
I have a 2010 Eos GT Sport DSG (phase 1.5 - phase 1 with the phase 2 interior).
I did the retrofit of the multifunction steering wheel.
All is working fine, no errors in vcds.
As part of the retrofit, I changed the steering wheel module based on the "Ross-Tech Steering Wheel Control Module Versions". Previous was 5K0 953 569 - new one is 5K0 953 569 E (which is apparently compatible with MFD, CCS, MFSW & AT).
The issue i have is that in module 16 - steering wheel, I can't tick the box for byte 0 / bit 3 (Automatic transmission (ignition key removal lock) installed). I get the Error 31 message.
I also tried with VCP -> same issue.
Does it mean that the steering module 5K0 953 569 E is not compatible with DSG?
Which module should it take? A "T"? An "AL"?
Here is my scan:
Thanks a lot,
Laurent
Here is my scan:
Sunday,02,February,2020,12:32:34:59253
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WVWZZZ1FZAV018055 License Plate:
Chassis Type: 1F-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 26 42 44 46 52 55 5F 62 72
VIN: WVWZZZ1FZAV018055 Mileage: 142570km-88588miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 PL HW: 03L 906 022 G
Component: R4 2.0l TDI G000AG 9980
Revision: 13H03--- Serial number:
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 7EA4083C3CF902A7BBB-802A
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2112
Revision: 51112 Serial number: 00001001271349
Shop #: WSC 00020 000 90108
VCID: 25160750F9EF717F9A1-8070
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 543B6008092300022A0B06E9901E0042350000
Shop #: WSC 00020 790 00000
VCID: 7AAC042C2CD12E87873-802E
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 00020 999 00000
VCID: 7EA4083C307902A7BBB-802A
Part No SW: 5K0 937 087 D HW: 5K0 937 087 D
Component: BCM PQ35 H 011 0028
Revision: BE011001
Coding: 46000A3B8A25F260400800803400092443555488712085605C8000000000
Shop #: WSC 00020 790 12345
VCID: 3634D01C58490AE723B-8062
Subsystem 1 - Part No: 1Q1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 02031 22 0512
Coding: 009795
Component: RLS 260210 05 54 0403
Coding: 0330CD
Subsystem 3 - Part No: 1Q0 951 177 C
Component: Innenraumuebe 200 0203
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 K HW: 1K0 919 475 K
Component: PARKHILFE 005 1706
Revision: 00005000 Serial number: 0 263 004 388
Coding: 101101
VCID: 3A2CC42C6C51EE87C73-806E
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: A6 Airbag VW8C 0180
Revision: 92010018 Serial number: 003B3004UPA0
Coding: 0016694
VCID: 3A2CC42C6051EE87C73-806E
Subsystem 1 - Serial number: 6332SRB40AFB5398G
Subsystem 2 - Serial number: 6342SRB40AFD9521B
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 009 0135
Revision: FF010037 Serial number: 20100723200446
Coding: 008A140000
Shop #: WSC 01608 666 28888
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA60F303D7F19BFA21-8028
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Part No SW: 1Q0 920 874 K HW: 1Q0 920 874 K
Component: KOMBI H05 0305
Coding: 171F00
VCID: 3B22C12863EBD78FDC5-806E
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 141015F1000195
Coding: 355000
VCID: 72BC2C0C74A156C7CF3-8026
Component: IMMO H05 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8C346C5CF19E07773-803E
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 E HW: 1Q0 959 255 E
Component: Verdecksteuergeraet 0842
Revision: 0033100N Serial number: 100400027
Coding: 0655366
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2121
Coding: 0020663
VCID: 392EDB206557E59FCE9-806C
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 71 3001
Revision: 00H17000
VCID: 313EE300BD272DDF769-8064
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0020918
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0142
Coding: 2507971
VCID: 3430EA14423518F71DF-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000038
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000038
Part No SW: 5C0 035 680 B HW: 5C0 035 680 B
Component: MU-S-N-ER H20 0245
Serial number: --------------
Coding: 02230401FF00000011110001000808001F0100C40020010006
Shop #: WSC 00066 790 00071
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 20181644EA4D9457E97-8074
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
Reset counter: 195
Mileage: 142575 km
Date: 2020.02.02
Time: 12:30:15
Voltage terminal 30: 11.8 V
Part No SW: 1Q0 959 811 B HW: 1Q0 959 811 B
Component: Tuer-SG 004 0602
Coding: 0000144
Shop #: WSC 00020 790 1012544
VCID: 3536D710494F01FF2A1-8060
Part No SW: 1Q0 959 812 B HW: 1Q0 959 812 B
Coding: 0000144
VCID: 3634D01C54490AE723B-8062
End----(Elapsed Time: 01:41, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Laurent
