i have fitted a secondhand abs module to this a3. has original had no comunnication and handbrake would not work as handbrake module is incorporated in abs module. can someone help with coding abs please.original module had a part number of AR at end of part number new module ends in R. full scan of car attached.
Tuesday,11,February,2020,16:06:47:28694
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Dealer/Shop Name: autoelec
VIN: WAUZZZ8V0HA045881 License Plate: PJ66OKB
Mileage: 133330km-82847mi Repair Order: JUSTIN.NEW
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8V0HA045881 Mileage: 133330km-82847miles
Address 01: Engine (J623-DBKA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 CA HW: 04L 907 309 R
Component: R4 1,6L EDC H23 1662
Revision: B5H23---
Coding: 02190012032501092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906026CA 002004
ROD: EV_ECM16TDI01104L906026CA_002.rod
VCID: 6B83C0C3B302F13F0C5-803E
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:43
Engine speed: 0.00 /min
Coolant temperature: 6 °C
Intake air temperature: 6 °C
Voltage terminal 30: 12.360 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9999
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Charge air pressure specified value: 0 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 986.0 hPa
Mean injection quantity: 0.00 mg/stroke
25195 - Intake Air Temp. Sensor (G42)
P0113 00 [039] - Signal too High
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:43
4716 - No Communications with Parking Brake Control Module
U0128 00 [039] - -
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:42
Voltage terminal 30: 12.300 V
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
Component: ESC H31 0472
Revision: 00000000 Serial number: 62223000000394
VCID: 074B9C738FAA355F88D-8052
14 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
[FCAN: Mismatch between bytecoding and Lenkerposition signal]
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
8290 - Coding Not Possible
U10BC 00 [137] - -
[FCAN: Unplausible VIN number]
Reset counter: 240
Mileage: 133330 km
Date: 2020.02.08
Time: 03:47:41
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 240
Mileage: 133330 km
Date: 2020.02.08
Time: 03:47:41
8307 - Databus
[FCAN: PLA_Status_PLA_ESP signal is invalid]
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
8308 - Control Module Incorrectly Coded
U1014 00 [009] - -
[FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
[FCAN: Coding of ESP and TSK does not fit together]
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
32900 - Left Parking Brake Motor Voltage Supply
C100D 13 [137] - Electrical Malfunction
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
32901 - Right Parking Brake Motor Voltage Supply
C100E 13 [137] - Electrical Malfunction
Reset counter: 240
Date: 2020.02.08
Time: 03:47:36
Address 08: Auto HVAC (E87) Labels:| 8V0-820-047.clb
Part No SW: 8V0 820 047 F HW: 8V0 820 047 F
Component: AC Manuell el H03 0110
Revision: 20001000 Serial number: 00000000244919
Coding: 03100104002000001000000000000000
ASAM Dataset: EV_AirCondiFrontManAU37X 008018
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 392F2A8B89DE93AFCE9-806C
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001623800597
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5B0493D77A7D9FB0D-802A
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160810 043 0580
Serial number: 160817183816
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 D HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0004
Serial number: 50066833
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Serial number: 30 06 2016 00000255
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY162041M86
Serial number: 00000000000036271688
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 HW: 5QA 919 283
Component: PDC 4 KanalH07 0031
Serial number: 000308419616239
Coding: 0700040001
ASAM Dataset: EV_EPHVA14AU3700000 009027
ROD: EV_EPHVA14AU3700000_009.rod
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 240
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:41
13637426 - Databus
Reset counter: 240
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:40
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR22KSD8
Coding: 98CCC0000C0000005C5400CA00C800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 1079B72FFAE472E7597-8044
Subsystem 1 - Part No SW: ----------- HW: 480 003 108 16
Serial number: 357000000002509C2C1F
Subsystem 2 - Part No SW: ----------- HW: 480 003 108 16
Serial number: 358000000008509C2C1M
Subsystem 3 - Part No SW: ----------- HW: 480 402 908 16
Serial number: 3510001A72216EE2A798
Subsystem 4 - Part No SW: ----------- HW: 480 402 908 16
Serial number: 35200019B2216EE2471+
Subsystem 5 - Part No SW: ----------- HW: 480 402 507 16
Serial number: 3550002B3211FA32211O
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001A320F2B2512E.
Subsystem 7 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_P 000 6149
Serial number: 22900019D20F2B22031V
Subsystem 8 - Part No SW: ----------- HW: 480 000 508 16
Serial number: I0M00000000F53816D16
Subsystem 9 - Part No SW: ----------- HW: 480 000 508 16
Serial number: I0N00000000A8B09DC1J
B13BC F2 [137] - No function
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:40
Part No SW: 8V0 953 521 HB HW: 5Q0 953 549 E
Revision: -------- Serial number: 31081608490097
Coding: A408
VCID: 015F826BA18E0B6FC69-8054
Part No SW: 8V0 920 972 L HW: 8V0 920 972 L
Component: KOMBI H04 8316
Coding: 27A40A002B8026000100E8001001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 47CB5C73CF2AF55F48D-8012
16776967 - Databus
[EPB_02 keine Kommunikation]
Reset counter: 240
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:40
16776973 - Databus
[RKA_01 keine Kommunikation]
Reset counter: 240
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:40
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1265
Revision: -------- Serial number: 0005260751
Coding: 030100041F0873005B000248080B00000001010000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7BA3F083C36261BF9C5-802E
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0003
Serial number: 20160811080501 20915
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001608235553
Component: TSG FS 020 0041
Serial number: 210816EHL04561
Coding: 00108A204001040000001002
VCID: 43D34863FB12D97F945-8016
Component: EPS_MQB_ZFLS 128 1072
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D7567BF526E74FBA1-8010
Component: TSG BFS 020 0041
Serial number: 100616EFA05309
Coding: 001082204001040000001002
VCID: 42DD4D67E408D0779F3-8016
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 192 HW: 81A 035 192
Component: MU-HS-LND-EU 045 0148
Coding: 01730301FF00000011111101000A00102F002AC601F00100CE
ROD: EV_MUHigScl6C3DELP.rod
VCID: 5EE5991770B094979BB-800A
Subsystem 1 - Part No SW: 8W0 919 866 C HW: -----------
Component: ECE 2016 --- 0009
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY2075GV
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL122081600010260
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 240
Mileage: 133330 km
Date: 2020.02.08
Time: 03:46:44
Voltage terminal 30: 12.2 V
BAP-BAP_Function_ID: 02
Component: TSG HFS 020 0041
Serial number: 220816CHF05967
Coding: 000082204001040000001002
Component: TSG HBFS 020 0041
Serial number: 220816CHF05748
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.5V)-----------
