can work?
the pin 9 Pin to pin 39 of the unit
the pin 10 of the button, the fuse SC34
pin 2 lighting button
pin 1 to ground
demonjrm: I've been tackling the same issue on my mk7 Golf, and what you describe is similar in my car.
I'm not sure if I have transgressed forum etiquette here (given golfi_vend's post) and I hope that the Benevolent Dictator will be kind in his advice to the contrary, but here's how the TCS/ESP button works on my car. As you can see it uses the same PIN-OUT as you have described. The problem with my model is that I suspect I will need to tell the control module that the button is installed (once fitted). My suspicion is that this is done with a coding change to the control module, but there is not much coding information on address 03 for my car at the moment in the current RT software. So work-in-progress at this stage, for me
