When using a script, the value is not found.
rapgod
S.Korea
C?ID=381521
I use script well.
Always thank you.
Often when I use some scripts I can't find a value.
For example
StartVCDS ()
OpenUnit ("09")
LoginToUnit ("31347")
ChangeAdpChannel ("Leuchte23SL HLC10-Dimming Direction EF 23", "minimize")
ChangeAdpChannel ("Leuchte24SL HRA65-Dimming Direction EF 24", "minimize")
ChangeAdpChannel ("Leuchte23SL HLC10-Lichtfunktion C 23", "Brake light")
ChangeAdpChannel ("Leuchte24SL HRA65-Lichtfunktion C 24", "Brake light")
CloseUnit ()
The two items above find the value and modify it, but in the case of the two-line "Brake light", the value is not found and the script stops.
Please let me know if you know the cause.
Thank you!
hadez16
C?ID=289891
Hi there and thank you for using the tool ;)
At the moment I have no idea what the problem could be.
What I already saw is that some fancy blank spaces are included in some values meaning something like "Brake light_"
Could you manually change the value to Brake Light and create an CSV adaptation map of your BCM? Let's see how it is reflected in an admap.
