Golf MK6 Bi-Xenon with LED DRL and AFS retrofitted
somlioy
Norway
C?ID=210881
Hello
First of all, the intent of this thread is mainly for an informational purpose from my side.
I've recently retrofitted Bi-Xenon with LED DRL and AFS to my Golf Mk6, MY- 09. Car was originally fitted with halogen headlamps, euro headlight switch and RLS.
Wiring is done the same way as factory fitted bi-xenon headlamps. Please see attached sketch for how it's wired:
The wire colours I've written doesnt necessary fit your car just so you know...
To quickly recap what i've fitted, heres a list of parts and partnumbers.
  • New BCM (1K0 937 087 AL)
  • AFS master module (5M0 907 357 C)
  • 2x AFS slave modules (at headlamps) (7L6 941 329 B)
  • 2x Xenon Ballasts (5M0 907 391)
  • Level sensor at rear axle (1K0 941 273M, part number for AWD only I believe)
Wiring harnesses will also have to be fitted. I bought a harness kit for xenon retrofit. This includes adapters for headlamps including some new wires. Wiring for the AFS master and the rear level sensor. After checking the harnesses I discovered some wiring errors in the 10-to-14-pin adapter and I decided to just ditch the adapter and replace the 10-pin connector originally fitted in the car with the new 14-pin connector. However my sketch illustrates how the 10-to-14 pin adapter should be wired if used.
If you decide to replace the 10 pin connector aswell you need to replace the terminal crimped on pin 4 (10-pin connector) with a smaller one (Part number: N10335807).
Coding
Attached picture shows partly how my BCM is coded:
To get the LED DRL function properly with this wiring I figured I had to change Byte 18 in my BCM aswell. For my light setup I found Byte 18 coded to 40 to work as expected. (Originally coded to 02)
I've also seen people just connect pin 10 and 12 together but I don't think LEDs will work properly (dimming) with this bodge. Please correct me on this.
Before you do anything to Byte 18 I'll advice you to read up on byte 18.
This thread may be a good starting point.
My exterior light setup:
  • Bi-Xenon with LED
  • Front fog-lights
  • Halogen tail lights
  • Single reverse light
  • Tail fog light
  • 3x Brake lights
  • Turn Signals
You also have to code the AFS Master module, #55 in VCDS (Xenon Range/Headlight Range).
Module has to be enabled in the CAN-Gateway if you havent done that.
Please read the following Ross-Tech wiki: VW Golf (1K) Headlight Aim Control (Xenon with AFS)
My AFS-Master is under the group "not documented" and after an inquiry to Ross-Tech, Dana provided me with the following coding: 1475676
To quote Dana:
Dana said:
That includes AWD (which I missed earlier), 1 level sensor in addition to the RLS for the RoW market.
This is all I know about that coding. I have no clue what effect the AWD and RLS bit have on the light system. AFS Slaves are coded automaticly after you cycle your ignition.
I used 1446940 as coding previously, however Dana provided me with information saying this was for the NAR-market 2010+ GTI, and also missing a bit for RLS and AWD.
When I change to my new coding it felt like the AFS were "less aggressive" compared to the NAR coding. I'll do some testing and provide more information about this at a later point.
To finalize the AFS installation you need to complete the Basic Settings. Again, the Wiki above contains all information your need to know about this.
With all this done everything (should) works flawlessly. LED DRL should be lighted alone when its bright outside (not able to test this yet). However I've tested them manually. LEDs are dimming when I turn on the turn signal etc. Bi-Xenons are working aswell. No fault-codes.
This thread can also be worth reading
Feel free to correct me if I've done any misstakes. :thanks:
Auto-Scan:
Sunday,25,January,2015,09:35:12:59807
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: License Plate:
Mileage: 114680km-71258mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 22 25 37 42 44 46 52 55 56 62
          72 77
VIN: Mileage: 114680km-71258miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BJ    HW: 03L 906 022 G
   Component: R4 2,0L EDC G000SG  6758
   Revision: 13H01---    Serial number:
   Coding: 0000172
   Shop #: WSC 18496 000 1048576
   VCID: 6ED3C097797E9A518D7-803B
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 143B600D092700FB280F06E5901900423500
   VCID: 75E1EFFBDC28A9894CD-8020
   Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
   Component: Climatronic   130 0303
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 74E7D2FFDF52B0817B3-8021
   Part No SW: 1K0 937 087 AL    HW: 1K0 937 087 AL
   Component: BCM PQ35  H+  112 0771
   Revision: AF112771
   Coding: 46180A3898251AC040080088710089EC477F4088733D8DF0E48420040000
   VCID: 7BF5F9C3FA0CFFF93A9-802E
   Component: Wischer 18110  21  0501
   Coding: 009795
   Component: RLS 281108 05  54  0402
   Coding: 0330AD
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475     HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0002
   Revision: --------    Serial number: 60630832100423
   Coding: 100001
   VCID: 73E5D1E3D25CB7B9629-8026
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    022 0507
   Serial number: 003C2D063RL1
   Coding: 00003135
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 77FDE5F3CE24DB995E1-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 4F697241ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 40417241ZZZZZZZZZZZZ
   Serial number: 201F1247ZZZZZZZZZZZZ
   Serial number: 041A1315ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000532
   VCID: 78FFE6CF0B3AD4E157B-802D
   Subsystem 1 - Part No: 3C8 959 537 B
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 5K0 920 870 C    HW: 5K0 920 870 C
   Component: KOMBI         H21 0029
   Coding: 170F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 2D51079B7CF8A149F4D-8078
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 24011400F14111
   Coding: 350002
   VCID: 7CF7FADFFF02F8C1333-8029
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 0101856B74745D545420363E00
   VCID: 2D51079B74F8A149F4D-8078
Address 22: AWD        Labels: Redir Fail!
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43854123027C4739329-8016
   Component: IMMO          H21 0029
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
   Component: RNS-MID       H23 6270
   Revision: AB001001    Serial number: VWZ6Z7P4569654
   Coding: 04000400040000A00000
   VCID: 366328F781AEE291857-8063
   Component: EU West V10  8048
   Part No SW: 1K0 959 701 AN    HW: 1K0 959 701 AN
   Component: Tuer-SG         008 2015
   Coding: 0004342
   VCID: 7AFBFCC73536C6F121F-802F
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 01324 785 00200
   VCID: 2A5B0C878516B67111F-807F
   Part No SW: 1K0 959 702 AG    HW: 1K0 959 702 AG
   Component: Tuer-SG         008 2033
   Coding: 0004598
   VCID: 74E7D2FF1752B0817B3-8021
   Coding: 1446940
   VCID: 346712FF57D2F081BB3-8061
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Coding: 00000022
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000208
   Shop #: WSC 01357 011 1012551
   VCID: 7BF5F9C33A0CFFF93A9-802E
00123 - Outside Warning Light/Door exit Light; Rear Right
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603519167
   Coding: 020000010100010000000400
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_SE36.rod
   VCID: 2345E1A32A3C6739529-8076
End-------------------------(Elapsed Time: 02:31)--------------------------
golfhappy
C?ID=214466
Great!!! NASA awaits!
If you connect pins 10 and 12 together you get a front side light error code, think the code was 02896, short to ground. This happens when you switch on the main beams. My Drls are set at 100% brightness and don't dim with the pins connected. It was documented in Bruno Prado write up that you had to bridge the pins to get the drls to work. We did this and i had the error code problem.
somlioy
Norway
C?ID=210881
Did you fix this issue? Did you connect pin 10 or 12 from the car/cecm when you jumped 10-12 on the headlamp or did you short them together?
I believe Pin 10 should go to CECM connector T52c pin 26 (left, grey/black)and T52a pin 44 (right, grey/red). Pin 12 should go to T52a pin 6 (left, blue/yellow) and T52a pin 28 (right, blue/green).
However if your car dosent have rear fog light Pin 12 on right headlamp might be connected to T52c pin 47. Not sure why its done like that. What MY is your car anyway?
52-pin connector -T52 A- black -A-
6 - Left daytime running light bulb -L174-
28 - Right daytime running light bulb -L175-
44 - Right side light bulb -M3-
47 - Left rear fog light bulb -L46- , left reversing light bulb -M16-
52-pin connector -T52 C- brown-C-
26 - Left side light bulb -M1-
golfhappy
C?ID=214466
They were shorted together. Forum member from Golfgti.co.uk posted me his long helper code for the CECM and i've got new Kufatec harnesses to go in. Tried the harnesses without the AFS and it worked did throw an error bulb in the dash but VCDS didn't pick a code up. I asume it was the AFS not being connected that threw the bulb.
somlioy
Norway
C?ID=210881
Shorting the output from the CECM is generally a bad idea I'd say, because if one of the outputs is enabled while the other one isnt. The one that is disable will then recieve a 12v signal and the CECM thinks theres a short to positive.
golfhappy
C?ID=214466
Sorry the car is a 2012 plate GTD. I suppose when the guy in Mexico did the retrofit that was the only way he could get his drls to work.
somlioy
Norway
C?ID=210881
Alright I've done some testing with the AFS. It seems theres not much difference between the two codes I provided in the first post in terms of "aggressiveness".
Claudiu
C?ID=221613
Hello guys,
I've recently done this retrofit on RHD 2009 tdi Golf and I cannot make the DRL to turn on properly. Can you please help. I bought the adapters from Carsystem.pl and the plugs are wired as the above wiring diagram.
Before BCM upgrade scan
Wednesday,28,June,2017,12:19:16:25075
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ1KZAP013389   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAP013389   Mileage: 154670km-96107miles
37-Navigation -- Status: Not registered 0011
   Part No SW: 03L 906 022 LA    HW: 03L 906 022 G
   Component: R4 2.0l TDI G000SG  9978
   Revision: 13H02---    Serial number:
   Coding: 0001072
   Shop #: WSC 84224 544 534920
   VCID: 6FEDCD087EFCFF3900-803A
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 163B400D092300FD680E02EC902200823400
   Shop #: WSC 00028 028 00001
   VCID: 7EF3E04CE99686B19B-802A
02214 - Tire Pressure Warning
                    Reset counter: 7
                    Mileage: 154429 km
                    Date: 2011.11.07
                    Time: 01:00:09
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50709
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00028 028 00318
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 326B047C654E92D12F-8066
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0537
   Revision: 00103 AC
   Coding: 48180A3A9825F1C044080080140081E443510088536D8960648000200000
   VCID: 306F0E746342A0C159-8064
   Component: Wischer 26050  21  0501
   Coding: 009795
   Component: RLS 090609 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
                    Fault Status: 00101010
                    Fault Frequency: 46
                    Reset counter: 12
                    Mileage: 154385 km
                    Date: 2011.11.05
                    Time: 20:17:38
                    Voltage: 13.95 V
                        Term 50 Off
   Part No SW: 5K0 919 475 C    HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0008
   Revision: --------    Serial number: 12940915406240
   Coding: 100001
   VCID: 3663386C81268EF103-8062
   Component: AirbagVW10    033 0604
   Serial number: 003C2D0BB10A
   Coding: 00003230
   Shop #: WSC 00028 790 00306
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77FDF568CEACB7F9D8-8022
   Serial number: 106E6447ZZZZZZZZZZZZ
   Serial number: 0B313048ZZZZZZZZZZZZ
   Serial number: 18502F4DZZZZZZZZZZZZ
   Serial number: 282E2D3DZZZZZZZZZZZZ
   Coding: 0000532
   VCID: 78FFF6540BB2B881D1-802C
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Coding: 00000226
   Part No SW: 5K0 920 970 J    HW: 5K0 920 970 J
   Component: KOMBI         H05 0206
   Coding: 470B00
   VCID: 35613F60942085E90A-8060
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 040609F1002433
   Coding: E9A07F06000212000003
   VCID: 66C3A82C51063E7173-8032
                    Reset counter: 247
                    Mileage: 153982 km
                    Date: 2011.10.29
                    Time: 14:14:22
            000 -  -
                    Mileage: 153982 km
                    Date: 2011.10.29
                    Time: 14:30:06
   Component: IMMO          H05 0206
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667461881
   VCID: 2643E82C5186FE71B3-8072
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H50 2840
   Revision: AB001001    Serial number: VWZ6Z7L3080015
   Coding: 000002000200000000
   Shop #: WSC 05314 123 12345
   VCID: 2E53100C7976B6314B-807A
            000 -  -
                    Reset counter: 244
                    Mileage: 153976 km
00857 - CD Changer Unit (R41)
                    Reset counter: 244
                    Mileage: 153976 km
01523 - Microphone for Telephone (R38)
                    Reset counter: 229
                    Mileage: 154483 km
                    Date: 2011.11.11
                    Time: 21:13:53
                    Reset counter: 229
                    Mileage: 154483 km
                    Date: 2011.11.11
                    Time: 21:13:53
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
   Part No SW: 5K0 959 701 E    HW: 5K0 959 701 E
   Component: Tuer-SG         009 2124
   Coding: 0004790
   VCID: 34670264575A9CE13D-8060
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H15000
   VCID: 2F6D0D08BE7CBF3940-807A
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Coding: 0005046
   VCID: 35613F605C2085E90A-8060
            000 -  -
                    Reset counter: 244
                    Mileage: 153976 km
                    Reset counter: 244
                    Mileage: 153976 km
                    Reset counter: 229
                    Mileage: 154483 km
                    Date: 2011.11.11
                    Time: 21:13:53
                    Reset counter: 229
                    Mileage: 154483 km
                    Date: 2011.11.11
                    Time: 21:13:53
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
End-------------------------(Elapsed Time: 02:26)--------------------------
After BCM upgrade and coding scan
Friday,16,March,2018,22:14:22:22001
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Mileage: 160700km-99854mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZAP013389   Mileage: 160700km-99854miles
   Coding: 0001072
   VCID: 6FAE3FD97EC8FD3CF1-803A
   Revision: 00H45001
   VCID: 7EB0129DE9A284B46A-802A
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000004003
   Shop #: WSC 00028 028 00025
   VCID: 004C6C659B56F24418-8054
          U1111 00 [009] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 176
                    Mileage: 160709 km
                    Date: 2018.03.16
                    Time: 21:04:50
   Part No SW: 5K0 937 087 R    HW: 5K0 937 087 R
   Component: BCM PQ35 H    021 0064
   Revision: BE021001
   Coding: 48180A3AF825F1C040880080950089EC43D50488536D8D60E48020040040
   Shop #: WSC 04941 123 12345
   VCID: 44C4A075C7CE2E647C-8010
   Coding: 009795
   Coding: 0730AD
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101010
                    Reset counter: 176
                    Mileage: 160709 km
                    Date: 2012.08.06
                    Time: 22:13:13
                    Voltage: 13.80 V
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                    Reset counter: 176
                    Mileage: 160709 km
                    Date: 2012.08.06
                    Time: 22:13:13
                    Voltage: 13.80 V
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Coding: 100001
   VCID: 3620CABD81128CF4F2-8062
   Coding: 00003230
   VCID: 77BE07B9CE98B5FC29-8022
   Coding: 0000532
   VCID: 78BC04850B86BA8420-802C
   Coding: 00000226
   Coding: 170900
   VCID: 3522CDB1941487ECFB-8060
   Coding: E9A17F06400212000003
   VCID: 66805AFD51323C7482-8032
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 26001AFD51B2FC7442-8072
   Coding: 040004000200008100
   VCID: 2E10E2DD7942B434BA-807A
   Coding: 0004790
   VCID: 3424F0B5576E9EE4CC-8060
   Revision: 00H15000
   VCID: 2F2EFFD9BE48BD3CB1-807A
   Coding: 0005046
   VCID: 3522CDB15C1487ECFB-8060
   Coding: 1446940
   Shop #: WSC 33361 790 00052
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:32, VBatt start/end: 13.8V/13.7V)-----------
The car has also LED taillights. I would be very grateful if you guys can point me in the right direction.
Claudiu
C?ID=221613
hi guys,
just to let you know that I have managed to sort it out with the setup I had. I've changed byte 18 to 4E VW Golf/Jetta Variant (VW362) and this made everything work less the outer rear taillights. To make them lit up I have amended the EEPROM in the BCM1 and now all works as it should.
