Central Locking Pump replaced on A3 8L
Juan J. Conde
Mexico
C?ID=205506
Good day.
Last June I changed my CLP because was leaking. I replaced it by repaired one. After replaced it did not work due coding and WS were different. I changed code and WS number and worked perfectly. A month later after drive and turned off ignition remote controller did not work. I checked fault memory and get 00095 - key 1: Adaptation Limit Surpassed, so erased fault, matched key and worked again. One month later (approx.) again same issue. This time changed remote control batteries, erased remote controllers, matched again and worked. Again, a month later same issue was present, but after test all possible factors found that it solved only turned ignition ON and OFF. :confused:.
On a month time frame, same issue, same solution, but not fault was present on module 35. Was not a big deal if only need turned ON and OFF ignition to solve problem every month. But one month ago start to fails every week and that's make me upset.
This was old CLP configuration:
Address 35: Centr. Locks Labels:. 8D0-862-257.clb
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 13932
Shop #: WSC 18500
VCID: 408F411540E6584FD1-4EEA
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
This was new CLP with original configuration:
Component: CV-Pump D10
Coding: 16140
Shop #: WSC 06335
This is new CLP with modified configuration on last scan:
Saturday,01,February,2020,17:16:17:26011
VCDS Version: 19.6.2.0 (x64)
VIN: 93UMC28L014003866   License Plate: A3
Mileage: 268660km-166937mi   Repair Order:
Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: 93UMC28L014003866   Mileage: 268660km-166937miles
Address 01: Engine        Labels: 06A-906-032-AJQ.clb
   Part No: 06A 906 032 FB
   Component: 1.8L R4/5VT         0003
   Coding: 04500
   Shop #: WSC 66565
   VCID: 63C5AE99F1302357DA-5140
   93UMC28L014003866     AUZ7Z0Y1655196
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00000 785 00200
   VCID: 2B5506B98960AB1722-5140
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 8L0 820 043 H
   Component: A3  KLIMAAUTOMAT   0101
   Coding: 00040
   VCID: 2D5108A1E774A5273C-2598
Address 15: Airbags        Labels: 8L0-959-655-AI8.lbl
   Part No: 8L0 959 655 L
   Component: Airbag Front+Seite 7008
   Coding: 00104
   Shop #: WSC 18500
   VCID: 479D5A0965C86F7726-515E
Address 17: Instruments        Labels: 8L0-920-xxx-17.lbl
   Part No: 8L0 920 931 MX
   Component: KOMBI+WEGFAHRS. VDO D14
   Coding: 00544
   VCID: 1129B4515B0CE1C738-5140
   Coding: 13932
   Shop #: WSC 18500
   VCID: 408F411540E6584FE7-4EEA
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00001
   VCID: 60CFA195E026384FC7-4B32
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 8L0 035 186 B
   Component:  Radio              D05
   Coding: 00017
   VCID: 2D5108A1E774A5273C-4B1A
   Note: Excessive Comm Errors
End-------------------------(Elapsed Time: 04:01)--------------------------
I will appreciate any comments to solve this.
MartinsX
Riga, Latvia
C?ID=268515
Water ingress into module 35. Maybe not now, just late effect after some water has been there. Or microcontroller chip just starts to go crazy. Those modules used ones are still available for a low price. Mostly with worn pump motors, but You can disassamble it, leave Your pump (if it is good) and take only PCB from another one.
Juan J. Conde
Mexico
C?ID=205506
My pump was good. Leak was on pipes from electronic board. The problem is new ones are not available for my car, that's why I got a refurnished CLP, I think this one came from an A4. I was thinking could it be a configuration problem, because replace CLP again is a nightmare for reinstall trim due age car. But if is the only solution I will do it.
Thanks MartinX
Juan J. Conde
Mexico
C?ID=205506
That´s will be my first option if I need remove it again.
Thanks MartinX
