Retrofit MK6 Golf-R instrument cluster to MK5 Golf GTI
NitrousOxide
Jamaica
C?ID=269481
Greetings,
I had just retrofitted a 2012 MK6 Golf-R instrument cluster in my 2008 MK5 GTI thinking that the donor cluster was from a MK6 Golf. I did the necessary immobilizer work and paired a new key (with lots of advice from a member here "Jetta,97"). There are a few things I had noticed before, during and after a test-drive. The fuel gauge in the new cluster is showing that my car has a bit more fuel than my original cluster did. Since my car has a 55 liter tank, I placed an additional 20 liters of petrol in the tank for peace of mind until I can figure out what my new coding value should be since I know that AWD vehicles have a smaller tank than FWD. I manually transferred the odometer reading from my previous cluster to this one, but I want to ensure that the speedometer and odometer is working correctly. I like to accurately track my fuel economy when I feel like hypermiling, and avoid speeding tickets when I choose to put my foot down. My cluster has all sorts of ABS, TPMS, steering and traction control errors, but I suspect that it is due to the difference in AWD vs FWD ABS units, so I am seeking assistance with suggested coding or adaptation channels to go through. Below is is what the instrument cluster looks like with the fault codes. Disclaimer, I had placed the internals including needles and gauges of the Golf-R cluster in a 2010 Jetta housing so that it bolts to my MK5 Golf dashboard. At a later date, this will be placed in an appropriate Scirocco R or RS housing to have the GTI aesthetics for the MK5/MK6
Here is the Auto Scan of the car before the retrofit:
Sunday,19,January,2020,15:37:40:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078   License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078   Mileage: 189870km-117979miles
77-Telephone -- Status: Sporadic communication error 1000
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070160
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5EE744-8060
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 189844 km
                    Time: 08:14:57
                    RPM: 1748 /min
                    Load: 20.8 %
                    Speed: 23.0 km/h
                    Temperature: 90.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
Readiness: 0110 0001
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 05108020    Serial number: 00001009061622
   Shop #: WSC 04940 001 00001
   VCID: 1C192DFCDF37EFAF5B-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900D7AA-8026
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000014002
   Shop #: WSC 12345 123 61029
   VCID: 0021798C9B9F2B4FA7-8054
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 215
                    Mileage: 189844 km
                    Time: 08:14:50
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
                    Reset counter: 215
                    Mileage: 189844 km
                    Time: 08:14:49
   Revision: 00H54000    Serial number: 01000007456322
   Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
   VCID: 71C72C48683532C758-8024
   Component: Wischer 300807 021  0501
   Coding: 00039861
   Shop #: WSC 12345
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 12345
01502 - Bulb for Rear Fog; Left (L46)
                    Fault Status: 01111100
                    Reset counter: 215
                    Mileage: 189854 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.25 V
02499 - Right Low Beam Reflector Motor (V295)
                    Reset counter: 215
                    Mileage: 189862 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.10 V
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86A78C-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
00589 - Airbag Igniter 1; Passenger Side (N131)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012122
   VCID: 01277C8858952247A8-8054
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0006103
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 030312F2002329
   Coding: 350001
   VCID: 3A55CB64B5C3B19FA9-806E
                    Reset counter: 0
                    Mileage: 189854 km
                    Time: 08:59:15
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000564
   Shop #: WSC 11111 111 45799
   VCID: 3851D16C4BCFA38F5F-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 207    3305
   Revision: 00H22000
   Shop #: WSC 00028 028 00001
   VCID: 3753D25046D1ACF756-8062
   Coding: 98900A085103007F42040F0FF00A5A0690BC00
   VCID: 032B768042893057BA-8056
                    Reset counter: 213
                    Mileage: 189844 km
                    Time: 08:15:00
   Coding: 0000564
   VCID: 3957D46870C5BA87A0-806C
   Part No: 1T0 907 357
   Coding: 0000003
   Shop #: WSC 00000 785 00200
   VCID: 74C9255C172707EFB3-8020
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3180243
   Coding: 01000401000005
   VCID: 63EB560062C99057DA-8036
                    Reset counter: 213
                    Mileage: 189844 km
                    Time: 08:15:02
02633 - Antenna for Satellite Tuner
                    Reset counter: 213
                    Mileage: 189844 km
                    Time: 08:15:02
                    Reset counter: 213
                    Mileage: 189844 km
                    Time: 08:15:02
                    Reset counter: 213
                    Mileage: 189854 km
                    Time: 13:12:38
Address 77: Telephone
End-------------------------(Elapsed Time: 01:19)--------------------------
This is the Auto Scan of the car after the retrofit and a test drive in an attempt to calibrate the steering:
Friday,07,February,2020,06:36:12:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VIN: WVWZZZ1KZ8W111078   Mileage: 190190km-118178miles
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:14
                    RPM: 823 /min
                    Load: 28.2 %
                    Temperature: 89.0°C
                    Temperature: 57.0°C
                    Voltage: 13.589 V
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0004738
7 Faults Found:
   Revision: 00001004
   Coding: 0000014002
                    Reset counter: 243
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:07
   Coding: 00039861
   Shop #: WSC 12345
   Coding: 00208933
   Shop #: WSC 12345
                    Fault Status: 01101100
                    Reset counter: 243
                    Mileage: 190182 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.20 V
   Coding: 0013121
   Coding: 0012122
   Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
   Component: KOMBI         H04 0617
   Coding: 170C01
   VCID: 3851D16C83CFA38F5F-806C
   Coding: 350001
                    Reset counter: 27
                    Mileage: 190187 km
                    Date: 2020.02.07
                    Time: 04:50:41
   Component: IMMO          H04 0617
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AF53B248DE3C11F19-803E
   Coding: 0000564
   Revision: 00H22000
                    Fault Status: 11100101
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:19
                    Battery Volts: 13.6 V
                        DU
                    Temperature: 44.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Shop #: WSC 12345 111 45725
                    Reset counter: 242
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:19
   Coding: 0000564
   Coding: 0000003
                    Reset counter: 242
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:21
                    Reset counter: 242
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:21
                    Reset counter: 242
                    Mileage: 190185 km
                    Date: 2020.02.07
                    Time: 04:45:08
End-------------------------(Elapsed Time: 01:29)--------------------------
m87a
Bosnia and Herzegovina
C?ID=156900
as for coding and speedometer you're ok, did you clear dtc's before scan? vcds can't help you with fuel tank capacity, that needs to be changed in eeprom...
NitrousOxide
Jamaica
C?ID=269481
The only DTCs that remain currently is the one for the traction control and TPMS. The fault codes for the steering adaptation went away with clearing all codes again then doing another test drive. Would you suggest that my existing ABS module is compatible with this cluster? Or would I have to do something in EEPROM for that as well.
downtime
Finland
C?ID=280813
That would’ve been my question as well that are you sure your ABS block is compatible with the newer cluster?
NitrousOxide
Jamaica
C?ID=269481
I recall two individuals in this forum saying that the ABS module was compatible. I'm looking for that thread now.
downtime
Finland
C?ID=280813
I remember that as well. Spacewalker knows if it’s compatible or not. But why I’m asking is because the errors on the ABS look a bit like there’s a compatibility issue.
Especially when the ABS coding has not changed.
golfi_vend
Tartu, Estonia
C?ID=195131
ESP is OK and compatible.
Fuel chart may be tweaked in eeprom.
rhinopower
C?ID=58979
Have you matched the immo correctly? You haven’t turned the immo off in the ecu? The vin in the cluster must match the ecu
NitrousOxide
Jamaica
C?ID=269481
I didn't use the "VCDS" method of pairing the immobiliser as it wasn't accepting the PIN for the immobiliser. I had used a third party tool called AVDI to do the process.
I hadn't disabled the immobiliser, if I intentionally try the wrong key, I get the warning on the dashboard until the correct key is used. The one thing I noticed is that the dashboard's serial number is: "00000000000000".
The original VIN is still in my ECU and the donor immobiliser.
downtime
Finland
C?ID=280813
You can’t use the VCDS method on that clustet anymore anyway as the IMMO generation is too new for that.
Reading the immo data from your old cluster and moving that to the new one wasn’t an option??
NitrousOxide
Jamaica
C?ID=269481
That's what I did with AVDI. The instructions didn't include touching the serial number field of the cluster itself.
downtime
Finland
C?ID=280813
If you did that, then why is the IMMO disabled on the new cluster? You can clone your old clusters IMMO data, so there should not be any need to disable the IMMO.
NitrousOxide
Jamaica
C?ID=269481
I don't understand what you mean. The car doesn't stay running with the wrong key in the ignition.
I had manually transferred the VIN, PIN ,CS, MAC and Power class using AVDI. I didn't touch the serial number as it wasn't a part of the steps.
downtime
Finland
C?ID=280813
NitrousOxide
Jamaica
C?ID=269481
Basic Settings could not be initiated even after entering the 40168 security code. The error message I kept getting last night was something along the lines of "group not accessible". I'll try the process later today after another test drive.
On another note: What I found interesting with this retrofit was that my previously retrofitted MK6 RCD-510 which keeps asking for its PIN code each time the main battery is disconnected (and was locked out for 60 minutes as I entered the incorrect PIN twice from memory), activated itself without waiting for the timeout to elapse the moment I copied over the immo data from my previous MK5 cluster to this MK6 one. The radio was in no way previously paired to the new cluster before.
m87a
C?ID=156900
ok so can you post the latest scan please? I don't understand what people expect we can do to help if we don't see the latest issues/problems?????:banghead:
NitrousOxide
Jamaica
C?ID=269481
The fault codes worked themselves out after another drive. I erroneously activated the system function test, but it never completes even after the documented test drive procedure.
Saturday,08,February,2020,20:26:32:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VIN: WVWZZZ1KZ8W111078   Mileage: 190220km-118197miles
                    Mileage: 190219 km
                    Date: 2020.02.08
                    Time: 14:29:29
                    RPM: 833 /min
                    Load: 32.5 %
                    Temperature: 89.0°C
                    Temperature: 57.0°C
                    Voltage: 12.954 V
   Revision: 00H11001
   Coding: 0004738
01486 - System Function Test Activated
   Revision: 00001004
   Coding: 0000014002
                    Reset counter: 248
                    Mileage: 190227 km
                    Date: 2020.02.08
                    Time: 19:57:19
   Coding: 00039861
   Shop #: WSC 12345
   Coding: 00208933
   Shop #: WSC 12345
                    Reset counter: 248
                    Mileage: 190227 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.20 V
   Coding: 0013121
   Coding: 0012122
   Coding: 170C01
   Coding: 350001
   Coding: 0000564
   Revision: 00H22000
                    Reset counter: 248
                    Mileage: 190227 km
                    Date: 2020.02.08
                    Time: 20:02:08
   Coding: 0000564
   Coding: 0000003
                    Reset counter: 248
                    Mileage: 190227 km
                    Date: 2020.02.08
                    Time: 19:48:49
                    Reset counter: 248
                    Mileage: 190227 km
                    Date: 2020.02.08
                    Time: 19:48:49
                    Reset counter: 248
                    Mileage: 190228 km
                    Date: 2020.02.08
                    Time: 20:16:06
End-------------------------(Elapsed Time: 01:28)--------------------------
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H04 0617
           Software Coding: 000000
            Work Shop Code: WSC 01357
Advanced Identification/FAZIT
     Identification: VDD-024
     Date: 27.02.12
     Manufacturer number: 1901
     Test stand number: 2506
Flash Status
     Flash Date: 00.00.00
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A03009
Car Info
     Chassis Number: WVWZZZ1KZ8W111078
Immobilizer
     Transponder ID (Current val.): 2AD7EECA
     Transponder ID 1: F0C9618B
     Transponder ID 2: F0D30D8A
     Transponder ID 3: 00329F01
     Transponder ID 4: 2AD7EECA
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
                Address 01: Engine
Control Module Part Number: 1K0 907 115 R
  Component and/or Version: 2.0l R4/4V TFSI     0020
           Software Coding: 040300101C070160
            Work Shop Code: WSC 66565
     Identification: RB8-658
     Revision: 5BH16---
     Date: 13.08.07
     Test stand number: 1360
     Manufacturer number: 0408
Flash Status
     Programming Attempts: 46
     Successful Attempts: 35
     Programming Status: 00000000
     Required Conditions: 00000001
Software
     A000
     A4.9.6
Misc.
     Hardware number: 8P0 907 115 B
Car Info
VCDS Info:
       Labels: 06F-907-115-AXX.clb
       Readiness: 06F-907-115-AXX.crd
Control Module Part Number: 1K0 907 379 AC
  Component and/or Version: ESP FRONT MK60      0101
           Software Coding: 0004738
            Work Shop Code: WSC 12345
     Identification: CTA-000
     Revision: 00H11001
     Date: 11.09.07
     Test stand number: 0102
     Manufacturer number: 0296
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Required Conditions: 00000000
     Flash Tool Code: 00000 000 00000
Misc.
     Hardware number: 1K0 907 379 AC
VCDS Info:
downtime
Finland
C?ID=280813
It will complete. Just try again. Sometimes it takes several tries and sometimes it goes on one go :)
Big enough parking lot where you can drive figure 8s :)
NitrousOxide
Jamaica
C?ID=269481
It finally completed after almost a week of daily driving.
Thursday,13,February,2020,19:24:29:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64)
VIN: WVWZZZ1KZ8W111078   Mileage: 190350km-118278miles
   VCID: 354FD8585CDD5EE746-8060
                    Mileage: 190345 km
                    Date: 2020.02.12
                    Time: 21:10:19
                    RPM: 2031 /min
                    Load: 31.4 %
                    Speed: 17.0 km/h
                    Temperature: 89.0°C
                    Temperature: 39.0°C
                    Voltage: 13.843 V
               P0300 - 002 -
                    Fault Status: 01100010
                    Mileage: 190355 km
                    Date: 2020.02.13
                    Time: 19:19:36
                    RPM: 725 /min
                    Load: 25.5 %
                    Temperature: 89.0°C
                    Temperature: 57.0°C
                    Voltage: 13.462 V
000769 - Cylinder 1
               P0301 - 002 - Misfire Detected
                    Mileage: 190355 km
                    Date: 2020.02.13
                    Time: 19:20:31
                    RPM: 747 /min
                    Load: 25.1 %
                    Temperature: 88.0°C
                    Temperature: 58.0°C
                    Voltage: 13.589 V
000771 - Cylinder 3
               P0303 - 002 - Misfire Detected
                    Mileage: 190355 km
                    Date: 2020.02.13
                    Time: 19:20:31
                    RPM: 747 /min
                    Load: 25.1 %
                    Temperature: 88.0°C
                    Temperature: 58.0°C
                    Voltage: 13.589 V
000770 - Cylinder 2
               P0302 - 002 - Misfire Detected
                    Mileage: 190355 km
                    Date: 2020.02.13
                    Time: 19:20:31
                    RPM: 747 /min
                    Load: 25.1 %
                    Temperature: 88.0°C
                    Temperature: 58.0°C
                    Voltage: 13.589 V
   VCID: 1C192DFCDF37EFAF59-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900D7A8-8026
   Revision: 00001004
   Coding: 0000014002
   VCID: 0021798C9B9F2B4FA5-8054
                    Reset counter: 2
                    Mileage: 190355 km
                    Date: 2020.02.13
                    Time: 19:09:52
   VCID: 71C72C48683532C75A-8024
   Coding: 00039861
   Shop #: WSC 12345
   Coding: 00208933
   Shop #: WSC 12345
                    Reset counter: 2
                    Mileage: 190345 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.50 V
   Coding: 0013121
   VCID: 3D5FC07864ED86A78E-8068
   Coding: 0012122
   VCID: 01277C8858952247AA-8054
   Coding: 170C01
   VCID: 3851D16C83CFA38F5D-806C
   Coding: 350001
   VCID: 3A55CB64B5C3B19FAB-806E
                    Reset counter: 41
                    Mileage: 190349 km
                    Date: 2020.02.12
                    Time: 21:19:47
   VCID: 6AF53B248DE3C11F1B-803E
   Coding: 0000564
   VCID: 3851D16C4BCFA38F5D-806C
   Revision: 00H22000
   VCID: 3753D25046D1ACF754-8062
   VCID: 032B768042893057B8-8056
                    Reset counter: 0
                    Mileage: 190345 km
                    Date: 2020.02.12
                    Time: 21:10:23
   Coding: 0000564
   VCID: 3957D46870C5BA87A2-806C
   Coding: 0000003
   VCID: 74C9255C172707EFB1-8020
   VCID: 63EB560062C99057D8-8036
                    Reset counter: 0
                    Mileage: 190345 km
                    Date: 2020.02.12
                    Time: 21:10:24
                    Reset counter: 0
                    Mileage: 190345 km
                    Date: 2020.02.12
                    Time: 21:10:24
                    Fault Status: 00101011
                    Reset counter: 0
                    Date: 2020.02.13
                    Time: 07:34:06
End-------------------------(Elapsed Time: 01:54)--------------------------
I have to some EEPROM work to get the fuel gauge to display the correct reading. It is zeroed correctly (both with the ignition on and off). I was driving and the low level fuel light came on (although the needle was displaying a little above 1/4 tank. I ignored it for a few kilometers, then pulled into a petrol station (in which the gauge still showed 1/4 tank). I filled the tank to capacity. I was surprised to see that my 55 liter tank required 53 liters to fill it to capacity, which indicates to me that I was dangerously low with 2 liters actually remaining in the tank (I felt sorry for putting my fuel pump through all that). My understanding from the operator's manual is that under normal circumstances the warning light indicates that there is still approximately 7 liters in the stock tank, so the time it comes on in my case, is now too short notice when I'm driving in the middle of nowhere. Also in filling the tank, I can see where the needs shows quite a bit more that 100% full.
The VCDS gauge test sweeps from the "empty" position to the "full" position and back, so I know that the gauges end points are somewhat set correctly.
NitrousOxide
Jamaica
C?ID=269481
I had forgotten to close the thread some time ago to explain that everything with the retrofit went smoothly including the horn, ABS and fuel gauge.
However for the past 2 weeks, I've been sometimes hearing a rhythmic clicking sound in the passenger side of the dashboard when the ignition is OFF. The sound is like that of non-VAG turn signals (like the clicking of a relay or bi-metalic strip / switch). My indicator lights aren't actually flashing (but they do work), and I had removed the speaker from my instrument cluster, so I know there shouldn't be any noise there. The sound occurs once the ignition is OFF at random intervals, and will pause if I switch on the radio (and even leave it on mute), or lock/unlock the doors using the keyfob or door button. The sound occurs if the car is just not being used. I've recorded the noise below:
I've posted the Auto Scan below.
Sunday,07,June,2020,19:09:31:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
VIN: WVWZZZ1KZ8W111078   Mileage: 193010km-119930miles
   VCID: 354FD8585CDD5E2EE8-8060
   VCID: 1C192DFCDF37EF66F7-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB26401229001E06-8026
   Revision: 00001004
   Coding: 0000014002
   VCID: 0021798C9B9F2B860B-8054
                    Reset counter: 204
                    Mileage: 192992 km
                    Date: 2020.06.06
                    Time: 15:05:58
   Coding: F78F8B270004800047140A001400008080191C075C00010D00  0000000000
   VCID: 71C72C486835320EF4-8024
   Coding: 00039861
   Shop #: WSC 12345
   Coding: 00208933
   Shop #: WSC 12345
                    Reset counter: 204
                    Mileage: 192992 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.15 V
   Coding: 0013121
   VCID: 3D5FC07864ED866E20-8068
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001632
   VCID: 76CD1F54015B153621-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H06 0010
   Coding: 00000131
   Coding: 170C00
   VCID: 3851D16C83CFA346F3-806C
   Coding: 350001
   VCID: 3A55CB64B5C3B15605-806E
   VCID: 6AF53B248DE3C1D6B5-803E
   Coding: 0000560
   VCID: 3851D16C4BCFA346F3-806C
   Revision: 00H22000
   VCID: 3753D25046D1AC3EFA-8062
   Coding: 98900A085103007F42000F0FF0CA5A0610BC40
   VCID: 032B76804289309E16-8056
                    Reset counter: 203
                    Mileage: 192992 km
                    Date: 2014.10.28
                    Time: 15:06:08
   Coding: 0000564
   VCID: 3957D46870C5BA4E0C-806C
   Coding: 0000003
   VCID: 74C9255C172707261F-8020
   Coding: 00000401000005
   VCID: 63EB560062C9909E76-8036
                    Reset counter: 203
                    Mileage: 192992 km
                    Date: 2014.10.29
                    Time: 16:20:28
                    Reset counter: 203
                    Mileage: 192992 km
                    Date: 2014.10.29
                    Time: 16:20:31
                    Reset counter: 203
                    Date: 2014.10.29
                    Time: 17:51:57
                    Reset counter: 204
                    Mileage: 192994 km
                    Date: 2014.10.29
                    Time: 17:57:13
End-------------------------(Elapsed Time: 01:26)--------------------------
