- Jan 9, 2020
- 6
- 3
- Sofia, Bulgaria
- C?ID=30121
Grettings i have and issue with a car new for me audi a3 e-tron never had an e-tron before in my workshop so every information is valuable here is an autosacan from the car i dont know from where should i start the biggest problem is that the car don't want to crank the car had and accident it is crashed in the passenger door
Best regards
Best regards
Wednesday,05,February,2020,13:22:24:05211
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUVPBFF2GA142540 License Plate:
Mileage: 52856km-32843mi Repair Order:
Chassis Type: FF-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 6C
75 8C BB BC C0 C6
VIN: WAUVPBFF2GA142540 Mileage: 52856km-32843miles
23-Brake Booster -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CXUA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 H HW: 04E 907 309 F
Component: R4 1.4l TFS H22 9258
Revision: X3H22---
Coding: 021D0012632401083000
Shop #: WSC 45358 001 1048576
ASAM Dataset: EV_ECM14TFS01104E906023H 006004
ROD: EV_ECM14TFS01104E906023BD.rod
VCID: 2502EA1A24F55D67F4-8070
17158 - Databus
Mileage: 52856 km
Date: 2018.09.19
Time: 00:16:53
Coolant temperature: 1 °C
Intake air temperature: 3 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 14.800 V
Acceleration: 0.000 m/sІ
Cruise Control System (CCS): status-Bits 0-7: 6
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 136
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 5
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:22
Intake air temperature: 2 °C
Voltage terminal 30: 14.840 V
Cruise Control System (CCS): status-Bits 0-7: 7
10260 - Vehicle Speed Sensor
P0502 00 [167] - Signal too Low
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:22
Voltage terminal 30: 14.780 V
Outside air temperature: 1 °C
Absolute intake pressure: 94 kPa abs
Engine torque: 0.0 Nm
Fuel level: 42.00 l
E-machine torque actual value: 0.0 Nm
Operating mode control expanded electrical driving: False result
Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
High-volt. battery: charge state: abs. value: 13.98 %
27723 - Coolant Pump for Intercooler
P16BA 00 [038] - Running Dry
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:26
Absolute intake pressure: 93 kPa abs
Fuel level: 42.00 l
U0428 00 [039] - -
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
Voltage terminal 30: 14.860 V
Fuel level: 42.00 l
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
[ABS brake control moduleRead out DTC]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:22
Fuel level: 42.00 l
Readiness: 1110 1101
Part No SW: 0DD 300 045 P HW: 0DD 927 770 B
Component: GSG DQ400E H31 1122
Revision: 00031033 Serial number: TFK01602130719
Shop #: WSC 46151 001 1048576
ROD: EV_TCMDQ400021_VW41.rod
VCID: 3424075E9F2F34EF73-8060
30097 - Transmission Fluid Pressure
P0867 00 [047] - Function Restriction due to Low Pressure
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:51
Engine speed: 6.25 /min
Engine torque: -100 Nm
Vehicle speed: 46 km/h
Control Module temperature: -39 °C
CURRENT pressure: -10.0 bar
Clutch: primary stat: New
selected gear: GANG_5
Driving position: N
Accelerator position: 0.4 %
DTC memory status: 12032
10856 - Transmission Fluid Pressure
P0867 00 [044] - Function Restriction due to Low Pressure
Mileage: 52856 km
Date: 2018.09.19
Time: 00:14:21
Vehicle speed: 48 km/h
Driving position: N
DTC memory status: 23808
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AK HW: 5Q0 907 379 H
Component: ESC H31 0809
Revision: 00000000 Serial number: 60636000000481
Coding: 12FF40923824326E017C020481C32948021C4C80408194F402A100588608
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001_AU37.rod
VCID: 05428A9A84357D6794-8050
11 Faults Found:
0072 - Rear Left Wheel Speed Sensor
C101C 01 [167] - Electrical Failure
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:24
0088 - Rear Right Wheel Speed Sensor
C101D 01 [167] - Electrical Failure
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:24
0297 - Steering angle sensor
B1168 16 [167] - Voltage Too Low
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
8309 - Engine Control Module Incorrectly Coded
P1612 00 [047] - -
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
16412 - Display for Tire Pressure Monitoring
C1146 02 [175] - Signal Failure
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
32830 - Parking Brake Motors
C10E1 29 [175] - Signal Implausible
[IPB-Actuator: Actuator state UNKNOWN]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:23
32900 - Left Parking Brake Motor Voltage Supply
C100D 13 [175] - Electrical Malfunction
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:23
32901 - Right Parking Brake Motor Voltage Supply
C100E 13 [175] - Electrical Malfunction
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:23
32948 - Comfort limitation
C10D7 00 [047] - -
[IPB-Miscellaneous: EEPROM data failure]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:24
32992 - Control Module for Electric Parking Brake
C10E2 F0 [175] - RPM Sensor Implausble Signal
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:23
32994 - Control Module for Electric Parking Brake
C10E2 F0 [047] - RPM Sensor Implausble Signal
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:23
Revision: 00021000 Serial number: 0395792573
Coding: 030C0C
VCID: 3A382966BD4BC29FA9-806E
Part No SW: 8V0 820 043 J HW: 8V0 820 043 J
Component: AC Automat H06 0510
Revision: 20012000 Serial number: 00000000873756
Coding: 0300001001000000000000000000140001000000
ASAM Dataset: EV_AirCondiFrontNARAU37X 001015
ROD: EV_AirCondiFrontNARAU37X.rod
VCID: 393A366AB84DC987A0-806C
Geber fьr Kдltemitteldruck/Kдltemitteltemperatur:
Subsystem 1 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G395 pT-Sens1 H61 0006
Subsystem 2 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: LM160673003807000200
Subsystem 3 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0003
Serial number: 59484618000000000001
Subsystem 4 - Part No SW: 12E 820 803 D HW: 12E 820 803 D
Component: J842 eKK H02 0004
Serial number: IADD00000K0000000081
27795 - Databus
U1123 00 [047] - Received Error Message
[Motorsteuergeraet_unplausible_Botschaft_MOTOR_31]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:27
Unlearning counter according OBD-OBD Parameter: 40
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 BK HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061606500120
Coding: 04151A46C25122F541CC5004531407A80800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 034694828A014357BA-8056
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160216 043 0580
Serial number: 160226062749
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 61453593
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Serial number: 09 12 2015 00001779
Serial number: 00000000000064967315
Sun Roof:
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000TL9H400000
Coding: 101F00
Revision: -------- Serial number: 39391606104722
Coding: 0010150011
VCID: 43C65482CA818357FA-8016
B10FC 13 [009] - Open Circuit
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:18:59
13637120 - Databus
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
13637409 - Databus
[Bremsensteuergerдt - ESP_10.ESP_WegimpulsHL - Fehlerspeicher auslesen]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
13637410 - Databus
[Bremsensteuergerдt - ESP_10.ESP_WegimpulsHR - Fehlerspeicher auslesen]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
13637426 - Databus
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Serial number: 003GCR04JDLT
Coding: 9DFCFCC0002000009000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47DE4092FEB9AF7726-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A01031650272
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A01031640075
Coding: 333135
Occupant Detection:
Serial number: 694000000000001GASYM
Coding: 303333
Subsystem 4 - Part No SW: ----------- HW: 480 001 211 15
Serial number: 357000000009F031F71N
Subsystem 5 - Part No SW: ----------- HW: 480 001 211 15
Serial number: 35800000000BF031F71Q
Subsystem 6 - Part No SW: ----------- HW: 480 400 703 16
Serial number: 3510002B71F93A03F1BB
Subsystem 7 - Part No SW: ----------- HW: 480 400 703 16
Serial number: 3520002B71F93A04F1EG
Subsystem 8 - Part No SW: ----------- HW: 480 401 902 16
Serial number: 3550002C11F35385514Z
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 902 16
Serial number: 3560002BB1F353856255
12 Faults Found:
9438225 - Igniter for Front passenger's Head Curtain Airbag
B1004 11 [137] - Short to Ground
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9441307 - Rear; passenger's side; side-airbag igniter
B1010 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [137] - Resistance Too High
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:36
U1101 00 [137] - Active
[ATP Inconsistency]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
1050117 - Databus
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Part No SW: 8V0 953 521 FB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 04031608490753
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 7F4E1872E6E927B7DE-802A
Part No SW: 8V0 920 972 G HW: 8V0 920 972 G
Component: KOMBI H03 6423
Coding: 0B640C192B80D7050203A8101B00000000000000
VCID: 42C85186D59B8A5FF1-8016
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 E HW: 5QE 907 530 A
Component: GW MQB EV 312 3245
Revision: -------- Serial number: 22021610801180
Coding: 0201001726F200005B00120C580000000001010100010000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 48DC43AEF3A7A00F2F-801C
Subsystem 1 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 23 02 2016 E0072002
197175 - Control unit for battery monitoring
U1050 00 [009] - No Communication
[BDM (LIN#1) Timeout]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Supply voltage: Terminal 30: 14.6 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [009] - Warning Triggered
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Terminal 15: On
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430010731
Coding: 03720100331A02030002050500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003_AU37.rod
VCID: 4FEE68B216C977376E-801A
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861230216154223
162560 - Implausible Data Received from ESP Control Module
U0416 00 [047] - -
[iBoVAG_Scl_EPB_01_EPB_Status_Error]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
239616 - Implausible Data Received from Engine Control Module
U0401 00 [047] - -
[iBoVAG_Scl_Motor_31_MO_Fahrzeugabstellzeit_Error]
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:26
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000042305006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
13637378 - Databus
[Errorvalue ESP_Wegimpulse]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:19
ELV State: 04
Information Clamps: 77 60
CoCo State: E0 01
WFS State: 17 06
Vehicle speed: 0.00 km/h
Voltage: 7F
AD-Value H-bridge: 3D
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 230116EAG02163
Coding: 001C1F204000048000000002
VCID: 41CA5E8AD09D9147E8-8014
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: C102
VCID: 44C4579ECF8F846FC3-8010
20228 - Databus
[ESP_19 Botschaft - SNA-Check]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Motor status: 00
Supply voltage: 14.50 V
Temperature: 12.0 °C
KFC: 4F
KFA: 00 04
Environmental conditions: 7F
uioUdNotFilt_xdu16: 14.48 V
uAdSensI_SwitchedKl30_xdu16: 14.48 V
16135 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Motor status: 00
KFC: 3F
KFA: 00 07
Environmental conditions: 5F
uioUdNotFilt_xdu16: 14.55 V
uAdSensI_SwitchedKl30_xdu16: 14.56 V
19716 - Databus
[ESP_10 Botschaft - SNA-Check]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Motor status: 00
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 14.67 V
uAdSensI_SwitchedKl30_xdu16: 14.68 V
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 D HW: 5G0 907 080 D
Component: VW370P3815010 H07 4492
Revision: 00H07000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080D 001018
ROD: EV_DMCM09550115G0907080D.rod
VCID: 281CE32E53E7400FCF-807C
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 090216EAU05709
Coding: 001C17204000048000000002
VCID: 40CC5B8EDB97984FE7-8014
Component: LWR-ECU 005 0080
Coding: 011A000101000000
VCID: 75A2FA5AD4D56DE784-8020
13705985 - Databus
[ESP_19: Fehlerwert im Signal ESP_HL_Radgeschw]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:19
13705987 - Databus
[ESP_19: Fehlerwert im Signal ESP_HR_Radgeschw]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:19
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 C HW: 8V0 035 844
Component: MU-S-S-US 014 0660
Serial number: A7A01002160846
Coding: 01730300FF0A000021220001001A00002F0001040100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9GY30GURG
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: ALJAL115011600040071
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
Voltage terminal 30: 14.7 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 302C0B4E6B3708CF17-8064
13705989 - Databus
[Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HL]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
passive
13705990 - Databus
[Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HR]
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
passive
9529428 - Steering angle sensor
Reset counter: 6
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:20
passive
Component: OCULowMQBUS 007 0568
Coding: 017393011094BA0100F800000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5Q0 915 182 C HW: 5Q0 915 182 C
Component: BECM H05 0753
Serial number: TA280034
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006037
ROD: EV_BECM09620115Q0915182.rod
VCID: 332604429A2133D76A-8066
Battery Junction Box:
Subsystem 1 - Part No SW: 5Q0 915 250 D HW: 5Q0 915 250 D
Component: BJB H27 0240
Subsystem 2 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0472
Serial number: V013C15C0230790
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0472
Serial number: V013C15C0230137
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0472
Serial number: V013C15C0230140
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0472
Serial number: V013C15C0230097
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0472
Serial number: V013C15C0230778
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0472
Serial number: V013C15C0230779
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0472
Serial number: V013C15C0230727
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0472
Serial number: V013C15C0230533
26635 - High Voltage System Interlock
P0A0A 00 [167] - Open Circuit
Mileage: 52856 km
Date: 2018.09.19
Time: 00:09:21
Pack Voltage: 335.4 V
Pack Current: -0.00 A
Isolation Resistance: 5080 kOhm
Maxumum charge current limit: 0 A
Maximum discharge current limit: 0.0 A
Contactor Voltage: 22 V
OBD unlearned counter: 40
Crash status: 00
Pilot Line Status: 00
Fuse Status: 00
(Minus) Contactor Status: 00
(Plus) Contactor Status: 00
Terminal 15 status: 01
Max Cell Temperature: 3 °C
Min Cell Temperature: 2 °C
Air inlet temperature: 3 °C
Air outlet temperature: 2 °C
LV Battery Voltage: 14.6 V
Min.cell voltage: 3.489 V
Max.cell Voltage: 3.495 V
Max.cell SOC: 15 %
Min.cell SOC: 14 %
Hybrid Battery Pack Remaining Life: 13.7 %
Max Charge Pack Current(10s duration): 0 A
Max Discharge Pack Current(10s duration): 0.0 A
Max Pack Voltage(10s duration): 334 V
Min Pack Voltage(10s duration): 334 V
Max.cell Voltage(10s duration): 3.496 V
Min.cell Voltage(10s duration): 3.488 V
Accelerator Pedal Position D: 14.5 %
Calculated LOAD Value: 0.0 %
Engine coolant temperature: 1 °C
Engine RPM: 0.00 /min
Vehicle Speed Sensor: 0 km/h
Ambient Air Temperature: 215 °C
Hybrid Battery Pack Remaining Life: 13.73 %
control module system voltage: 14.623 V
absolute load: 0.0 %
Time After Engine Start: 0 s
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 100216BB905015
Coding: 000C17204000048000000002
Component: TSG HBFS 020 0041
Serial number: 100216BB905018
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 L HW: 5QE 035 335 B
Component: E_SOUND_SG H08 0211
Serial number: EN160705000000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 006013
ROD: EV_ENoiseS1NNVW3707_006.rod
VCID: 4AD879A6EDAB521F39-801E
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AB HW: 5QE 915 682 AB
Component: OBC KOSTAL H61 3012
Revision: -------- Serial number: 1002160B5000RD
Coding: 105168003000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
VCID: 0D52B2BADC450527DC-8058
End----------(Elapsed Time: 02:07, VBatt start/end: 14.7V/14.7V)-----------
