Audi a3 e-tron from usa can't crank
stammba
Sofia, Bulgaria
C?ID=30121
Grettings i have and issue with a car new for me audi a3 e-tron never had an e-tron before in my workshop so every information is valuable here is an autosacan from the car i dont know from where should i start the biggest problem is that the car don't want to crank the car had and accident it is crashed in the passenger door
Best regards
Wednesday,05,February,2020,13:22:24:05211
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUVPBFF2GA142540   License Plate:
Mileage: 52856km-32843mi   Repair Order:
Chassis Type: FF-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 6C
          75 8C BB BC C0 C6
VIN: WAUVPBFF2GA142540   Mileage: 52856km-32843miles
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CXUA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 H    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 9258
   Revision: X3H22---
   Coding: 021D0012632401083000
   Shop #: WSC 45358 001 1048576
   ASAM Dataset: EV_ECM14TFS01104E906023H 006004
   ROD: EV_ECM14TFS01104E906023BD.rod
   VCID: 2502EA1A24F55D67F4-8070
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:16:53
                    Engine speed: 0.00 /min
                    Coolant temperature: 1 °C
                    Intake air temperature: 3 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 14.800 V
                    Acceleration: 0.000 m/sІ
                    Cruise Control System (CCS): status-Bits 0-7: 6
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 136
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:22
                    Intake air temperature: 2 °C
                    Voltage terminal 30: 14.840 V
                    Cruise Control System (CCS): status-Bits 0-7: 7
10260 - Vehicle Speed Sensor
          P0502 00 [167] - Signal too Low
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:22
                    Voltage terminal 30: 14.780 V
                    Outside air temperature: 1 °C
                    Absolute intake pressure: 94 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 42.00 l
                    E-machine torque actual value: 0.0 Nm
                    Operating mode control expanded electrical driving: False result
                    Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
                    High-volt. battery: charge state: abs. value: 13.98 %
27723 - Coolant Pump for Intercooler
          P16BA 00 [038] - Running Dry
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:26
                    Absolute intake pressure: 93 kPa abs
                    Fuel level: 42.00 l
          U0428 00 [039] - -
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
                    Voltage terminal 30: 14.860 V
                    Fuel level: 42.00 l
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:22
                    Fuel level: 42.00 l
Readiness: 1110 1101
   Part No SW: 0DD 300 045 P    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1122
   Revision: 00031033    Serial number: TFK01602130719
   Shop #: WSC 46151 001 1048576
   ROD: EV_TCMDQ400021_VW41.rod
   VCID: 3424075E9F2F34EF73-8060
30097 - Transmission Fluid Pressure
          P0867 00 [047] - Function Restriction due to Low Pressure
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:51
                    Engine speed: 6.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 46 km/h
                    Control Module temperature: -39 °C
                    CURRENT pressure: -10.0 bar
                    Clutch: primary stat: New
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 12032
10856 - Transmission Fluid Pressure
          P0867 00 [044] - Function Restriction due to Low Pressure
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:14:21
                    Vehicle speed: 48 km/h
                    Driving position: N
                    DTC memory status: 23808
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
   Component: ESC           H31 0809
   Revision: 00000000    Serial number: 60636000000481
   Coding: 12FF40923824326E017C020481C32948021C4C80408194F402A100588608
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001_AU37.rod
   VCID: 05428A9A84357D6794-8050
11 Faults Found:
0072 - Rear Left Wheel Speed Sensor
          C101C 01 [167] - Electrical Failure
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:24
0088 - Rear Right Wheel Speed Sensor
          C101D 01 [167] - Electrical Failure
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:24
0297 - Steering angle sensor
          B1168 16 [167] - Voltage Too Low
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [047] - -
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
16412 - Display for Tire Pressure Monitoring
          C1146 02 [175] - Signal Failure
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
32830 - Parking Brake Motors
          C10E1 29 [175] - Signal Implausible
          [IPB-Actuator: Actuator state UNKNOWN]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:23
32900 - Left Parking Brake Motor Voltage Supply
          C100D 13 [175] - Electrical Malfunction
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:23
32901 - Right Parking Brake Motor Voltage Supply
          C100E 13 [175] - Electrical Malfunction
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:23
32948 - Comfort limitation
          C10D7 00 [047] - -
          [IPB-Miscellaneous: EEPROM data failure]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:24
32992 - Control Module for Electric Parking Brake
          C10E2 F0 [175] - RPM Sensor Implausble Signal
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:23
32994 - Control Module for Electric Parking Brake
          C10E2 F0 [047] - RPM Sensor Implausble Signal
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:23
   Revision: 00021000    Serial number: 0395792573
   Coding: 030C0C
   VCID: 3A382966BD4BC29FA9-806E
   Part No SW: 8V0 820 043 J    HW: 8V0 820 043 J
   Component: AC Automat    H06 0510
   Revision: 20012000    Serial number: 00000000873756
   Coding: 0300001001000000000000000000140001000000
   ASAM Dataset: EV_AirCondiFrontNARAU37X 001015
   ROD: EV_AirCondiFrontNARAU37X.rod
   VCID: 393A366AB84DC987A0-806C
   Geber fьr Kдltemitteldruck/Kдltemitteltemperatur:
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number: LM160673003807000200
   Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 59484618000000000001
   Air Conditioning Compressor Sub:
   Subsystem 4 - Part No SW: 12E 820 803 D    HW: 12E 820 803 D
   Component: J842 eKK  H02 0004
   Serial number: IADD00000K0000000081
27795 - Databus
          U1123 00 [047] - Received Error Message
          [Motorsteuergeraet_unplausible_Botschaft_MOTOR_31]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:27
                    Unlearning counter according OBD-OBD Parameter: 40
   Part No SW: 5Q0 937 085 BK    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061606500120
   Coding: 04151A46C25122F541CC5004531407A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 034694828A014357BA-8056
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160216  043 0580
   Serial number:         160226062749
   Coding: 0A47F7
   Serial number: 61453593
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 09 12 2015  00001779
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064967315
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000TL9H400000
   Coding: 101F00
   Revision: --------    Serial number: 39391606104722
   Coding: 0010150011
   VCID: 43C65482CA818357FA-8016
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:18:59
13637120 - Databus
          [Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
13637409 - Databus
          [Bremsensteuergerдt - ESP_10.ESP_WegimpulsHL - Fehlerspeicher auslesen]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
13637410 - Databus
          [Bremsensteuergerдt - ESP_10.ESP_WegimpulsHR - Fehlerspeicher auslesen]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
13637426 - Databus
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
   Serial number: 003GCR04JDLT
   Coding: 9DFCFCC0002000009000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47DE4092FEB9AF7726-8012
   Belt Pretensioner left:
   Serial number: 34230167A01031650272
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A01031640075
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001GASYM
   Coding: 303333
   Subsystem 4 - Part No SW: -----------    HW: 480 001 211 15
   Serial number: 357000000009F031F71N
   Subsystem 5 - Part No SW: -----------    HW: 480 001 211 15
   Serial number: 35800000000BF031F71Q
   Subsystem 6 - Part No SW: -----------    HW: 480 400 703 16
   Serial number: 3510002B71F93A03F1BB
   Subsystem 7 - Part No SW: -----------    HW: 480 400 703 16
   Serial number: 3520002B71F93A04F1EG
   Subsystem 8 - Part No SW: -----------    HW: 480 401 902 16
   Serial number: 3550002C11F35385514Z
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 902 16
   Serial number: 3560002BB1F353856255
12 Faults Found:
9438225 - Igniter for Front passenger's Head Curtain Airbag
          B1004 11 [137] - Short to Ground
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
          B1006 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
9441307 - Rear; passenger's side; side-airbag igniter
          B1010 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [137] - Resistance Too High
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:36
15360768 - Component Protection
          U1101 00 [137] - Active
          [ATP Inconsistency]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
   Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 04031608490753
   Coding: A418
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 7F4E1872E6E927B7DE-802A
   Part No SW: 8V0 920 972 G    HW: 8V0 920 972 G
   Component: KOMBI         H03 6423
   Coding: 0B640C192B80D7050203A8101B00000000000000
   VCID: 42C85186D59B8A5FF1-8016
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3245
   Revision: --------    Serial number: 22021610801180
   Coding: 0201001726F200005B00120C580000000001010100010000000000000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 48DC43AEF3A7A00F2F-801C
   Subsystem 1 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 23 02 2016  E0072002
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    Supply voltage: Terminal 30: 14.6 V
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [009] - Warning Triggered
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    Terminal 15: On
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
   Component: EBKV          H14 0182
   Serial number:   085430010731
   Coding: 03720100331A02030002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
   ROD: EV_BrakeBoostBoschMQBOMG_003_AU37.rod
   VCID: 4FEE68B216C977376E-801A
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861230216154223
162560 - Implausible Data Received from ESP Control Module
          U0416 00 [047] - -
          [iBoVAG_Scl_EPB_01_EPB_Status_Error]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
239616 - Implausible Data Received from Engine Control Module
          U0401 00 [047] - -
          [iBoVAG_Scl_Motor_31_MO_Fahrzeugabstellzeit_Error]
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:26
   Revision: 00000000    Serial number: 16000042305006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:19
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 7F
                    AD-Value H-bridge: 3D
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 230116EAG02163
   Coding: 001C1F204000048000000002
   VCID: 41CA5E8AD09D9147E8-8014
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: C102
   VCID: 44C4579ECF8F846FC3-8010
20228 - Databus
          [ESP_19 Botschaft - SNA-Check]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    Motor status: 00
                    Supply voltage: 14.50 V
                    Temperature: 12.0 °C
                    KFC: 4F
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 14.48 V
                    uAdSensI_SwitchedKl30_xdu16: 14.48 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
16135 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    Motor status: 00
                    KFC: 3F
                    KFA: 00 07
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 14.55 V
                    uAdSensI_SwitchedKl30_xdu16: 14.56 V
19716 - Databus
          [ESP_10 Botschaft - SNA-Check]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    Motor status: 00
                    KFC: 4D
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 14.67 V
                    uAdSensI_SwitchedKl30_xdu16: 14.68 V
   Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
   Component: VW370P3815010 H07 4492
   Revision: 00H07000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM09550115G0907080D 001018
   ROD: EV_DMCM09550115G0907080D.rod
   VCID: 281CE32E53E7400FCF-807C
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 090216EAU05709
   Coding: 001C17204000048000000002
   VCID: 40CC5B8EDB97984FE7-8014
   Coding: 011A000101000000
   VCID: 75A2FA5AD4D56DE784-8020
13705985 - Databus
          [ESP_19: Fehlerwert im Signal ESP_HL_Radgeschw]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:19
13705987 - Databus
          [ESP_19: Fehlerwert im Signal ESP_HR_Radgeschw]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:19
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     014 0660
   Serial number: A7A01002160846
   Coding: 01730300FF0A000021220001001A00002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9GY30GURG
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: ALJAL115011600040071
          B11CF 53 [009] - Deactivated
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    Voltage terminal 30: 14.7 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 302C0B4E6B3708CF17-8064
13705989 - Databus
          [Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HL]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    passive
13705990 - Databus
          [Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HR]
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    passive
9529428 - Steering angle sensor
                    Reset counter: 6
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:20
                    passive
   Component: OCULowMQBUS   007 0568
   Coding: 017393011094BA0100F800000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
   Component: BECM          H05 0753
   Serial number: TA280034
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006037
   ROD: EV_BECM09620115Q0915182.rod
   VCID: 332604429A2133D76A-8066
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
   Component: BJB  H27 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0472
   Serial number: V013C15C0230790
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0472
   Serial number: V013C15C0230137
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0472
   Serial number: V013C15C0230140
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0472
   Serial number: V013C15C0230097
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0472
   Serial number: V013C15C0230778
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0472
   Serial number: V013C15C0230779
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0472
   Serial number: V013C15C0230727
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0472
   Serial number: V013C15C0230533
26635 - High Voltage System Interlock
          P0A0A 00 [167] - Open Circuit
                    Mileage: 52856 km
                    Date: 2018.09.19
                    Time: 00:09:21
                    Pack Voltage: 335.4 V
                    Pack Current: -0.00 A
                    Isolation Resistance: 5080 kOhm
                    Maxumum charge current limit: 0 A
                    Maximum discharge current limit: 0.0 A
                    Contactor Voltage: 22 V
                    OBD unlearned counter: 40
                    Crash status: 00
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 00
                    (Plus) Contactor Status: 00
                    Terminal 15 status: 01
                    Max Cell Temperature: 3 °C
                    Min Cell Temperature: 2 °C
                    Air inlet temperature: 3 °C
                    Air outlet temperature: 2 °C
                    LV Battery Voltage: 14.6 V
                    Min.cell voltage: 3.489 V
                    Max.cell Voltage: 3.495 V
                    Max.cell SOC: 15 %
                    Min.cell SOC: 14 %
                    Hybrid Battery Pack Remaining Life: 13.7 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0.0 A
                    Max Pack Voltage(10s duration): 334 V
                    Min Pack Voltage(10s duration): 334 V
                    Max.cell Voltage(10s duration): 3.496 V
                    Min.cell Voltage(10s duration): 3.488 V
                    Accelerator Pedal Position D: 14.5 %
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 1 °C
                    Engine RPM: 0.00 /min
                    Vehicle Speed Sensor: 0 km/h
                    Ambient Air Temperature: 215 °C
                    Hybrid Battery Pack Remaining Life: 13.73 %
                    control module system voltage: 14.623 V
                    absolute load: 0.0 %
                    Time After Engine Start: 0 s
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 100216BB905015
   Coding: 000C17204000048000000002
   Serial number: 100216BB905018
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 L    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H08 0211
   Serial number: EN160705000000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 006013
   ROD: EV_ENoiseS1NNVW3707_006.rod
   VCID: 4AD879A6EDAB521F39-801E
   Part No SW: 5QE 915 682 AB    HW: 5QE 915 682 AB
   Component: OBC KOSTAL    H61 3012
   Revision: --------    Serial number: 1002160B5000RD
   Coding: 105168003000
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
   ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
   VCID: 0D52B2BADC450527DC-8058
End----------(Elapsed Time: 02:07, VBatt start/end: 14.7V/14.7V)-----------
   Coding: 00000000
I believe that's the 12V control circuit that has the disconnect plug in the engine bay. This will definitely prevent the car from cranking.
Andy
Sector 7G
HC424490
Here's some pix showing the disconnector in my 2018 A3 e-tron:
FYI, just in case there is confusion about normal operation of the A3 e-tron, the gas engine won't normally start up when the vehicle isn't moving.
morski
Cheshire UK
C?ID=90186
You can get the engine to start... Once you have have the power gauge on left showing ready press the accelerator to the floor and the engine will start. but as Uwe has stated the battery disconnect needs to be enabled. Also check the fuse box behind the glovebox as there is a particular one that has a sticker on it that is usually disconnected as well.
pauls13
C?ID=172848
Can someone tell me what the part number or the official name of the disconnector is?
Andy
Sector 7G
HC424490
pauls13
C?ID=172848
From the writing on the green part:
"Drive Motor Inverter Connector"
You are my hero, VW won't sell me the part unless they see the car nor will they tell me the part number even though I work in the trade??
