VW TRANSPORTER 2008 T5 2.5TDI
Gapel3
Australia
C?ID=313356
HI HERE.
GOT PROBLEM WITH MY VAN
FITTED NEW INJECTOR ON CYL 1. STARTS GOOD RUNS FINE ....VAG READING AFTER WORM UP INJECTOR ON CYL 1 GOES from -0.05 to 2.99M/G maximum reading.
...NO POWER NO REV ABOVE 3K RPM...USELESS TO DRIVE ....TURBO BOOST OK...STILL ACCEPTABLE.
NO OVER BOOST OR UNDER BOOST FAULT CODES,NO FUEL PRESSURE OR INJECTORS FAULT.
THANK YOU PLEASE HELP
South Molton, UK
1. Please turn off the CAPS LOCK, it looks like you are shouting!
2. Please post a full unedited VCDS Auto-Scan so that we can see how your T5 is equipped and put your problems in context.
Gapel3
Australia
C?ID=313356
Thursday,13,February,2020,09:09:43:39620
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WV1ZZZ7HZ8H047706   License Plate:
Mileage: 284190km-176587mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H047706   Mileage: 284190km-176587miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DQ    HW: 070 906 016 DQ
   Component: R5 2,5L EDC G000SG  1583
   Revision: --H05---    Serial number: VWZ7Z0G5746272
   Coding: 0051172
   Shop #: WSC 02736 790 00000
   VCID: E288F0DD3CD5F55F51-513C
004420 - Mass Air Flow Sensor (G70)
               P1144 - 000 - Open or Short to Ground - MIL ON
                    Fault Status: 11110000
                    Mileage: 284195 km
                    Duty Cycle: 100.6 %
                    Bin. Bits: 00101100
                    Mass Air / Rev.: 985.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
000260 - Mass Air Flow Sensor (G70)
               P0104 - 000 - Intermittent - MIL ON
                    Fault Status: 11100000
                    Mileage: 284195 km
                    Duty Cycle: 100.6 %
                    Bin. Bits: 00101100
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
   Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
   Component: ESP MK25E1          0104
   Revision: 00H31001
   Coding: 0001634
   VCID: C4C4164586019B6F43-5118
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 R
   Component: CLIMA/AC            0202
   VCID: B4244685D6A12BEFF3-5118
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000101
   VCID: F4A4868596216BEF33-5118
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
   Part No: 1C0 909 605 F
   Component: 0T AIRBAG VW61 0R   0004
   Coding: 12372
   Shop #: WSC 02736
   VCID: A71EA1C94777507746-5118
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 851 R
   Coding: 00722
   Shop #: WSC 00001
   VCID: BA3868BDA4C5DD9F29-5118
   WV1ZZZ7HZ8H047706     VWZ7Z0G5746272
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 02736
   VCID: F0AC8A95B23957CFD7-5118
   Part No: 7H0 907 554 F
   Component: HALDEX 4Motion      2110
   Coding: 0000002
   VCID: B3264599D3AF2CD7EA-5118
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00031
   Shop #: WSC 02736
   VCID: B228409D7CB525DFE1-4B00
Address 76: Park Assist        Labels: 7H0-919-283.lbl
   Part No: 7H0 919 283
   Component: Parkingsyst. T5 T5N 401
   Coding: 00137
   Shop #: WSC 02736
   VCID: EFAE89E9AF074837CE-513C
01545 - Sensor for Parking Aid; Rear Left (G203)
            37-00 - Faulty
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            37-00 - Faulty
End----------(Elapsed Time: 05:56, VBatt start/end: 12.3V/12.2V)-----------
I would start by fixing whatever is causing the MAF fault.
Gapel3
Australia
C?ID=313356
ignore MAF fault....been disconnected while scanning already....its not fault present when all back together ...sorry not to mentioned before
