2006 A6 Q 3.2 BKH Transmission Replacement
rprellidzynr
Carmel, IN, USA
C?ID=339591
I got this A6 with a bad transmission. The transmission replacement is complete. I understand I need to code the new transmission to the existing controller.
Please find scan attached:
Wednesday,05,February,2020,21:41:48:28853
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUDG74F76N033087   License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUDG74F76N033087   Mileage: 270040km-167795miles
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0040
   Revision: --H15---    Serial number:
   Coding: 01050106190F0120
   Shop #: WSC 98765 666 36249
   VCID: 2E05F2144C104E276BB-807A
000821 - Crankshaft Position Sensor (G28)
               P0335 - 006 - Malfunction - Intermittent
                    Mileage: 270040 km
                    Date: 2005.02.07
                    Time: 15:52:09
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 9.0°C
                        Engine Off
                    Bin. Bits: 00000001
               P1653 - 008 -
                    Mileage: 270040 km
                    Date: 2005.02.07
                    Time: 15:52:17
                    RPM: 1440 /min
                    Mass Air / Rev.: 218.0 mg/str
                    Temperature: 10.5°C
                        Idle
                    Load: 21.6 %
Readiness: 0110 0101
   Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0030
   Revision: --H01---    Serial number:        4065592
   Coding: 0000002
   Shop #: WSC 02331 785 00200
   VCID: 313FE9685D2E51DF769-8064
005889 - Transmission Control Unit
               P1701 - 000 - Locked
                    Mileage: 270040 km
                    Date: 2005.02.02
                    Time: 23:12:58
                    (no units): 30.0
                    (no units): 21.0
                    Temperature: 12.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0020895
   Shop #: WSC 02327 785 00200
   VCID: 2D07F5184116353F521-8078
                    Fault Frequency: 13
                    Reset counter: 128
                    Mileage: 270040 km
                    Date: 2005.02.02
                    Time: 23:13:05
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0196
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0180
   Revision: 30070501    Serial number: 10600300182362
   Coding: 0000015
   Shop #: WSC 44401 000 1048576
   VCID: 639353205752B34FB45-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0080
   Component: FBSAUDIC6 KSG   H26 0080
   Component: FBSAUDIC6 IDG   H01 0053
7 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
            006 - Short to Plus - Intermittent
                    Fault Status: 00110110
                    Reset counter: 64
                    Mileage: 251317 km
                    Date: 2017.08.02
                    Time: 19:39:02
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01110010
                    Fault Frequency: 30
                    Reset counter: 107
                    Mileage: 265241 km
                    Date: 2018.06.13
                    Time: 09:08:56
                    Reset counter: 168
                    Mileage: 270040 km
                    Date: 2018.10.19
                    Time: 10:58:14
                    Fault Frequency: 11
                    Reset counter: 168
                    Mileage: 270040 km
                    Date: 2018.10.19
                    Time: 10:56:38
                    Fault Status: 00100001
                    Reset counter: 168
                    Mileage: 270040 km
                    Date: 2005.02.01
                    Time: 12:04:47
                    Fault Frequency: 11
                    Reset counter: 168
                    Mileage: 270040 km
                    Date: 2005.02.01
                    Time: 12:00:01
02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
                    Reset counter: 128
                    Mileage: 270040 km
                    Date: 2005.02.01
                    Time: 18:12:42
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 303FH057501249
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000174635
   Subsystem 3 - Serial number: 0107.06.050000000100011081ÿ
   Subsystem 4 - Serial number: 011081ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000000151665
   Coding: 0524326
   VCID: 5BE36BC06F228B8FFC5-800E
00739 - Coolant Circulation Pump (V50)
                    Fault Frequency: 15
                    Reset counter: 168
                    Mileage: 270040 km
                    Date: 2005.02.02
                    Time: 22:52:37
                    Temperature: 31.0°C
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   VCID: 66954A34A460C66753B-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Subsystem 3 - Part No: 4F0 910 279
   Subsystem 4 - Part No: 4F1 910 113
   Subsystem 5 - Part No: 4E0 910 557
No Faults Found
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7182428
   VCID: 1C6128DC2AACCCB735F-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E3011089
   VCID: 2809040C6EF41017A17-807C
16344 - Control Module - RAM Error
                    Fault Status: 00101110
                    Reset counter: 168
                    Mileage: 258911 km
                    Date: 2018.03.15
                    Time: 17:19:27
                    Reset counter: 128
                    Mileage: 270040 km
                    Date: 2005.02.02
                    Time: 23:13:14
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 10H29000    Serial number: 00359D08CWPL
   Coding: 0013878
   Shop #: WSC 02136 444 53368
   VCID: 2A0DFE0470F82207B73-807E
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME0A3F4B206
   Subsystem 3 - Serial number: 6342CSME0A4A7978H
   Subsystem 4 - Serial number: 6352QSME02221B713
   Subsystem 5 - Serial number: 6362QSME051941637
   Subsystem 6 - Serial number: 63734SME02013A59V
   Subsystem 7 - Serial number: 63834SME0214240DS
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026051520382
   Coding: 0002041
   Shop #: WSC 02323 785 00200
   Component: Lenkradmodul    H07 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H15 0630
   Revision: 01000000    Serial number: 4PY31ZY55
   Coding: 2129263
   Shop #: WSC 05300 758 69175
   VCID: 211F19280DCEE15FE69-8074
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 12008055298123
   Coding: ECFE73CD1B7904
   Shop #: WSC 02325 785 00200
   VCID: 270B073063EA1F6FA8D-8072
                    Reset counter: 128
                    Mileage: 270040 km
                    Date: 2005.02.02
                    Time: 23:01:55
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 619F59284D4EA15FA69-8034
   Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
   Component: MNS US          H44 0740
   Revision: 00000000    Serial number: 355FP057548041
   VCID: 3829D44CBE548097317-806C
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00-00000
   Coding: 0051947
   VCID: 290F010875FE291FBE9-807C
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01008329410000
   Coding: 4618301
                    Reset counter: 128
                    Mileage: 133920 km
                    Date: 2013.09.24
                    Time: 15:47:46
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000788720
   Coding: 0000026
   VCID: 25170D3819E60D7F9A1-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000002567
   Coding: 0002114
   VCID: 5EE562D47C309EA79BB-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00-00000
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DE765D8713685BF821-8008
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000016
   VCID: 26150A3464E0066793B-8072
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
02071 - Local Databus
                    Mileage: 270040 km
                    Date: 2005.02.02
                    Time: 23:13:51
02627 - Dynamic Cornering Light Motor; Left (V318)
                    Fault Status: 11101010
                    Mileage: 270040 km
                    Date: 2005.02.05
                    Time: 21:56:25
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 394F/057556693
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000048807
   Shop #: WSC 02136 444 53427
   VCID: 2313132017D2F34FF45-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  1506051281
   Coding: 344630393135313035432056413031353036303531323831
   Shop #: WSC 00000 384 00290
02256 - Quiescent Current
                    Reset counter: 168
                    Mileage: 270040 km
                    Date: 2005.02.06
                    Time: 04:55:44
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0051754
   VCID: 698F4108B57EE91F7E9-803C
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000900006860
   Coding: 0062221
   VCID: 60995C2C4644A857A97-8034
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000506130141
   Shop #: WSC 12336 024 394758
   VCID: 3431E07CA23C64F71DF-8060
                    Fault Status: 00110100
                    Reset counter: 168
                    Mileage: 270040 km
                    Date: 2005.02.05
                    Time: 22:40:35
                    Reset counter: 128
                    Mileage: 270040 km
                    Date: 2005.02.02
                    Time: 23:14:19
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0051754
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0020
   Revision: 00H09000    Serial number: 11720515003701
   Coding: 0001206
02070 - Rear Parking Aid Sensors
                    Reset counter: 128
                    Mileage: 270040 km
                    Date: 2005.02.05
                    Time: 22:33:49
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H11 1130
   Revision: 00000000    Serial number: 00000007501782
   Coding: 0010900
End----------(Elapsed Time: 05:00, VBatt start/end: 12.1V/12.1V)-----------
NostraJackAss
Did you know you can swap controller or see dealer for SVM permitted the Transmission is correct for application?
rprellidzynr
Carmel, IN, USA
C?ID=339591
Jack, I have an inside guy at the local dealer, another DIYer. I can get info through him from Audi. The replacement transmission came from Brickyard Imports....they are a used parts yard, so not a VAG specialist repair shop, but are the European specialists in Indiana. They provided the replacement trans based on the Audi trans code from the factory trunk label. I expect I have no way to lay hands on the donor TCM or any codes from that car. Rob
rprellidzynr
Carmel, IN, USA
C?ID=339591
And are you saying I need those for my car or from the donor car?
005889 - Transmission Control Unit - Locked
This is effectively a "Component Protection" fault. The only proper way to fix that is via on-line access to Audi's servers.
rprellidzynr
Carmel, IN, USA
C?ID=339591
Uwe, so is this something done by me or Audi dealer only? Rob
Audi dealer or independent with ODIS software who has jumped through all the hoops to get access to Audi's servers.
rprellidzynr
Carmel, IN, USA
C?ID=339591
Jack, go easy, cowboy, I'm only asking because I don't know. The dumber my question sounds to you, the expert, only indicates how far off I am in my understanding of the subject matter. Ask me about how to win LeMans or Indy and I'll be kind in my answer and offer you my experience and knowledge. You are by far the more experienced and knowledgeable person on coding Audi modules. All I'm asking for is help. Rob
rprellidzynr
Carmel, IN, USA
C?ID=339591
Uwe, thank you, I will pursue a solution that way. I appreciate your kind and direct answer. Best, Rob
NostraJackAss
No question is dumb unless it's from shear laziness........ :rolleyes:
rprellidzynr
Carmel, IN, USA
C?ID=339591
Classy. I ask for help and you first are a smart mouth and now resort to name calling. Uwe, it's your name on this business, you really should consider that you are helpful and direct, but Jack should change the middle two letters in his name to 'er'. He is not a good representative for Ross Tech. Other forum users just like me read these posts.
NostraJackAss
I never called you a name and my questions were valid, if you have a guy inside a dealer and you are aware of partslink24 why would you ask if a parts catalogue is a repair manual?
I think you forget to realize that the forum is free and not a substitute for the RTFB or PAID tech support from RT directly.
rprellidzynr
Carmel, IN, USA
C?ID=339591
1. You implied I was lazy. Don't think so highly of yourself that you can be like that and not be called out for it. And if you know me, you'd know you're a mile off.
2. You did not ask any valid question. When I was looking for direction to research VSS and the other acronym you offered up, I went to the link you provided but found nothing there to help. When I asked more questions to dig deeper, you came back with "Did I say that?". That is how a petulant child would respond, not a mature adult. I don't mind one bit doing my own research, and you are here, I believe, to help. "Did I say that?" is immature, petty, and not up to the standards of civilized people.
I'm not assuming or forgetting anything. I'm asking questions on a forum that Ross Tech provides for EXACTLY that reason. If you're having a bad day, I'm sorry for you and hope tomorrow is better. If you're tired of answering questions and helping people, then you clearly should not be moderating a help forum.
Your actions have now taken the focus of this forum from problem solving to bickering about me asking questions and you acting like a child, a bully, or whatever it is you believe you are.
Take a page from Uwe's book. He quickly got to Component Protection and I'll look into that as a solution.
Solutions, Jack, not smart mouth, petty replies is what all users here want. Raise your standards if not for me, then for yourself.
NostraJackAss
Do you maybe think you misunderstood my questions or are reading to deep into things and seeking to be argumentative?
Did you know you could always set me to ignore?
I'm sorry you think these things, but why such hot heads reside in Indiana?
Did you know questions are not statements or instruction and are done this way to prevent someone from implying a liability, name calling & if they choose on their own to do as they wish while hurting one self?
It is with regard to protect you and me or other forum readers why I point them to the RTFB & to derive their own answers not step by step instructions to possibly be misinterpreted, see my point?
Seriously, you are an Engineer & with formal F1 experience but refrain from having the RTFB and than trying to bully answers in a forum by accusing someone of being a wise ass when you were given the questions to answer your own self evident questions, really?
For the record I'm a self declared asshole!
Just to avoid any potential confusion: Jack is not a "representative" for Ross-Tech. He is a customer of ours, and spends a great deal of his own time on this forum trying to help people, but he does have a rather unique bedside manner, which some people can't abide. If you do not wish to interact with him, there is a simple solution; click on the avatar to the left of one of his posts and then:
rprellidzynr
Carmel, IN, USA
C?ID=339591
Jack has been a total waste of time for me. His self description may be accurate but it is not funny or cute. People come here for help. Either help or remain silent. Uwe, thank you for your help.
NostraJackAss
My self described definement is a badge of honor, oh is indeed correct. :p
Specialty asshole aka NostraJackASS!
I'd still like to know how or WTF is going through your head as an alleged professional engineer & not using the RTFB but you feel you have the need to announce you have access to an insider at dealer to get information and when asked why you haven't checked X you get defensive?
How is that using good engineering judgement?
Must be global warming and lead water contamination in Indiana, huh?
