15 reg evertime i start car active cruise control fault comes up on display. car was working fine, just came up with this fault. scan attached if someone could help with this fault please.
Monday,03,February,2020,15:00:37:28694
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Dealer/Shop Name: autoelec
VIN: WVWZZZAUZFW276781 License Plate: PN15OXD
Mileage: 61632km-38296mi Repair Order: VW GOLF
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZFW276781 Mileage: 61632km-38296miles
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 E HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 091900322446050B2004
ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
ROD: EV_ECM20TFS0205G0906259E.rod
VCID: 303917AF5AA452E7797-8064
15472 - Engine Coolant Level Sensor/Switch
P2556 00 [175] - Electrical Malfunction
Mileage: 61632 km
Date: 2020.02.03
Time: 13:14:38
Engine speed: 0.00 /min
Coolant temperature: 52 °C
Intake air temperature: 37 °C
Voltage terminal 30: 11.933 V
Engine: operating status: ES
Engine temp. management actuator: raw value: 0
Engine temperature management actuator: stop open: 137
Engine temperature management actuator: after-run stop: 3957
RVC_SP: 19.00 °
RVC_AV: 0.00 °
RVCPWM: -100.000 %
17186 - Databus
Mileage: 61632 km
Date: 2020.02.03
Time: 14:48:19
Coolant temperature: 49 °C
Intake air temperature: 38 °C
Voltage terminal 30: 12.480 V
ACC variants (coding): ACC
CCS Switch: ACC operating unit
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: operated
Cruise control switch actuation-Large increment: not activated
ACC variants: ACC
17920 - Cruise Control Switch (E45)
P0568 00 [101] - Implausible Signal
Mileage: 61632 km
Date: 2020.02.03
Time: 14:48:19
ACC variants: ACC
18876 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Mileage: 61632 km
Date: 2020.02.03
Time: 14:48:18
ACC variants: ACC
19853 - Implausible Data Received from Steering Column Control Module
U0429 00 [032] - -
Mileage: 61632 km
Date: 2020.02.03
Time: 14:48:20
ECU_STATE: ENG_STOP
Engine oil temperature: 57.0 °C
Time since engine start: 0.0 s
T_ES: 34 min
STATE_ERR_ABC_PRED: 18
Readiness: 1010 0001
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 60495000000875
Coding: 01FA93A154272972077E070841C46980C92A94E0E08296F714405078C008
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7EA5F997D0707497BBB-802A
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120004200100011005000000101000
VCID: 6A8DC5C7BCF8E837773-803E
Air quality sensor:
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011505100955
Coding: 03000A46C24122F30BA44080B11C07281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 0059876FAA840267C97-8054
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150205 042 0551
Serial number: 150211134413
Component: RLHS 037 0059
Serial number: S5Y15M02D24H17M05S16
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150282VTH
Serial number: 00000000000061704411
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391505004262
Coding: 0071051001
VCID: 3D273E9B9DF6AF8FE21-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 05081476511588
Coding: 00000300FE0739
VCID: 38292F8FB2D48AA7317-806C
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 50
Mileage: 61632 km
Date: 2020.02.03
Time: 14:55:09
Control Module temperature: 25 °C
Voltage terminal 15: 14.6 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0CFXBF
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F5B0493D77A7D9FB0D-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B07081470635
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B07081440203
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 602 15
Serial number: 3576700000047124D31K
Subsystem 4 - Part No SW: ----------- HW: 480 001 802 15
Serial number: 35867000000D873C731/
Subsystem 5 - Part No SW: ----------- HW: 480 401 002 15
Serial number: 3516502A31993FC511FK
Subsystem 6 - Part No SW: ----------- HW: 480 401 102 15
Serial number: 3526502AB198E153722A
Subsystem 7 - Part No SW: ----------- HW: 480 400 508 14
Serial number: 3556502A716DB8131405
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 17021504220071
Coding: 0C00
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 7BA3F083C36261BF9C5-802E
Part No SW: 5G1 920 958 HW: 5G1 920 958
Component: KOMBI 304 4310
Coding: 27AD08002F80260001882A011400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
VCID: 6E85C9D7801004172BB-803A
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0003158949
Coding: 030100042F085900EF00027E080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72BDDDA7942820F7CF3-8026
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0038
Serial number: 29140001520710014304
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 1760294703
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00013.01.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
VCID: 46D55177C820EC57B3B-8012
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 090215BB503818
Coding: 003F0220D001048000001000
VCID: 42DD4D67E408D0779F3-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005307723
Coding: 0D0000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
VCID: 372B2CB3BFCA85DF38D-8062
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 120215BBB15765
Coding: 003F0020DE01048000801000
VCID: 41DF426BE10ECB6F869-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005328476
Coding: 150000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02AE01000B000200
VCID: 40D9476FEA04C267897-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 041 0421
Serial number: V5C02401152425
Coding: 02730000FF00000021111201000800001F0207060100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F1BE413373ADD9FD0D-804A
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9RS207G5P
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 150122200434
VCID: 2D070EDB4D963F0F521-8078
End----------(Elapsed Time: 01:52, VBatt start/end: 12.4V/12.3V)-----------
