Mk5 jetta 2.5 crank no start
Imprez07
I took a chance and bought a cheap jetta that had a no start condition . Ive got the car to at least crank now but I cant get vcds to connect to the ecu .Ive checked fuses and they are good and ive checked wiring from ecu to roughly the firewall and i cant visibly see or feel any bumps in the wiring . any suggestions or places to look
What kind of VCDS cable are you using?
What do/does the LED(s) do when you plug it into the car (only the car, no computer on the other end).
Does it connect to any of the other modules in the car, like the CAN Gateway?
Imprez07
I can get you an answer to the led question tomorrow. I did do a scan and this is what I got . the car kept blowing fuse sb10 for the ecu so I searched and didn’t see anything , eventually I unplugged the secondary air injection pump which stopped blowing the fuse and allowed the car to crank but still not Start . The battery is bad in this car and I eventually will replace but I wanna make sure it runs before I dump a bunch of money in it
https://cdn.fbsbx.com/v/t59.2708-21...36e2f74ce92cc037b9530160b312&oe=5E382D62&dl=1
Westbury, UK
Editorial note: When posting an Auto-Scan here please copy and paste it inline between [code] and [/code] tags, not as an attachment.
Imprez07
The light is solid green . I did another scan but it’s not really any different than the first
Imprez07
Sorry to keep posting but I did another scan and it’s different now that I got the car to crank . I don’t fully understand the scan but a couple of the errors are because of the headlight switch. And dimmer switch and the footwell light on the drivers side being disconnected.
 Sunday,02,February,2020,16:11:43:16521
VCDS Version: 19.6.2.0 (x64)
VIN: 3VWRF71K66M630543   License Plate:
Mileage: 243230km-151136mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWRF71K66M630543   Mileage: 243230km-151136miles
01-Engine -- Status: Cannot be reached 1100
Address 01: Engine
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   Shop #: WSC 00066 000 00000
   VCID: 408F7E0313C34A4FE7-8014
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70EFEEC363E39ACF57-8024
            013 - Check DTC Memory
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000107702
   Coding: 04050E234004180000140000001400000008730B5C
   VCID: 2A5B3CAB85BFA01FD9-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00066
7 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 81
                    Voltage: 12.35 V
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 81
                    Voltage: 12.35 V
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Reset counter: 81
                    Mileage: 243231 km
                    Voltage: 12.00 V
                    Reset counter: 81
                    Mileage: 243231 km
                    Voltage: 12.00 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 81
                    Voltage: 12.35 V
                    Reset counter: 81
                    Voltage: 12.35 V
                    Reset counter: 81
                    Voltage: 12.35 V
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD02JXR
   Coding: 0012627
   VCID: 2E5330BBB957CC3F05-807A
   Subsystem 1 - Component: BF-Gewichtsens.
   Subsystem 2 - Serial number: 6332MSME0A1B04412
   Subsystem 3 - Serial number: 6342MSME0866701CC
   Subsystem 4 - Serial number: 6351HSME07385E69J
   Subsystem 5 - Serial number: 6361HSME073B26276
   Subsystem 6 - Serial number: 63727SME07104070M
   Subsystem 7 - Serial number: 63827SME0710427B-
02511 - Control Module for Seat Occupied Recognition (J706)
            008 - Implausible Signal - MIL ON
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78FFD6E30B93C28F9F-802C
   Part No: 1K0 920 952 C
   Component: KOMBIINSTRUMENT 3HL 1012
   Coding: 0023203
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105423817F
   Coding: 3D3F0340071002
                    Reset counter: 81
                    Mileage: 243231 km
                    Time: 21:48:52
                    Fault Frequency: 21
                    Reset counter: 81
                    Mileage: 243231 km
                    Time: 21:48:53
01304 - Radio
                    Fault Frequency: 21
                    Reset counter: 81
                    Mileage: 243231 km
                    Time: 21:48:57
   Component: IMMO            3HL 1012
   Shop #: WSC 09416 444 68462
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001269
   VCID: 366318DB4107F4FF4D-8062
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326B24CBAD6FE8DF61-8066
                    Mileage: 3200 km
                    Temperature: 7.0°C
                    Voltage: 12.10 V
                    Voltage: 12.00 V
   Part No: 1K0 959 433 AF
   Coding: 137803281B09058F880F048051A0
   VCID: 74E7E2D317FBA6EFB3-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 377D15DF460D0DF756-8062
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 31692BC7A869D3C718-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
End-------------------------(Elapsed Time: 01:34)--------------------------
Engine Control Module is off-line. Check power and ground connections to it.
Imprez07
I can check them right at the ecu correct ? Also would appreciate it if you verified the wires I need to check as well . Just to make sure I’m right , there’s 2 brown ground wires and there’s 4 power wires a red/green, white , yellow/purple, red/black
Westbury, UK
If that's what the WD for your car shows (check from erwin) ...
Imprez07
honestly cant find a diagram . ive been using mitchell prodemand for alot of stuff but it doesnt show power and ground pinouts, i assumed those were the wires because of a video i saw. i do know t121/62 the red black wire has power and is in good shape.
Westbury, UK
Logged on and paid for a factory diagram how can you tell which colors are power wires .
Follow the wires on the WD, the ones that go back to the fuses are the power wires.
There's a thread on here about "How to read a WD", I can't find it at the moment but I'm sure someone will post a link ;)
Imprez07
Maybe a stupid question but I’ve looked the diagrams over what wires would power up the ecu .
Imprez07
Turned out to be computer for anyone having similar symptoms. Car only starts for 2 seconds before shutting off . Will be sending the computer away to have the immobilizer taken care of
