Audi A3 8v 2015 error 19226 and 20169
maxx16v
C?ID=342531
got these two codes but no eml light on.....
are they related ?
will the particulate trap bank 1 error 19226 trigger exhaust pressure sensor 1 error 20169 ?
what would be the best way to determine using VCDS and values expected on a CRKB engine May 2015 ?
bit of a copy and paste below from log
Saturday,01,February,2020,10:42:06:15453
VIN: WAUZZZ8V3FA163064   License Plate:
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 021 AQ    HW: 04L 907 309 E
  Component and/or Version: R4 1.6l TDI   H22 9229
           Software Coding: 02190012032501092000
            Work Shop Code: WSC 61792 001 1048576
              ASAM Dataset: EV_ECM16TDI01104L906021AQ 002007 (AU37)
                       ROD: EV_ECM16TDI01104L906021AN_VW37.rod
                      VCID: 74A425E3DF8772EFB3-8020
20169 - Exhaust Pressure Sensor 1
          P0471 00 [101] - Implausible Signal
                    Mileage: 235842 km
                    Date: 2020.02.01
                    Time: 09:56:52
                    Coolant temperature: 89 °C
                    Intake air temperature: 64 °C
                    Voltage terminal 30: 12.940 V
                    Exhaust mass flow of low-pressure EGR: calculated: 32.767
                    Differential pressure ratio: low-pressure EGR: 0.0 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 940.1 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 1055.9 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 0.00 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 0.13 %
19226 - Particulate Trap Bank 1
          P2002 00 [101] - Efficiency Below Threshold
                    Mileage: 235837 km
                    Date: 2020.02.01
                    Time: 09:48:54
                    Engine speed: 1611.50 /min
                    Normed load value: 66.3 %
                    Vehicle speed: 57 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 68 °C
                    Voltage terminal 30: 14.860 V
                    Exhaust mass flow of low-pressure EGR: calculated: 25.787
                    Differential pressure ratio: low-pressure EGR: 29.4 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 1051.8 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 1056.0 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 56.29 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 45.63 %
thanks
MartinsX
Riga, Latvia
C?ID=268515
Hi!
1) Post a full autoscan, in Code tags
2) Check measured value of exhaust pressure sensor with engine not running (just ignition on), engine idling, and @ 3000-3500 rpm
maxx16v
C?ID=342531
Saturday,01,February,2020,14:17:12:15453
VIN: WAUZZZ8V3FA163064   License Plate: RE15
Mileage: 235847km-146548mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8V3FA163064   Mileage: 235847km-146548miles
Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 AQ    HW: 04L 907 309 E
   Component: R4 1.6l TDI   H22 9229
   Revision: 86H22---
   Shop #: WSC 61792 001 1048576
                    Mileage: 235842 km
                    Date: 2020.02.01
                    Time: 09:56:52
                    Mileage: 235837 km
                    Date: 2020.02.01
                    Time: 09:48:54
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 60885000000102
   Coding: 12F18AA224260A6F0177060641C72548512450806082A4F2024100788208
   Shop #: WSC 06314 790 00021
   VCID: 48DCA113F38FA60F2F-801C
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000131111
   Coding: 03100104002000001000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 373ED2EF8E71D9F756-8062
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0137
   Serial number: 01011508400470
   Coding: 07040842C241005D03844004B31407080000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DB200C7ECCD33A7CC-8028
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150319  041 0580
   Serial number:         150321142112
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 AG    HW: 8V0 941 531 AG
   Serial number: 07 02 2015  00001190
   Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY150581V13
   Serial number: 00000000000032144441
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231508402084
   Coding: 0000050001
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   VCID: 3B36CEDFB259FD97B2-806E
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Serial number: 003M2R0B62H4
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BD69E1FE2F94D1702-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 703 15
   Serial number: 357670000000F8CC631%
   Subsystem 2 - Part No SW: -----------    HW: 480 002 703 15
   Serial number: 35867000000909CC631
   Subsystem 3 - Part No SW: -----------    HW: 480 402 503 15
   Serial number: 3516502B119DB893F2DW
   Subsystem 4 - Part No SW: -----------    HW: 480 402 503 15
   Serial number: 3526502AF19DB893935X
   Subsystem 5 - Part No SW: -----------    HW: 480 401 602 15
   Serial number: 3556502B11993FC383CR
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502BF19EFF55B197
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502BD19EFF5590D7
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 603 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 23065029919EFF52A02N
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 03041508490548
   Coding: A408
   VCID: 095A6417A8051F07F0-805C
   Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
   Component: KOMBI         H02 4292
   Coding: 27A50A00238026000100E8001000000000000000
   VCID: 3FCEBACFA641E1B79E-806A
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1204
   Revision: --------    Serial number: 0003253828
   Coding: 030100041F0876005B000248080B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 71AA2CF7A09547C758-8024
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 18 03 2015  D0052981
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001503161850
   Serial number: 040315BBO13812
   Coding: 00108E204001040000001002
   VCID: 42C8B33BD5B38C5FF1-8016
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 0103
   VCID: 43C6B63FCAA98557FA-8016
   Serial number: 130315BCD00429
   Coding: 001086204001040000001002
   VCID: 41CABC37D0B59747E8-8014
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 140315BCE11556
   Coding: 000086204001040000001002
   VCID: 44C4B523CFA7826FC3-8010
   Component: TSG HBFS      020 0028
   Serial number: 140315BCE1148C
End----------(Elapsed Time: 01:11, VBatt start/end: 12.1V/12.1V)-----------
maxx16v
C?ID=342531
how do I in vcds check measured value of exhaust pressure sensor with engine not running ?
maxx16v
C?ID=342531
lol....
how do I get to that measuring block ?
lol....
Open the engine ECU, select the function for Measuring Blocks (or Advanced Measuring if your controller is UDS) and choose the appropriate measuerment value
MartinsX
Riga, Latvia
C?ID=268515
You have UDS based ECU, so You will have MVB grayed out. Use Advanced measured values instead. Use search window in this mode, type in "exhaust", for example
maxx16v
C?ID=342531
ok thankyou....
will have a look and see what values I get...
the other thing I did notice was it does not rev past 2000 rpm when engine is running and in neutral....is this a safety thing with Audi ?
maxx16v
C?ID=342531
got two readings....
at ignition on
IDE07084   Differential pressure ratio: low-pressure EGR 0.0 kg/h
  IDE07745   Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 11 hPa
  IDE07746   Particl.filt.: differential press.sens.1 bank 1: uncnd.voltage 1067.6 mV
  IDE07748   Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset 8 hPa
  IDE07750   Exhaust recirculat.2: different.press.sens.1 bank 1: raw value 18.6 hPa
  IDE07751   Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value -178.9 hPa
  IDE07752   Exh.recirculat.2: different.press.sensor 1 bank 1: uncnd.volt. 1064.4 mV
  IDE08067   Exhaust recirculat.2: different.press.sens.1 bank 1: offset 197.5 hPa
and at idle
  IDE07745   Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 6 hPa
  IDE07746   Particl.filt.: differential press.sens.1 bank 1: uncnd.voltage 1040.4 mV
  IDE07748   Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset 10 hPa
  IDE07750   Exhaust recirculat.2: different.press.sens.1 bank 1: raw value 16.1 hPa
  IDE07751   Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value -181.4 hPa
  IDE07752   Exh.recirculat.2: different.press.sensor 1 bank 1: uncnd.volt. 1055.8 mV
faulty sensor ???
maxx16v
C?ID=342531
I am getting variable readings every time...there are 2 sensors...worth just replacing both ?
An offset of nearly 200 mbar seems really high for a differential pressure sensor, doesn't it?
Is the line contaminated to PSI sensor with negative deviation?
maxx16v
C?ID=342531
mmm....what is PSI and what exactly do you mean by line contamination with negative deviation ?
as posted earlier....its variable readings every time I tried a read
maxx16v
C?ID=342531
2 exact same coded sensors sit beside each other in a silver heat bag
but looks untouched and unmolested ......so
can I swap them round and see what happens ?
I am inclined just to replace both though
reading the codes with no eml ....just pending emissions codes and very random as when it throws the fault but never with an eml or any lack of driveability...
the 2 sensors are 04L906051 and have just noticed a single further towards the front of engine coded 04L906051 B aswell
