VW T5 DPF Pressure Sensor Short To Ground
Fearns
England
C?ID=385526
Can anyone help with the following DPF sensor error, I've replaced the sensor, blown through the pipes to confirm they are not blocked, authorised the new sensor through VCDS and done a DPF regen.
Every third start of the engine after clearing the error throws up the Short to GND error.
Below is the VCDS Print.
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [038] - Short to GND
Mileage: 154014 km
Date: 2020.01.31
Time: 13:55:54
Engine speed: 0.00 /min
Coolant temperature: 50 °C
Intake air temperature: 17 °C
Voltage terminal 30: 12.280 V
Sensor for particle filter differential press: raw value: -214 hPa
Particle filter: difference pressure: 0 hPa
Particle filter: offset for differential press.: -75 hPa
Particle filter: differential pressure: dynamic offset: 0 hPa
Outside air temperature: 13.0 °C
Particle filter: soot mass measured: -3.28 g
Particle filter: soot mass calculated: 3.18 g
Trowbridge, UK
We'll need to see a full unedited VCDS Auto-Scan. BTW just copy and paste the saved .txt file as explained in my signature.
Fearns
England
C?ID=385526
Friday,31,January,2020,17:07:26:09734
Mileage: 154010km-95697mi   Repair Order:
Chassis Type: 6N0
Scan: 01 03 04 09 15 17 19 25 56 0B
   Mileage: 154010km-95697miles
Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CD    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X41 9970
   Revision: 26X41---    Serial number: 00000000000000
   Coding: 01114010230400080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01103L906022CD 002014
   ROD: EV_ECM20TDI01103L906019AM_002.rod
   VCID: 698FBACB69FB822F7E9-803C
                    Mileage: 154014 km
                    Engine speed: 532.50 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 86 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 11.180 V
                    Outside air temperature: 22.5 °C
                    Particle filter: soot mass calculated: 0.93 g
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 508724AD89A40A9524A29178A96710
   Shop #: WSC 02736 790 49152
   VCID: 363521B768451DD723B-8062
   Part No SW: 7H0 937 086 F    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0230
   Revision: BM047001    Serial number: 0395 038110262
   Coding: A0A0303A0E212031000008103C2B8C100000430F60060000300000000000
   Shop #: WSC 02734 790 00000
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL003X5XT
   Shop #: WSC 02734 790 50316
   VCID: 353726BB75C316CF2A1-8060
   Part No SW: 7E0 920 960 C    HW: 7E0 920 960 C
   Component: KOMBI         H04 0204
   Coding: 460200
   Shop #: WSC 02736 790 50316
   VCID: 290FFACBA97B422FBE9-807C
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 0230
   Coding: 042300
   VCID: 70B9D7AF4AA173E7397-8024
                    Reset counter: 205
                    Mileage: 154014 km
                    Date: 2014.06.23
                    Time: 16:08:10
   Component: IMMO          H04 0204
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC5C76CFD8937773-803E
Address 56: Radio
End-----(Elapsed Time: 01:15, VBatt start/end: 13.9V/0.0V. VIgn 0.0V)------
Fearns
England
C?ID=385526
Thanks, full scan above.
Got wiring diagrams for this vehicle?
The first thing to do with a "Short to GND" code is look for a missing voltage supply at the sensor or actuator that's flagged in the fault.
Fearns
England
C?ID=385526
I don't have a wiring diagram, I've removed the multiplug on the sensor, there are 3 wires numbered 1, 2 and 3.
With the earth probe on 2 and positive on 1 there is no reading.
With the earth probe on 2 and the positive on 3 it reads just over 5 volts.
I did read somewhere that 5 volts was correct but i dont know what pin 1 should read.
MartinsX
Riga, Latvia
C?ID=268515
Hi!
If You want to diagnose and repair Your vehicle Yourself, You need WD and other repair information. The best source is ERWIN.
burdabur
Scotland
C?ID=362775
Bringing an old thread back from the dead here, curious as to whether you got the bottom of this issue? I have the same issue after replacing the sensor, wondering if you found something in software before I start in about the wiring?
