Hi guys, first time poster.
So our workshop loan car is an 05 Audi A6 2.4 it has a load of dtcs in it which don't seem to effect the way the car drives,
it just has a heap of warning lights appear at random whist driving, usually bulb warning messages.
we are thinking it may be a faulty module, but being in Australia it's difficult to get factory information.
wondering if anyone could steer me in the right direction.
Cheers,
Brad.
Cheers,
Brad.
Tuesday,28,January,2020,08:16:16:24635
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ4F96N025813 License Plate: S384ASG
Mileage: 171400km-106503mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
62 72 76
VIN: WAUZZZ4F96N025813 Mileage: 171400km-106503miles
62-Door, Rear Left -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine (BDW) Labels:. 06E-910-552-BDW.clb
Part No SW: 4F0 910 552 R HW: 4F0 907 552 D
Component: 2.4l V6 MPI 0010
Revision: --H17--- Serial number:
Coding: 0105000302070120
Shop #: WSC 02325 785 00200
VCID: 3261F0F2AD4F5ADF61-8066
005137 - Secondary Air Injection System; Bank 2
P1411 - 007 - Insufficient Flow - Intermittent
Fault Status: 00000010
Reset counter: 35
Mileage: 171229 km
Date: 2019.10.18
Time: 09:17:48
Mass Air / Rev.: 0.0 mg/str
Temperature: 33.0°C
Engine Off
005686 - Powertrain Data Bus
P1636 - 009 - Missing Message from Airbag Controller - Intermittent
Fault Status: 00000100
Reset counter: 11
Mileage: 171259 km
Date: 2019.10.21
Time: 08:22:00
Temperature: 91.5°C
Engine Off
Voltage: 12.04 V
P1653 - 008 - - Intermittent
Reset counter: 14
Mileage: 171263 km
Date: 2005.02.01
Time: 12:00:31
RPM: 1024 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 25.5°C
Idle
Load: 32.5 %
Readiness: 0010 0001
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F1 910 155 F HW: 01J 927 156 JG
Component: V30 01J 2.4l 4V RdW 0030
Revision: --H01--- Serial number: 00000000000041
Coding: 0000001
Shop #: WSC 02327 785 00200
VCID: 26491CA29187367FFD-8072
17111 - RPM Signal from ECU
P0727 - 000 - No Signal - Intermittent
Fault Frequency: 109
Reset counter: 29
Mileage: 171224 km
Date: 2019.10.17
Time: 21:04:38
RPM: 96 /min
(no units): 13.0
Torque: -16.0 Nm
Temperature: 41.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H03 0090
Coding: 0021330
VCID: 2C5DEE8A8F6B0C2F2B-8078
Reset counter: 201
Mileage: 171263 km
Date: 2005.02.01
Time: 12:01:29
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x018D
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300178535
Coding: 0000019
Shop #: WSC 02323 785 00200
VCID: 63CF45B6A2358357DA-8036
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H39 0040
Fault Frequency: 50
Reset counter: 212
Mileage: 171293 km
Date: 2005.02.15
Time: 10:36:48
Reset counter: 212
Mileage: 171317 km
Date: 2005.03.03
Time: 16:38:42
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 HW: 4E0 035 729
Component: Interfacebox H43 1200
Revision: 00000000 Serial number: 350EN057565163
Coding: 0000002
Shop #: WSC 02335 785 00200
VCID: 5FC749468E5DA7B7FE-800A
Component: Bedienteil MMIC6H04 0060
Subsystem 2 - Serial number: 00000000723195
Subsystem 3 - Serial number: 0105.04.070000000100010169ÿ
Subsystem 4 - Serial number: 010169ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F2 820 043
Component: KLIMABETAETIGUNGH04 0150
Revision: 00000025 Serial number: 00000030019146
Coding: 0001094
VCID: 5BBF7D569A45BB9792-800E
Reset counter: 211
Mileage: 171315 km
Date: 2005.03.03
Time: 16:00:04
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Coding: 0000101
VCID: 2855129A9B93200FCF-807C
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7191663
VCID: 1B3F3D56DAC5FB9752-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD085GYL
Coding: 0013382
VCID: 2953179E80991907D0-807C
Subsystem 1 - Serial number: 6332CSME090A270C1
Subsystem 2 - Serial number: 6342CSME0A0C5E53B
Subsystem 3 - Serial number: 6352QSME02021903.
Subsystem 4 - Serial number: 6362QSME02022E7BG
Subsystem 5 - Serial number: 63734SME021C1473V
Subsystem 6 - Serial number: 63834SME021C4951-
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025051340252
Coding: 0102041
VCID: 66C95CA25107F67F3D-8032
Component: Lenkradmodul H07 0080
Part No SW: 4F0 910 900 A HW: 4F0 920 900 M
Component: KOMBIINSTR. M73 H10 0630
Revision: 01000000 Serial number: 4R417VD55
Coding: 2304763
Shop #: WSC 00999 444 64523
VCID: 1E393442C9D7EEBFB5-804A
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080551480EB
Coding: ECFE53C41B0104
VCID: 275711A6968D2F77C6-8072
Fault Status: 00101011
Fault Frequency: 30
Reset counter: 227
Mileage: 171259 km
Date: 2019.10.21
Time: 08:28:18
Fault Frequency: 119
Reset counter: 212
Mileage: 171293 km
Date: 2005.02.15
Time: 10:36:49
Reset counter: 212
Mileage: 171317 km
Date: 2005.03.03
Time: 16:38:42
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H11 0040
Coding: 0000538
VCID: 2A51E892859F121FD9-807E
Fault Frequency: 18
Reset counter: 212
Mileage: 171293 km
Date: 2005.02.15
Time: 10:42:17
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01004416990000
Coding: 0262157
VCID: 2E59E482B9777E3F05-807A
Fault Status: 00101001
Fault Frequency: 29
Reset counter: 222
Mileage: 171260 km
Fault Frequency: 11
Reset counter: 226
Mileage: 171271 km
Date: 2005.02.07
Time: 16:58:42
Reset counter: 212
Mileage: 171315 km
Date: 2005.03.03
Time: 16:03:51
Fault Frequency: 14
Reset counter: 226
Mileage: 171315 km
Date: 2005.03.03
Time: 16:13:59
02739 - Bulb for Tail/Brake Light; Right
Fault Frequency: 8
Reset counter: 226
Mileage: 171324 km
Date: 2005.03.17
Time: 11:13:51
02741 - Bulb for Tail Light 2; Right
Fault Frequency: 8
Reset counter: 226
Mileage: 171340 km
Date: 2005.03.19
Time: 12:18:31
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 20S00001 Serial number: 01905050098849
Coding: 0000007
VCID: 1D3B334EC4D1F5A7AC-8048
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000095245
Coding: 0001014
VCID: 5EB974428957AEBFF5-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H11 0040
Coding: 0000538
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0002031
Shop #: WSC 02334 785 00200
VCID: 5DBB734E8451B5A7EC-8008
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394E-057550786
Coding: 0000001
VCID: 234F05B6E2B5C3579A-8076
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000045264
Shop #: WSC 00000 384 00290
Subsystem 1 - Part No: 4F0 915 105 B
Component: von MLA 0505170307
Coding: 34463039313531303542204D4C4130353035313730333037
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 220
Mileage: 171351 km
Date: 2005.03.20
Time: 14:39:51
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H11 0030
Coding: 0000002
Fault Status: 00101110
Reset counter: 212
Mileage: 171317 km
Date: 2005.03.03
Time: 16:38:38
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H11 0030
Coding: 0000002
Fault Frequency: 85
Reset counter: 212
Mileage: 171293 km
Date: 2005.02.15
Time: 10:36:48
Fault Frequency: 85
Reset counter: 212
Mileage: 171293 km
Date: 2005.02.15
Time: 10:36:48
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0020
Revision: 00H09000 Serial number: 11720514001314
Coding: 0001006
End-------------------------(Elapsed Time: 02:18)--------------------------
Address 01: DTCs cleared
