2018 Audi B9 A5 Steering Angle Calibration Issue
kartashon
C?ID=392126
Recently changed steering wheel, and in the process I broke clock spring. Ordered a new Steering wheel column multi-function switch, and took out just the clock spring and replaced it on the current/factory column switch.
A5 is still mad and triggers warnings on EPS, Audi Pre-sense, steering wheel malfunction, blind spot, and other steering related assist features. I tried auto calibration by turning steering wheel at least 30 degrees to left or right then drive straight kind of thing, then tried to reset angle to 0 by going into Select -> 16-Steering wheel but it gives an error that some requirements are not met. I can take a screenshot of the exact error message if its important.
Wednesday,22,January,2020,21:00:07:60834
Dealer/Shop Name: TheGarageAuto31
VIN: WAUENCF51JA129563   License Plate:
Chassis Type: F5-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
          6D 81 A5 A9 BB BC CA CF D6 D7
VIN: WAUENCF51JA129563   Mileage: 26300km-16342miles
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0002
   Revision: --H15---
   Coding: 1A2500322326010E34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
   ROD: EV_ECM20TFS020_AU49.rod
   VCID: 48C95FD9323D2167417-801C
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:46:05
                    Engine speed: 1372.75 /min
                    Normed load value: 6.3 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 11.875 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    ACC variants (coding): CCS
                    Drivetrain coordinator: brake fault status-ESP system error: No
23081 - Implausible Data Received from Steering Column Control Module
          U0429 00 [047] - -
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
                    Engine speed: 766.25 /min
                    Normed load value: 11.4 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 14.921 V
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_2: 49152
                    LF_MVB_PDU_INTC_DIAG_3: 3
                    LF_MVB_PDU_INTC_DIAG_4: 12288
                    LF_MVB_PDU_INTC_DIAG_5: 0
                    LF_MVB_PDU_INTC_DIAG_6: 61472
                    LF_MVB_BUS_INTC_DIAG: 256
Readiness: 1000 0100
   Part No SW: 8W2 927 155 BA    HW: 0CJ 927 156
   Component: 0CL 20TFSINAR H05 0001
   Revision: --H05---    Serial number: 0000000831
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 015F82FD5187D02FC69-8054
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180171000039
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 Q    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0775
   Coding: 18AA409A28A40A9F11A3489700805292E5359A180214508812004A49A7AC59
   Shop #: WSC 06334 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 53F378B5FB7B92BF245-8006
6293504 - Steering Angle Sensor
          C2008 00 [175] - Signal Qualification
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
                    95 00 00 00 CA 00 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0251
   Coding: 140805095548000D10000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D14BE90E150507ADF-8010
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002543233
   Serial number: 5080153900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500363E0081CCD0515871518AC98B9110B3D08000000000000000020001A010A690122025705
   VCID: 025D8DF15481CB37DF3-8056
   Subsystem 1 - Part No SW: 8W6 955 119     HW: 8W6 955 119   Labels: 1KX-955-119.CLB
   Component: 494 LL 050618  036 0471
   Serial number: 00000001805290301894
   Coding: 5FC7F7
   Serial number: 21563837X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AK    HW: 4M0 941 531 AK
   Component: E1 - LDS  H06 0008
   Serial number: 28 03 2018  01380012
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z012602
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20180611185947 01062
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE113041823610455
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CS    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00863956
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000059627004
131945 - Databus
          [EPS control module: received error value in signal EPS_steering-rack_pos]
                    Fault Frequency: 8
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
                    average_Voltage_terminals: 15.00 V
                    Outside air temperature sensor-Resistance: 2.56 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: -3.00 °C
                    interior_temperature: 16.00 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
196758 - Databus
          [Brake control module: received error value in signal ESP system status]
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
196761 - Databus
          [Power steering control module: received error value in signal EPS steering rack position]
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
   Component: Airbag10.44   H05 0107
   Serial number: 003UQ00315ZH
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4DC76ECDDD5FC44F721-8018
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705G0173S01599
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706J0178S00012
   Coding: 80000D
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J180009PM0708
   Subsystem 4 - Part No SW: -----------    HW: 442 062 706 18
   Serial number: 3577Y0099279D02434A%
   Subsystem 5 - Part No SW: -----------    HW: 442 062 706 18
   Serial number: 3587Y00B527DBDE293BT
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 106 18
   Serial number: 3517700AF2A77571E2BS
   Subsystem 7 - Part No SW: -----------    HW: 442 0B2 006 18
   Serial number: 3527700A729299631444
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 106 18
   Serial number: 3557500A72AEF870B14S
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 106 18
   Serial number: 3567500A72AEF870E11T
          B13BC F2 [137] - No function
                    Reset counter: 188
                    Mileage: 24871 km
                    Date: 2020.01.06
                    Time: 07:24:58
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1061893 - Databus
          [NWD: 0x0A0 LH_EPS_04 error value EPS_Zahnstangen_Pos]
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
   Part No SW: 4M0 907 129 GK    HW: 4M0 907 129 GK
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7F5B04052773A6DFB0D-802A
5586944 - Steering angle sensor
          B1168 04 [009] - Internal System Fault
                    Mileage: 24945 km
                    Date: 2020.01.06
                    Time: 18:36:19
                    Freeze_Frame_SAS_Failures-Angle_Qualifier: 00
                    Freeze_Frame_SAS_Failures-corresponding_SAS_Velocity: 0 °/s
                    Freeze_Frame_SAS_Failures-last_valid_Sign_Steering_Angle_Main: 00
                    Freeze_Frame_SAS_Failures-last_valid_Steering_Angle_Main: 192.0 °
                    Freeze_Frame_SAS_Failures-second_to_last_valid_Sign_Steering_Angle_Main: 00
                    Freeze_Frame_SAS_Failures-second_to_last_valid_Steering_Angle_Main: 192.0 °
                    Freeze_Frame_SAS_Failures-Sign_SAS_Speed: 00
                    Freeze_Frame_SAS_Failures-Vehicle_Speed_FL: 0.00 km/h
                    Freeze_Frame_SAS_Failures-Voltage_12V: 12060.94 mV
                    Freeze_Frame_SAS_Failures-VZ_Vehicle_Speed_VL: 00
   Part No SW: 8W5 920 890 G    HW: 8W5 920 890 G
   Component: FBenUSA       H19 0377
   Coding: 09E641C72888CF05022369601800000008000000
   VCID: 47CB5CE53F232E1F48D-8012
   Part No SW: 8W6 907 468 F    HW: 8W6 907 468 E
   Component: Gateway       H43 0123
   Revision: 7B000002    Serial number: 0287B773918629
   Coding: 030100010000064029070000005900126C180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   Subsystem 1 - Part No SW: 36A 953 509 C    HW: 36A 953 509 C
   Component: J453 MFL  H04 0002
   Serial number: 20170109105555 RD058
   Serial number: 0136468404
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78A9EF19025D91E7F17-802C
   Component: MEM-FS        009 0042
   Serial number: 00000330825135
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: 79AFEA1D395788EF8E9-802C
   Part No SW: 4M0 907 566 E    HW: 4M0 907 566
   Component: MRR1Rear      H20 0430
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 372B2C254FC35E9F38D-8062
1192224 - Databus
          [databus error value received - EPS_Zahnstangen_Pos]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
                    Control Module temperature: 31 °C
                    Voltage terminal 30: 15.00 V
                    Terminal 15 status: On
                    Voltage terminal 15: Measured value not available
1192210 - Databus
          [databus error value received - ESP_Systemstatus]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
                    Voltage terminal 30: 14.90 V
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0129
   Serial number: 0000329063667
   Coding: 005F4B625E00108000010432
   VCID: 43D348F50B1B023F945-8016
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DD4DF114010B379F3-8016
44032 - Terminal 30
          U140A 00 [008] - Open Circuit
          [KFC_RESET_ZERO]
                    Reset counter: 8
                    Mileage: 26223 km
                    Expanded ambient data 1-Engine running: Engine_Running_Stable
                    Expanded ambient data 1-Supply voltage: 0.00 V
                    Expanded ambient data 1-Temperature: -70 °C
                    Expanded ambient data 1-System status: 4
                    Expanded ambient data 1: 00
                    Expanded ambient data 1-driving_direction: 0
                    Expanded ambient data 1-KFA: 0
                    Expanded ambient data 1-KFC: 172
                    Expanded ambient data 1-Ready_To_Drive_Bit: 0
                    Expanded ambient data 1-StartStop Info: 0
                    Expanded ambient data 1-Steering_Angle_Calculated: 0 °
                    Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
                    Expanded ambient data 1-Steering_torque: 0.00 Nm
                    Expanded ambient data 1-Steering_Torque_Sign: 0
                    Expanded ambient data 14-KFA_FAST_RESET: 0
                    Expanded ambient data 14-KFC_FAST_RESET: 0
                    Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 14.91 V
                    Expanded ambient data 14-Voltage_terminal_30_unfiltered: 15.03 V
27136 - Databus
          [KFC_LWI_01_SNA]
                    Reset counter: 223
                    Mileage: 26223 km
                    Expanded ambient data 1-System status: 5
                    Expanded ambient data 1-KFC: 106
                    Expanded ambient data 1-Steering_torque: 0.20 Nm
                    Expanded ambient data 15-MsgStateFifo_Byte0: 00 00 00 00
                    Expanded ambient data 15-MsgStateFifo_Byte1: FF FF FF FF
                    Expanded ambient data 15-MsgStateFifo_Byte2: FF FF FF FF
                    Expanded ambient data 15-MsgStateFifo_Byte3: FF FF FF FF
                    Expanded ambient data 15-NumOfMsgCntFaults: 00
                    Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
                    Expanded ambient data 15-NumOfMsgNoFaults_3: 00
                    Expanded ambient data 15-NumOfMsgTimoFaults_1: 00
17664 - Databus
          [KFC_ESP_22_SNA]
                    Reset counter: 225
                    Mileage: 26223 km
                    Expanded ambient data 1-KFC: 69
                    Expanded ambient data 15-MsgStateFifo_Byte1: 00 00 00 00
                    Expanded ambient data 15-MsgStateFifo_Byte2: 00 00 00 00
                    Expanded ambient data 15-MsgStateFifo_Byte3: 00 00 00 00
   Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0387
   Coding: 013400004FB100C0650BA0006E01080233024000810026502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY181421QES
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099409366
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: 12045793
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Fault Frequency: 11
                    Reset counter: 10
                    Mileage: 26224 km
                    Date: 2020.01.21
                    Time: 21:49:54
                    Supply voltages-Supply voltage: Terminal 30: 12.745 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.758 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.785 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 10 00 80
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAJJA04H61W
   Coding: 0194030800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 76B5E1210849E797E3B-8022
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0129
   Serial number: 0000329102500
   Coding: 005F4B225E00108000010430
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 D    HW: 8W5 035 880
   Component: MU-P-LNS-US   034 1320
   Serial number: A798F0JB111166
   Coding: 019403020000000053220002041A00102F000EE501700904FE
   VCID: 40D947F91A0D1927897-8014
   Subsystem 1 - Part No SW: V03 959 803 AF    HW: -----------
   Component: NAR 2020  --- 0076
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00118051800820292
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK115061800020901
   Compact Disc Database:
   Component: Gracenote2  --- 3012
          B11CF 53 [009] - Deactivated
                    Reset counter: 223
                    Mileage: 26224 km
                    Date: 2020.01.22
                    Time: 07:26:18
                    Voltage terminal 30: 13.0 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Component: RVC Compact   H12 0250
   Coding: 0294030102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 333318355BBBB2BF045-8066
13705996 - Databus
          [Errorvalue-monitoring LH_EPS_04.EPS_Zahnstangen_Pos]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
                    passive
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0166
   Revision: --------    Serial number: 32005184600000
   Coding: 0630
   Part No SW: 8W1 713 041 G    HW: 8W1 713 041 J
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18062748001940
   ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W6 907 217 A    HW: 8W6 907 217 A
   Component: BVS           H17 0050
   Coding: 0404090300000203022023A2A50000FC00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
8 Faults Found:
1123080 - Databus
          [LWI_01_LWI_QBit_Lenkradwinkel]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 15.00 V
1123714 - Databus
          [Airbag_01_AB_Systemfehler]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:56
                    Voltage terminal 15: 14.80 V
1123157 - Databus
          [LH_EPS_03_EPS_Berechneter_LW]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123159 - Databus
          [LH_EPS_04_EPS_Zahnstangen_Pos]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123186 - Databus
          [LWI_01_LWI_Lenkradwinkel]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123188 - Databus
          [LWI_01_LWI_Lenkradw_Geschw]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123733 - Databus
          [SWA_01_SWA_rel_Fehler]
                    Fault Frequency: 8
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8W0 907 159 H    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0008
   Serial number: 180525201207
   VCID: 46D551E138293717B3B-8012
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0130
   Serial number: 0000329884414
   Coding: 000F4B220000108040000020
   VCID: 45D756ED052F3C0FBA1-8010
   Component: TSG HBFS      005 0130
   Serial number: 0000329887109
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 228000049301
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D273E0D6DFF74CFE21-8068
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 E    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 34311B295EB5B5871DF-8060
1192224 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
                    Control Module temperature: 28 °C
   VCID: 176BCCA52F037E9F18D-8042
End----------(Elapsed Time: 02:08, VBatt start/end: 12.0V/12.0V)-----------
                Address 16: Steering wheel  (4M0 907 129 GK)
21:05:51
  IDE08696-MAS00037   Steerg. wheel angle sens.-Calibration status not calibrated
  IDE08696-MAS02128   Steerg. wheel angle sens.-Q bit: steering wheel angle invalid
  IDE08696-MAS02358   Steerg. wheel angle sens.-Calibration angle outside permissible range
  IDE08696-MAS02406   Steerg. wheel angle sens.-Steering wheel angle: internal value 295.0 °
  IDE08696-MAS02453   Steerg. wheel angle sens.-Steering wheel angle offset 0.0 °
  IDE08696-MAS02983   Steerg. wheel angle sens.-Steering wheel angle 819.1 °
21:05:53
I see bunch of fault codes and tried clearing ABS Brake, Steering Wheel and Steering Wheel Assist, but no luck so far. I also just started using VCDS, so I figured I'd reach out for help before breaking anything else. Would I be able to calibrate the steering angle using VCDS?
Any input is greatly appreciated.
kartashon
C?ID=392126
Audi Steering Wheel Angle Calibration B9
Re-posting:
Recently changed steering wheel on 2018 A5, and in the process I broke clock spring. Ordered a new Steering wheel column multi-function switch, and took out just the clock spring and replaced it on the current/factory column switch.
Car is still mad and throws bunch of fault codes on steering related assist features. I tried resetting ABS Brake, and auto calibration by turning steering wheel at least 30 degrees to left or right then drive straight kind of trick. Then tried to reset steering angle by going into Select -> 16-Steering Wheel, but it gives an error that some requirements are not met.
Dealer/Shop Name:
   Revision: --H15---
17178 - Databus
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:46:05
          U0429 00 [047] - -
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
   Coding: 5FC7F7
   Coding: 02005D
   Coding: 350000
131945 - Databus
                    Fault Frequency: 8
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
196758 - Databus
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
196761 - Databus
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:53
   Coding: 80000D
   Coding: 80000D
   Occupant Detection:
                    Reset counter: 188
                    Mileage: 24871 km
                    Date: 2020.01.06
                    Time: 07:24:58
1050117 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1061893 - Databus
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
                    Mileage: 24945 km
                    Date: 2020.01.06
                    Time: 18:36:19
   Revision: --------
   Coding: 0E8002
1192224 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
1192210 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
44032 - Terminal 30
          [KFC_RESET_ZERO]
                    Reset counter: 8
                    Mileage: 26223 km
27136 - Databus
          [KFC_LWI_01_SNA]
                    Reset counter: 223
                    Mileage: 26223 km
17664 - Databus
          [KFC_ESP_22_SNA]
                    Reset counter: 225
                    Mileage: 26223 km
65896 - Databus
                    Fault Frequency: 11
                    Reset counter: 10
                    Mileage: 26224 km
                    Date: 2020.01.21
                    Time: 21:49:54
                    Reset counter: 223
                    Mileage: 26224 km
                    Date: 2020.01.22
                    Time: 07:26:18
13705996 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
                    passive
   Coding: 0630
8 Faults Found:
1123080 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123714 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:56
1123157 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123159 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123173 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123186 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123188 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
1123733 - Databus
                    Fault Frequency: 8
                    Reset counter: 225
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:52
   Revision: --------
   Coding: 0E8002
1192224 - Databus
                    Reset counter: 223
                    Mileage: 26223 km
                    Date: 2020.01.21
                    Time: 21:26:51
21:05:51
21:05:53
Re-posting
Threads merged. Please don't open duplicate threads with the same question about the same car. If someone had an immediate answer for you, I'm sure they'd post it.
Have you looked at the values from the steering angle sensor?
I would start with IDE00326 -- Steering wheel angle in the ABS module. It should be close to zero with the front wheels pointed straight ahead and the steering wheel centered. It should go negative when the steering wheel is turned one way and positive when it's turned the other way.
kartashon
C?ID=392126
My bad, new here and didn't know existing posts go on top of the first page if I update it. I know that B9 is relatively new and resources are still quite limited, but felt little bit rushed to fix it as like 7 different warning beeps/chimes beat my eardrums every time I start the car.
As of now, I managed to get steering angle to almost 0 (+-2, within permissible range) when steering wheel is centered, but I get one more reading of 819 degree that flashes back and forth with 0 - is this normal? I did research but was not able to find anything with two steering angles.
I am still getting errors when trying to reset values or calibrate steering wheel angle. I guess that if I manage to get the 819 degree to near 0, I will be able to reset the value and calibrate steering wheel angle with IDE00326 or similar, but the reading does not seem to change even if I steer.
I don't think so, but I have no personal experience with that vehicle.
United States
You may already have this sorted however this info from Address 16: Steering wheel makes is look like the slip ring could be 1, if not 2, turns off from center mechanically:
I found a few examples of IDE08696-MAS02406 but this was a non-broken 2018 Audi S5 Cabriolet: https://forums.ross-tech.com/showth...-Scan-and-maps&p=106275&viewfull=1#post106275
The wheel probably wasn't perfectly straight but that vehicle had:
[16-Steering wheel]
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,5.2, °
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,0.3, °
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,4.6, °​
[03-ABS Brakes]
IDE00326,Steering wheel angle,2.30, °​
I would be inclined to trust the "internal value" because that should be the actual internal G85 data in address 16 itself. If you can get that to zero, and stay on zero, it should be possible to calibrate G85. If you cannot because the readings are erratic please verify that the new unit wasn't a turn or two off center. I hope not because that can damage the unit.
kartashon
C?ID=392126
I did not fix it until yesterday actually. Apparently, I thought I only broke the clock spring, but it turned out I did more extensive damage to the steering wheel column. The steering wheel angle: internal value was stuck at 819.1, while steering wheel angle was flickering between the real input value and the internal value. No matter what I did, the internal value did not budge.
In the beginning I only swapped the clock spring out of the new steering wheel column switch to minimize workloads and risk of breaking something even more. Then I decided to swap the whole column switch, which was an easier job than I imagined, then the flickering on the angle stopped while showing only one value and fixed everything. I manually calibrated the steering wheel angle to be near 0 when steering wheel is pointing straight, and checked that IDE08696-MAS02358: steering wheel calibration angle is in a permissible range. Then drove for few miles, maneuvered widely in an empty parking lot under 15mph hoping that it would calibrate on its own, and it did, as all the warnings went away after restarting the engine. Cleared all default codes including airbags, and they did not comeback on later, at least on the dash. Steering wheel 16-> Basic settings -> Reset steering wheel angle calibration was not throwing any more errors and I was successfully run them as well.
All the steering wheel related features/assists like blind spot monitoring, ESP, cornering lights, etc, are working. Feels like I got an upgrade after a month of driving without them. Steering wheel feedback feels very strange now after driving without power steering/assist. Good decision to get VCDS instead of taking it to the dealer, worth every penny just for this fix alone. Now I am learning how to configure/code B9. Locking the car while engine is running is pretty convenient. Hopefully I can retrofit multi-color ambient lights using VCDS and swapping the current white lights with QQ2 RGB LED modules.
Thanks @Uwe and @Dana for your inputs, greatly appreciated!
