Hello all,
2012 Jetta TDI Premium
My RNS-315 head unit has the built in Bluetooth module (I believe) and came with the car when I bought it. I drove home with my phone connected to Bluetooth and was streaming music no issues. Also I was able to make and receive phone calls. Turned the car off, and when I left for work the next day, the screen says "telephone not supported". So basically I can not connect to Bluetooth anymore as if the internal module went Tango Uniform. Could this be a coding thing that somehow dropped off when I turned the vehicle off? Is there a known issue with the internal Bluetooth modules as compared to the external ones? Any help or info would be appreciated. I have been driving around with out it for a while now.
Wednesday,22,January,2020,13:58:34:59350
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 19.6.1.0 (x64)
VIN: 3VWLL7AJ6CM393621 License Plate:
Mileage: 241810km-150253mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VWLL7AJ6CM393621 Mileage: 241810km-150253miles
Part No SW: 03L 997 030 M HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 387F62E34BB45D8F61-806C
Readiness: 0 0 0 1 1
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001112151651
VCID: 1427F653379C59EF2D-8040
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: B14B400C492B00FD8D1102E6921A0042A71000
VCID: 7DF1B3F7E416B8A7F2-8028
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0162918823
Coding: 030C0C
VCID: 346756D39FDCB9EF4D-8060
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000838963
VCID: 6FED99BF7E7ADA3770-803A
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0257
Revision: B2066001 Serial number: 04371070120025
Coding: 7A994B9A08AB0B0008382000240884C50082502E6000000030A000000000
Shop #: WSC 28600 002 1048576
VCID: 2F6D59BF7EFA9A3730-807A
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH0004CCWU
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0105934
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM04XSKQ
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000AE3D0A
Coding: 303044
Serial number: 3572MSME3225506AZZZQ
Serial number: 3582MSME116C536AZZZ
Serial number: 3516KSME39464217ZZZP
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME3C045B17ZZZX
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME151B2515ZZZP
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME40612515ZZZJ
Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
Component: KOMBI H04 0604
Coding: 270A01
Shop #: WSC 00066 000 00123
VCID: 2959B7A7481EF407EE-807C
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0257
Revision: B2066001
Coding: 102200
VCID: 70EF9AC3A344C5CF69-8024
Component: IMMO H04 0604
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB88AB8D983F1F27-803E
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000227901003
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E5344BB71F0933F3B-807A
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661874335
Coding: 020000
VCID: 2959B7A7401EF407EE-807C
Part No SW: 1K0 035 274 E HW: 1K0 035 274 E
Component: RNS315-NAR H62 0319
Serial number: VWZAZ2N0556613
Coding: 06090001010006000000100A
Shop #: WSC 64522 123 104857
ROD: EV_RNS315NARV2UDS.rod
VCID: 2643BC9B5900DB7FC3-8072
Component: NAR_V3_(0037) 0037
1048630 - CD Changer
B1101 31 [009] - No Signal
Reset counter: 149
Mileage: 241817 km
Date: 2020.01.22
Time: 13:56:15
B11CF 53 [009] - Deactivated
Reset counter: 149
Mileage: 241817 km
Date: 2020.01.22
Time: 13:56:15
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 377D61DF46AA52F768-8062
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K H06 0362
Revision: -------- Serial number: BP225311013876
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 306F5AC36BC485CF29-8064
End-------------------------(Elapsed Time: 03:32)--------------------------
