- Mar 31, 2014
- 17
- 4
- United Kingdom
- C?ID=41543
Hi I have this vehicle in with the EML light on, it only had the fault regards the egr coolant pump but after replacing the pump(genuine pump was fitted) the fault was still present.
I have then proceeded to check the wiring diagram and supply voltage all ok.
Cycling the ignition has introduced all the other faults in the ECM, and I cant clear them either.
Clear faults EML light goes off and cycle the ignition the faults are still present.
Is there a possibility of ECM fault?
Thursday,23,January,2020,10:55:19:32967
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
VIN: WAUZZZ8P6AA024475 License Plate: OU59ZKR
Mileage: 119320km-74142mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72 77
VIN: WAUZZZ8P6AA024475 Mileage: 119320km-74142miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: R4 1.6l TDI H23 9979
Revision: --H23--- Serial number: AUX7Z0I5FNT03N
Coding: 00114016030501080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023M 003017
ROD: EV_ECM16TDI02103L997557R.rod
VCID: B02C989CEBA314CF97-80E4
10 Faults Found:
7300 - Throttle Position Sensor (G69)
P0123 00 [032] - Signal too High
Engine speed: 0.00 /min
Coolant temperature: 9 °C
Intake air temperature: 10 °C
Voltage terminal 30: 12.085 V
Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Throttle valve: activation-PWM_HBR_THR[0]: 0.000 %
Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.995 V
Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.688 V
Throttle valve adapter: offset open-V_THR_TOL[0]: 4.600 V
Throttle valve adapter: status-LF_STATE_THR_DISP[0]: 0
7332 - Mass Air Flow Sensor (G70)
P0103 00 [032] - Signal too High
Engine speed: 0 /min
Battery voltage: 11.7 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
7411 - Turbocharger Boost Control Position Sensor Circuit
P2564 00 [032] - Signal too Low
Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: -13.025 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 95.001 %
High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.000 V
Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.501 V
High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 0
10156 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [100] - Electrical Fault
Mileage: 119328 km
Date: 2020.08.23
Time: 09:36:53
Voltage terminal 30: 11.972 V
Glow status-STATE_GLOW: 48
Fuel temperature-TFU: 10 °C
Sensor for engine block temperature: raw value-Coolant temperature: 9 °C
10158 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [100] - Electrical Fault
Mileage: 119328 km
Date: 2020.08.23
Time: 09:36:53
10131 - Fuel Pressure Sensor (G247)
P0193 00 [032] - Short to Plus
Voltage terminal 30: 11.859 V
Supply voltage of analog output 1-VCC_1: 5.00 V
Fuel high pressure sensor: unconditioned voltage-VP_PFU: 4.9939 V
Fuel pressure: 200000 kPa rel
Fuel high pressure: actual value-FUP_FIL: 199.997 MPa
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 0.000 kPa
ECM system status-Binary 16 Bit: 00000000 00000000
10113 - Fuel Pressure Regulator Valve (N276)
P2294 00 [032] - Open Circuit
Fuel pressure regulator valve actual value-CFB_PCV_MES: 0.073 A
Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV: 3.2877 V
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
Fuel Pressure Regulator Valve-PCV: 0.000 %
Fuel Metering Valve-VCV: 0.000 %
9867 - Coolant Pump 2
P261A 00 [168] - Open circuit
Fault Frequency: 90
Mileage: 116607 km
Date: 2020.06.05
Time: 21:40:40
Engine speed: 2047.50 /min
Normed load value: 23.1 %
Vehicle speed: 55 km/h
Coolant temperature: 54 °C
Voltage terminal 30: 14.231 V
Coolant temperature at radiator outlet: actual value-TCO_2: 14 °C
Battery voltage: 14.6 V
9870 - Coolant pump 2
P261B 00 [237] - Implausible signal
Fault Frequency: 41
Mileage: 117289 km
Date: 2020.06.28
Time: 13:06:35
Engine speed: 784.50 /min
Normed load value: 9.8 %
Coolant temperature: 66 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.456 V
Coolant temperature at radiator outlet: actual value-TCO_2: 13 °C
Battery voltage: 14.0 V
9871 - Exhaust Gas Recirculation Cooling Valve Control
P2425 00 [032] - Open Circuit
Sensor for temp after charge air cooler: raw value-TBA_MES: 10 °C
Charge air pressure: actual value-MAP_MMV: 200.00 hPa
Air mass: actual value:: 0.00 g/s
Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL: 1.00000
Readiness: 1 2 0 0 0
Part No SW: 1K0 907 379 BA HW: 1K0 907 379 BA
Component: ESP MK60EC1 H45 0109
Revision: 00H45001
Coding: 13422012492400FEC80F04EB921E00913800
Shop #: WSC 25463 000 1048576
VCID: F2A852942D2F66DF21-80A6
Part No SW: 8P0 820 043 BK HW: 8P0 820 043 BK
Component: KlimavollautomatH09 0130
Revision: 000105 Serial number: 8P0820043BK
VCID: F6A06E8481477AFF0D-80A2
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 104 0575
Revision: 00104 AH
Coding: 0E000A2CB005F0C0207041E00000015C431A29AA004DC12AE4008F800041
Shop #: WSC 00751 210 98641
VCID: B2289294EDAF26DFE1-80E6
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Component: LIN BACKUP HO H03 1301
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0140
Revision: -------- Serial number: 003FB001W2XB
Coding: 30314238303830303037554A305238503053
ROD: EV_Airba10AURB4.rod
VCID: CFEEFB60965D6B37EE-809A
Serial number: 3572DRB40000916069DU
Serial number: 3582DRB400009160F21L
Serial number: 35128RB400004E2D41CP
Serial number: 35228RB400004E275C7R
Serial number: 35547RB400004DD073AU
Serial number: 35647RB400004DCF78C9
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004012
VCID: C6C0DE44B127AA7F5D-8092
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H02 0980
Revision: D0H02002 Serial number: 2245I002002972
Coding: 0004428
VCID: C0CCC85C9303844F67-8094
Part No SW: 1K0 907 530 AC HW: 1K0 907 951
Component: J533 Gateway H17 0222
Revision: H17 Serial number: 1021J095190695
Coding: E9807F06000602042103
VCID: E89C30FCDBF39C0F8F-80BC
Revision: D0H02002 Serial number: AUX7Z0I5FNT03N
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0131764
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 232 2901
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: AF2E9BE03E9D0B378E-80FA
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0131764
VCID: C7DED340B62DB377A6-8092
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 E HW: 8P0 035 152 E
Component: R Chorus2+ H02 0280
Revision: 00H02000 Serial number: AUZ1Z2I5214719
Coding: 0600021
VCID: AD1281E834917927BC-80F8
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0222
Revision: -------- Serial number: 1021J095190695
Coding: 0303085A
VCID: E89C30FC1BF39C0F8F-80BC
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790585430
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 06314 000 1012544
VCID: C2C8C2549D0F965F71-8096
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: C3C6C75082159F577A-8096
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H34 0600
Revision: 00000000 Serial number: 00000005103746
Coding: 0001222
VCID: F5A269889C4171E704-80A0
End----------(Elapsed Time: 01:29, VBatt start/end: 14.3V/14.4V)-----------
