Where does one begin? 2009 Audi A4 B8 2.0T
audiyadosir
C?ID=342309
I was hit by another driver. The body shop tore down my car to get the full repair estimate without my permission. Visual inspection only for initial repair estimate, champs! Duh! :banghead:
Made the insurer release my car and the shop put it back together and every single module had an error code. Every single module.
So, I cleared them all, fixed what I knew how to fix and here I am...with this mess. I don't even have passenger seat memory, but my car thinks the driver seat is the passenger seat and I can't get VCDS to reassign the number from 06 to 36 no matter what i do. Seat seems to work okay, up, down, front, back, backrest up and down, seat heat all good...wrong seat <sigh>
Lil help?
If I flash the MMI with the original CDs, "the system" or ECM will get a re-installation of the basic original software/drivers/whatever for all installed option modules, yes? If so, how do I upgrade from the base point without going to Audi and have them charge me too much to install software from svm? Is this fixable using vcds?
Tuesday,21,January,2020,20:56:32:13712
Dealer/Shop Name: Three Time Mechanic
VIN: WAUGF78K49A192023   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46
          47 52 53 55 56 62 65 67 6C 72 77
VIN: WAUGF78K49A192023   Mileage: 179280km-111399miles
0F-Digital Radio -- Status: Not registered 0011
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 010C010A190F0160
   Shop #: WSC 22145 444 84529
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79AFEEE6D95A0BCF8E9-802C
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0051
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 06335 123 12345
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 363525DAA8C424B723B-8062
   Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
   Component: ESP8 quattro  H04 0210
   Coding: 150500
   VCID: 7DA7FAF6CDF237EFA21-8028
   Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
   Component: BCM2 1.1      H80 0145
   Coding: 090200
   VCID: 75B7E2D6F5C26FAFEA1-8020
   Subsystem 1 - Part No SW: 8T0 959 754 G    HW: 8T0 959 754 G
   Component: FBSAUDIB8 IDG  H61 0072
   Serial number: 0511000078743003
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000102844008
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:39
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-BFS       H05 0043
   Revision: AA000000    Serial number: 00001001158803
   Coding: 00585300000000000000
   VCID: 77ABE8DEEFCE1DBFF8D-8022
03333 - Motor for Cushion Angle Adjustment
                    Fault Status: 01100101
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:38
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:38
03330 - Motor for Fore/Aft Adjustment
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:39
03331 - Motor for Backrest Angle Adjustment
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:39
03332 - Motor for Height Adjustment
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:39
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340AJ097518153
   Coding: 0001003
   VCID: 43D34C0EE796811F945-8016
   Subsystem 1 - Part No: 8T0 919 609 A
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000206757
   Subsystem 3 - Serial number: 0102.12.080000000100010370ÿ
   Subsystem 4 - Serial number: 010370ÿ
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01130120090307
   Coding: 64002000
   VCID: 72BDD9CA84AC7897CF3-8026
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000293598
   Coding: 260810091023CF010000080300003D0D4F9C460800010161000000
   VCID: 303913C24A200A87797-8064
   Component: WWS 130109  H06 0070
   Serial number: SWF09010135573
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10352847
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
   Serial number: 00000000000901091646
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBI8722594
   VCID: 2A0D01AA60FC7057B73-807E
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7I0506078
   Coding: 0000100
   Shop #: WSC 06335 000 00000
   VCID: 313F16C64D2A038F769-8064
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:50
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140900804852
   Coding: 200103
   VCID: 3C2137F29668FEE7D5F-8068
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD14RLR$
   Coding: 303836354230303030304A55304C384B3053
   VCID: 40D94302FA009A07897-8014
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R08000039R4
   Serial number: 6334MSME426570164
   Serial number: 6344MSME447118122
   Serial number: 6352QSME341A2518B
   Serial number: 6362QSME3C172620B
   Serial number: 63732SME3E17302C+
   Serial number: 63832SME3E171604-
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304IA800023
   Coding: 000017
   VCID: 3D273AF68D72F7EFE21-8068
   Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
   Component: KOMBIINSTR.   H18 0224
   Revision: 00000000    Serial number: 9E17670D8
   Coding: 030511000300D705020201
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E091078306
   Coding: 000303
   VCID: 4EC56D3A30D47C770BB-801A
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1805B278041208
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:40
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:40
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:44
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   Coding: 020000
   VCID: 2B0304AE6306695F4C5-807E
Address 36: Seat Mem. Drvr
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 341AN097522836
   VCID: 38292BE2AE50D2C7317-806C
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008282729
   Coding: 011F03200F00410101
   VCID: 41DF4606F18A930F869-8014
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:39
   Revision: 00002001    Serial number: 0116443622
   Coding: 016216E220F2C406033002
   Component: GTO BF  H06 0040
   Serial number: 00000000000000111055
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS130  H06 0037
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:38
00198 - Automatic Day/Night Interior Mirror (Y7)
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:42
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 AD    HW: 8T0 035 223 G
   Component: DSP STD       H08 0300
   Revision: S2600000
   Coding: 020201
   VCID: 70B9D3C28AA04A87397-8024
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008294094
   Coding: 011F03200F00410001
   VCID: 40D94302FA809A07897-8014
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:39
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:39
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 00000000290993
   VCID: 323D19CA442C38970F3-8066
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 77ABE8DEE3CE1DBFF8D-8022
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 357AT097517255
   Coding: 0000002
Address 62: Door, Rear Left
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140782266448
   Coding: 0CD154
02214 - Tire Pressure Warning
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 183
                    Mileage: 179280 km
                    Date: 2020.01.21
                    Time: 20:43:38
                    Bin. Bits: 00000000 10100101
                    Voltage: 12.50 V
                    Text:  12,5°C; -0,66bar;3453386624;80h; 24°C
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000812030072
   Shop #: WSC 12336 024 394758
   VCID: 34311FD2B23836A71DF-8060
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8Y92OH
   Coding: 1000007
   VCID: 372B28DEA34EDDBF38D-8062
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000008368121
   Coding: 010F01200040220001
   VCID: 44D14F12EE988627ADF-8010
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005076316
   Coding: 0010900
   VCID: 2809FBA27EF04247A17-807C
End----------(Elapsed Time: 02:13, VBatt start/end: 12.3V/12.3V)-----------
NostraJackAss
Why are you not requiring the shop or insurance company to pay for it if a result of being torn down or related damage from a collision?
IIRC, the drivers and passenger's seat memory modules are the same and their address is determined by "PIN Coding", meaning there's a pin on the connector that's tied to GND or +12 or left to float that determines whether the module is 06 or 36. Check wiring diagrams to be sure.
audiyadosir
C?ID=342309
Seriously, can’t believe I have to explain what I went through to get more direct assistance from a forum I joined to help me use a product I don’t know how to use that well, but have read enough to get as far as I did, but since you asked, Jack...
It took me 2 weeks to get my car back from the body shop, put back together in “accident condition” after having to sign a waiver stating I wouldn’t hold the body shop liable because they made my car unsafe to drive...even though I dropped it off to them drivable, in what I believed to be relatively safe driving condition with a dented in left front quarter panel, detached lower bumper that I reattached, grille and belly pan that I reattached (belly pan in the trunk), scarred right front rim from where I was pushed into the right curb by The Idiot, and a dented hood that closed okay, but cockeyed my left headlight a little. My insurer was going to total my car, so they didn’t care my car was dismantled without the proper authorization. What I signed for was the full repair job, not a tear down auth and the document wasn’t legally sufficient to stand as an authorization to tear down my car, but nobody cared.
The body shop doesn’t get to see the final repair estimate so all they know is they’ve got a damaged car sitting in their lot. My insurer didn’t want me to see the repair estimate and the repair agent actually declined to produce the full repair estimate when I asked because they’d deemed my car a total loss, which surprised the body shop and me, and allegedly the repair adjuster. Anyway, knowing my insurer does their full estimates online, as she’s telling me she won’t send me the total repair estimate because it’s a total loss, I logged into the insurance website and download the total repair estimate they’d done. There was a $2000-$2100 disparity between what they deemed my car’s ACV, plus $1932 they could sell for salvage and although my car wasn’t given a proper valuation they didn’t care.
Meanwhile, my insurer is telling me I have to take the rental car back (due 3 days after a determination of total loss is assigned by my insurer and a settlement offer is made as per my contract), my insurer is also paying storage to the body shop at $250/day, my adjuster is telling me if I pick it up I get a salvage title and a check or they keep it and the storage keeps adding up and they’re not coming clean on my options, and it’s all based on a legally insufficient document that I signed to authorize the full repair of my car, not a tear down estimate with a reassembly estimate, plus an express authorization to tear down my car for the purposes of a full repair estimate, which is what California law requires <sigh>.
So, before anyone starts telling me to find another insurer, these are the facts of my situation and the answer to the find another insurer question is “No, shit,”. First, I have to get my property back, which I did... without a salvage title. Now, I can get the other appraisal I’m due under my contract and California Law and since I posted this request for help I have since gone above everyone’s head at my insurer’s office and gone to the insurer’s district claims manager, who’s having my car repaired this Tuesday probably because he doesn’t think my aftermath is worth the $2k difference in the valuation and the repairs he’ll have to put up with if he didn’t agree to not total my car.
So, after two weeks, daily emails declining their determination, demanding info on how they reached such a determination, why they weren’t releasing my car to me without threats of salvage, tearing apart the body shop via my insurer’s repair adjuster and her supervisor because they didn’t abide by CA law when they tore my car down, but my insurer agreed to pay the body shop to put my car back together again (or the shop realize they screwed up so they put it back together without a charge) and meanwhile I’m contacting the Insurance Commissioner about my insurer and the “Bureau of Automotive Repair,” an alleged government agency in CA responsible for the enforcement of auto body and auto repair work as per the State’s “owner’s rights” statement. So I FINALLY get my property back and every module has an error...and I didn’t give two shits the lights were pointed 10’ in front of me, it was raining, I had no power brakes, seemed like no power steering and every warning light going off...I didn’t care. I just got her home and I believe all of that is a good reason why I didn’t ask the body shop to fix the computer and why I haven’t broached the topic with the regional director of claims...who’s agreed to allow me up to $7k in repairs done to the body of my car for what I believed to be a fender bender.
As I said, I fixed all of the other modules as best I knew how with the coding and other things I saved from prior scans. I’m just stuck now. I guess I could ask them on Tuesday if the body shop can update my ECM, but I’d prefer not to have a rocky road moving ahead because it’s taken me 2 weeks to get here without a salvage title and with an insurer who’s going to fix my car without totaling it. I dunno. I guess I just think I’ll be lucky to stay out of Court and get my car back, fixed, with an intact title that I hadn’t thought to see if they’d update the computer and fix the electric seat memory. Luxury complaint, like tears rolling from my eyes as I’m screaming like a spoiled little child that “my Audi’s broke!” I dunno...but on to the wiring diagram direction from Uwe...
audiyadosir
C?ID=342309
Uwe, thanks for the direction...
I’m not quite sure I understand how the wiring diagrams are going to help. I have them. But, the 06 position doesn’t exist in my VCDS scans prior to the accident. After the accident my computer doesn’t read my driver’s seat, saying 36 can’t be reached, but it thinks the passenger seat is my seat even when I move it up and down, back and forward with the controls. It’s all plugged in below the seat, red to red, airbag yellow to airbag yellow, etc. The Computer just thinks the passenger seat it my seat and the passenger seat doesn’t have a seat memory module in the door beneath the door handle like my driver seat does. I’m lost. Any help appreciated! Oh, and just for shits and giggles, so as not to be presumptious they cannot help me after all I’ve been through, I will ask on Tuesday when I drop her off for body repairs at a new, reputable shop, if the shop can flash my car‘s computer and update all the modules even though it wasn’t part of the accident.
NostraJackAss
Well did you establish at each module which is not with communication, if power, ground and twisted set for CAN high/low is available?
Did you check all fuses?
One by one let's establish communication and see if CP goes away, if not you will need SVM session at dealer, understand?
Sorry to hear about your issue with insurance company and body shop fun, however, did you learn the importance about signing a document before reading it and a go pro camera to capture such fraud to possibly show a true meeting of minds didn't allegedly take place?
Again, I believe the module will respond at address 36 (driver's seat} if the wiring to it is configured one way, and 06 (passenger's seat) if the wiring to it is configured another way. The difference is probably just one pin and could be explained by something as simple as a broken wire.
