Reported ROD file missing
BavarianCare
Ireland
C?ID=11022
Per title,
Wednesday,22,January,2020,20:12:32:34893
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WV1ZZZ2HZCA072939   License Plate: 12MO2775
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 10 15 17 19 22 25 37 56 69
Address 01: Engine (J623-CDCA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FA    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9745
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 01194012232600080000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20BTD01103L906019FA 002005
   ROD: EV_ECM20BTD_002_VN81.rod
   VCID: 6FBBD185B71588AF20D-803A
4875 - Coolant Pump 2
          P261A 00 [032] - Open circuit
                    Mileage: 255859 km
                    Date: 2085.14.15
                    Time: 14:21:01
                    Engine speed: 873.00 /min
                    Normed load value: 38.8 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 39 °C
                    Intake air temperature: 10 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 14.200 V
                    Unlearning counter according OBD: 33
                    Coolant temperature at radiator outlet: actual value: 5.7 °C
                    Bypass valve for EGR cooler: status-Bits 0-7: 00000000
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 00000000
                    EGR cooling function: status-Bits 0-7: 00000000
                    exh.gas recirc. (EGR) cooler pump: specified value: 69.32 %
                    Temp sensor for EGR after cooler: raw value: -270.6 °C
                    Exh.gas temp.sen 1: 91.8 °C
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 J    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0109
   Revision: 00H44001
   Coding: C07324B6919B039724AB89A6AF5990
   Shop #: WSC 07456 790 49164
   VCID: 372B29E58F45006F38D-8062
                    Reset counter: 100
                    Mileage: 249208 km
                    Date: 2018.14.31
                    Time: 17:22:37
                    Count: 16384
                    Count: 4097
                    Count: 8239
                    Count: 1022
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H0 907 040 C    HW: 2H0 907 040 C
   Component: ClimatronicT5 H18 0404
   Revision: 00001002
   Coding: 0000000002
   Shop #: WSC 07456 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 211FE7BD31416EDFE69-8074
          U1111 00 [008] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 100
                    Mileage: 249208 km
                    Date: 2082.14.31
                    Time: 17:31:06
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 69
                    Mileage: 255214 km
                    Date: 2084.14.20
                    Time: 19:11:39
9477872 - AC Compressor First Run-In
          B109E F0 [009] - Not Performed
                    Reset counter: 60
                    Mileage: 249208 km
                    Date: 2082.14.31
                    Time: 17:31:06
   Part No SW: 6R7 937 087 K    HW: 6R7 937 087 K
   Component: PQ25 BCM      H27 0532
   Revision: -1------    Serial number: 1009009900
   Coding: 3D0002380C410400923808100C4B84D50080410E60000000300000000000
   Shop #: WSC 22002 758 00808
   VCID: 4CC16609E6C393B765F-8018
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3321
   Coding: 110000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3321
   Coding: 110000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor      001  001 0103
   Component: LIN BACKUP HORN H11  H11 9005
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0083985
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3321
   Coding: 100000
   Subsystem 8 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3321
   Coding: 100000
                    Fault Frequency: 11
                    Reset counter: 41
                    Mileage: 255724 km
                    Date: 2020.14.27
                    Time: 10:35:30
03302 - Response Closing Status of Passenger's Door
                    Reset counter: 45
                    Mileage: 256122 km
                    Date: 2021.14.18
                    Time: 09:21:13
   Part No SW: 7E0 919 475 D    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361206901440
   Coding: 118003
   Shop #: WSC 53863 115 183226
   ASAM Dataset: EV_VW75XParkAssis4K A01006
   ROD: EV_VW75XParkAssis4K_A01.rod
   VCID: 33331DF59BBDEC4F045-8066
1079572 - Rear Right Parking Aid Sensors
          B1079 14 [009] - Open or Short to Ground
                    Reset counter: 60
                    Mileage: 249208 km
                    Date: 2082.14.31
                    Time: 17:47:46
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00M H07 0013
   Revision: --------    Serial number: 003HN007ZWVJ
   Coding: 00000000000000000000000000000000304D
   Shop #: WSC 07446 790 50316
   Serial number: 3495RRB404P126SE8OH4
   Serial number: 3505RRB404P126SEFGS6
   Serial number: 3555YRB405D15A9MC94C
   Serial number: 3565YRB405B14E7CB8LH
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 2H0 920 963 B    HW: 2H0 920 963 B
   Component: KOMBI         H02 0505
   Coding: 450A00
   ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04114
   ROD: N/A
   VCID: 290FFF9D4971A69FBE9-807C
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
   Part No SW: 6N0 909 901     HW: 6R7 937 087 K
   Component: GW-K-CAN TP20 H27 0532
   Revision: -1------
   Coding: 742300
   Shop #: WSC 07462 790 50316
   VCID: 70B9D2F9AAAB9757397-8024
   Part No SW: 2H0 927 755 C    HW: 2H0 927 755 C
   Component: SG offroad VTG      0155
   Revision: 00H07000    Serial number: T1IYC114213K1X
   Coding: 0000013
   VCID: 303912F9662BD757797-8064
   Component: IMMO          H02 0505
   Shop #: WSC 00078 790 12345
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC0918CF76D87773-803E
   Part No SW: 3C0 035 279 H    HW: 3C0 035 279 H
   Component: RNS315-EU   H36 0263
   Serial number: VWZAZ2M3977476
   Coding: 000004110200160000031002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2809FA99527B9F97A17-807C
   Component: EUR_W_0038  0038
   Revision: 3A001001    Serial number: 00008030130770
   Coding: 0100000100000000
   VCID: 303912F96A2BD757797-8064
02562 - Trailer; Brake Lamps
                    Fault Status: 11101010
                    Reset counter: 252
                    Mileage: 255950 km
                    Date: 2021.14.16
                    Time: 18:08:10
02563 - Trailer; Right Tail Lamps (M61)
            010 - Open or Short to Plus - Intermittent - MIL ON
                    Fault Status: 10101010
                    Reset counter: 37
                    Mileage: 255950 km
                    Date: 2021.14.16
                    Time: 18:08:10
02564 - Trailer; Left Tail Lamps (M60)
                    Reset counter: 252
                    Mileage: 255950 km
                    Date: 2021.14.16
                    Time: 18:08:11
End----------(Elapsed Time: 01:02, VBatt start/end: 13.7V/13.6V)-----------
No, sorry, "EV_Kombi_cÿ_VDD_RM09" is not a valid ASAM Dataset name. We've seen this before. It seems to be a prank that the VDO programmers played on people who "manipulate" these clusters using certain back-door techniques.
BavarianCare
Ireland
C?ID=11022
Interesting.
It is very possible this Amarok was 'clocked'. He has nothing but problems with it for past year.
