2009 audi a3 abs long coding error 31
RyanRCS
IE
C?ID=390755
new to the forum but really need HELP!!!!! to cut a long story short the car came in custoomer had ordered new plastic facia for the clocks as he broke them but he disconnected the clocks and then turned the ingition on and forgot the clocks where disconected he has the previous data scan with the code but vcds wont accept it error 31
has wiped abs coding to 00000000000000000000
the sorftware he was using wasnt legit but mine is PAID FOR but wont work any help appriciated both auto scans attahced
this is all the advanced ID matching the VIN
Tuesday,21,January,2020,22:26:12:41992
VIN: WAUZZZ8P99A011568   License Plate: 08G18904
                Address 01: Engine
Control Module Part Number: 03G 906 056 S
  Component and/or Version: R4 1,9L EDC  000SG  2917
           Software Coding: 0000071
            Work Shop Code: WSC 66565
                      VCID: 372B2C3F9347C43F38D-8062
Advanced Identification
     Serial number: AUX7Z0H5FNR0IU
     Identification: BPG-810
     Revision: --H08---
     Date: 19.06.08
     Test stand number: 1349
     Manufacturer number: 0134
Flash Status
     Programming Attempts: 1
     Successful Attempts: 1
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 00032 257 66565
     Flash Date: 07.07.14
Software
     P0101
     HBXC
Misc.
     Hardware number: 03G 906 021 AB
     Immo Challenge: 73 67 AE 63
Car Info
     Chassis Number: WAUZZZ8P99A011568
VCDS Info:
       Labels: 03G-906-021-BLS.clb
       Readiness: No script available
                Address 17: Instruments
Control Module Part Number: 8P0 920 982 C
  Component and/or Version: KOMBIINSTR. VDO H15 0820
           Software Coding: 0006428
            Work Shop Code: WSC 80093
                      VCID: 392F2A07A553D24FCE9-806C
     Serial number: 2245H004002070
     Identification: VDD-024
     Revision: D0H15004
     Date: 27.06.08
     Test stand number: 7601
     Manufacturer number: 0678
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Flash Tool Code: 00000 000 00000
     Flash Date: 27.06.08
Misc.
     Hardware number: 8P0 920 982 C
     Lot Number:
     Type Lock: VDD-
Car Info
VCDS Info:
       Labels: 8P0-920-xxx-17-MY8.clb
     Revision: D0H15004
     Date: 27.06.08
Flash Status
Misc.
     Lot Number:
     Type Lock: VDD-
Car Info
VCDS Info:
                Address 25: Immobilizer
           Software Coding:
            Work Shop Code: WSC 00196
     Revision: D0H15004
     Date: 27.06.08
Misc.
     Lot Number:
     Type Lock: VDD-
     Immo Challenge: EA F7 9C 45
Car Info
VCDS Info:
       Labels: 1K0-920-xxx-25.clb
Data from customer's clone/pirate scan removed.
RyanRCS
IE
C?ID=390755
anybody able to help ????:confused:
RyanRCS
IE
C?ID=390755
yeah all part numbers are original from the car nothing was replaced but now wont accept coding
NostraJackAss
The information is not consistent with what has been stated by you or the customer has lied to you about
" something "!
RyanRCS
IE
C?ID=390755
the car was delivered to us he said he removed the instrument cluster to replace the broken plastic screen witch he did but when he turned the ignition on he forgot the instrument cluster was not connected and plugged it back in and had the ABS ESP and brake warning on the dash.
he said he plugged it in with his cloned VCDS and that is what he has sent me I have tried to enter the code from the previous scan he sent but not accepting coding
im here asking for help as it was supposed to be a simple code in and out the door witch it hasn't tuned out to be
I can only give the information that I have been given if you cant help that's fine
I've edited the thread title; the VIN shows us this is a 2009 MY car, not 2008.
NostraJackAss
Well if that is what your customer told you, I'm completely comfortable letting you know that your customer is lying to you or is providing wrong information!
RyanRCS
IE
C?ID=390755
Ok I will ring the customer and try and get to the bottom of it
RyanRCS
IE
C?ID=390755
Right so a phone call to the customer and the story unfolds so he damaged the clocks facia and tried putting a different set of clocks into the car but he didn’t have any way of programming them as the Immobilizer blocked it but used the plastic from the other clocks but then had no ABS coding and that’s where he brought it to us
Does that sound likely
Can anyone Help I’m sick of looking At this car
NostraJackAss
He is still holding back information and being a filthy PIRATE liar to you!
RyanRCS
IE
C?ID=390755
Ok jack I don’t know what to say is there anything I can do or am I just gonna be stuck with this issue you say he’s holding back but I’m out of pocket for this already and need to get it sorted is there a solution
Or a way to rectify it Please I’m asking for help
NostraJackAss
I don't blame you for this, I'm just telling you your customer is indeed a liar or holding back information, do you really want to deal with someone like this? :rolleyes:
PLEASE PROVIDE A PICTURE OF VIN NUMBER DATA PLATE OF DASH & DOOR JAM OF CAR IN CUSTODY & ALSO PR CODE TAG IN TRUNK AREA.
NZDubNurd
New Zealand
C?ID=230482
All your time is chargeable - you didn't break the car ;) More-so, if they won't tell you what they've really done! Or the fact they've screwed around with pirated tools and then want it fixed by a legit user.
If the coding isn't accepted: then it's wrong or there is more to the story.
It's happened before when "clones" have altered strings when reading or writing (most recently in BCMs though).
but WHY was he doing an autoscan WHILE the clocks were out of the car??? "He forgot" while he sat at the steering wheel, connected his "VCDS" and turned on the ignition and ran through the whole process??? Yeah right!
That autoscan should have been before he started, but it could still be his "clone" causing issues.
The CAN gateway is looking for a sliding door too... so there has been some other fiddling at some point.
I guess Jack and some others will try to reverse engineer the coding... make sure you charge for all your time - it's not your problem ;)
NostraJackAss
In this case the data provided is not TRUTHFUL & possibly vicariously.
Still no photos, must not be imperative..............
RyanRCS
IE
C?ID=390755
yeah I don't but as ive time on it already and this will not be got away with the price just went up I have no idea but these lads think they can buy the cable and the software off of ebay for next to nothing and wonder why genuine users charge for the service
RyanRCS
IE
C?ID=390755
im trying to upload a picture but wont let me
NostraJackAss
RyanRCS
IE
C?ID=390755
RyanRCS
IE
C?ID=390755
[/IMG]
