Top servis
Unverified
CCodifica allegato
Did you miss this?![]()
Provided you have a GENUINE Ross-Tech cable and you use the ENGLISH version of VCDS it should be OK.tomorrow i send you a scan with the vcds i haven't used it for a while i should have version 20 ... will it be good for my machine?
Data from Clone devices is not welcome here -- Deleted ---
This forum is run by Ross-Tech to support owners of genuine VCDS - so using a clone isn't going to get you any help here.I thank anyone who will give me a hand since this problem has had other forum members
Uwe said:Getting help in this forum requires the use of a legitimate VCDS system.
They are available directly from us:
https://store.ross-tech.com/shop/cat/VCDS
... Or from any of our authorized resellers:
http://www.ross-tech.com/distributors.php
Let us know if/when you get one and we'll adjust your forum status.
If ODIS does the exact same things, then VAG probably has a forum to help you with Retrofits, right?in fact I don't use it, I work with odis and it does the exact same things, so I asked you for help. Thanks
