2008 A5 door module coding
fraazz
Canada
C?ID=101765
Hi there.
Replaced a window regulator on this A5 with all dealer parts including control module. Having an issue coding as in it won't accept coding the new module and there is limited info with the coding helper.
Tuesday,21,January,2020,16:39:39:30041
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4513.4
Dealer/Shop Name: Euro Otto Sport
VIN: WAUDK68T58A035617   License Plate: BLKA5
Mileage: 139300km-86557mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 3C 42 46
          47 52 53 55 56 65 6C 77
VIN: WAUDK68T58A035617   Mileage: 139300km-86557miles
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine (J623-CALA)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8T0 907 559 H    HW: 8T0 907 559 B
   Component: 3.2 SIMOS8.2  H04 0005
   Revision: --------
   Coding: 01140009180F0121
   Shop #: WSC 06325 123 12345
   ASAM Dataset: EV_ECM32FSI8T0907559H A01003
   ROD: EV_ECM32FSI8T0907559G.rod
   VCID: 47DEA05CFED8AD7726-8012
6202 - EVAP System
          P0456 00 [096] - Very Small Leak Detected
                    Mileage: 138876 km
                    Date: 2019.12.24
                    Time: 05:48:34
                    Engine speed: 2326.00 /min
                    Normed load value: 74.9 %
                    Vehicle speed: 86 km/h
                    Coolant temperature: 69 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 14.523 V
                    Unlearning counter according OBD: 3
                    Height correction: 1002.9551 hPa
                    Intake air temperature: 8.25 °C
                    Coolant temperature (unfiltered): 69.0 °C
                    Vehicle speed: actual: 86 km/h
                    T_AST_ENVD: 950.90 s
                    TEMP_CAT_ENVD[0]: 655.000000 °C
6208 - Fuel Trim: Bank 1 (Add)
          P1136 00 [104] - System too Lean
                    Mileage: 138368 km
                    Date: 2019.12.12
                    Time: 18:06:13
                    Engine speed: 2161.00 /min
                    Normed load value: 42.7 %
                    Vehicle speed: 95 km/h
                    Coolant temperature: 97 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 14.421 V
                    Unlearning counter according OBD: 13
                    Engine speed: actual: 2592 /min
                    MAF_ENVD: 185.20000 mg/stroke
                    Coolant temperature (unfiltered): 99.0 °C
                    Engine: operating status: PL
                    T_AST_ENVD: 3212.50 s
                    STATE_LS_ENVD[0]: 2
   Part No SW: 8K0 907 379 Q    HW: 8K0 907 379 Q
   Component: ESP8 quattro  H04 0170
   Coding: 0D0500
   Shop #: WSC 06325 000 00000
   VCID: 47DEA05CF6D8AD7726-8012
   Part No SW: 8K0 907 289 F    HW: 8K0 907 289 F
   Component: BCM2.01       H38 0253
   Revision: 00003002
   Coding: 0B0000
   VCID: 3C34CFB0BF1EFEAFBB-8068
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H35 0052
   Serial number: 0507000001473011
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000006315006
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 85
                    Mileage: 139300 km
                    Date: 2020.01.21
                    Time: 14:17:22
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001069992
   Coding: 08017025002444111000
   VCID: 42C8B148DDFA885FF1-8016
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 D    HW: 4E0 035 729 A
   Component: Interfacebox    H43 3010
   Revision: 00000000    Serial number: 340BI087505318
   Coding: 0005003
   VCID: 3A38C9A8752AC09FA9-806E
   Subsystem 1 - Part No: 8T0 919 609 A
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000035423
   Subsystem 3 - Serial number: 0120.12.070000000100010088ÿ
   Subsystem 4 - Serial number: 010088ÿ
02244 - Button in Control Head is Stuck
                    Mileage: 139299 km
                    Date: 2020.01.16
                    Time: 16:00:30
                    Bin. Bits: 00000000
                    Bin. Bits:  0010000
                    Bin. Bits:      000
   Part No SW: 8T1 820 043 R    HW: 8T1 820 043 R
   Component: KLIMA 3 ZONEN H05 0120
   Revision: C1000000    Serial number: 0120.02.080506
   Coding: 46022000
   VCID: 40CCBB40D3F69A4FE7-8014
                    Reset counter: 229
                    Mileage: 137859 km
                    Date: 2019.11.27
                    Time: 18:03:11
                    Fault Status: 01101000
                    Reset counter: 229
                    Mileage: 137859 km
                    Date: 2019.11.27
                    Time: 18:03:11
                    Temperature: 32.0°C
                    Reset counter: 125
                    Mileage: 139300 km
                    Date: 2020.01.21
                    Time: 16:26:25
   Component: BCM1 1.0      H21 0253
   Revision: 05021001    Serial number: 00000000100919
   Coding: 26001096451CAF210601000300003D3D4F9C138800010141000000
   Shop #: WSC 12345 123 61029
   VCID: 302CEB8063560ACF17-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150208  H13 0040
   Serial number: SWFBIE 0000432
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10064242
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 J    HW: 8K0 941 531 J
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002002080393
                    Reset counter: 229
                    Mileage: 137859 km
                    Date: 2019.11.27
                    Time: 18:03:00
03207 - Charisma Switch Module
                    Reset counter: 229
                    Mileage: 137859 km
                    Date: 2019.11.27
                    Time: 18:03:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H41 0390
   Revision: 00041001    Serial number: AUZ5ZBH8325104
   VCID: 2A18F9E8858A701FD9-807E
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7H0252261
   Coding: 0000102
   VCID: 2F2EE8FCBE6815370E-807A
                    Reset counter: 19
                    Mileage: 138410 km
                    Date: 2019.12.13
                    Time: 05:30:27
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330805613592
   Coding: 300001
   VCID: 383CD3A08B26D28F5F-806C
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EGD05GYW4
   Coding: 30413833433030303030554A304C38543053
   Shop #: WSC 91450 999 92482
   VCID: 42C8B148D5FA885FF1-8016
   Serial number: 6334MSME3C63052EI
   Serial number: 6344MSME3A026F74L
   Serial number: 6352QSME562D0F39U
   Serial number: 6362QSME5630095BH
   Serial number: 63732SME576B531F9
   Serial number: 63832SME4E1A41270
   Component: Lenks.Modul   H11 0012
   Revision: --------    Serial number: 90315HBO0007I
   Coding: 000016
   VCID: 3D32C2B4A404F7A78C-8068
   Part No SW: 8T0 920 931     HW: 8T0 920 931
   Component: KOMBIINSTR.   H28 0216
   Revision: 00000000    Serial number: 71U305N28
   Coding: 830D010003000008020000
   VCID: 74A42790D7CE76EFB3-8020
   Part No SW: 8T0 907 468 G    HW: 8T0 907 468 G
   Component: GW-BEM 5CAN-M H08 0084
   Revision: FB102034    Serial number: 3400F081108091
   Coding: 000003
   Shop #: WSC 79408 025 535012
   VCID: 45C2AA54CCD4BF67D4-8010
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H03 0150
   Serial number: 18006E74020208
                    Fault Frequency: 8
                    Reset counter: 125
                    Mileage: 139300 km
                    Date: 2020.01.21
                    Time: 14:17:22
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 271E00DC56984D77C6-8072
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001069691
   Coding: 08197325002444111000
   Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
   Component: MNS US          H51 0990
   Revision: 00000000    Serial number: 341BI087505623
   VCID: 312AEE84A85C03C718-8064
   Part No SW: 8K0 907 566     HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH10 0040
   Revision: 00H10000    Serial number: 6PZ 009 014-02
   Coding: 0000004
   VCID: 74A4279017CE76EFB3-8020
   Subsystem 1 - Part No: 8K0 907 568
   Component: J0770_SWA_Slave_H08 0040
   Subsystem 2 - Serial number: 6PZ 009 014-22
   Subsystem 3 - Serial number: 3F18.02.0800H0800000010203ÿ
   Subsystem 4 - Serial number: 010203ÿ
02856 - Sensing Area for Control Module 2 Blocked
                    Reset counter: 100
                    Mileage: 139013 km
                    Date: 2020.01.03
                    Time: 05:51:39
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011C03225E00120102
   Shop #: WSC 91450 999 123732
   VCID: 50EC8B0003966ACF77-8004
                    Fault Frequency: 8
                    Reset counter: 125
                    Mileage: 139300 km
                    Date: 2020.01.21
                    Time: 14:17:22
   Revision: 00003002    Serial number: 0109416767
   Coding: 01060698007A04C402B000
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB09  H01 0170
                    Fault Frequency: 8
                    Reset counter: 125
                    Mileage: 139300 km
                    Date: 2020.01.21
                    Time: 14:17:22
00166 - Access/Start Authorization Switch (E415)
                    Reset counter: 104
                    Mileage: 138622 km
                    Date: 2019.12.20
                    Time: 05:35:07
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 P    HW: 8T0 035 223 A
   Component: DSP STD       H07 0250
   Revision: S2400000
   Coding: 010101
   VCID: 3B36CCACBA10F997B2-806E
02247 - Subwoofer (R148/R157)
                    Fault Status: 01111011
                    Reset counter: 229
                    Mileage: 137866 km
                    Date: 2019.11.27
                    Time: 19:33:29
                    Voltage: 12.10 V
                    Temperature: 12.0°C
                    Bin. Bits: 00000011
00418 - Front Right DSP Mid-Bass Speaker (R102)
                    Fault Status: 00111011
                    Reset counter: 125
                    Mileage: 139299 km
                    Date: 2020.01.16
                    Time: 16:23:08
                    Voltage: 11.90 V
                    Temperature: 7.0°C
                    Bin. Bits: 00000111
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: 4A…
   Coding: 011C03225E002201
   VCID: 7CB40FB0FF9E3EAFFB-8028
                    Fault Status: 00101100
                    Fault Frequency: 54
                    Reset counter: 125
                    Mileage: 137868 km
                    Date: 2019.11.27
                    Time: 19:40:51
02111 - Motor for Window Regulator
                    Reset counter: 125
                    Mileage: 139299 km
                    Date: 2020.01.16
                    Time: 16:22:53
02123 - Door Warning Light / Entry Light
                    Reset counter: 125
                    Mileage: 139299 km
                    Date: 2020.01.17
                    Time: 09:00:26
   Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
   Component: EPB Audi B8   H04 0050
   Revision: 00000003    Serial number: 10000000000049
   Part No: 8K0 907 357 B
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 3424E790574E36EF73-8060
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336BS087540486
   Coding: 0000002
   VCID: 2E10F5F8B9621C3F05-807A
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 12926780076183
   Coding: 0CD154
            002 - Lower Limit Exceeded - MIL ON
                    Fault Status: 11100010
                    Reset counter: 229
                    Mileage: 137866 km
                    Date: 2019.11.27
                    Time: 19:33:17
                    Bin. Bits: 00000000 00001001
                    Voltage: 12.30 V
                    Text:  00,0°C;n.erkannt;     n.erkannt
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8290JO
   Coding: 1000008
   VCID: 373ED09C4638DDF756-8062
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005025535
   Coding: 0010900
   VCID: 25020AD4EC945F67F4-8070
End----(Elapsed Time: 01:58, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)-----
Any help would be appreciated.
Kevin
Which one did you replace? Driver or Passenger side?
Do you have a scan from before you replaced it?
What coding value are you trying to enter, and what's the exact error message when it "won't accept" the coding?
fraazz
Canada
C?ID=101765
As you can see it was the end of the day Uwe and I got into this for one of the guys here. I found the bulletin for this and it needs a SVM update because of the newer module on top of a couple minor mechanical alterations as per the bulletin. 64 11 12 2022450/4 February 10, 2011
That was a scan with the old module plugged in.
Kevin
