Monday,25,December,2017,15:57:21:29062
-- Windows Based VAG/VAS Emulator Running on Windows 7 x86
Version: 17.8.0.1
VIN: WAUZZZ4G8EN103926 License Plate: 25.12,17
Mileage: 112427km-69858mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
62 6D 72
VIN: WAUZZZ4G8EN103926 Mileage: 112427km-69858miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CDUD) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 Q HW: 4G0 907 401
Component: 3.0TDI EDC17 H41 0002
Revision: 53H41---
Coding: 12254012052601020000
Shop #: 02391 785 00200
Dataset: EV_ECM30TDI0114G0907401Q 001003
: EV_ECM30TDI0114G0907401Q.
VCID: 316C99676058DCCE35-8064
Part No SW: 4G2 927 156 P HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H02 0003
Revision: --H02---
Dataset: EV_TCMDL501021 001015
: EV_TCMDL501021.
VCID: 3B70BB4FB214269E9F-806E
Address 03: Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 27A69F01E465F980DB00
Dataset: EV_ESPPremiAU57X 004039
: EV_ESPPremiAU57X_004_AU57.
VCID: 3A7EBE4BBD2E1F9684-806E
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 EN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0521
Coding: 01B93046000000000000
VCID: 79FC6147F0A8D48ECD-802C
Component: J764 ELV H40 0046
Serial number: 0213000389021006
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AJ HW: 4G0 820 043 AJ
Component: KLIMA 2 ZONEN H14 0094
Serial number: 14121300110442
Coding: 3622000821
Dataset: EV_AirCondiBasisUDS 004002
: EV_AirCondiBasisUDS_004.
VCID: 67D8373F9E1C527E2B-8032
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Reset counter: 34
Mileage: 112427 km
Date: 2017.12.25
Time: 15:51:45
Compressor current: actual value: 0 mA
Outside air temperature: 11.0 °C
Temperature after evaporator: 8.92 °C
Engine speed: 220 /min
Part No SW: 4H0 907 063 CE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0130
Revision: 19012002 Serial number: 00000001815055
Coding: 2600A01040349FE001810080000005040F9DC70807080301000004206000
VCID: 6DD44517B4E0782E51-8038
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 131208 H36 0080
Serial number: 131209210342
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22105522
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - H07 0044
Serial number: 09 12 2013 00000832
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: A77843E6000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE H01 0083
Revision: 11001001 Serial number: 61061335601495
Coding: 08C308
Dataset: EV_EPHVA18AU57X0000 004009
: EV_EPHVA18AU57X0000_003.
VCID: 71EC5967A0D89CCE75-8024
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00G56VA
Coding: 3032343631334E303537554A305234473053
Dataset: EV_AirbaAU10BPAAU64X 001014
: EV_AirbaAU10BPAAU64X_AU57.
VCID: 3666AA7B8936FBF660-8062
Serial number: 3575HRB40692ATKIAHUF
Serial number: 3585HRB405P2AIFU6PNO
Serial number: 3515JRB401E50PQ2GGPX
Serial number: 3525JRB400O50PQ2IPG2
Serial number: 3554VRB404V2FD2ML1C+
Serial number: 3564VRB404V2FD2M7OB7
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140109000202
Coding: 000035
VCID: 306A9C636352D5C63A-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 950 S HW: 4G8 920 950 S
Component: MDieGb H43 0411
Revision: 27450259 Serial number: 658281113592037
Coding: 23A710000B412600010000
Dataset: EV_RBC7KMID 004048
: EV_RBC7KMID.
VCID: 3F88CF5FA60C3ABEB3-806A
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001222074
Coding: 00CD077D00
Dataset: EV_GatewPkoUDS 001019
: EV_GatewPkoUDS_001.
VCID: 72EE566BA5DEA7D68C-8026
Serial number: 3620501903
Voltage stabilizer:
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H03 0056
Revision: -------- Serial number: EJ1BPA7207NAXX
Shop #: 00000 000 00000
Dataset: EV_SARA2 005012
: EV_SARA2.
VCID: 3360936F9A44EEDE47-8066
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: FA H03 0507
Coding: 011C16004001620002080002
VCID: 4798D7BFF6DC727E0B-8012
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0004118059
Coding: 101000010000
Dataset: EV_RCEPS 009008
: EV_RCEPS_009.
VCID: 326E966B655EE7D64C-8066
Revision: 00002001 Serial number: 0322466267
Coding: 013F0622A0B930008320090400010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Component: BACKUP HO H05 1501
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000061327
VCID: 1D3455D704C048AE81-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Component: BF H03 0507
Coding: 011C16004401620002080002
VCID: 4686DABBF1D66B76F0-8012
Component: -4 H04 0015
Revision: -------- Serial number: 00000001583618
Dataset: EV_ParkiBrake 001028
: EV_ParkiBrake_AU57.
VCID: 2D5485177C60B82E11-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 140106-0002-002
Coding: 1122A6101000A300
Dataset: EV_HeadlRegulBasic 005001
: EV_HeadlRegulBasic.
Part No SW: 4G0 035 192 P HW: 4G0 035 192 F
Component: RMC Nav Plus H54 0818
Coding: 0101010101415B47082B060301020100000001
VCID: 2F689F1F7E6CCA3E23-807A
Subsystem 1 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464K+0D2642347
Subsystem 2 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349MLA000BH
Address 62: Door, Rear Left (J388) Labels: None
Component: HL H03 0507
Coding: 010814004001620002080002
VCID: 499CD187E0C8840E1D-801C
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 351301238
Coding: 097205C010
Dataset: EV_HDSGAu572 001022
: EV_HDSGAu571.
VCID: 3564AD779430F0EE69-8060
Address 72: Door, Rear Right (J389) Labels: None
Component: HR H03 0507
End-------------------------(Elapsed Time: 04:21)--------------------------
