VW Golf 7 Discovery Pro problem
daniel.b
Europe
C?ID=318819
Please help me correctly encode Discovery Pro. It is likely that the coding was changed by accident, the sound does not work on the radio, no car logo, the volume control does not work, the Voice button is inactive. Is anyone able to help?
Car Volkswagen Golf 7 2013
Monday,20,January,2020,19:51:48:07292
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4441.4
VIN: WVWZZZAUZEP524413   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 47 52 55 5F
VIN: WVWZZZAUZEP524413   Mileage: 102394km-63624miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 11190032032405082000
   Shop #: WSC 00028 028 00210
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: F9BAB2B678C5AE821A-80AC
   Revision: 00000000    Serial number: 626030000001B4
   Coding: 04FA62A124220970037B060141C62920462490C0608294F300605076C009
   VCID: FBB6A8BE72F99C9208-80AE
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02020104202100011005000000101000
   VCID: E680E9CA197B317AC7-80B2
   Air quality sensor:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
          [PTC-Reduzierung durch BCM]
                    Reset counter: 248
                    Mileage: 102392 km
                    Date: 2020.01.20
                    Time: 18:22:56
                    Voltage terminal 30: 11.4 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Reset counter: 248
                    Mileage: 102392 km
                    Date: 2020.01.20
                    Time: 18:23:18
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
   Part No SW: 5Q0 937 086 L    HW: 5Q0 937 086 L
   Component: BCM PQ37BOSCH 020 0078
   Revision: --------    Serial number: 86580709130084
   Coding: 00000A46C24122FB0BA44080B11C0708100A000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 011005
   ROD: EV_BCMBOSCH_011.rod
   VCID: C3C6105E4A89245200-8096
   Component: WWS    130903  042 0551
   Serial number:         130913070901
   Component: RLFS  024 0042
   Serial number: Y13M09D22H11M13S59S1
   Coding: 06A8DD
   Serial number: 000000000ZY132310DEM
   Serial number: 00000000000027758216
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131326001499
   Coding: 0031061041
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: BD3266A62C6D52A276-80E8
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR00HWPI
   Coding: 98FCC0C0000000005C5400CF004800000065
   Shop #: WSC 00028 028 00054
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: FF4E5CAE66E180B224-80AA
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B17091340887
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B18091350530
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 003 108 13
   Serial number: 357670000006BC4CDD0D
   Subsystem 4 - Part No SW: -----------    HW: 480 003 108 13
   Serial number: 3586700000099C7DAD0G
   Subsystem 5 - Part No SW: -----------    HW: 480 401 609 13
   Serial number: 3516502A311FBEB0424C
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 13
   Serial number: 3526502AF11FBEB3338W
   Subsystem 7 - Part No SW: -----------    HW: 480 401 609 13
   Serial number: 3556502AF11FBEB350E/
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0085
   Revision: FF026026    Serial number: 20130828400136
   Coding: 0400
   ASAM Dataset: EV_SMLSVALEOMQB 001011
   ROD: EV_SMLSVALEOMQB.rod
   VCID: BA386DBA3D43659A53-80EE
   Part No SW: 5G0 920 871 A    HW: 5G0 920 871 A
   Component: KOMBI         353 2210
   Coding: 07BD11002B900008070A7E00040000
   Shop #: WSC 12345 123 61029
   VCID: A81CA7F2D3EFE70A35-80FC
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 13091310802186
   Coding: 030100040B087300EF00064C080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   VCID: BB3668BE32795C9248-80EE
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H15 0038
   Serial number: 27130001449110123363
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 7535981303
131695 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:40:03
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000075214831
   Coding: 003A02208000028000001000
   VCID: 8248D55A1513ED5A4B-80D6
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002705473
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 03
   ROD: EV_SteerAssisMQB_008.rod
Address 47: Sound System
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000075176230
   Coding: 003A00208E00028000801000
   VCID: 814ADA561015F64252-80D4
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002699212
   Coding: 090000
   Coding: 029A000001010000
   VCID: F5A2BE8654DDCAE27E-80A0
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 043 B    HW: 5G0 035 043
   Component: MU-H-N-EU     H40 0192
   Serial number: A457I0D7505755
   Coding: 02730001FF00000011110002000800031F0206A40100010047
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 9D7286268CAD32A256-80C8
   Component: ABT_High  H42 0020
   Serial number: VWZ8Z9N2300YEL
   Compact Disc Database:
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 1008
9 Faults Found:
2563 - Navigation System
          B126C F1 [009] - Navigation Database Missing
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:05
                    Voltage terminal 30: 12.3 V
6666 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:45:08
                    Voltage terminal 30: 12.0 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -14 °C
                    Temperature of MOST transceiver-Current: 46 °C
7171 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Auxiliary heater (0x03) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:07
                    BAP-BAP_Function_ID: 02
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:07
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:07
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:07
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:07
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:07
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 102394 km
                    Date: 2020.01.20
                    Time: 19:25:07
End----(Elapsed Time: 01:15, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Spacewalker
Poland
C?ID=159607
where is Sound system from your car ?
seems is missing .
if is not available - remove it from GW first
myounus
Northwest UK
C?ID=321059
Did you perform a scan before making coding changes?
There seems to be quite a few errors. Has this been removed/retrofitted to this vehicle?
daniel.b
Europe
C?ID=318819
seems is missing .
The Sound System has been re-coded at Can Gateway. It will be deleted because it is inactive
daniel.b
Europe
C?ID=318819
I did not scan before, in such a state a client came to me for diagnostics. Discovery Pro functioned correctly before, probably an error appeared after unconscious use of the green menu
Discover behaves similarly to the video 4: 09min, so it looks as if it lost coding
MasterTommy
Amsterdam
C?ID=295586
Some stuff can only be changed, or f***ed up, in the developer menu. If all else fails reload firmware (probably a dealer job).
daniel: I suspect that this car has multiple MIB problems
Just to be clear - does the vehicle actually have a Sound System installed? I ask because notwithstanding that the hex47 module has been unregistered from the Gateway list (as you say), the MIB appears to have its long-code software switches enabled as if there was an external amplifier connected (i.e. MOST is active and Byte 11 points to an external amplifier)! If the MIB is truly meant to operate using its own internal amplifier - then the long-code set-up may well explain why there is no volume (because- with the current long-code values, the audio signal is being digitized and is being sent over the MOST bus instead of appearing at the speaker pins on the rear quad-connectors on the MIB housing.
Also in respect of the no-logo matter, I'm not sure if it helps - but I've been presented with cars in which the MIB shows similar symptoms. On a couple of occasions, the problem has been that the owner has inadvertently chosen a skin and screening value that is not present in the module firmware. When this happens, the change appears to be accepted - but when the MIB is energized and it goes through its start-up sequence, it fails to load the logo and background screens. Hence a blank screen. Perhaps try changing both from their current values?
