2013 Audi Q7 Optical ring broken. Amp or Radio?
OKCIS
OKC, OK, USA
C?ID=385730
Monday,20,January,2020,19:31:51:53967
VCDS Version: Release 19.6.2 (x64)
Control Module Part Number: 4F0 907 468 S
  Component and/or Version: GW-BEM 5CAN-M H06 0058
Optical Bus Diagnostic : Standard
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	OK
5F-Information Electr.(High/D3)	OK                  	OK
47-Sound System     	OK                  	ERROR
56-Radio            	ERROR               	ERROR
Looking at this is the Amp whats bad? My car shows all signs of a bad amp but after seeing this i wasnt sure if its maybe the amp or if its the radio module?
South Molton, UK
You need to replace one module at a time in the optical ring with an optical link to diagnose problems in the optical ring.
I'd also be concerned about the 56 showing an electrical error, please post an unedited VCDS Auto-Scan.
OKCIS
OKC, OK, USA
C?ID=385730
That was the concern i had when i saw that all the signs before scan point at the AMP but after running this the radio part had me concerned if it wasnt for that error i would go straight to the amp. I had to leave town for work but ill be back tonight and will post a full scan.
OKCIS
OKC, OK, USA
C?ID=385730
Here is the full scan.... Holy hell.... No blow fuses i've checked everyone of them in all 3 fuse blocks.
Still haven't fixed the Optical ring issue yet i need to get the tools to remove the radio. I tested the amp and it was fine.
Is it possible that one issue is causing all of these other issues?
Saturday,25,January,2020,23:34:17:53967
VIN: WA1DGAFE8DD013495   License Plate: STEPH2
Mileage: 131030km-81418mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE8DD013495   Mileage: 131030km-81418miles
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
4C-Tire Pressure II -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4L0 910 551 Q    HW: 4L0 907 551 A
   Component: 3.0l V6 TFSI        0030
   Revision: --H08---    Serial number:
   Coding: 0121000A290F0928
   Shop #: WSC 31414 790 00001
   VCID: 363521B8F44A514723B-8062
               U1017 - 000 -  - Intermittent
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 14:42:25
                    RPM: 1504 /min
                    Mass Air / Rev.: 218.0 mg/str
                    Temperature: 12.0°C
                    Bin. Bits: 00000010
                    Load: 17.6 %
   Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
   Component: AL1000 AISIN  002 2090
   Coding: 001378
   Shop #: WSC 99999 999 83333
   ROD: EV_TCMAL991031_002.rod
   VCID: 3A2D3588CCD2B527C73-806E
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099409
   VCID: 34311BB0E23643571DF-8060
                    Reset counter: 175
                    Mileage: 131003 km
                    Count: 192
                    Count: 2881
                    Count: 297
                    Count: 33792
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702051700
   Coding: 0000135
   VCID: 2517F6F459EC2ADF9A1-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H04 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
   Revision: 00---031    Serial number: 00000000366298
   Coding: 000CC026
   VCID: 2517F6F455EC2ADF9A1-8070
   Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0053266859
   Coding: 070000
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133123
   VCID: 6E85C9D8CC9A29872BB-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 174
                    Mileage: 131000 km
                    Date: 2020.01.25
                    Time: 12:33:00
00061 - Footwell Lights
                    Fault Status: 00110111
                    Reset counter: 174
                    Mileage: 131000 km
                    Date: 2020.01.25
                    Time: 12:30:00
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55961306500143
   Coding: 25011F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 34311BB0EEB643571DF-8060
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH44 0230
   Revision: 08H44000    Serial number: 0038QD0C34B.
   Coding: 0014131
   VCID: 2B0300CC3F081CAF4C5-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME662C4D52P
   Subsystem 3 - Serial number: 6342QSME662C174ES
   Subsystem 4 - Serial number: 6352QSME3C2B4158N
   Subsystem 5 - Serial number: 6362QSME2B2B0F60P
   Subsystem 6 - Serial number: 63734SME692C4E68J
   Subsystem 7 - Serial number: 63834SME672C4768B
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90026130170350
   Coding: 0012142
   VCID: 2809FFC02EFE37B7A17-807C
   Component: E0221           H03 0040
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 12:33:31
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
   Component: KOMBIINSTR.   H35 0317
   Revision: 00000000    Serial number: VJ342HA3E
   Coding: 8BD663040900CF05020205
   VCID: 44D14B70BE96F3D7ADF-8010
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB700037    Serial number: 3700M1330201D9
   Coding: 00C303
   VCID: 3FDB449CD770900FF0D-806A
   Component: J367-BDM  H07 0125
   Serial number: 40060K58094120271281
00384 - Optical Databus
                    Reset counter: 126
                    Mileage: 130761 km
                    Date: 2020.01.20
                    Time: 19:02:32
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 7
                    Bin. Bits:    00000
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 176
                    Mileage: 130790 km
                    Date: 2020.01.21
                    Time: 10:12:00
                    Reset counter: 176
                    Mileage: 130790 km
                    Date: 2020.01.21
                    Time: 13:12:00
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 18
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 12:33:31
                    Bin. Bits:    00000
                    Voltage: 11.50 V
                    Count: 8
                    Bin. Bits:    00000
                    Time: 1.70 s
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 12:37:28
                    Bin. Bits:    00000
                    Voltage: 11.50 V
                    Count: 11
                    Bin. Bits:    00000
                    Time: 11.30 s
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Revision: 00---011    Serial number: 00000030275468
   Coding: 0000006
   VCID: 6889BFC0EE7EF7B7617-803C
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000053227558
   Coding: 00581B00000011110000
   VCID: 323D1DA814224D670F3-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E0509D80C1A69876BB-807A
   Component: J0770_SWA_Slave_H02 0050
   Subsystem 3 - Serial number: 5F28.02.1300H02000AMS15709ÿ
   Subsystem 4 - Serial number: S15709ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000054976525
   Coding: 011F57205E40440004
   VCID: 48C95F4082BED7B7417-801C
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 12:33:42
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01923060450000
   Coding: 3569949
   VCID: 38292F80FE5EA737317-806C
Address 47: Sound System
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191001626
   Coding: 0693965
   VCID: 2313E8EC57D8D4EFF45-8076
                    Fault Status: 00101101
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 14:42:25
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 10.70 V
                    Temperature: 17.0°C
                    (no units): 0.0
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 14:42:25
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 10.70 V
                    Temperature: 17.0°C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000136329
   Coding: 0012001
   VCID: 5EE599183C3AB9079BB-800A
                    Reset counter: 174
                    Mileage: 131000 km
                    Date: 2020.01.25
                    Time: 12:33:00
                    Voltage: 11.700 V
                    Temperature: 77.0°C
                    Reset counter: 174
                    Mileage: 131000 km
                    Date: 2020.01.25
                    Time: 12:37:00
                    Voltage: 11.700 V
                    Temperature: 20.0°C
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000054987468
   VCID: 47CB5C7C8FA0D8CF48D-8012
                    Reset counter: 174
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
Address 56: Radio
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000055001172
   Coding: 010E57204040230004
   VCID: 46D5517888AAC1C7B3B-8012
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 12:33:42
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000193095646
   Coding: 0200000000000000
   VCID: 313F12A41124767F769-8064
   Revision: --H07---    Serial number: 525PA8-J32414U
   Coding: 1021201
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C3D0FA86DB9705F-8038
ó
   Subsystem 3 - Serial number: RD08.03.13--H57001002F0125ÿ
   Subsystem 4 - Serial number: 2F0125ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 132362311-----
   Coding: 0003595
   VCID: 2615F1F824EA21C793B-8072
   Component: J_245_EE16_SKB10H14 0220
   Component: J_394_EE16_SKB10H14 0220
   Component: J_392_EE16_SKB10H14 0220
                    Reset counter: 174
                    Mileage: 131003 km
                    Date: 2020.01.25
                    Time: 12:37:28
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000055015644
                    Reset counter: 174
End----------(Elapsed Time: 01:59, VBatt start/end: 14.4V/14.4V)-----------
AIB Wolfgang
Hello
disconnect the optical bus on the sound system and bridge with a "loopback" 4E0-973-802 for Most-Bus
will bring you the best result
Hello
It seems to me the fault is most likely in the Radio, no?
OKCIS
OKC, OK, USA
C?ID=385730
Hello
I have the loopback tool and tested the amp. I am going to test what i think is the radio module tonight. Im having a hard time finding a diagram that shows me where each one of the modules are at to be able to test them. Had to get radio removal tools for this one tonight and they came in the mail today.
OKCIS
OKC, OK, USA
C?ID=385730
Well that wasnt the radio module it was the MMI module or in the optical ring test 5F - Information Elec.
Now to track down the Radio module....
OKCIS
OKC, OK, USA
C?ID=385730
