Case Study B13BC - Multiple collision brake: No function
Jef
HQ
ST?ID=91869
2019 Q5, hit pothole, rack was damage and replaced. Airbag has B13BC. ODIS run on it several tries, no luck.
We tried airbag Basic Settings Reset analysis measured values and from that, the B13BC went from a hard code to intermittent and was able to clear out.
Jef
HQ
TSD?ID=121275
2018 Q5, similar story, some mishap but no airbags deployed, power steering rack busted up and replaced. Airbag had the same B13BC - Multiple collision brake: No function. Fresh key cycle, went into airbag and did Basic Settings "Calibrate installation location". He George didn't notice finished correctly, just not running. [Stop] and backed out of Basic Settings and was able to clear the code out.
So.... is this a fault code to expect when replacing the J500?
NEtech
Denmark
C?ID=56995
Jef, do you have the complete DTC text ?
Hi Niels,
We don't have scans from either of those example cars however this recent one has that B13BC DTC in 15-Airbags:
https://forums.ross-tech.com/showth...tiple-fault-codes-after-tire-change-alignment
I *believe* B13BC F2 [137] Multiple collision brake: No function would have been stored in Jef's example cars (because it is often stored after alignments and repairs including new 16 modules) however I found other examples in our scans.
B13BC F1 [009] Multiple collision brake: triggered (Chassis Type: FS (8U0) scan)
B13BC F3 [009] Multiple Collision Brake: Function Disabled by Driver (same Chassis Type: FS (8U0 scan)
There's also a B13BC Multiple collision brake: Crash data stored but I don't have scans to obtain the complete DTC info.
Jef
HQ
ST?ID=106861
4N0 959 655 K
2019 A6, airbag has:
Basic Settings IDE13545-ENG167462 Reset analysis measured values
Get a error for Security Access required. Exit out, ignition cycle, Security Access gives a pop up window with a code, accepted. Try the Basic Settings, again, SA required message. We try this a few times.. and hey, the airbag light is going out now when the ignition is cycled back on... the B13BC was now able to be cleared out.
Never got a "Finished Correctly" or "OK" type message, just nag about Security Access. Mission failed successfully. :confused:
servis-sk
Slovakia
C?ID=101135
Hi.
I am also solving the problem on the A4/B9 year 2016, how to turn off the airbag light.
There is a "collision brake" problem, and the problem of some "Databuses"
Do not notice the driver's airbag, it was disconnected during the scan because I was changing the steering wheel ring.
The car was after a partial collision, the front lights, mask and radiator were broken
How can it be solved? delete?.
Thanks for the help
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 B    HW: 8W0 959 655 B
   Component: Airbag10.44   H56 0084
   Serial number: 003QQ0001EWG Dataset Number: 8W0909602N  0002
   Coding: AECCF0C00C800000985400F3C04C00000000
   Shop #: WSC 06335 790 00001
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 48C8A695B230B02A873-801C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W0857705A0102Q00840
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W0857706A0103Q00517
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 062 809 15
   Serial number: 3577Y00C71A537D2112Y
   Subsystem 4 - Part No SW: -----------    HW: 442 062 309 15
   Serial number: 3587Y00B11A537E2207Y
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 409 15
   Serial number: 351770020293A827157-
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 409 15
   Serial number: 35277001E293A827C4EO
   Subsystem 7 - Part No SW: -----------    HW: 442 0C3 103 16
   Serial number: 3557500C12057263F383
   Subsystem 8 - Part No SW: -----------    HW: 442 0C3 103 16
   Serial number: 3567500C12057266038Z
   Subsystem 9 - Part No SW: -----------    HW: 442 0C3 103 16
   Serial number: 2307500C52057262115M
   Subsystem 10 - Part No SW: -----------    HW: 442 430 103 16
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00C51B1C0E400BD
   Subsystem 11 - Part No SW: -----------    HW: 442 430 103 16
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00C51B1C0E3B1FT
9 Faults Found:
          B1000 1B [137] - Resistance Too High
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:19:01
9571867 - Ignitor for Drivers Airbag Release Valve
          B120E 1B [137] - Resistance Too High
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:19:01
          B13BC F2 [137] - No function
                    Reset counter: 58
                    Mileage: 244171 km
                    Date: 2023.02.04
                    Time: 03:37:29
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 59
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:18:59
1061893 - Databus
          [NWD: 0x0A0 LH_EPS_04 error value EPS_Zahnstangen_Pos]
                    Reset counter: 59
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:19:00
1060613 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Objektstatus]
                    Reset counter: 59
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:19:00
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 59
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:19:00
1060615 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
                    Reset counter: 59
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:19:00
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 59
                    Mileage: 244195 km
                    Date: 2023.06.14
                    Time: 21:19:00
servis-sk
Slovakia
C?ID=101135
Hello.
Can anyone think of anything? I can't delete B13BC and make the basic settings in group 15 airbags?
I still have an unsuccessful attempt, because I don't have, I don't know, the security access code.
Or do you have a specific procedure?
Thanks for the help
Jef
HQ
ST?ID=111327
2020 A5 - Another busted up J500 due to some unplanned off road adventure. J500 replaced and coded.
Part No SW: 8W0 959 655 N HW: 8W0 959 655 N
Component: Airbag10.44 H09 0109
B13BC F2 [10001001] - No function
Basic Setting:
IDE03567-ENG167462 - Calibrate installation location
Was getting the "Finished Correctly" statement, but the codes would not clear out. Then the ABS has new DTCs:
4529411 - Multi-Axis Accelerometer in Airbag Control Module C051D 00 [10100111] - Not Calibrated
Fix seem to be to lock the car up for +1 minute (cranky baby needs a nap), after that, was able to get DTCs to clear out of 03, 15 and 44. No warning lights now.
S4Phil
Scotland, UK
C?ID=124175
ST?ID=111327
Basic Setting:
This worked perfectly for me, as described above (Thanks Jef)
Car was a 2021 Audi A5 35 TDI MHEV, airbag module details below.
Part No SW: 8W0 959 655 P HW: 8W0 959 655 P
Component: Airbag10.44 H03 0122
We weren't even working on the airbags or ABS, but the engine control unit had to be removed as part of a repair in that area. On reconnecting everything and first ignition cycle we had the B13BC F2 fault permanently logged in the Airbag ECU and unable to clear it.
Carried out the calibration in Basic settings - IDE03567-ENG167462 - Calibrate installation location
It finished very quickly, stating 'finished correctly', then 'not running'.
Locked the car and left it for 5 minutes, then we were able to clear out the logged faults in ABS, Airbag & Steering Assist modules.
Jef
HQ
ST?ID=113908
2018 SQ5, auction car, so no known history.... I can't find anything that implies it took an unplanned off road adventure (crashed).
Airbag:
So this was doing some Security Access and then Basic Settings:
  • IDE03567-ENG167462-Calibrate installation location
  • IDE13545-ENG167462-Reset analysis measured value
IDE03567-ENG167462-Calibrate installation location would run briefly and then not running...
IDE13545-ENG167462-Reset analysis measured value was ask for Security Access.
So after a few times of stumbling through those 2 basic settings, the code did clear out, but there was a yellow triangle warning in the cluster, but no relevant DTCs. Tech locked the car up and came back 30 mninutes later, no more yellow triangle warning light.... so some cars will need a bit of an extended nap.
SeattleMatt
C?ID=282387
I was not able to find IDE13545-ENG167462-Reset analysis measured value was ask for Security Access. What module is this in? Or is there another way to access IDEs directly?
SeattleMatt
C?ID=282387
After running IDE03567-ENG167462-Calibrate installation I got a full batch Airbag errors for all 3 airbag modules with no ability to reset. And dash lit up with ABS errors. Not sure if it is because I wasn't able to run the second IDE?
Jef
HQ
2020 Q5, hit rock or something, J500 survived, but an inner tie rod got bent. Tech damaged inner tie rod out and tossed to towards the scrap metal bin.... the bent inner tie rod circled back around and hit the service writer in the head. Alignment performed and everything is all good minus the airbag fault code:
   Part No SW: 80A 959 655 L    HW: 80A 959 655 L
   Component: AirbagVW30    063 0610
   Serial number: 003W1M05SGBW Dataset Number: 80A909602J  0002
   Coding: AECCFCC000800000A000003FF20C400000C5
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 3C341518B7F18F7BDB-8068
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 80A857705M0170T00471
   Coding: 80000D
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 80A857706M0192T01698
   Coding: 80000D
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000C21ZM0C
   Coding: 303033
   Subsystem 4 - Part No SW: -----------    HW: 480 002 007 19
   Serial number: 35700000000ED22D1E3Y
   Subsystem 5 - Part No SW: -----------    HW: 480 001 707 19
   Serial number: 35800000000F664DCD32
   Subsystem 6 - Part No SW: -----------    HW: 480 032 406 19
   Serial number: 351001C2001DFE20DACI
   Subsystem 7 - Part No SW: -----------    HW: 480 031 907 19
   Serial number: 352001C244E04EA0A9EM
   Subsystem 8 - Part No SW: -----------    HW: 480 031 907 19
   Serial number: 355001C244E90DF0AE1Q
   Subsystem 9 - Part No SW: -----------    HW: 480 031 907 19
   Serial number: 356001C244E90EE0BD4U
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 907 19
   Component: CentrSensorXY  004 0108
   Serial number: I0O0001042C9CA23457R
                    Reset counter: 237
                    Mileage: 61492 km
                    Date: 2025.05.07
                    Time: 09:49:18
First we tried Basic Settings IDE13545-ENG167462-Reset analysis measured values and got an error message, out or range. Then we tried Basic Setting IDE03567-ENG167462-Calibrate installation location and again the error message.
Locked the car up for +30 seconds, back into the Airbag module and tried Basic Settings DE03567-ENG167462-Calibrate installation location again, in the blink of an eye, went to "not running" and with that, the fault code was cleared out.
Ziddywerks
Northern NJ USA
C?ID=208579
Not sure what you found. But this is a common occurence when changing out components that talk to abs, airbag module and so on. The fix is always a 30minute sleep bus cycle, after which the fault goes passive and can be erased.
This TSB outlines the procedure for this specific fault and occurence.
EuroMasterTek
Las Vegas, USA
C?ID=104263
2019 SQ5, After alignment,
B13BC-Multiple Collision Brake - No Function, Solid MIL ON, Tried to clear so many times, and ran all adaptations.
Just close and lock the vehicle for a couple minutes, MIL was off, Code cleared.
Hope this helps!!!
Jef
HQ
Summary on this:
  • A lot of cars are going to act like the Basic Settings MAS00041-ENG167462-Resetting seat occupied recognition didn't work, don't panic yet.
  • A lot of cars will need you to lock the car up after doing the Basic Settings. +1 minute lock up seems to be fine for in most cases.
  • Doesn't hurt to read over the TSB link that @Ziddywerks shared 2 post up.
While unplanned off road adventures is the most common cause, some times having a Koi pond where the J393 is located can also cause this:
Thank you to pizza making Joe for sharing that video clip.
ST?ID=119511
