Audi E-Tron 55 DAB+ retrofit
vastechnics
C?ID=143747
I have an Audi E-Tron 55 Quattro with DAB+ preparation. If I look at the PR codes I get Q0D and that means DAB+ preparation. If I look at the MIB the DAB+ antenne is connected. I have also compared the antennas with a similar car with DAB+ from factory, all are the same. Sharkvin antenna, antenna amplifier all are same. If I look at the coding, I can see that the DAB+ option is already active, but not working at all. Maybe someone can share a scan from E-Tron with OEM DAB+. Below scan of car with DAB+ preparation:
Thursday,02,January,2020,13:59:21:43540
VIN: WAUZZZGE9LB011748   License Plate: ETRON
Mileage: 850km-528mi   Repair Order:
Chassis Type: GE-AU58 (4KL)
Scan: 01 03 09 13 15 16 17 19 2B 36 42 44 46 51 52 5F 6C 6D 74 75
          81 8C A5 BB BC C5 C6 CA CE D6 D7 8104
VIN: WAUZZZGE9LB011748   Mileage: 850km-528miles
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CE-Drive Motor 2 -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 A    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0001
   Coding: 2A0A0012006E040034080000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558A 001004
   ROD: EV_VCU00XXX0204KE907558A.rod
   VCID: 47CAADB91F27557F48D-8012
   Part No SW: 4KE 909 059 AD    HW: 4KE 909 059 N
   Component: ESC           H11 0231
   Revision: 00000000    Serial number: 62779000003773
   Coding: 008800BA3D950B9A93570875187FD2E025BEA10000BCD0C910184B07A47D85
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_BRSContiMKC1AU516 011001
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 094E6B8149B3E30F9E9-805C
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07000143C1F900DD0740870898AF8C68130B33100806009701010A00792216810A4509BB62B62A0B000001000009101A0002800000010000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016_AU49.rod
   VCID: 7DA60F510D7BCFAFA21-8028
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001909030402367
   Coding: 7DC727
   Serial number: 23658741X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S14.10.1900690458
   Serial number: GX1CE116071923611243
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0415
   Serial number: B01435935
   Coding: 0D0104
   Part No SW: 4KE 907 561 C    HW: 4K0 907 561
   Component: LRR4R         H04 0354
   Coding: 7E61FF4358082C00010380200000003A4A1246494401009E01
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 43D2B9A92B1F795F945-8016
   Part No SW: 4KE 959 655 D    HW: 4KE 959 655 D
   Component: AirbagVW32    H42 3221
   Serial number: 0031NM00NU7N
   Coding: AACCF0C0003000009A5400FFF80D49A800C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4FFA8599F7578D3F00D-801A
   Belt Pretensioner left:
   Serial number: 00AI2019219726900000
   Coding: 03F002
   Belt Pretensioner right:
   Serial number: 00AI2019239660800000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 000 110 19
   Serial number: 357000000004D1293F3M
   Subsystem 4 - Part No SW: -----------    HW: 480 000 810 19
   Serial number: 35800000000910808F3H
   Subsystem 5 - Part No SW: -----------    HW: 480 030 110 19
   Serial number: 351002C00445C9D01CB8
   Subsystem 6 - Part No SW: -----------    HW: 480 030 110 19
   Serial number: 352001C2495435A0FE5D
   Subsystem 7 - Part No SW: -----------    HW: 480 021 110 19
   Component: FrontSensor_D  000 0149
   Serial number: 35500010662EBD733294
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 021 110 19
   Component: FrontSensor_P  000 0149
   Serial number: 35600010662EBD73F66I
   Sensor High Voltage System 1:
   Subsystem 9 - Part No SW: -----------    HW: 480 021 110 19
   Component: HVSensor_gSat  000 0149
   Serial number: I0T00010262EBD7556A0
   Side Sensor B-Pillar Driver Front:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 110 19
   Component: SideSens_B_Df  000 0149
   Serial number: I0P00010262EBD74579
   Side Sensor B-Pillar Passenger Front:
   Subsystem 11 - Part No SW: -----------    HW: 480 020 410 19
   Component: SideSens_B_Pf  000 0149
   Serial number: I0Q00010662F2C63B4B.
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 79AE1B411953F38F8E9-802C
   Part No SW: 4KE 920 795 A    HW: 4KE 920 795 A
   Component: FHybRDWACC--- H13 0105
   Coding: 850400C87C9000080DA6E170B284480008000000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 45D6A7B1252B476FBA1-8010
   Part No SW: 4KL 907 468     HW: 4KL 907 468
   Component: Gateway       H04 0362
   Serial number: 14F05089868301
   Coding: 02030005000100C000810000005B01329C8A0047180000000900009E00000000
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 0D465F913DDBFF2FB21-8058
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 7674960200191005000C
   Control module for steering wheel touch recognition:
   Subsystem 3 - Part No SW: 4N0 419 508 A    HW: 4N0 419 508
   Component: J1158 KLR  H46 0041
   Serial number: 19252056110S00414601
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000264568006
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3430EA757EB1CEE71DF-8060
   Serial number: 00000390943019
   Coding: 005812400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
   Component: TSG FS        010 0387
   Serial number: 0000390427868
   Coding: 001FDB0052000480A001B002
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   VCID: 46D4A0BD182D4C77B3B-8012
196631 - Remote Rear Lid Unlock Button
          B1210 29 [009] - Signal Implausible
                    Reset counter: 32
                    Mileage: 850 km
                    Date: 2020.01.18
                    Time: 13:56:08
   Coding: B4110101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323CEC6D84A5C0D70F3-8066
   Part No SW: 8W1 907 064 AP    HW: 8W1 907 064 P
   Component: BCM2 MLBevo   044 0530
   Coding: 017400002FB100E16309A0046400880200000000804F06582F04000000040030001F0100010F13
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU58.rod
   VCID: 0B42518943CFF11FAC5-805E
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1925500GS
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047778774
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W70000PVY
   Rear Light Left 2:
   Subsystem 4 - Part No SW: 4KE 945 429     HW: 4KE 945 429
   Component: T2 LH ECE HD  H11 0403
   Serial number: A1WK0000T5P
   Rear Light Right 1:
   Subsystem 5 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD0000FJD
   Rear Light Right 2:
   Subsystem 6 - Part No SW: 4KE 945 430     HW: 4KE 945 430
   Component: T2 RH ECE HD  H11 0403
   Serial number: A1WL0000T5Q
   Part No SW: 0EF 907 080 E    HW: 0EF 907 080 E
   Component: CUFZD68540AD0 H05 1002
   Revision: --------    Serial number: -00107.07.19000
   Coding: 01000000000000000000
   Shop #: WSC 08845 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003009
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3828DE4562D92A87317-806C
   Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
   Component: TSG BFS       010 0387
   Serial number: 0000391434172
   Coding: 001FDB005E000480A001B000
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   Part No SW: 4KE 035 063 B    HW: 4KE 035 063
   Component: MU-H-LND-EU   054 2658
   Coding: 01157601FF0A000043111101C00802102F0001E4037008008E
   VCID: 372ADD796FC725FF38D-8062
   Subsystem 1 - Part No: V03 959 804 LN
   Component: MIB2P_EU_Q219  0371
   Subsystem 2 - Part No SW: 4KE 919 605 C    HW: 4KE 919 605
   Component: DU AU516 High  H41 0147
   Serial number: INX00118081900130408
   Compact Disc Database:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000109892047
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00113071900140592
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900564889003
   Part No SW: 4M0 980 556 A    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0240
   Coding: 0237060102002001000040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 3332E9697BBFC9DF045-8066
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 32
                    Mileage: 850 km
                    Date: 2020.01.18
                    Time: 13:56:07
                    passive
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2
   Coding: 3310
   ROD: EV_DeckLidCONTIAU736_AU38.rod
   VCID: 4ACC948D0C35A817573-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AM    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2312
   Serial number: 2909191045
   Coding: 18D8586BDA4030
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 176A3DF90F0705FF18D-8042
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130734434
   Coding: 303030
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F120830
   Coding: 01C0E0FFC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 28080E05B279BA07A17-807C
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SJG00377
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C20C25556E106A7D5F-8068
   Part No SW: 4KE 915 233 B    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0442
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   VCID: 3D26CF514DFB0FAFE21-8068
   Battery Junction Box:
   Subsystem 1 - Part No SW: 4KE 915 253 B    HW: 4KE 915 253 B
   Component: BJB_MLBBEV  H05 0444
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
   Cell module: control module 9:
   Subsystem 10 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
H06 0110
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 108     HW: 4K4 907 108
   Component: zFAS Var B    H09 0352
   Coding: 04218400000000000008060000D4642E189E57000000008000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D80000009000800080000000000080400000A0
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003.rod
   VCID: 6C8032156601562705F-8038
   Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
   Component: TSG HFS       010 0387
   Serial number: 0000391099798
   Coding: 000FD90000000480A000B000
   ROD: EV_DCU2RearDriveMAXHCONT_AU58.rod
   VCID: 48C8AE8512395A07417-801C
   Component: TSG HBFS      010 0387
   Serial number: 0000391099797
   ROD: EV_DCU2RearPasseMAXHCONT_AU58.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0077846
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_002_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00104.2W.2B20370813
   Air Conditioning Compressor Sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019100300705
   Geber für Kältemitteldruck/Kältemitteltemperatur 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Refrigerant Expansion Valve 2:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151073809
   Refrigerant Shut Off Valve 3:
   Subsystem 6 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 36000000000000005546
   Refrigerant Shut Off Valve 5:
   Subsystem 7 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 33000000000000005546
   Radiator shutter:
   Subsystem 8 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1  H13 0110
   Serial number: 20190919060103050779
   Radiator Shutter 2:
   Subsystem 9 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V550KJS2  H13 0110
   Serial number: 20190828060404051658
   Coolant valve 1:
   Subsystem 10 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000396341
   Coolant valve 2:
   Subsystem 11 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000143084
   Coolant valve 3:
   Subsystem 12 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000393351
   Coolant valve 4:
   Subsystem 13 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000388080
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0020
   Serial number: ---------------
   Coding: 2B48844542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F470FDC88DFCF7C3B-8002
   Coding: 628040051602
   VCID: 75B61771354B97EFEA1-8020
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 F    HW: 0EF 907 180 F
   Component: CUBZE68540AD0 H05 1002
   Revision: --------    Serial number: -00104.07.19000
   ASAM Dataset: EV_DMCM2HITACAU516 003009
   VCID: 3A2CC44D5CD53897C73-806E
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU38.rod
   VCID: 71BE23614123BBCF369-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ROD: EV_LMSRightHELLAAU58X_AU38.rod
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
   VCID: 3FDAB55947F71DBFF0D-806A
End----------(Elapsed Time: 02:21, VBatt start/end: 13.2V/13.2V)-----------
