DSG/ VCDS error?
Losanti2004
C?ID=356506
Hey guys, so I have a 2010 dsg gti.
After owning the car about 20k (bought at 90k) the car would sometimes bang three times into gear, when changing from neutral, drive or reverse. Another issue i had was periodically if I would creep forward, the car would engage in gear and then drop it, but it wouldn't rev, it would just get move a bit forward then harshly shudder and then it would proceed. After this going on for too long, I decided to do a dsg adaptation thru vcds.
after doing the procedure The transmission felt new and crisp again. shifts were faster, smoother, never hesitated again. The adaptation also cured the car banging into gear. a few days later maybe 100 miles in total, when in d mode. The car started to hang alot in 3rd gear, it did it a couple of times. i disregarded it as i was told this was fine after an adaptation.
this turned into an issue when it stay in third and never shift into fourth as i acceleerated.
when trying to shift into 4th from 3nd in manual mode it would never shift and i heard alot of clicking noise from the tranny with the window down.
i next moved onto the shoulder as my gear selector began blinking. Turned the car on and off and seemed to work fine till about an hour later it would shift fine 1st, 2nd and out of 2nd into third, but if i kept it in third for too long it would eventually just let go, gear selector would start blinking and free rev. after a couple of tries this would end bring up the error on vcds as unexpected mechanical disengagement.
Friday,17,January,2020,20:05:44:33727
                Address 02: Auto Trans       Labels: 02E-927-770.CLB
Control Module Part Number: 02E 300 053 B    HW: 02E 927 770 AL
  Component and/or Version: GSG DSG AG6     511 2113
           Software Coding: 0000020
            Work Shop Code: WSC 01357 011 00200
                      VCID: 1471BE2E5273B4577DF-8040
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 005 -  - Intermittent
                    Fault Status: 00100101
                    Fault Frequency: 255
                    Reset counter: 39
                    Mileage: 209447 km
                    Date: 2048.14.04
                    Time: 01:42:32
                    Reset counter: 60
                    Mileage: 209466 km
                    Date: 2048.14.04
                    Time: 08:07:43
            P2711 - 004 -
                    Reset counter: 40
                    Mileage: 209466 km
                    Date: 2048.14.04
                    Time: 08:08:52
when doing the basic adaptations,
Group 60 always seems to get back to the correct values,(13-0-4-1) but never switches to ON unlike all of the other steps in which do turn ON.
the rest of the procedure works fine.
i have redone the adaptations along with the correct driving procedure, i have also let the car learn by itself.
They both work flawlessly for a couple of miles but it always returns to the same issue.
Clearing all faults will instantly return the error 01087 - Basic Setting Not Performed
in addition to this i have also checked the speed sensors and their values to see if it something wasnt being read right.
i always end up in the same scenario.
i am not getting errors for any solenoids so i dont want to blame the mechatronics unit as the issue.
i am trying to pinpoint the issue here that is causing a fault in the transmission as it drives absolutely great for a few miles.
Sunday,19,January,2020,17:32:21:33727
VIN: WVWFD7AJ6AW344266   License Plate:
Mileage: 209460km-130152mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 65 77
VIN: WVWFD7AJ6AW344266   Mileage: 209460km-130152miles
   Part No SW: 1K0 907 115 AL    HW: 1K0 907 115 AK
   Revision: E3H21---    Serial number:
   Coding: 040301081C070160
   VCID: 70B9D2BE06AB2877397-8024
Readiness: 1110 1101
   Part No SW: 02E 300 053 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2113
   Revision:    51112    Serial number: 00001002231584
                    Reset counter: 60
                    Mileage: 209468 km
                    Date: 2014.06.11
                    Time: 03:35:36
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Revision: 00H30001
   Coding: 114B600C492600FE880D06EA921F0041310800
   VCID: 7AADF0965CD76227873-802E
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B7E3AA75490D5FEA1-8020
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: BCM PQ35  H+  103 0576
   Revision: 00103 AF
   Coding: 6D180A3E90272A0480080081600005C443010086434D8D60648020200000
   Shop #: WSC 08061 444 67066
   VCID: 353723AA35494D5F2A1-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 25021  21  0512
   Coding: 009795
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4D0AP6ZM
   Coding: 00003031
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392F2F9A19D1A93FCE9-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00052G2X00
   Serial number: 3572MSME014F4550ZZZR
   Serial number: 3582MSME1F772050ZZZV
   Serial number: 3512QSME26084B3FZZZ/
   Serial number: 3522QSME0A515023ZZZI
   Serial number: 35527SME3A183720ZZZA
   Serial number: 35627SME0A183720ZZZ8
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001632
   VCID: 76B5E4A664CF0647E3B-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5K6 920 970 H    HW: 5K6 920 970 H
   Component: KOMBI         H03 0305
   Coding: 270C00
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 240210F1000748
   Coding: ED801F07400612000000
   VCID: 698FBFDA2571D9BF7E9-803C
   Component: IMMO          H03 0305
   VCID: 6A8DC0D62CF7D2A7773-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667850933
   VCID: 2615F4E6F8EF36C793B-8072
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684 C
   Component: RNS-MID       H06 1000
   Revision: AB001001    Serial number: VWZ6Z7K7061033
   Coding: 04000400040000A600
   VCID: 2313EDF28BDDC3EFF45-8076
                    Reset counter: 8
                    Mileage: 209464 km
   Component: Tuer-SG         009 2111
   Coding: 0001076
   VCID: 313F17BACD21617F769-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   Coding: 0001076
   VCID: 323D18B6C8275A670F3-8066
                    Reset counter: 8
                    Mileage: 209464 km
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           103 0521
   Coding: 018704
02214 - Tire Pressure Warning
                    Mileage: 209468 km
                    Date: 2014.06.11
                    Time: 03:16:48
                    Text: 3451341284
                    Pressure: 0.00 bar
                    Pressure: 2.40 bar
                    Temperature: 52.4°C
                    Text: 00
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000330660514
   Coding: 412100
   VCID: 2A0D00D6ECF712A7B73-807E
End----------(Elapsed Time: 00:59, VBatt start/end: 14.1V/14.2V)-----------
Advanced Identification
     Identification: TFK-030
     Revision:    51112
     Date: 23.02.10
     Test stand number: 8501
     Manufacturer number: 1584
Flash Status
     Programming Attempts: 2
     Successful Attempts: 2
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 00200 011 01357
     Flash Date: 00.14.00
Software
     0017
Misc.
     Hardware number: 02E 927 770 AL
     Lot Number: F10
     Type Lock: 0003
VCDS Info:
myounus
Northwest UK
C?ID=321059
The first thing I would advise you to do is check for TPI's and see if a software update is available.
Jef
HQ
ST?ID=91977
http://wiki.ross-tech.com/wiki/index.php/19143/P2711/010001
  • Please see VW TSB 30-14-03, August 7, 2014 (TPI 2028714)
From VW:
Updated clutch installed as of March 12, 2010.
Found your date of production... 11.03.2010
Hahahahahahaa... 1 day away! I bet your car was build at 4:55PM to boot! The last car with the old clutch design. :banghead:
At any rate... +130K on the odometer in an environment of stop-N-stop-N-go-stop again traffic is asking a lot of any clutch pack.
