- Jan 13, 2020
- 22
- 0
- Richardson, TX, USA
- C?ID=288000
Well I'm back again. 2011 A3 TDI CBEA engine...
Last night the glow plug light started blinking and the CEL came on, but the car was running normally. I did not save the auto scan, but I did pull P0638 - Throttle Body Actuator (J338), Bank 1 - Range/Performance Problem/Implausible Signal.
So today I removed the throttle body (I know TDI's don't need a throttle body, and this one actually regulates the EGR), and cleaned all the carbon from the inside. The butterfly seemed to move much more smoothly afterwards. Put everything together, cleared the codes, and took it out for a drive. I thought there was an adaptation to be done, but was unable to do it. Apparently it doesn't need to be done on a TDI, according to the Ross Tech Throttle Body Alignment video on youtube. Car ran really well. Went into a store for about an hour, and it wouldn't start. I had to crank if for 10 seconds, and it started a bit rough then smoothed out. Drove home and everything again was fine. I did another autoscan and saved it this time. No new codes, the three that are there are preexisting, I addressed those in another topic. But here it is anyway:
So whatever triggered the no start didnt store a code or set off the CEL. I might go on a drive in an hour or two after the car cools off to see if I can replicate it. Just not sure of this is a "one off" anomaly related to the TB cleaning or a sign of something else.
Sunday,19,January,2020,20:19:07:53989
VCDS Version: 19.6.2.0 (x64)
VIN: WAUBJBFM6BA046812 License Plate:
Mileage: 144780km-89962mi Repair Order:
Chassis Type: FM-AU35 (8P0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 56 62 72
77
VIN: WAUBJBFM6BA046812 Mileage: 144780km-89962miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 R HW: 03L 906 019 CT
Component: R4 2.0l TDI G000AG 9983
Revision: 12H08--- Serial number: AUX7Z0J8FN10EJ
Coding: 0350078
Shop #: WSC 09198 003 1048576
VCID: 3D70BF6464A34BA78C-8068
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9136
Revision: 05151112 Serial number: 00001008200462
Shop #: WSC 06314 000 00000
VCID: 183E4EF02B414E8F7F-804C
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 1150400F49260000881302E5921B0042BF0C00
VCID: 78FE6E70CB01AE8F9F-802C
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0170
Revision: 000311 Serial number: 8P0820043BN
VCID: 79F86B74300BB787E0-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 Q HW: 8P0 907 063 K
Component: BCM PQ35 M 107 0719
Revision: 00107 AF
Coding: 6E000A2FA01336E4287041E00000054D401A60AA104DC128E40008800040
VCID: 428ACC98DD5D345FF1-8016
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0050
Coding: 00DD13
01134 - Alarm Horn (H12)
Reset counter: 62
Mileage: 144737 km
Date: 2020.01.19
Time: 15:31:03
Term 15 Off
Voltage: 14.30 V
Term 50 Off
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7K0587993
Coding: 0000100
VCID: 3662A048419598FF4D-8062
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 Q HW: 8P0 959 655 Q
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FC001ATTD
Coding: 303142393041303030384A55304C38503053
ROD: EV_Airba10AURB4.rod
VCID: 50AEF6D00B31D6CF77-8004
Subsystem 1 - Part No SW: 8P0 910 339 C HW: 8P0 959 339 C
Component: BF-Gewichtss. H02 0030
Serial number: 5810000R0000004WTY
Serial number: 3572DRB40000C78931A-
Serial number: 3582DRB40000C7892A0Z
Serial number: 35128RB400005C0A791J
Serial number: 35228RB400005C0AF1EX
Serial number: 35547RB400005C63859S
Serial number: 35647RB400005C63855P
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014042
VCID: 4682D0883175087FDD-8012
Component: E0221 H04 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 S HW: 8P0 920 982 S
Component: KOMBIINSTR. VDO H01 0090
Revision: D0H01003 Serial number: 2248J003001632
Coding: 0272288
Shop #: WSC 31198 001 1048576
VCID: 4998DBB4206BE70730-801C
00003 - Control Module
Fault Status: 01100101
Mileage: 144430 km
Date: 2020.01.16
Time: 18:32:05
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 HW: 1K0 907 951
Component: J533 Gateway H32 5304
Revision: H32 Serial number: 290710F2001674
Coding: ED907F0610070200002102
VCID: 70EE56506371F6CF57-8024
Revision: D0H01003 Serial number: AUX7Z0J8FN10EJ
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0001205
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31689354A8FBBFC718-8064
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158086279092
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0001205
VCID: 4A9AE4B8256DEC1F39-801E
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AC HW: 8P0 035 186 AC
Component: R Concert2+ H02 0293
Revision: 00H02000 Serial number: AUZ1Z3K1264127
Coding: 0750112
VCID: 73E4595C1267CDD7AA-8026
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0001168
Shop #: WSC 06314 000 1012544
VCID: 428ACC981D5D345FF1-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0001168
VCID: 4384C99C02473D57FA-8016
Part No SW: 8P1 862 336 HW: 8P1 862 336
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005038769
Coding: 0001277
VCID: 75E067441C13D3E784-8020
End-------------------------(Elapsed Time: 02:19)--------------------------
